Radiocrafts
Embedded Wireless Solutions
RCxxxx-IEB
Radiocrafts IOT-Module Expansion Board for FX30 and
mangOH Gateway
Product Description
The RCxxxx-IEB is a series of
expansion boards for the Sierra Wireless
FX30 Programmable IoT Gateway
(hereafter named FX30) and the open
source HW mangOH.
A complete IoT solution is easily created
by using the Radiocrafts IOT expansion
board and the gateway in combination
with sensor nodes based on Radiocrafts
RF modules in a local wireless network.
The boards contain an RF module giving
wireless connectivity, and the interface
circuitry to the host processor in the
gateway. The card has an SMA connector for connecting the external antenna.
The insertion board series include several different products supporting different frequencies
and radio protocols. The embedded protocol inside the RF module handles all RF
communication and only data payload and easy-to-use commands are sent over the UART or
SPI serial bus to/from the gateway processor.
Supported Protocols and Network Standards
Wireless M-Bus
IEEE 802.15.4g
RC232/TinyMesh
ZigBee
Applications
3G/4G LTE gateway solutions for:
Internet of Things applications
Wireless Sensor Networks
AMR / Smart Metering
Home automation, building automation and industrial automation
Fleet and inventory management
2018 Radiocrafts AS
RCxxxx-IEB Data Sheet (rev. 1.02)
Page 1 of 12
Radiocrafts
RCxxxx-IEB
Features
On-board radio module with embedded protocol
Easy-to-use UART/SPI interface connects to powerful Sierra Wireless-internal WP
module
RF interface with SMA connector connects to any standard antenna
Same PCB supports modules from a large portfolio of RF modules
Miniature LED indicators (connects to RF module-processor)
CE certified module for EU frequencies
FCC pre-qualified for dedicated RF modules
2018 Radiocrafts AS
Page 2 of 12
Radiocrafts
RCxxxx-IEB
Functional block diagram
Sierra Wireless FX30 Gateway/mangOH
Sierra Wireless
Internal
CPU
UART/SPI
Ethernet/
Serial
Radiocrafts IoT Expansion
Board
Level shifter
circuitry
Radiocrafts
RF Module
SMA
EEPROM
(optional)
USB
Figure 1: Functional block diagram for FX30 gateway and IoT expansion board
Gateway programming1
The FX30 and mangOH integrates the Legato® Open Source Linux Platform that simplifies
application-level development with a secure application framework, maintained Linux
distribution, and feature-rich development environment. Legato® enables efficient C-level
programming, making FX30 the core component for distributed IoT systems. Legato features
an application sandbox that provides a secure environment to run and control multiple
applications. With security and connectivity built in, Legato’s robust APIs enable users to
connect to any cloud or network, and allow developers to focus on building the value-add IoT
applications. Legato offers an Eclipse-based integrated development environment (IDE),
providing an extensible and familiar toolset with built-in API awareness. With multi-language
support, Legato allows developers to code in their preferred language, and provides a robust
suite of diagnostic tools, to enable- local and remote debugging, troubleshooting, monitoring
and profiling.
Figure 2. FX30 gateway from Sierra Wireless
1
Information from Sierra Wireless FX30 Datasheet
2018 Radiocrafts AS
Page 3 of 12
Radiocrafts
RCxxxx-IEB
Figure 3. mangOH Red gateway
Antenna connection
A quarter wave antenna can be directly connected to the SMA antenna connector. If the
modem is placed in environments where RF performance is reduced, an external antenna
can be connected via an extension coaxial cable to the SMA connector. It is strongly
recommended that the Sierra Wireless 3G/4G antenna and the antenna on the expansion
card are not pointing in the same direction, in order to reduce possible interference and range
reductions. Thus, use angled 3G/4G antenna if straight antenna is used with the expansion
card, and vice versa.
Product variants
For detailed information on each variant of the insertion boards, please see the User Manual
and Data Sheet for the respective Radiocrafts modules used on the different variants.
Datasheets can be downloaded from the Radiocrafts site www.radiocrafts.com
IOT expansion board
The expansion board is designed to be the link between the local radio network (ISM band
radio), and the cell phone network modem.
The IoT Expansion Card form factor represents an open hardware standard for sensors,
network adapters, and other IoT technologies that can be "plugged" into host applications to
provide new features and interfaces. As a family, IoT Expansion Cards share a standardized
footprint and pinout, with several interfaces to support various IoT technologies
The IOT module has a standardized PCB edge connector that fit in the QSFP+ IoT
Connector at the host. The pinout is standardized but described here for each module.
2018 Radiocrafts AS
Page 4 of 12
Radiocrafts
RCxxxx-IEB
RCxxxx-IEB Circuit Diagram
The board will have different components mounted depending on the type of Radiocrafts
module used. Table 1 shows which signal from FX30 is used at each expansion board. Figure
2-5 shows the schematic for each type of expansion boards.
26
27
2829
30
31
32
3337
38
GPIO3
NC
VCC_3V3
VCC_1V8
TXD
RXD
CTS
RTS
SPI_CLK
SPI_MISO
SPI_MOSI
SPI_SS
NC
GND
I2C
I2C
NC
GPIO2
RC2400HP-ZNM
VCC_5V
NC
GND
NC
RC1701HP-MBUS4
1
2-3
4
510
11
12
13
14
15
16
17
18
19
22
23
24
25
Description and internal MCU connection
RC1880CEF
Pin name
RC1180-MBUS3
Pin
no
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
GND
n_Card_detect
n_Reset
NC
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
۷
GND
۷
2018 Radiocrafts AS
5V supply
Not Connected (USB)
System ground
Not Connected (SDIO)
1.8V supply
Connects to the module TXD (RXD on host)
Connects to the module’s RXD-pin
Connects to the module’s CTS-pin
Connects to the module’s RTS-pin
Both RC1880CEF and RC2400HP-ZNM default use
UART as communication port at baud rate 115200.
But the expansion board include the driver for SPI
as an option.
Config (enable module configuration mode)
System ground
Not Connected (GPIO1)
Connect to BSL_ENABLE (RC1880) and CONFIG
pin for all other
MRDY signal for SPI Enabled modules
Not Connected (GPIO4)
3.3V Supply
System ground
Not Connected (I2S/PPS)
۷
۷ ۷ System ground
Table 1. Pin mapping
Page 5 of 12
Radiocrafts
RCxxxx-IEB
Figure 4. RC1880CEF-IEB schematic
2018 Radiocrafts AS
Page 6 of 12
Radiocrafts
RCxxxx-IEB
Figure 5 RC2400HP-ZNM-IEB schematic
2018 Radiocrafts AS
Page 7 of 12
Radiocrafts
RCxxxx-IEB
Figure 4: RC1701HP-MBUS4-IEB schematic
2018 Radiocrafts AS
Page 8 of 12
Radiocrafts
RCxxxx-IEB
Figure 5: RC1180-MBUS3-IEB schematics
2018 Radiocrafts AS
Page 9 of 12
Radiocrafts
RCxxxx-IEB
RCxxxx-IEB PCB and Assembly layout
The PCB is a 4-layer board where Layer 2 is used as ground plane. The laminate used is
compliant to IPC4101D/126 giving excellent reliability in challenging environment. The PCB is
1.0 mm thick. PCB is edge bevelled/chamfered were is connect to host for easy and repeated
mating with connector at host.
Figure 6: RCxxxx-IEB PCB component placement, top side
Mechanical Drawing
22.3 mm
45 mm
Figure 7: Mechanical drawing
Mechanical Dimensions
The board size is 35.7 x 57.0 x 4.1 mm (total height for PCB and module).
2018 Radiocrafts AS
Page 10 of 12
Radiocrafts
Article Numbers
Ordering Number
RC1180-MBUS3-IEB
RC2400HP-ZNM-IEB
RC1701HP-MBUS4IEB
RC1880CEF-IEB
RC1180-RC232-IEB
RC1190-RC232-IEB
RC1180-TM-IEB
RC1170-TM-IEB
RC1701HP-RC232IEB
Module Description
Embedded Wireless M-Bus
protocol (EN13757-4:2005, 868
MHz radio)
ZNM module for 2.45 GHz mesh
protocol (EN13757-4:2005, 169
MHz radio) for gas, water, heat
and electricity meter readings
IEEE 802.15.4g connectivity
Module is delivered as HW
platforms, but as part of our
internal tests the module is loaded
with COP freeware.2
868 and 915 MHz high speed
modules, RC232 protocol
Tinymesh gateway
RCxxxx-IEB
Availability
Standard parts
Non standard parts. Contact
Radiocrafts sales for lead time
and MOQ
169 MHz module with RC232
firmware
Other variants are available upon request.
Please contact sales@radiocrafts.com
2
The COP FW is a firmware image which implements the MAC IEEE 802.15.4-2006 standard
in a dedicated system on a chip (SoC), providing a simple serial interface to an external host
processor for control and processing of the Co-Processor operations.
http://dev.ti.com/tirex/content/simplelink_cc13x0_sdk_1_40_00_10/docs/ti154stack/ti-15.4stack-cop-interface-guide.pdf. The image is also available for download on
www.radiocrafts.com.
2018 Radiocrafts AS
Page 11 of 12
Radiocrafts
Document Revision History
Document Revision
1.00
1.01
1.02
RCxxxx-IEB
Changes
First release
Part number update on RC1880 variant
Name change from –FX30 to IEB in order to also focus on mangOH
Disclaimer
Radiocrafts AS believes the information contained herein is correct and accurate at the time of this printing. However,
Radiocrafts AS reserves the right to make changes to this product without notice. Radiocrafts AS does not assume any
responsibility for the use of the described product; neither does it convey any license under its patent rights, or the
rights of others. The latest updates are available at the Radiocrafts website or by contacting Radiocrafts directly.
As far as possible, major changes of product specifications and functionality, will be stated in product specific Errata
Notes published at the Radiocrafts website. Customers are encouraged to check regularly for the most recent updates
on products and support tools.
Trademarks
RC232™ is a trademark of Radiocrafts AS. The RC232™ Embedded RF Protocol is used in a range of products from
Radiocrafts. The protocol handles host communication, data buffering, error check, addressing and broadcasting. It
supports point-to-point, point-to-multipoint and peer-to-peer network topologies.
All other trademarks, registered trademarks and product names are the sole property of their respective owners.
Life Support Policy
This Radiocrafts product is not designed for use in life support appliances, devices, or other systems where malfunction
can reasonably be expected to result in significant personal injury to the user, or as a critical component in any life
support device or system whose failure to perform can be reasonably expected to cause the failure of the life support
device or system, or to affect its safety or effectiveness. Radiocrafts AS customers using or selling these products for
use in such applications do so at their own risk and agree to fully indemnify Radiocrafts AS for any damages resulting
from any improper use or sale.
© 2018, Radiocrafts AS. All rights reserved.
Contact Information
Web site: www.radiocrafts.com
Address:
Radiocrafts AS
Sandakerveien 64
NO-0484 OSLO
NORWAY
Tel: +47 4000 5195
Fax: +47 22 71 29 15
E-mails: sales@radiocrafts.com
2018 Radiocrafts AS
Page 12 of 12
很抱歉,暂时无法提供与“RC1701HP-MBUS4-IEB”相匹配的价格&库存,您可以联系我们找货
