BC832
BC832
    FANSTEL
    BC832
BC832 数据手册
Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 BluNor BC832 is a powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) using Nordic nRF52832 SoC. With an ARM CortexTM M4F MCU, 512KB flash, 64KB RAM, embedded 2.4GHz multi-protocol transceiver, and an integrated chip antenna. It allows faster time to market with reduced development cost. For applications needing limited number of IO pins, prototyping and production are easier using 16 castellated pins. Additional 20 LGA (Land Grid Array) pins provide access to 30 GPIOs of nRF52832 CIAA. Specifications:
 Nordic nRF52832 with ARM Cortex M4F. Complete RF solution with integrated antenna Integrated DC-DC converter, needs external inductors Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 512KB/64KB. 30 General purpose I/O pins 12 bit/200KSPS ADC 3 SPI Master/Slave (8Mbps) Low power comparator Two 2-wire Master/Slave (I2C compatible) I2S audio interface UART (with CTS/RTS and DMA) 20 channel CPU independent Programmable Peripheral Interconnect (PPI). Quadrature Demodulator (QDEC) 128-bit AES HW encryption 5 x 32 bits, 3 x 24 bits Real Time Counters (RTC) NFC-A tag interface for OOB pairing Receiver Sensitivity: -96 dBm TX power: +/- 0 dBm; programmable +4dBm to -20dBm in 4 dB steps. Sizes: 7.8x8.8x1.3mm Hybrid pins: 16 castellated and 20 LGA. Integrated chip antenna FCC ID: X8WBC832 Industrial Canada: 4100A-BC832 CE: Approved QDID: 97989 Operation voltage: 1.7V to 3.6V Operation temperature: - 4 0 ° C t o + 8 5 ° C
 Applications
 IoT (Internet of Things) Wearable Beacons/Proximity Fitness/Sports Smart toys Connected appliances Lighting products Sensors Home and building automation Key fobs Wrist watches Wireless charger Interactive entertainment devices
 Model Summaries module SoC Flash/RAM Bluetooth range BC832 nRF52832-CIAA 512KB/64KB 50 meters !1 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Table Of Contents 1. Introduction ..................................................................................................................................................3 2. Codes Development Using Nordic Tools ......................................................................................................3 Easy, fast and safe code development.............................................................................................................. 3 Over-The-Air DFU .............................................................................................................................................3 SoftDevices ....................................................................................................................................................... 4 Development Tools ............................................................................................................................................4 3. Product Overview .........................................................................................................................................5 Block Diagram ................................................................................................................................................... 5 Mechanical Drawing ..........................................................................................................................................7 BC832 Photo ..................................................................................................................................................... 7 Pin Assignments of BC832 ................................................................................................................................ 8 Pin Functions ..................................................................................................................................................... 9 Mounting BC832 on the Host PCB .................................................................................................................. 10 4. AT Commands ........................................................................................................................................... 10 Brief description of AT commands ...................................................................................................................11 Command mode .............................................................................................................................................. 11 Data Mode ....................................................................................................................................................... 13 Communicating with a PC ............................................................................................................................... 13 5. Evaluation Board .......................................................................................................................................14 EV BC832 Evaluation board schematics .........................................................................................................14 EV BC832 V2 Evaluation Board Schematics .................................................................................................. 14 Suggestion for Battery Power Application .......................................................................................................15 6. Miscellaneous ............................................................................................................................................16 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 16 Cautions, Design Notes, and Installation Notes .............................................................................................. 16 Packaging ........................................................................................................................................................ 19 FCC Label ....................................................................................................................................................... 19 Revision History ............................................................................................................................................. 20 Contact Us ..................................................................................................................................................... 21 !2 Bluetooth Low Energy (BLE) 5 Micro Module BC832 1. Introduction Ver 2.01 Dec. 2017 BluNor BC832 is powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) modules using Nordic nRF52832 SoCs. With an ARM CortexTM M4F MCU, 512KB flash, 64KB RAM, embedded 2.4GHz multiprotocol transceiver, and an integrated antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BC832. Antenna circuit and main clock are integrated. All 32 GPIOs of nRF52832 can be accessed from main board. For lower power consumption at idle state, a 32.768 kHz crystal is added on the main board. Connection to an external NFC (Near Field Communication) antenna is provided. 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used . Easy, fast and safe code development Nordic development environment for nRF52832 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52832 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. !3 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S132: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. SoftDevices available from ANT Wireless: S212: ANT stack S332: Bluetooth low energy concurrent central/peripheral/observer/broadcaster/ANT stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. !4 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 3. Product Overview Brief description of nRF52832 SoC is provided. For full description of the SoC, please download from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy Block Diagram The following is a block diagram of Nordic nRF52832 Bluetooth Low Energy (BLE) SoC. !5 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +4dBm down to -20 dBm in 4dB steps. Sensitivity is increased to -96 dBm to -89 dBm, depending on data rate. Sensitivity for BLE is -96 dBm, and -92.5 dBm for ANT. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. !6 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Mechanical Drawing The following is a mechanical drawing of BC832. Two types of pins are available to meet different application requirements. • 16 castellated pins for application needing limited number of IOs. SMT equipment is not required for soldering castellated pins. • 20 LGA (Land Grid Array) pins to access all 32 GPIOs of nRF52832 when needed. BC832 Photo !7 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Pin Assignments of BC832 The followings are BC832 pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52832 Product Specifications for detailed descriptions and features supported. http://infocenter.nordicsemi.com/pdf/nRF52832_PS_v1.1.pdf There are two versions of BC832. • BC832 V0. This version has all 32 GPIO pins of nRF52832 CIAA available. There is no connection for 2 inductors required for built-in DC to DC converter. DC to DC converter shall not be enabled by firmware. • BC832 V1. To provide external connection for 2 inductors required for DC to DC converter, pins B3 and C3 are used for inductor connection. Pins B5 (P031) and A5(P030) of nRF52832 CIAA are not available at BC832 V1 pins. BC832 V1 should be used in new designs. !8 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Pin Functions BC832 nRF52832 CIAA pin# 1 2 3 4 5 6 pin# C5 G2 G1 F1 H2 G4 pin name GND P20 SWDIO SWDCLK P18 P13 pin name VSS P0.20 SWDIO SWDCLK P0.18 P0.13 Descriptions Ground GPIO, LED pin on EV-BC832 GPIO, connection for 32.768kHz crystal Serial Wire Debug I/O GPIO, LED pin on EV-BC832 GPIO, button pin on EV-BC832 7 P11 H6 P0.11 UART RX 8 9 A1 A2 A3 A4 P12 P03/AIN1 P21/RESET P00/XL1 P01/XL2 P02/AIN0 P27/SCL P26/SDA VDD P28 P17 P04 P06 F4 D6 H1 D7 C7 C6 B4 D3 A7 A3 G3 E6 F7 P0.12 P0.03 P0.21 P0.00 P0.01 P0.02 P0.27 P0.26 VDD P0.28 P0.17 P0.04 P0.06 UART TX GPIO, Analog input 1 configured as reset on EV-BC832 GPIO, connection for 32.768kHz crystal GPIO, connection for 32.768kHz crystal GPIO, Analog input 0 GPIO, configured as I2C SCL on EV-BC832 GPIO, configured as I2C SDA on EV-BC832 DC power supply, 1.7V to 3.6V GPIO GPIO GPIO GPIO A5 P08 G7 P0.08 GPIO B1 B2 B3 B4 B5 C1 C2 C3 C4 C5 D1 D2 D3 D4 D5 P25 P29 P31/DCC P05 P07 P24 P22 P30/DEC4 P15 P09 P23 P19 P16 P14 P10 B3 A4 B5 E7 F6 E1 F2 A5 H4 G6 E2 F3 H3 H5 G5 P0.25 P0.29 P0.31 P0.05 P0.07 P0.24 P0.22 P0.30 P0.15 P0.10/NFC1 P0.23 P0.19 P0.16 P0.14 P0.10/NFC2 GPIO GPIO P31 in BC832 V0; DCC for inductor connection in BC832 V1 GPIO GPIO GPIO GPIO P30 in BC832 V0; DEC4 for inductor connection in BC832 V1 GPIO GPIO, NFC antenna connection GPIO GPIO GPIO GPIO GPIO, NFC antenna connection 10 11 12 13 14 15 16 !9 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Mounting BC832 on the Host PCB The following figure shows recommended mounting of BC832 module on the host PCB. • For the best Bluetooth range performance, the antenna area of module shall extend 3.2 mm outside the edge of a ground plane. • The next choice is to place module on a corner of host PCB. No ground place directly below the 3.2x7.8mm antenna area of module. • For wearable, it is acceptable to place a coin battery directly below the antenna area of module. Bluetooth range is reduced but acceptable when pairing with a smartphone on the antenna side. Bluetooth signal is blocked on the battery side. 4. AT Commands BC832 module is available with firmware supporting AT commands. Part number is BC832-AT. !10 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 Brief description of AT commands • Each command line consists of a prefix, a body and a terminator. • All command lines begin with the prefix AT (ASCII 065, 084) or at (ASCII 097, 116). • The body is a string of characters in the ASCII range 032-255. Control characters other than (carriage return; ASCII 013) and (back space; ASCII 008) in a command line are ignored. • The terminator is . • There is no distinction between upper-case and lower-case characters. A command line can have a maximum length of 80 characters. It is automatically discarded if the input is longer. Corrections are made • AT command is case-insensitive, following /r/n for end code. • The default baud rate is 9600 one stop bit and no parity Command mode When P0.03 of nRF52832 (pin 9 of BC832) is pulled high, it is set to AT command mode. In AT command mode, the host processor communicates with the processor on BC832. Command Response Parameter example AT OK or FAIL none AT+RESET OK or FAIL none +VERSION: Software version number AT+VERSION?/r/n Device name AT+NAME?/r/n AT+VERSION? AT+NAME? OK +NAME: OK AT/r/n OK/r/n AT+RESET/r/n OK/r/n +VERSION140804 OK/ r/n +NAME:EZPro OK/r/n AT+NAME=Fanstel/r/n AT+NAME= Device name OK or FAIL Or AT_Name=”Fanstel”/r/n OK/r/n AT+UART? +UART:,, OK Baud rate, AT+UART?/r/n Stop bit, +UART:115200,1,0 Parity OK/r/n AT+UART=115200/r/n +UART:115200,1,0 !11 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 OK/r/n 1200 2400 4800 9600 default AT+UART= +UART: 19200 Baud rate 38400 57600 115200 230400 460800 921600 1000000 AT+ADDR? +ADDR: OK Device MAC address AT+REGISTER OK or FAIL none AT+QUITREGISTER OK or FAIL none AT+RX? AT+ADDR?/r/n +ADDR:abb5:cd: 604ace OK/r/n AT+REGISTER/r/n OK/r/n AT+QUITREGISTER/r/n OK/r/n +Name: AT+RX?/r/n +UART: +NAME:EZPro/r/n none +ADDR: +UART:115200,1,1/r/n +ADDR: abb5:cd: 604ace/r/n AT+DEFAULT OK or FAIL none AT+DEFAULT/r/n OK/r/n AT+RFPW?/r/n +RFPW:-4 OK/r/n 0:+4 AT_RFPW? +RFPW:parm +4~-8 1:+0 default 2:-4 3:-8 AT+RFPW= 1/r/n !12 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 OK/r/n 0:+4 AT_RFPW= OK or FAIL +4~-8 1:+0 2:-4 3:-8 AT+PIO= OK or FAIL AT+PIS= OK or FAIL P00-P05 AT+PIO=05, 0\r\n 1=High , 0=low OK/r/n P00-P05 AT+PIS=05, 1\r\n 1=output, 0=input OK/r/n Data Mode When P0.03 of nRF52832 (pin 9 of BC832) is pulled low, it is set to data mode. In data model, BC832 provides transparent data transfer between the host processor and a remote device, for example, a smartphone. Communicating with a PC A quick and easy way to evaluate BC832 is to use a PC as the host processor. Connect the development board EV-BC832 to a PC with an USB cable. Then, • • Set S1, BC832 is set to command mode. PC will communicate with BC832. Set switch S1 to the other position, BC832 is set to data mode. PC will communicate with a remote device through BC832 Bluetooth wireless connection. Docklight is a testing, analysis and simulation tool for serial communication protocols (RS232, RS485/422 and others). It allows you to monitor the communication between two serial devices or to test the serial communication of a single device. Docklight significantly increases productivity in a broad range of industries, including automation and control, communications, automotive, equipment manufacturers, and embedded / consumer products. Docklight is easy to use and runs on almost any standard PC using Windows 10, Windows 8, Windows 7, Windows Vista or Windows XP operating system. Docklight software can be downloaded from the following: http://www.docklight.de/download_en.htm. !13 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 5. Evaluation Board EV BC832 Evaluation board schematics Evaluation board schematics and Gerber files can be downloaded from http://www.fanstel.com/download-document/ Library component for your PCB layout can be extracted from Gerber files. EV BC832 was developed for evaluation of Bluetooth mesh stacks. All new BC832 evaluation boards are EV BC832 V2. EV BC832 V2 Evaluation Board Schematics EV BC832 V2 evaluation board is developed to accommodate BC832 V0 and BC832 V1. EV BC832 V2 has the same footprint as that of Arduino UNO R3. It is not an UNO R3 compatible board. Many UNO R3 shields can be used with EV BC832. • It is preloaded with firmware for evaluating Bluetooth mesh stacks. • Firmware can be developed for other applications. You need Nordic nRF52 development tools. An nRF52 DK is recommended for programming. • If not used on board, all GPIO pins are available at connectors. Whenever possible, with firmware configuration, pin function can be compatible with that of Arduino UNO R3. • Portable smartphone charger can be used to power this board. The circuitry to the left of micro USB connector, J16 produces periodic load to prevent portable smartphone charger from shutting down. !14 Bluetooth Low Energy (BLE) 5 Micro Module BC832 5 4 3 2 SW1 P13 1 P14 1 U1 P20 1 GND 2 P20/LED A1 SWDIO 3 SWDCLK 4 SWDCLK P18 5 P18/LED P13 6 P13/BUTTON P11 UART_RX 7 P12 UART_TX 8 SWDIO B1 A2 C1 B2 C2 B3 C3 D3 A4 B4 C4 D4 P11/ RX P12/ TX B5 16 15 P26 P27/SCL 14 P27 P02/AIN0 13 P02 P01/XL2 12 P01 P00/XL1 11 P00 P21/RESET 10 P21 9 AT_COM P03 D2 A3 A5 VDD P26/SDA D1 C5 D5 P03/AIN1 P15 GND 2 GND 1 2 GND 2 GND P16 1 A P18 C P19 C A A C A 5VIN P28 P17 P04 P06 P08 P25 P29 P31 P05 P07 P24 P22 P30 P15 P09 P23 P19 P16 P14 P10 A1 A2 A3 A4 A5 B1 B2 B3 B4 B5 C1 C2 C3 C4 C5 D1 D2 D3 D4 D5 J3 3V Battery DEC4 P28 P17 P04 P06 P08 P25 P29 P31 P05 P07 P24 P22 P30 P15 P09 P23 P19 P16 P14 P10 AT_COM BAT-ADC BAT-EN R5 10K GND GND Q2 2N7002/SOT BAT-EN P24 P25 RESET 3 GND GND R9 1K 1% 1 J8 1 2 L3 OFF ON 10uH 3 B R13 100K NC CTS RTS RXD TXD DSR DTR GND 2 4 120OHM 1 5V 14 13 12 11 10 9 8 2 D- + 3 D+ NC NC SUSPEND SUSPEND NC RST VBUS 1 1 2 3 4 5 6 7 CT1 10uF/10V RST R16 10K / 1% GND GND C7 0.1uF GND C8 1uF GND 5 4 2 3 4 5 3V3 J11 External supply VDD SW8 1 2 3 EN 5 NC 4 GND 2 4 3 GND GND B GND 3V3 R14 1K JS1 1 3 5 7 9 GND A LED5 GND VDD R15 10R 1% C5 10uF / 10V C4 10nF C VDD 1 3 5 7 9 2 4 6 8 10 2 4 6 8 10 SWDIO SWDCLK SWO P18 JS2 P21 DEBUG - IN 1 2 3 4 VDD 1 2 3 4 CON4 GND A FANSTEL Corporation. 1 2 J12 Current meter 3 VO GND OFF ON 1 2 VI R12 100K J12 connect Current meter 3V 3V3 U2 TCR3DF33 1 C6 10uF / 10V SW8 pin2-3 on , J13 connect Oscilloscope GND GND 1 Current measurement , SW8 pin1-4 off SW8 pin2-3 off , 3V C9 0.1uF 5VIN GND A GND 1 GND GND ID DCD RI GND D+ DVDD REGIN 5 G NC NC NC NC NC NC NC L4 C 1 2 3 4 5 6 7 8 9 L1 S2 S4 5VIN CP2102 21 20 19 18 17 16 15 1 2 U3 S3 S1 22 23 24 25 26 27 28 29 GND Q4 A42 S4 S2 J10 mini USB (PC) P10 P09 P08 P07 P06 P05 P21 P01 P00 VDD 120OHM S1 S3 R11 47R 1/2W C3 47uF / 10V 1 2 3 4 5 6 7 8 J7 P23 DETECT ICSP 2 2 5V OFF ON 4 3 Q3 A92 2 4 6 R10 1M J9 MICRO 15nH D- DEC4 DCC L2 D+ 1 2 SW7 UART_TX P12 UART_RX P11 ID 4 3 SW7 all off SW7 all on (D0 RX) (D1 TX) (D2) (D3) (D4) (D5) (D6) (D7) 5VIN 1 3 5 1 G BC832 - V0 BC832 - V1 D J5 P11 P12 P13 P14 P15 P16 P17 P18 1 2 3 4 5 6 GND GND SW6 (A0) (A1) (A2) (A3) (A4) (A5) J6 R8 3.01K BAT-ADC GND Current measurement , SW6 all off P03 P04 P28 P29 P30 P31 Q1 TP0610T R7 10K R6 10K S1 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 9 10 J4 SW on , 32K768Hz 2 J2 P19 (D8) P20 (D9) P22 (D10 SS) P23 (D11 MOSI) P24 (D12 MISO) P25 (D13 SCK) GND P02 (AREF) P26 (SDA) P27 (SCL) 1 OFF ON P03 AT_COM GND 3V3 1 2 C2 12pF nop SW off , GPIO VDD VDD VDD RESET VDD 5V GND GND P21 J3 input , J9 off Y1 32.768KHz 4 3 2 J1 VDD R4 1K LED4 1 VDD R3 1K LED3 P20 RESET VDD R2 1K LED2 1 VDD R1 1K LED1 C1 12pF nop SW5 DCC C SW4 1 2 C 2 SW3 VDD 2 GND D P17 SW2 7.8x8.8 mm Ver 2.01 Dec. 2017 Title EV BC832V2 J13 Oscilloscope 1 2 2 Size B Document Number Date: Thursday, March 16, 2017 Rev 1.0 BC832 EVM (UNO) Sheet 1 of 1 1 Suggestion for Battery Power Application Standby current consumption is important for battery-powered product. We suggest adding a 32.768 kHz crystal and 2 capacitors on the main board. The 32MHz main clock won’t be active at idle state to save power. BC832 V1 or newer should be used. Inductors required for DC to DC converter should be added on the main board. !15 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 6. Miscellaneous Soldering Temperature-Time Profile for Re-Flow Soldering Maximum number of cycles for re-flow is 2. No opposite side re-flow is allowed due to module weight. Cautions, Design Notes, and Installation Notes Failure to follow the guidelines set forth in this document may result in degrading of the product’s functions and damage to the product. Design Notes (1)Follow the conditions written in this specification, especially the control signals of this module. (2)The supply voltage has to be free of AC ripple voltage (for example from a battery or a low noise regulator output). For noisy supply voltages, provide a decoupling circuit (for example a ferrite in series connection and a bypass capacitor to ground of at least 47uF directly at the module). (3)This product should not be mechanically stressed when installed. (4)Keep this product away from heat. Heat is the major cause of decreasing the life of these products. (5)Avoid assembly and use of the target equipment in conditions where the products' temperature may exceed the maximum tolerance. (6)The supply voltage should not be exceedingly high or reversed. It should not carry noise and/or spikes. !16 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 (7)this product away from other high frequency circuits. Notes on Antenna and PCB Layout (1)Don’t use a module with internal antenna inside a metal case. (2)For PCB layout: • • • Avoid running any signal line below module whenever possible, No ground plane below antenna, If possible, cut-off the portion of main board PCB below antenna. Installation Notes (1)Reflow soldering is possible twice based on the time-temperature profile in this data sheets. Set up the temperature at the soldering portion of this product according to this reflow profile. (2)Carefully position the products so that their heat will not burn into printed circuit boards or affect the other components that are susceptible to heat. (3)Carefully locate these products so that their temperatures will not increase due to the effects of heat generated by neighboring components. (4)If a vinyl-covered wire comes into contact with the products, then the cover will melt and generate toxic gas, damaging the insulation. Never allow contact between the cover and these products to occur. (5)This product should not be mechanically stressed or vibrated when reflowed. (6)If you want to repair your board by hand soldering, please keep the conditions of this chapter. (7)Do not wash this product. (8)Refer to the recommended pattern when designing a board. (9)Pressing on parts of the metal cover or fastening objects to the metal will cause damage to the unit. (10)For more details on LGA (Land Grid Array) soldering processes refer to the application note. Usage Condition Notes (1)Take measures to protect the unit against static electricity. If pulses or other transient loads (a large load applied in a short time) are applied to the products, check and evaluate their operation before assembly on the final products. (2)Do not use dropped products. (3)Do not touch, damage or soil the pins. (4) Follow the recommended condition ratings about the power supply applied to this product. (5)Electrode peeling strength: Do not add pressure of more than 4.9N when soldered on PCB (6) Pressing on parts of the metal cover or fastening objects to the metal cover will cause damage. !17 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 (7) These products are intended for general purpose and standard use in general electronic equipment, such as home appliances, office equipment, information and communication equipment. Storage Notes (1)The module should not be stressed mechanically during storage. (2)Do not store these products in the following conditions or the performance characteristics of the product, such as RF performance will be adversely affected: • Storage in salty air or in an environment with a high concentration of corrosive gas. • Storage in direct sunlight • Storage in an environment where the temperature may be outside the range specified. • Storage of the products for more than one year after the date of delivery storage period. (3) Keep this product away from water, poisonous gas and corrosive gas. (4) This product should not be stressed or shocked when transported. (5) Follow the specification when stacking packed crates (max. 10). Safety Conditions These specifications are intended to preserve the quality assurance of products and individual components. Before use, check and evaluate the operation when mounted on your products. Abide by these specifications, without deviation when using the products. These products may short-circuit. If electrical shocks, smoke, fire, and/or accidents involving human life are anticipated when a short circuit occurs, then provide the following failsafe functions, as a minimum. (1)Ensure the safety of the whole system by installing a protection circuit and a protection device. (2)Ensure the safety of the whole system by installing a redundant circuit or another system to prevent a dual fault causing an unsafe status. Other Cautions (1)This specification sheet is copyrighted. Reproduction of this data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. (2)Do not use the products for other purposes than those listed. (3)Be sure to provide an appropriate failsafe function on your product to prevent an additional damage that may be caused by the abnormal function or the failure of the product. (4)This product has been manufactured without any ozone chemical controlled under the Montreal Protocol. (5)These products are not intended for other uses, other than under the special conditions shown below. Before using these products under such special conditions, check their performance and reliability under the said special conditions carefully to determine whether or not they can be used in such a manner. !18 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Ver 2.01 Dec. 2017 • In liquid, such as water, salt water, oil, alkali, or organic solvent, or in places where liquid may splash. • In direct sunlight, outdoors, or in a dusty environment • In an environment where condensation occurs. • In an environment with a high concentration of harmful gas. (6) If an abnormal voltage is applied due to a problem occurring in other components or circuits, replace these products with new products because they may not be able to provide normal performance even if their electronic characteristics and appearances appear satisfactory. (7) When you have any question or uncertainty, contact Fanstel. Packaging Production modules are delivered in reel, 1000 modules in each reel. FCC LABEL The Original Equipment Manufacturer (OEM) must ensure that the OEM modular transmitter must be labeled with its own FCC ID number. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown below. If the FCC ID is not visible when the equipment is installed inside another device, then the outside of the device into which the equipment is installed must also display a label referring to the enclosed equipment The end product with this module may subject to perform FCC part 15 unintentional emission test requirement and be properly authorized. This device is intended for OEM integrator only. !19 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Revision History • December 2017. Ver. 2.01: Add QDID number and clarify specifications !20 Ver 2.01 Dec. 2017 Bluetooth Low Energy (BLE) 5 Micro Module BC832 Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com !21 Ver 2.01 Dec. 2017
BC832 价格&库存
很抱歉,暂时无法提供与“BC832”相匹配的价格&库存,您可以联系我们找货
BC832
    • 1+60.71487
