0.90
H
10.50
1.45
1.20
C5
C
E
C2
C3
C4
12.00
8.00
5.00
12.90±0.10
13.40±0.10
C1
C6
2.89
C7
2.20
C
G
F
13.40
Specifications 规格
Material 物料
Plastic Housing 塑胶外壳: Thermoplastic, UL94V-0, black
Contact Terminal 接触端子: Phosphor Bronze
Metallic Shell 金属外壳: Stainless Steel SUS304
C8
2.54
Plating 电镀
Contact Area 接触区域: 3µ" Gold
Solder area: 3µ" Gold
Underplating 底层电镀: 50µ" Ni overall
Solder area 焊接区域镀金 1µ" Gold
0.90
2.29
Recommended PCB Layout
12.20
As viewed from component side General tolerance ±0.05
Component Outline
Solder Area
Electrical 电气
Voltage Rating电压额定值: 50V
Current Rating 电流额定值: 1A max.
Operating Temperature 工作温度: -40°C to +85°C
Dielectric Withstanding Voltage 耐电压: 500V AC (60Sec min.)
Insulation Resistance 绝缘电阻: 1000 MΩ min. (Apply 500V DC)
Contact Resistance 接触电阻: 100 mΩ max.
2.40
2.45
D
7.46
0.70
13.40±0.10
7.62
Mechanical & Environmental 机械 & 环境
Duration 耐久性: 5000 cycles
3.15
2.95
C
SIM7050
7.95
0.44
Ordering Grid
11.00±0.20
B
1.60
Section C-C
A
2
Request Samples
and Quotation
No. of Contacts
6 = 6 Pin
Packing Options
A = Tape & Reel
(contacts C4 & C8 removed from component)
(900 per Reel)
Product Description
Micro SIM Card Connector
Retainer Type, 6 & 8 Pin, SMT, Profile 2.45mm
By
Detail
4
A
SIM7050
24th August 2012
3
00
Part Number
10.50
1
8 = 8 Pin
Drawing Date
2.54
X
Revision
Date
5
AJO
Tolerances (Except as Noted)
SIM7050
C PCN
C
20/04/15
X.X ± 0.35
X.X° ± 3.0°
X.XX ± 0.25
X.XX° ± 2.0°
X.XXX ± 0.15
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
1/3
H
Micro SIM Reference
thickness = 0.76±0.08
G
25.00mm Mini
15.00±0.10
2.19
12.30mm Nano
F
C2
C6
C3
C7
7.62
C5
C1
8x1.70
D
12.00±0.10
15.00mm Mini
E
8.80mm Nano
7.62
C8
C4
C1
VCC
C2
RST
C3
CLK
C4
RFU
C5
GND
C6
Vpp
C7
I/O
C8
RFU
2.5C
C
8x2.00
5xR0.80
3.15
B
Part Number
Product Description
SIM7050
Drawing Date
A
24th August 2012
By
Detail
1
2
3
4
Revision
Date
5
AJO
SIM7050
C PCN
C
20/04/15
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
2/3
Notes:
1. Reel Diameter.: 33CM.
2. 900 PCS per Reel, Gross Weight: 0.77KG.
3. 10 Reels per Full Carton, Gross Weight: 7.7KG
H
Hard Cardboard
硬纸板
Bubble-Pad
气泡垫
ADHESIVE TAPE
G
PULL OUT DIRECTION
Ø1
3
330
F
Triangular Pad
三角垫
Reel
卷筒
325mm
REEL
E
35
Ou m m
tsi
de
Protection Tape
电周波
D
1.75
Empty carrier at reel end
200min.
2
4
Empty carrier at front end
Cover tape
350min.
50min.
Carton
纸箱
Ø1.5
13.7
11.5
24
C
900pcs loaded
m
0m
35
ide
s
t
Ou
Outside
Label
标签
TOTAL
5LAYERS
13.7
0.3
3.15
3.45
B
Part Number
Product Description
SIM7050
Drawing Date
A
24th August 2012
By
Detail
1
2
3
4
Revision
Date
5
AJO
SIM7050
C PCN
C
20/04/15
Length
Angle
X.X ± 0.15
X.XX ± 0.10
X.XXX ± 0.05
± 1.5°
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
3/3
很抱歉,暂时无法提供与“SIM7050-8-0-00-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 900+7.26910900+0.87940
- 1800+6.230671800+0.75377
- 2700+6.022982700+0.72865
- 6300+5.815306300+0.70352
- 9000+5.524549000+0.66835
- 国内价格 香港价格
- 1+12.010901+1.45305
- 10+10.1750310+1.23095
- 25+9.7613925+1.18091
- 50+9.5535450+1.15577
- 100+9.13814100+1.10551
- 250+8.30772250+1.00505
