3502
    ADAFRUIT
3502 数据手册
Adafruit Sharp Memory Display Breakout Created by Bill Earl https://learn.adafruit.com/adafruit-sharp-memory-display-breakout Last updated on 2022-07-20 02:29:08 PM EDT ©Adafruit Industries Page 1 of 30 Table of Contents Overview 3 Assembly 4 • • • • • Installing the Header: Position the header Position the display Solder! Remove the Protective Film Arduino Wiring 7 • Wiring to the Arduino: Arduino Programming 8 • Download the Libraries • Run the Example Code • Programming GFX Graphics 2.7" Display Bad Apple Example 9 • Uploading the Video • Additional Libraries • Open in Arduino CircuitPython displayio Setup 12 • CircuitPython Installation • Libraries CircuitPython displayio Usage 13 • Initialization • Drawing Circuitpython displayio Example 15 Python Wiring 20 Python Setup 20 • Python Installation of SharpMemoryDisplay Library • DejaVu TTF Font • Pillow Library Python Usage 22 • Initialization • Example Code CircuitPython Docs 27 Downloads and Links 27 • • • • • Libraries: Files Library Reference Schematic & Fabrication Print 2.7" Display Schematic & Fabrication Print 1.3" Display ©Adafruit Industries Page 2 of 30 Overview The 1.3" SHARP Memory LCD display is a cross between an eInk (e-paper) display and an LCD. It has the ultra-low power usage of eInk and the fast-refresh rates of an LCD. This model has a matt silver background, and pixels show up as little mirrors for a silver-reflective display, a really beautiful and unique look. It does not have a backlight, but it is daylight readable. For dark/night reading you may need to illuminate the LCD area with external LEDs. The display is 3V powered and 3V logic, so we placed it on a fully assembled & tested breakout board with a 3V regulator and level shifting circuitry. The display slots into a ZIF socket on board and we use a piece of double-sided tape to adhere it onto one side. There are four mounting holes so you can easily attach it to a box. The display is 'write only' which means that it only needs 3 pins to send data. The downside of a write-only display is that the entire memory must be buffered by the microcontroller driver. If you have one of the older 96x96 pixel versions, then 96x96 bits = 1,152 bytes. On an Arduino Uno/Leonardo that's half the RAM available and so it might not be possible to run this display with other RAM-heavy libraries like SD interfacing. If you have one of the newer 168x144 pixel versions, then 168x144 bits = 3,024 bytes. That won't fit on an Arduino Uno or Leonardo! You must use a chip with more RAM like a Metro or Feather M0 or ESP8266. ©Adafruit Industries Page 3 of 30 The Sharp Memory Display breakout board ships with optional headers for use in a breadboard. Assembly The display and support circuitry come pre-assembled and fully tested on a handy breakout board. For use in a breadboard, you will want to install the included 0.1" header strip: ©Adafruit Industries Page 4 of 30 Installing the Header: Position the header Trim the header to length if necessary and place it long pins down in your breadboard. Position the display Place the Sharp Memory Display over the pins on the breadboard. ©Adafruit Industries Page 5 of 30 Solder! Solder each pin to assure good electrical conductivity. ©Adafruit Industries Page 6 of 30 Remove the Protective Film After soldering is complete. Gently peel the film from the display. Arduino Wiring For the 144x168 Sharp Memory Display, you will need a microprocessor with more memory than the Uno such as the Arduino Mega, Metro M0 or Metro M4 Wiring to the Arduino: This display can be driven with only 3 pins. Any pins can be used. The wiring we show here uses pins 10, 11 and 13 for compatibility with the library example code. Microcontroller GND to LCD Gnd Microcontroller 5V to LCD Vin Microcontroller D13 to LCD Clk Microcontroller D11 to LCD DI Microcontroller D10 to LCD CS Download Fritzing Diagram https://adafru.it/GBd The other wires are optional, and connect directly to the Memory Display for more advanced uses. Check the raw display datasheet (in the downloads area) for details. ©Adafruit Industries Page 7 of 30 Arduino Programming Download the Libraries To use the Sharp Memory Display with your Arduino, you will need to download and install 2 libraries: • Sharp Memory Display Library (https://adafru.it/cgJ) • Adafruit GFX Library (https://adafru.it/aJa) • Adafruit BusIO Library (https://adafru.it/GxD) For details on how to install libraries, see this guide: All About Arduino Libraries (https ://adafru.it/aYM). Run the Example Code Once your libraries are installed, open the Arduino IDE and select: File->Examples->Adafruit_SHARP_Memory_Display->sharpmemtest Upload the example code to your Arduino and you should see the test graphics drawn on the screen. Programming GFX Graphics The Sharp Memory Display is part of the growing family of Adafruit graphical displays that use the Adafruit GFX Library. This library lets you use a common set of graphical drawing functions on a whole variety of displays including.LED matrices, OLEDs, TFT LCDs, eInk and the Sharp Memory Display! For more details about programming with GFX, see our Adafruit GFX Graphics Library Guide (https://adafru.it/aPx). ©Adafruit Industries Page 8 of 30 2.7" Display Bad Apple Example For this example, you'll want to preferably use a Metro M4 or Feather M4 so that it will be plenty fast. The Bad Apple video example was written for the 2.7" Sharp Display. This is a port of ESP32_BadApple (https://adafru.it/N1E) which as the name implies, was plays the Bad Apple video and was written to run on the ESP32 and OLED displays. You'll want to start by downloading and unzipping the example files first: Download Example Files https://adafru.it/N1F Uploading the Video It's easiest to start with uploading the video file first. The video data is kept in flash memory, so the easiest way to put it in there is to install CircuitPython briefly just to copy the file over before uploading the Arduino code. Fortunately, Installing CircuitPython is really easy. If you are not sure how, you can check out our Welcome to CircuitPython guide (https://adafru.it/Amd). ©Adafruit Industries Page 9 of 30 After it finished uploading, and with the Circuit Playground board connected over USB, it should appear on your computer as a flash drive called CIRCUITPY. You can find the file inside the data folder named video.hs. Go ahead and copy the video file over to the root of your CIRCUITPY drive. That's it, it's time to move over to arduino. Additional Libraries We'll assume you've already installed the libraries mentioned on the Arduino Programming page. There are a few additional libraries required to run the example: ©Adafruit Industries Page 10 of 30 Adafruit Zero DMA This is used by the Graphics Library if you choose to use DMA Adafruit SPIFlash This will let you read/write to the onboard FLASH memory with super-fast QSPI support SdFat (Adafruit Fork) The Adafruit fork of the really excellent SD card library that gives a lot more capability than the default SD library Open in Arduino Go ahead and open up the SHARP_BadApple.ino file up in Arduino. There's only one small change we may need to make. Go ahead and locate the following line of code: #define SHARP_SS ©Adafruit Industries A5 Page 11 of 30 If your Chip Select line is connected differently, you may to change the value of SHARP_SS . That's the only change. After that, go ahead and upload it to your board. You should see an animation similar to the following: CircuitPython displayio Setup CircuitPython Installation First make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/Amd) for your board, and that sharpdisplay is in its supported modules list. This feature is very new and not currently available in the latest public build, so you will need to go to https://circuitpython.org/, select your board, and find the "Absolute Newest" image. Libraries Next you'll need to install the necessary libraries to use the hardware--carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/uap).  Our CircuitPython starter guide has a great page on how to install the library bundle (https://adafru.it/ABU). ©Adafruit Industries Page 12 of 30 Download latest Library Bundle https://adafru.it/ENC There are many libraries in the bundle that enhance displayio, but the two we need for the example code are adafruit_display_text - to show text and labels adafruit_bitmap_font - to load fonts from CIRCUITPY for better typography than the "built in" font Before continuing make sure your board's lib folder or root filesystem has the adafruit_display_text and adafruit_bitmap_font folders copied over. CircuitPython displayio Usage This feature is very new and not currently available in the latest public build, so you will need to go to https://circuitpython.org/, select your board, and find the "Absolute Newest" image. It's easy to use the Sharp Memory Display with CircuitPython and the Adafruit CircuitPython SharpMemoryDisplay (https://adafru.it/GBn) module. This module allows you to easily write Python code to control the display. Check the support matrix (https://adafru.it/N2a) for your board to see whether it supports the sharpdisplay module. To demonstrate the usage, we'll initialize the library and the Python REPL will be displayed on it. You can type these lines in directly or put them in code.py. Initialization First, import required modules and release the existing display (if any). import board import displayio import framebufferio ©Adafruit Industries Page 13 of 30 import sharpdisplay # Release the existing display, if any displayio.release_displays() Next, create the display using the appropriate SPI bus, Chip Select (CS) Pin, width, and height. The baudrate can also be set, though the default value of 2MHz should work with all Sharp Memory Displays. Make sure to use the right pin names as you have wired up to your board!  If you use a nonstandard SPI bus, construct it with busi o.SPI instead of using board.SPI() . bus = board.SPI() chip_select_pin = board.D6 # Select JUST ONE of the following lines: # For the 400x240 display (can only be operated at 2MHz) framebuffer = sharpdisplay.SharpMemoryFramebuffer(bus, chip_select_pin, 400, 240) # For the 144x168 display (can be operated at up to 8MHz) #framebuffer = sharpdisplay.SharpMemoryFramebuffer(bus, chip_select_pin, width=144, height=168, baudrate=8000000) The last thing to do before you can use displayio routines is to connect the framebuffer as a display: display = framebufferio.FramebufferDisplay(framebuffer) If you are doing this interactively at the Python REPL, you will now see the REPL mirrored onto the Sharp Memory Display. ©Adafruit Industries Page 14 of 30 Drawing The SharpMemoryDisplay module supports all the methods for drawing that DisplayIO supports: Text, bitmaps, shapes, etc. For instance, if you wanted to display a label using the built-in terminal font, you would use something like the following: from adafruit_display_text.label import Label from terminalio import FONT label = Label(font=FONT, text="BLACK\nLIVES\nMATTER", x=120, y=120, scale=4, line_spacing=1.2) display.show(label) We cover CircuitPython displayio more in depth in its own guide, so now that you've got the display going, learn more about CircuitPython Display Support Using displayio (https://adafru.it/EGh) to get the most out of it. Circuitpython displayio Example This example displays the names of just some of the Black people injured or killed by police brutality in the United States. For more information about Adafruit's response to racial injustice, visit our dedicated Black Lives Matter (https://adafru.it/N2b) page. This particular example is designed to use the Adafruit 2.7" SHARP Memory Display. ©Adafruit Industries Page 15 of 30 Start by downloading the "project zip" and placing its contents on the CIRCUITPY drive. Then, if you didn't copy the libraries already, head back to the page "CircuitPython displayio Setup" to take care of that. If you don't you'll get an ImportError when you try to run the code. Here's how your CIRCUITPY drive should look when you've put the font file GothamBlack-54.bdf and the Python file code.py in it. # SPDX-FileCopyrightText: 2020 Limor Fried for Adafruit Industries # SPDX-FileCopyrightText: 2020 Jeff Epler for Adafruit Industries # # SPDX-License-Identifier: MIT import random import time import adafruit_display_text.label from adafruit_bitmap_font import bitmap_font import board import displayio import framebufferio import sharpdisplay ## When making several changes, this ensures they aren't shown partially ## completed (except for the time to actually update the display) class BatchDisplayUpdate: def __init__(self, the_display): self.the_display = the_display self.auto_refresh = the_display.auto_refresh def __enter__(self): self.the_display.auto_refresh = False def __exit__(self, unused1, unused2, unused3): self.the_display.refresh() self.the_display.auto_refresh = self.auto_refresh # https://saytheirnames.com/ # real people, not just #hashtags names = [ "Rodney King", "Abner Louima", "Amadou Diallo", "Sean Bell", "Oscar Grant", "Eric Garner", "Michael Brown", "Laquan McDonald", "Freddie Gray", "Antwon Rose Jr", "Ahmaud Arbery", "Breonna Taylor", "John Crawford III", ©Adafruit Industries Page 16 of 30 "Ezell Ford", "Dante Parker", "Michelle Cusseaux", "Laquan Mcdonald", "George Mann", "Tanisha Anderson", "Akai Gurley", "Tamir Rice", "Rumain Brisbon", "Jerame Reid", "Matthew Ajibade", "Frank Smart", "Nastasha McKenna", "Tony Robinson", "Anthony Hill", "Mya Hall", "Phillip White", "Eric Harris", "Walter Scott", "William Chapman II", "Alexia Christian", "Brendon Glenn", "Victor Maunel Larosa", "Jonathan Sanders", "Freddie Blue", "Joseph Mann", "Salvado Ellswood", "Sanda Bland", "Albert Joseph Davis", "Darrius Stewart", "Billy Ray Davis", "Samuel Dubose", "Michael Sabbie", "Brian Keith Day", "Christian Taylor", "Troy Robinson", "Asshams Pharoah Manley", "Felix Kumi", "Keith Harrison Mcleod", "Junior Prosper", "Lamontez Jones", "Paterson Brown", "Dominic Hutchinson", "Anthony Ashford", "Alonzo Smith", "Tyree Crawford", "India Kager", "La'vante Biggs", "Michael Lee Marshall", "Jamar Clark", "Richard Perkins", "Nathaniel Harris Pickett", "Benni Lee Tignor", "Miguel Espinal", "Michael Noel", "Kevin Matthews", "Bettie Jones", "Quintonio Legrier", "Keith Childress Jr", "Janet Wilson", "Randy Nelson", "Antronie Scott", "Wendell Celestine", "David Joseph", "Calin Roquemore", "Dyzhawn Perkins", "Christoper Davis", "Marco Loud", "Peter Gaines", ©Adafruit Industries Page 17 of 30 "Torry Robison", "Darius Robinson", "Kevin Hicks", "Mary Truxillo", "Demarcus Semer", "Willie Tillman", "Terrill Thomas", "Sylville Smith", "Sean Reed", "Alton Streling", "Philando Castile", "Terence Crutcher", "Paul O'Neal", "Alteria Woods", "Jordan Edwards", "Aaron Bailey", "Ronell Foster", "Stephon Clark", "Antwon Rose II", "Botham Jean", "Pamela Turner", "Dominique Clayton", "Atatiana Jefferson", "Christopher Whitfield", "Christopher Mccovey", "Eric Reason", "Michael Lorenzo Dean", "Tony McDade", "David McAtee", "George Floyd", ] # A function to choose "k" different items from the "population" list # We'll use it to select the names to display def sample(population, k): population = population[:] for _ in range(k): j = random.randint(0, len(population)-1) yield population[j] population[j] = population[-1] population.pop() # Initialize the display, cleaning up after a display from the previous run # if necessary displayio.release_displays() bus = board.SPI() framebuffer = sharpdisplay.SharpMemoryFramebuffer(bus, board.D6, 400, 240) display = framebufferio.FramebufferDisplay(framebuffer, auto_refresh = True) # Load our font font = bitmap_font.load_font("/GothamBlack-54.bdf") # Create a Group for the BLM text blm_group = displayio.Group() display.show(blm_group) # Create a 3 line set of text for BLM blm_font = [None, None, None] for line in range(3): label = adafruit_display_text.label.Label(font, color=0xFFFFFF) label.anchor_point = (0, 0) label.anchored_position = (8, line*84+8) blm_font[line] = label blm_group.append(label) # Get something on the display as soon as possible by loading # specific glyphs. font.load_glyphs(b"BLACK") blm_font[0].text = "BLACK" ©Adafruit Industries Page 18 of 30 font.load_glyphs(b"ISEV") blm_font[1].text = "LIVES" font.load_glyphs(b"RMT") blm_font[2].text = "MATTER" font.load_glyphs(b"' DFGHJNOPQUWXYZabcdefghijklmnopqrstuvwxyz") # Create a 2 line set of font text for names names_font = [None, None] for line in range(2): label = adafruit_display_text.label.Label(font, color=0xFFFFFF) # Center each line horizontally, position vertically label.anchor_point = (0.5, 0) label.anchored_position = (200, line*84+42) names_font[line] = label # Create a Group for the name text name_group = displayio.Group() for line in names_font: name_group.append(line) # Repeatedly show the BLM slogan and then 5 names. while True: display.show(blm_group) # Show the BLM slogan with BatchDisplayUpdate(display): blm_font[1].color = blm_font[2].color = 0 time.sleep(1) # hide lines 2&3 with BatchDisplayUpdate(display): blm_font[1].color = 0xFFFFFF # show middle line blm_font[0].color = blm_font[2].color = 0 # hide lines 1&3 time.sleep(1) with BatchDisplayUpdate(display): blm_font[2].color = 0xFFFFFF # show last line blm_font[0].color = blm_font[1].color = 0 # hide lines 1&2 time.sleep(1) with BatchDisplayUpdate(display): for line in blm_font: line.color = 0xFFFFFF time.sleep(2) # Show 5 names display.show(name_group) for name in sample(names, 5): print(name) lines = name.split(" ") with BatchDisplayUpdate(display): for i in range(2): names_font[i].text = lines[i] # Due to a bug in adafruit_display_text, we need to reestablish # the position of the labels when updating them. # Once https://github.com/adafruit/ Adafruit_CircuitPython_Display_Text/issues/82 # has been resolved, this code will no longer be necessary (but # will not be harmful either) names_font[i].anchor_point = (0.5, 0) names_font[i].anchored_position = (200, i*84+42) time.sleep(5) names_font[0].text = names_font[1].text = "" ©Adafruit Industries Page 19 of 30 Python Wiring It's easy to use the Sharp Memory Display with Python and the Adafruit CircuitPython SharpMemoryDisplay (https://adafru.it/GBn) module.  This module allows you to easily write Python code to control the display. We'll cover how to wire the display to your Raspberry Pi. First assemble your Sharp Display. Since there's dozens of Linux computers/boards you can use we will show wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  Connect the display as shown below to your Raspberry Pi. Raspberry Pi GND to LCD Gnd Raspberry Pi 3.3V to LCD Vin Raspberry Pi SCK (GPIO 11) to LCD Clk Raspberry Pi MOSI (GPIO 10) to LCD DI Raspberry Pi GPIO 6 to LCD CS Download Fritzing Diagram https://adafru.it/GBp Python Setup You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require enabling SPI on your platform and verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https: //adafru.it/BSN)! ©Adafruit Industries Page 20 of 30 Python Installation of SharpMemoryDisplay Library Once that's done, from your command line run the following command: • pip3 install adafruit-circuitpython-sharpmemorydisplay If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! If that complains about pip3 not being installed, then run this first to install it: • sudo apt-get install python3-pip DejaVu TTF Font Raspberry Pi usually comes with the DejaVu font already installed, but in case it didn't, you can run the following to install it: • sudo apt-get install fonts-dejavu This package was previously calls ttf-dejavu, so if you are running an older version of Raspberry Pi OS, it may be called that. Pillow Library We also need PIL, the Python Imaging Library, to allow using text with custom fonts. There are several system libraries that PIL relies on, so installing via a package manager is the easiest way to bring in everything: • sudo apt-get install python3-pil That's it. You should be ready to go. ©Adafruit Industries Page 21 of 30 Python Usage It's easy to use the Sharp Memory Display with CircuitPython and the Adafruit CircuitPython SharpMemoryDisplay (https://adafru.it/GBn) module. This module allows you to easily write Python code to control the display. You can use this display with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-for-Python compatibility library (https://adafru.it/ BSN). To demonstrate the usage, we'll initialize the library and use Python code to control the display from the board's Python REPL. Since we are running full CPython on our Linux/computer, we can take advantage of the powerful Pillow image drawing library to handle text, shapes, graphics, etc. Pillow is a gold standard in image and graphics handling, you can read about all it can do here (https://adafru.it/FU7). Initialization First need to initialize the SPI bus. To do that, run the following commands: import import import import board busio digitalio adafruit_sharpmemorydisplay spi = busio.SPI(board.SCK, MOSI=board.MOSI) scs = digitalio.DigitalInOut(board.D6) # inverted chip select display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168) The last three parameters to the initializer are the pins connected to the display's CS line, width and height in that order.  Again make sure to use the right pin names as you have wired up to your board! Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT """ This demo will fill the screen with white, draw a black box on top and then print Hello World! in the center of the display ©Adafruit Industries Page 22 of 30 This example is for use on (Linux) computers that are using CPython with Adafruit Blinka to support CircuitPython libraries. CircuitPython does not support PIL/pillow (python imaging library)! """ import board import busio import digitalio from PIL import Image, ImageDraw, ImageFont import adafruit_sharpmemorydisplay # Colors BLACK = 0 WHITE = 255 # Parameters to Change BORDER = 5 FONTSIZE = 10 spi = busio.SPI(board.SCK, MOSI=board.MOSI) scs = digitalio.DigitalInOut(board.D6) # inverted chip select # display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 96, 96) display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168) # Clear display. display.fill(1) display.show() # Create blank image for drawing. # Make sure to create image with mode '1' for 1-bit color. image = Image.new("1", (display.width, display.height)) # Get drawing object to draw on image. draw = ImageDraw.Draw(image) # Draw a black background draw.rectangle((0, 0, display.width, display.height), outline=BLACK, fill=BLACK) # Draw a smaller inner rectangle draw.rectangle( (BORDER, BORDER, display.width - BORDER - 1, display.height - BORDER - 1), outline=WHITE, fill=WHITE, ) # Load a TTF font. font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", FONTSIZE) # Draw Some Text text = "Hello World!" (font_width, font_height) = font.getsize(text) draw.text( (display.width // 2 - font_width // 2, display.height // 2 - font_height // 2), text, font=font, fill=BLACK, ) # Display image display.image(image) display.show() ©Adafruit Industries Page 23 of 30 Let's take a look at the sections of code one by one. We start by importing the board so that we can access the pin definitions, busio so we can initialize SPI, digitalio , several  PIL modules for Image Drawing, and the adafruit_sharpmemorydisplay  driver. import board import busio import digitalio from PIL import Image, ImageDraw, ImageFont import adafruit_sharpmemorydisplay To make it easy to keep track of which numbers represent which colors, we define some colors near the top. # Colors BLACK = 0 WHITE = 255 In order to make it easy to change display sizes, we'll define a few variables in one spot here. We have the border size and font size, which we will explain a little further below. BORDER = 5 FONTSIZE = 10 Next we set the SPI object to the board's SPI with busio.SPI() . We also define some Pins that will be used for the display and initialize the display. See the initialization section above for more details. By default, the initializer for the 144x168 display is uncommented because that's what we currently have in the store. If you had the 96x96 pixel version of the screen, you could use the other initializer instead. spi = busio.SPI(board.SCK, MOSI=board.MOSI) dc = digitalio.DigitalInOut(board.D6) # data/command cs = digitalio.DigitalInOut(board.CE0) # Chip select reset = digitalio.DigitalInOut(board.D5) # reset #display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 96, 96) display = adafruit_sharpmemorydisplay.SharpMemoryDisplay(spi, scs, 144, 168) Next we clear the display in case it was initialized with any random artifact data. # Clear display. display.fill(0) display.show() ©Adafruit Industries Page 24 of 30 Next, we need to initialize PIL to create a blank image to draw on. Think of it as a virtual canvas. Since this is a monochrome display, we set it up for 1-bit color, meaning a pixel is either white or black. We can make use of the display's width and height properties as well. # Create blank image for drawing. # Make sure to create image with mode '1' for 1-bit color. image = Image.new('1', (display.width, display.height)) # Get drawing object to draw on image. draw = ImageDraw.Draw(image) Now we start the actual drawing. Here we are telling it we want to draw a rectangle from (0,0) , which is the upper left, to the full width and height of the display. We want it both filled in and having an outline of black, so we pass BLACK for both values. # Draw a black background draw.rectangle((0, 0, display.width, display.height), outline=BLACK, fill=BLACK) If we ran the code now, it would still show a blank display because we haven't told python to use our virtual canvas yet. You can skip to the end if you would like to see how to do that. This is what our canvas currently looks like in memory. Next we will create a smaller white rectangle. The easiest way to do this is to draw another rectangle a little smaller than the full screen with no fill or outline and place it in a specific location. In this case, we will create a rectangle that is 5 pixels smaller on each side. This is where the BORDER variable comes into use. It makes calculating ©Adafruit Industries Page 25 of 30 the size of the second rectangle much easier. We want the starting coordinate, which consists of the first two parameters, to be our BORDER value. Then for the next two parameters, which are our ending coordinates, we want to subtract our border value from the width and height. Also, because this is a zero-based coordinate system, we also need to subtract 1 from each number. Again, we set the fill and outline to WHITE . # Draw a smaller inner rectangle draw.rectangle((BORDER, BORDER, display.width - BORDER - 1, display.height - BORDER - 1), outline=WHITE, fill=WHITE) Here's what our virtual canvas looks like in memory. Now drawing text with PIL is pretty straightforward. First we start by setting the font to the default system text. After that we define our text and get the size of the text. We're grabbing the size that it would render at so that we can calculate the center position. Finally, we take the font size and screen size to calculate the position we want to draw the text at and it appears in the center of the screen. # Load a TTF font. font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf', FONTSIZE) # Draw Some Text text = "Hello World!" (font_width, font_height) = font.getsize(text) draw.text((display.width//2 - font_width//2, display.height//2 - font_height//2), text, font=font, fill=BLACK) ©Adafruit Industries Page 26 of 30 Finally, we need to display our virtual canvas to the display and we do that with 2 commands. First we set the image to the screen, then we tell it to show the image. # Display image display.image(image) display.show() Don't forget you MUST call display.image(image) and display.show() to actually display the graphics. The display takes a while to draw so cluster all your drawing functions into the buffer (fast) and then display them once to the display (slow) Here's what the final output should look like. CircuitPython Docs CircuitPython Docs (https://adafru.it/MB8) Downloads and Links Libraries: • Sharp Memory Display Library (https://adafru.it/cgJ) • Adafruit GFX Library (https://adafru.it/aJa) ©Adafruit Industries Page 27 of 30 Files • Datasheet for the LS013B4DN04 LCD Module (https://adafru.it/cgK) • Datasheet for the LS027B7DH01 LCD Module (https://adafru.it/MQf) • Fritzing object in Adafruit Fritzing Library (https://adafru.it/aP3) • EagleCAD PCB files on GitHub (https://adafru.it/rHE) Library Reference • Adafruit GFX Library (https://adafru.it/aPe) LS013B7DH05 Datasheet https://adafru.it/DwW ©Adafruit Industries Page 28 of 30 Schematic & Fabrication Print 2.7" Display ©Adafruit Industries Page 29 of 30 Schematic & Fabrication Print 1.3" Display ©Adafruit Industries Page 30 of 30
很抱歉,暂时无法提供与“3502”相匹配的价格&库存,您可以联系我们找货
