Photocells
Created by lady ada
https://learn.adafruit.com/photocells
Last updated on 2021-11-15 05:47:52 PM EST
©Adafruit Industries
Page 1 of 21
Table of Contents
Overview
3
• Some Basic Stats
• Problems you may encounter with multiple sensors
4
4
Measuring Light
5
• What the Heck is Lux?
6
Testing a Photocell
7
Connecting a Photocell
8
Using a Photocell
9
• Analog Voltage Reading Method
9
Arduino Code
11
• Simple Demonstration of Use
• Simple Code for Analog Light Measurements
• BONUS! Reading Photocells Without Analog Pins
11
13
15
CircuitPython
18
Example Projects
21
Buy a Photocell
21
Page 2 of 21
Overview
Photocells are sensors that allow you to detect light. They are small, inexpensive, lowpower, easy to use and don't wear out. For that reason they often appear in toys,
gadgets and appliances. They are often referred to as CdS cells (they are made of
Cadmium-Sulfide), light-dependent resistors (LDR), and photoresistors.
Photocells are basically a resistor that changes its resistive value (in ohms Ω)
depending on how much light is shining onto the squiggly face. They are very low
cost, easy to get in many sizes and specifications, but are very innacurate. Each
photocell sensor will act a little differently than the other, even if they are from the
same batch. The variations can be really large, 50% or higher! For this reason, they
shouldn't be used to try to determine precise light levels in lux or millicandela.
Instead, you can expect to only be able to determine basic light changes.
Page 3 of 21
For most light-sentsitive applications like "is it light or dark out", "is there something in
front of the sensor (that would block light)", "is there something interrupting a laser
beam" (break-beam sensors), or "which of multiple sensors has the most light hitting
it", photocells can be a good choice!
Some Basic Stats
These stats are for the photocell in the Adafruit shop which is very much like the PDVP8001 (https://adafru.it/clX) . Nearly all photocells will have slightly different
specifications, although they all pretty much work the same. If there's a datasheet,
you'll want to refer to it
• Size: Round, 5mm (0.2") diameter. (Other photocells can get up to 12mm/0.4"
diameter!)
• Price: $1.00 at the Adafruit shop (https://adafru.it/aIH)
• Resistance range: 200KΩ (dark) to 10KΩ (10 lux brightness)
• Sensitivity range: CdS cells respond to light between 400nm (violet) and 600nm
(orange) wavelengths, peaking at about 520nm (green).
• Power supply: pretty much anything up to 100V, uses less than 1mA of current on
average (depends on power supply voltage)
• Datasheet (https://adafru.it/clX) and another Datasheet (https://adafru.it/clY)
• Two application notes on using (https://adafru.it/clZ) and selecting photocells (ht
tps://adafru.it/cm0) where nearly all of these graphs are taken from
If, when adding more sensors, you find that the readings are inconsistent, this
indicates that the sensors are interfering with each other when switching the analog
Page 4 of 21
reading circuit from one pin to the other. You can fix this by doing two delayed
readings and tossing out the first one.
See this post for more information (https://adafru.it/aKL)
Measuring Light
As we've said, a photocell's resistance changes as the face is exposed to more light.
When its dark, the sensor looks like an large resistor up to 10MΩ, as the light level
increases, the resistance goes down. This graph indicates approximately the
resistance of the sensor at different light levels. Remember each photocell will be a
little different so use this as a guide only!
Note that the graph is not linear, its a log-log graph!
Photocells, particularly the common CdS cells that you're likely to find, are not
sensitive to all light. In particular they tend to be sensitive to light between 700nm
(red) and 500nm (green) light.
Page 5 of 21
Basically, blue light wont be nearly as effective at triggering the sensor as green/
yellow light!
Most datasheets use lux (https://adafru.it/aKS) to indicate the resistance at certain
light levels. But what is lux (https://adafru.it/aKS) ? Its not a method we tend to use to
describe brightness so its tough to gauge. Here is a table adapted from a Wikipedia
article on the topic! (https://adafru.it/aKS)
Illuminance
Example
0.002 lux
Moonless clear night sky
0.2 lux
Design minimum for emergency lighting
(AS2293).
0.27 - 1 lux
Full moon on a clear night
3.4 lux
Dark limit of civil twilight under a clear sky
50 lux
Family living room
80 lux
Hallway/toilet
100 lux
Very dark overcast day
300 - 500 lux
Sunrise or sunset on a clear day. Well-lit
office area.
1,000 lux
Overcast day; typical TV studio lighting
10,000 - 25,000
lux
Full daylight (not direct sun)
Page 6 of 21
32,000 - 130,000
lux
Direct sunlight
Testing a Photocell
The easiest way to determine how your photocell works is to connect a multimeter in
resistance-measurement mode (https://adafru.it/aZZ) to the two leads and see how
the resistance changes when shading the sensor with your hand, turning off lights,
etc. Because the resistance changes a lot, an auto-ranging meter works well here.
Otherwise, just make sure you try different ranges, between 1MΩ and 1KΩ before
'giving up'.
Page 7 of 21
Because photocells are basically resistors, they are non-polarized. That means you
can connect them up 'either way' and they'll work just fine!
Photocells are pretty hardy, you can easily solder to them, clip the leads, plug them
into breadboards, use alligator clips, etc. The only care you should take is to avoid
bending the leads right at the epoxied sensor, as they could break off if flexed too
often.
Page 8 of 21
Using a Photocell
The easiest way to measure a resistive sensor is to connect one end to Power and
the other to a pull-down resistor to ground. Then the point between the fixed
pulldown resistor and the variable photocell resistor is connected to the analog input
of a microcontroller such as an Arduino (shown)
For this example I'm showing it with a 5V supply but note that you can use this with a
3.3v supply just as easily. In this configuration the analog voltage reading ranges from
0V (ground) to about 5V (or about the same as the power supply voltage).
Page 9 of 21
The way this works is that as the resistance of the photocell decreases, the total
resistance of the photocell and the pulldown resistor decreases from over 600KΩ to
10KΩ. That means that the current flowing through both resistors increases which in
turn causes the voltage across the fixed 10KΩ resistor to increase. It's quite a trick!
Ambient
light like…
Photocell
Ambient
resistance
light (lux)
(Ω)
Current
LDR +
Voltage
thru LDR
R (Ω)
across R
+R
Dim hallway 0.1 lux
600KΩ
610
KΩ
Moonlit night 1 lux
70 KΩ
80 KΩ 0.07 mA 0.6 V
Dark room
10 KΩ
KΩ
0.25 mA 2.5 V
Dark
overcast day 100 lux
/ Bright room
1.5 KΩ
11.5
KΩ
0.43 mA 4.3 V
Overcast
day
300 Ω
10.03
0.5 mA
KΩ
10 lux
1000 lux
0.008
mA
0.1 V
5V
This table indicates the approximate analog voltage based on the sensor light/
resistance w/a 5V supply and 10KΩ pulldown resistor.
If you're planning to have the sensor in a bright area and use a 10KΩ pulldown, it will
quickly saturate. That means that it will hit the 'ceiling' of 5V and not be able to
differentiate between kinda bright and really bright. In that case, you should replace
the 10KΩ pulldown with a 1KΩ pulldown. In that case, it will not be able to detect dark
level differences as well but it will be able to detect bright light differences better.
This is a tradeoff that you will have to decide upon!
You can also use the "Axel Benz" formula by first measuring the minimum and
maximum resistance value with the multimeter and then finding the resistor value
with: Pull-Down-Resistor = squareroot(Rmin * Rmax), this will give you slightly better
range calculations
Photocell
Ambient light Ambient
resistance
like…
light (lux)
LDR Current
+ R thru
LDR+R
Moonlit night 1 lux
70 KΩ
71
KΩ
0.07 mA 0.1 V
Dark room
10 KΩ
11
KΩ
0.45 mA 0.5 V
10 lux
Voltage
across R
Page 10 of 21
Dark
/ Bright room
1.5 KΩ
2.5
KΩ
2 mA
2.0 V
Overcast day 1000 lux
300 Ω
1.3
KΩ
3.8 mA
3.8 V
Full daylight 10,000 lux 100 Ω
1.1
KΩ
4.5 mA
4.5 V
resistance w/a 5V supply and 1K pulldown resistor.
Note that our method does not provide linear voltage with respect to brightness! Also,
each sensor will be different. As the light level increases, the analog voltage goes up
even though the resistance goes down:
Vo = Vcc ( R / (R + Photocell) )
That is, the voltage is proportional to the inverse of the photocell resistance which is,
in turn, inversely proportional to light levels.
Arduino Code
This sketch will take the analog voltage reading and use that to determine how bright
the red LED is. The darker it is, the brighter the LED will be! Remember that the LED
has to be connected to a PWM pin for this to work, I use pin 11 in this example.
Page 11 of 21
These examples assume you know some basic Arduino programming. If you don't, ma
ybe spend some time reviewing the basics at the Arduino tutorial? (https://adafru.it/
aKU)
/* Photocell simple testing sketch.
Connect one end of the photocell to 5V, the other end to Analog 0.
Then connect one end of a 10K resistor from Analog 0 to ground
Connect LED from pin 11 through a resistor to ground
For more information see http://learn.adafruit.com/photocells */
int photocellPin = 0;
int photocellReading;
int LEDpin = 11;
int LEDbrightness;
void setup(void) {
// We'll send debugging
Serial.begin(9600);
// the cell and 10K pulldown are connected to a0
// the analog reading from the sensor divider
// connect Red LED to pin 11 (PWM pin)
information via the Serial monitor
void loop(void) {
photocellReading = analogRead(photocellPin);
Serial.print("Analog reading = ");
Serial.println(photocellReading);
// the raw analog reading
// LED gets brighter the darker it is at the sensor
// that means we have to -invert- the reading from 0-1023 back to 1023-0
photocellReading = 1023 - photocellReading;
//now we have to map 0-1023 to 0-255 since thats the range analogWrite uses
LEDbrightness = map(photocellReading, 0, 1023, 0, 255);
analogWrite(LEDpin, LEDbrightness);
delay(100);
Page 12 of 21
You may want to try different pulldown resistors depending on the light level range
you want to detect!
This code doesn't do any calculations, it just prints out what it interprets as the
amount of light in a qualitative manner. For most projects, this is pretty much all thats
needed!
Page 13 of 21
// the analog reading from the analog resistor divider
void setup(void) {
// We'll send debugging information via the Serial monitor
Serial.begin(9600);
void loop(void) {
Serial.print(photocellReading);
// We'll have a few threshholds, qualitatively determined
if (photocellReading < 10) {
Serial.println(" - Dark");
} else if (photocellReading < 200) {
Serial.println(" - Dim");
} else if (photocellReading < 500) {
Serial.println(" - Light");
} else if (photocellReading < 800) {
Serial.println(" - Bright");
} else {
Serial.println(" - Very bright");
delay(1000);
To test it, I started in a sunlit (but shaded) room and covered the sensor with my hand,
then covered it with a piece of blackout fabric.
Page 14 of 21
Because photocells are basically resistors, its possible to use them even if you don't
have any analog pins on your microcontroller (or if say you want to connect more than
you have analog input pins). The way we do this is by taking advantage of a basic
electronic property of resistors and capacitors. It turns out that if you take a capacitor
that is initially storing no voltage, and then connect it to power (like 5V) through a
resistor, it will charge up to the power voltage slowly. The bigger the resistor, the
slower it is.
This capture from an oscilloscope shows whats happening on the digital pin (yellow).
The blue line indicates when the sketch starts counting and when the couting is
complete, about 1.2ms later.
Page 15 of 21
This is because the capacitor acts like a bucket and the resistor is like a thin pipe. To
fill a bucket up with a very thin pipe takes enough time that you can figure out how
wide the pipe is by timing how long it takes to fill the bucket up halfway.
In this case, our 'bucket' is a 0.1uF ceramic capacitor. You can change the capacitor
nearly any way you want but the timing values will also change. 0.1uF seems to be an
OK place to start for these photocells. If you want to measure brighter ranges, use a
1uF capacitor. If you want to measure darker ranges, go down to 0.01uF.
Connect one end of photocell to power, the other end to pin 2.
Then connect one end of a 0.1uF capacitor from pin 2 to ground
int photocellPin = 2;
// the LDR and cap are connected to pin2
// the digital reading
Page 16 of 21
int ledPin = 13;
// you can just use the 'built in' LED
void setup(void) {
Serial.begin(9600);
pinMode(ledPin, OUTPUT); // have an LED for output
void loop(void) {
// read the resistor using the RCtime technique
photocellReading = RCtime(photocellPin);
if (photocellReading == 30000) {
// if we got 30000 that means we 'timed out'
Serial.println("Nothing connected!");
} else {
Serial.print("RCtime reading = ");
// The brighter it is, the faster it blinks!
digitalWrite(ledPin, HIGH);
delay(photocellReading);
digitalWrite(ledPin, LOW);
delay(100);
// Uses a digital pin to measure a resistor (like an FSR or photocell!)
// We do this by having the resistor feed current into a capacitor and
// counting how long it takes to get to Vcc/2 (for most arduinos, thats 2.5V)
int RCtime(int RCpin) {
int reading = 0; // start with 0
// set the pin to an output and pull to LOW (ground)
pinMode(RCpin, OUTPUT);
digitalWrite(RCpin, LOW);
// Now set the pin to an input and...
pinMode(RCpin, INPUT);
while (digitalRead(RCpin) == LOW) { // count how long it takes to rise up to HIGH
reading++;
// increment to keep track of time
if (reading == 30000) {
// if we got this far, the resistance is so high
// its likely that nothing is connected!
break;
// leave the loop
// OK either we maxed out at 30000 or hopefully got a reading, return the count
return reading;
Page 17 of 21
CircuitPython
It's easy to read how much light a photocell sees with CircuitPython and its built-in
analog input support (https://adafru.it/CbI). By wiring the photocell to an analog input
of your board you can read the voltage from it and see how it changes as the amount
of light hitting the sensor changes too.
First wire up a photocell to your board as shown on the previous page for Arduino.
You'll want to setup the same voltage divider with a 10 kilo-ohm resistor circuit and
feed the output into any analog input on your board (note the special method of
reading photocells without an analog input is not currently supported by
CircuitPython).
Here's an example of wiring a photocell to a Feather M0:
Page 18 of 21
• Board 3.3V to one leg of the photocell (doesn't matter which leg). Note you
want to use the voltage from your board that corresponds to the maximum
analog input voltage. For Feather boards this is 3.3V, but for other boards it
might be higher or lower--consult your board documentation to be sure.
• 10 kilo-ohm resistor to the other leg of the photocell.
• Board GND to the other leg of the 10 kilo-ohm resistor.
• Board A1 (or any other analog input) to the junction of the photocell & 10 kiloohm resistor.
Next connect to the board's serial REPL (https://adafru.it/pMf)so you are at the
CircuitPython >>> prompt.
Now import the board and analogio modules that allow you to read an analog input.
Be sure you've read the CircuitPython analog I/O guide (https://adafru.it/CbJ) for more
background on using analog inputs too!
import board
import analogio
Create an analog input for the A1 pin connected to the photocell & resistor junction:
photocell = analogio.AnalogIn(board.A1)
At this point you can read the value property to get a reading of the light seen by the
photocell. Try it:
Page 19 of 21
photocell.value
Try covering the photocell with your hand to block the light it can see and read the
value again:
photocell.value
Notice the value changed! When the sensor sees less light the value is reduced. The
more light the sensor sees, the higher the value.
You might wonder, what's the range of possible values? It turns out for an analog
input in CircuitPython the maximum values range from 0 to 65535 (or the maximum
16-bit unsigned integer value). If you shine an extremely bright light on the photocell
you might see a value near 65k, and if you completely block the sensor you might see
a value down near 0.
If you're curious you can also convert this value into a voltage that's higher or lower
depending on how much light is hitting the sensor. Let's make a function to do this:
def analog_voltage(adc):
return adc.value / 65535 * adc.reference_voltage
volts = analog_voltage(photocell)
print('Photocell voltage: {0}V'.format(volts))
Cool! Notice the voltage increases up to near 3.3 volts as the light hitting the
photocell increases. If you cover the photocell up and read the voltage you'll see it
falls down near 0 volts.
You can use either the raw value or voltage to check how much light is hitting the
photocell. Both will change proportionally to the amount of light hitting the sensor.
Page 20 of 21
Here's a complete program that reads the photocell value and prints both the value
and voltage every second. Save this as main.py on your board and open the serial
output to see the printed values. Try shining light on the sensor or covering it up to
see how the value and voltage change!
import time
import board
import analogio
# Initialize analog input connected to photocell.
# Make a function to convert from analog value to voltage.
# Main loop reads value and voltage every second and prints them out.
while True:
# Read the value, then the voltage.
val = photocell.value
# Print the values:
print('Photocell value: {0} voltage: {1}V'.format(val, volts))
# Delay for a second and repeat!
time.sleep(1.0)
That's all there is to reading a photocell using an analog input with CircuitPython!
Example Projects
Noisemaker that changes frequency based on light level. (https://adafru.it/aKV)
Motor value and directional control with photoresistors and microcontroller
Line-following robot that uses photocells to detect the light bouncing off of white/
black stripes
Another robot, this one has two sensors and moves towards light (https://adafru.it/
aKW) (they're called Braitenberg vehicles)
Using a photocell and pocket laser pointer to create a breakbeam sensor (https://
adafru.it/aKX)
Buy a Photocell
Buy a Photocell (http://adafru.it/161)
Page 21 of 21
