Miniature limit switch
ES 50 ST 1Ö/1S
Material number: 1046989 (Material number old: 50005001)
Features/Options:
• Thermoplastic enclosure
• Actuator: Adjustable plunger ST
• Plunger with knurled-head setting screw
• Length of metal plunger adjustable for fine adjustment of
switching travel
Dimensions
Technical data
Applied standards
EN ISO 13849-1, EN 60947-5-1
Enclosure
thermoplastic, glass-fibre
reinforced, impact resistant, selfextinguishing UL 94 V-0
Actuator
plunger: brass
Tightening torque
enclosure mounting screws:
approx. 1 Nm
cover screws: approx. 0.6 Nm
Degree of protection
IP 30 to IEC/EN 60529
B10d (10 % load)
500 000
TM
max. 20 years
Degree of pollution
3
Contact material
silver
Switching system
slow action, positive break NC
contacts A
Switching elements
1 NC/1 NO contact, type Zb
Connection
screw connection terminals
Cable cross-section
max. 1.5 mm²
Rated impulse withstand
voltage Uimp
4 kV
Rated insulation voltage Ui
400 V
Conventional thermal current 4 A
Ithe
Rated operating current/
voltage Ie/Ue
4 A/400 VAC
Utilisation category
AC-15
Short-circuit protection
4 A gG/gN fuse
Ambient temperature
–20 °C … +75 °C
Mechanical life
> 1 million operations
Operation cycles
max. 1800/h
Errors and omissions excepted.
steute Technologies
GmbH & Co. KG
Brückenstraße 91
32584 Löhne, Deutschland
Telefon +49 5731 745-0
Telefax +49 5731 745-200
info@steute.com
www.steute.com
Page: 1 / 2
Printed: 22.07.2022
ES 50 ST 1Ö/1S
Technical data
Repeat accuracy of switching ± 0.1 mm
points
Contact diagram
11
23
Contact opening
max. 2 x 4 mm
Approvals
d
Weight
20 g
Switching diagram
2,5
24
1
3
5
23-24
11-12
T Positive break travel/angle
steute Technologies
GmbH & Co. KG
Brückenstraße 91
info@steute.com
www.steute.com
Page: 2 / 2
Printed: 22.07.2022
很抱歉,暂时无法提供与“STE-1046989ES50”相匹配的价格&库存,您可以联系我们找货
