IN-S85AT series
Top View SMD LED 0805 PCB Type
Features
0805 1.1mm SMD LED
High Brightness
AlInGaP / InGaN Technology
Small package
High reliability
Clear Lens
Description
The IN-S85AT series is a popular low profile 0805
package with versatile design capabilities. It is a PCB
type molding style LED which can be used in various
applications.
Recommended Solder Pattern
Applications
Consumer Electronics
Wearables
Automobile After Market
Industrial Equipment
Figure 1. IN-S85AT Solder Pattern
Package Dimensions in mm
Figure 2. IN-S85AT Package Dimensions
Inolux Corporation
Proprietary & Confidential
February, 13, 2019
Page 1
www.inolux-corp.com
IN-S85AT series
Absolute Maximum Rating at 25oC (Note 1)
Product
Emission
Color
IN-S85ATYG
Yellow Green
IN-S85ATY
Yellow
IN-S85ATA
Amber
IN-S85ATR
Red
IN-S85AT5B
Blue
IN-S85ATG
Green
IN-S85AT5UW
White
Pd (mW)
IF (mA)
IFP* (mA)
75
25
70
75
25
VR (V)
TOP (oC)
TST (oC)
5
-30oC~+85oC
-40oC~+90oC
100
Notes
1. Condition for IFP is pulse of 1/10 duty and 0.1msec width
ESD Precaution
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even
though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based
chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which
may be induced by electrostatic discharge (ESD).
Inolux Corporation
February, 13, 2019
Page 2
www.inolux-corp.com
IN-S85AT series
Electrical Characteristics T
A
= 25°C (Note 1)
VF(V)
Product
Emission
Color
IN-S85ATYG Yellow Green
Viewing
λ(nm)
Angel
IF(mA)
I*V(mcd)
min
max
λD
λP
△λ
2θ1/2
typ.
2.6
572
576
15
120
45
IN-S85ATY
Yellow
2.6
592
594
15
120
115
IN-S85ATA
Amber
2.6
605
610
80
IN-S85ATR
Red
2.6
625
630
140
IN-S85AT5B
Blue
5
2.6
3.4
470
473
30
120
80
IN-S85ATG
Green
3.6
520
528
35
120
600
IN-S85AT5UW
White
5
2.6
3.4
X=0.29
Y=0.29
120
180
Notes
1. Performance guaranteed only under conditions listed in above tables.
Inolux Corporation
February, 13, 2019
Page 3
www.inolux-corp.com
IN-S85AT series
Chromaticity Bin (for White only)
Inolux Corporation
February, 13, 2019
Page 4
www.inolux-corp.com
IN-S85AT series
Inolux Corporation
February, 13, 2019
Page 5
www.inolux-corp.com
IN-S85AT series
Typical Characteristic Curves – YG, Y, A, R
Inolux Corporation
February, 13, 2019
Page 6
www.inolux-corp.com
IN-S85AT series
Typical Characteristic Curves – B, G, W
Inolux Corporation
February, 13, 2019
Page 7
www.inolux-corp.com
IN-S85AT series
Typical Characteristic Curves – Radiation Pattern
Ordering Information
Product
Technolog Test Current
Emission Color
y
IF (mA)
Forward
Luminous Intensity
Voltage
IV (mcd)
VF (V)
(Typ.)
(Typ.)
Orderable
Part Number
IN-S85ATYG
Yellow Green
AllnGaP
2.0
IN-S85ATYG
IN-S85ATY
Yellow
AllnGaP
2.0
IN-S85ATY
IN-S85ATA
Amber
AllnGaP
2.0
IN-S85ATA
IN-S85ATR
Red
AllnGaP
2.2
IN-S85ATR
IN-S85AT5B
Blue
InGaN
5
80
3.0
IN-S85AT5B
IN-S85ATG
Green
InGaN
3.2
IN-S85ATG
IN-S85AT5UW
White
InGaN
5
180
3.0
IN-S85AT5UW
Inolux Corporation
February, 13, 2019
Page 8
www.inolux-corp.com
IN-S85AT series
Label Specifications
Inolux P/N:
I
N
S
8
Material
S = PCB
Type
Inolux
SMD
5
Package
A
T
Variation
Orientation
85A = 2.0 x 1.25 x 1.1mm
X
T = Top
Mount
Current
(Blank) =
20mA
Lens
Color
(Blank) = Clear
U = Diffused
R=630nm
A=610nm
Y=594nm
YG=576nm
G=528nm
B=473nm
W=White
5-5mA
X
X X
Customized
Stamp-off
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
01
24
001
Month
Date
Serial
February, 13, 2019
Page 9
X
www.inolux-corp.com
IN-S85AT series
Packaging Information: 3000pcs Per Reel
Tape Dimension
Reel Dimension
Inolux Corporation
February, 13, 2019
Page 10
www.inolux-corp.com
IN-S85AT series
Packing Dimension
5 boxes per carton are available depending on shipment quantity.
Specification
Material
Quantity
Carrier tape
Per EIA 481-1A specs
Conductive black tape
3000pcs per reel
Reel
Conductive black
Label
IN standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/ no-zipper
One reel per bag
Carton
IN standard
Paper
Non-specified
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same
bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists
of a product label as well.
Inolux Corporation
February, 13, 2019
Page 11
www.inolux-corp.com
IN-S85AT series
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during
transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly
sealed prior to shipment.
Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Reflow Soldering
• Recommended tin glue specifications: melting temperature in the range of 178~192 OC
• The recommended reflow soldering profile is as follows (temperatures indicated are as measured on
the surface of the LED resin):
Lead-free Solder Profile
Inolux Corporation
February, 13, 2019
Page 12
www.inolux-corp.com
IN-S85AT series
Precautions
Avoid exposure to moisture at all times during transportation or storage.
Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products.
It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a
reverse voltage.
Avoid operation beyond the limits as specified by the absolute maximum ratings.
Avoid direct contact with the surface through which the LED emits light.
If possible, assemble the unit in a clean room or dust-free environment.
Reworking
Rework should be completed within 5 seconds under 260 OC.
The iron tip must not come in contact with the copper foil.
Twin-head type is preferred.
Cleaning
Following are cleaning procedures after soldering:
• An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended.
• Temperature x Time should be 50oC x 30sec. or
很抱歉,暂时无法提供与“IN-S85ATR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1020+0.453271020+0.05476
