751
    ADAFRUIT
751 数据手册
Adafruit Optical Fingerprint Sensor Created by lady ada https://learn.adafruit.com/adafruit-optical-fingerprint-sensor Last updated on 2022-03-15 09:52:55 PM EDT ©Adafruit Industries Page 1 of 27 Table of Contents Overview 3 Enrolling vs. Searching 4 Enrolling New Users with Windows 4 Searching with the Software 9 Wiring for use with Arduino 10 • • • • Arduino UNO & Compatible Wiring Hardware Serial Wiring Soft & Hard Serial Upload 12 13 14 15 Enrolling with Arduino 16 Python & CircuitPython 17 • • • • • • • • • • 17 18 18 19 20 20 21 25 25 26 Sensor Wiring CircuitPython Microcontroller Wiring Python Computer Wiring CircuitPython Fingerprint Library Installation Python Installation of Fingerprint Library CircuitPython & Python Usage Example Code Enrolling Prints Finding Prints Deleting Fingerprints Python Docs 26 Downloads 26 ©Adafruit Industries Page 2 of 27 Overview Secure your project with biometrics - this all-in-one optical fingerprint sensor will make adding fingerprint detection and verification super simple. These modules are typically used in safes - there's a high powered DSP chip that does the image rendering, calculation, feature-finding and searching. Connect to any microcontroller or system with TTL serial, and send packets of data to take photos, detect prints, hash and search. You can also enroll new fingers directly - up to 162 finger prints can be stored in the onboard FLASH memory. We like this particular sensor because not only is it easy to use, it also comes with fairly straight-forward Windows software that makes testing the module simple - you can even enroll using the software and see an image of the fingerprint on your computer screen. But, of course, we wouldn't leave you a datasheet and a "good luck!" - we wrote a full Arduino library so that you can get running in under 10 minutes. The library can enroll and search so its perfect for any project (https://adafru.it/aRz). We've also written a detailed tutorial on wiring and use (https://adafru.it/clz). This is by far the best fingerprint sensor you can get. • Supply voltage: 3.6 - 6.0VDC • Operating current: 120mA max • Peak current: 150mA max • Fingerprint imaging time:  prompt. Python Installation of Fingerprint Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require enabling the hardware UART on your platform (see red note above) and verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https://adafru.it/BSN)! Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-fingerprint If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! CircuitPython & Python Usage To demonstrate the usage of the sensor, we'll use the example python script included with the library. This sensor is fairly complex so its hard to run it just from the REPL. ©Adafruit Industries Page 20 of 27 CircuitPython Microcontroller Usage Once you've installed the library, run this code.py example on your CircuitPython board. Linux/Computer/Raspberry Pi with Python If you're running fingerprint_simpletest.py on the Raspberry Pi (or any computer), you'll have to make some changes. On the Raspberry Pi, comment out the uart = busio.UART(...) line, and uncomment the applicable import serial and uart = serial.Serial(...) lines, depending on whether you're using USB serial or hardware UART.  Now you can run the program with the following command: python3 fingerprint_simpletest.py Example Code Remember, SAMD21 and other very-low-memory devices will not be able to run the following example. # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT import time import board import busio from digitalio import DigitalInOut, Direction import adafruit_fingerprint led = DigitalInOut(board.D13) led.direction = Direction.OUTPUT uart = busio.UART(board.TX, board.RX, baudrate=57600) # If using with a computer such as Linux/RaspberryPi, Mac, Windows with USB/serial converter: # import serial # uart = serial.Serial("/dev/ttyUSB0", baudrate=57600, timeout=1) # If using with Linux/Raspberry Pi and hardware UART: # import serial # uart = serial.Serial("/dev/ttyS0", baudrate=57600, timeout=1) finger = adafruit_fingerprint.Adafruit_Fingerprint(uart) ################################################## ©Adafruit Industries Page 21 of 27 def get_fingerprint(): """Get a finger print image, template it, and see if it matches!""" print("Waiting for image...") while finger.get_image() != adafruit_fingerprint.OK: pass print("Templating...") if finger.image_2_tz(1) != adafruit_fingerprint.OK: return False print("Searching...") if finger.finger_search() != adafruit_fingerprint.OK: return False return True # pylint: disable=too-many-branches def get_fingerprint_detail(): """Get a finger print image, template it, and see if it matches! This time, print out each error instead of just returning on failure""" print("Getting image...", end="", flush=True) i = finger.get_image() if i == adafruit_fingerprint.OK: print("Image taken") else: if i == adafruit_fingerprint.NOFINGER: print("No finger detected") elif i == adafruit_fingerprint.IMAGEFAIL: print("Imaging error") else: print("Other error") return False print("Templating...", end="", flush=True) i = finger.image_2_tz(1) if i == adafruit_fingerprint.OK: print("Templated") else: if i == adafruit_fingerprint.IMAGEMESS: print("Image too messy") elif i == adafruit_fingerprint.FEATUREFAIL: print("Could not identify features") elif i == adafruit_fingerprint.INVALIDIMAGE: print("Image invalid") else: print("Other error") return False print("Searching...", end="", flush=True) i = finger.finger_fast_search() # pylint: disable=no-else-return # This block needs to be refactored when it can be tested. if i == adafruit_fingerprint.OK: print("Found fingerprint!") return True else: if i == adafruit_fingerprint.NOTFOUND: print("No match found") else: print("Other error") return False # pylint: disable=too-many-statements def enroll_finger(location): """Take a 2 finger images and template it, then store in 'location'""" for fingerimg in range(1, 3): if fingerimg == 1: print("Place finger on sensor...", end="", flush=True) else: ©Adafruit Industries Page 22 of 27 print("Place same finger again...", end="", flush=True) while True: i = finger.get_image() if i == adafruit_fingerprint.OK: print("Image taken") break if i == adafruit_fingerprint.NOFINGER: print(".", end="", flush=True) elif i == adafruit_fingerprint.IMAGEFAIL: print("Imaging error") return False else: print("Other error") return False print("Templating...", end="", flush=True) i = finger.image_2_tz(fingerimg) if i == adafruit_fingerprint.OK: print("Templated") else: if i == adafruit_fingerprint.IMAGEMESS: print("Image too messy") elif i == adafruit_fingerprint.FEATUREFAIL: print("Could not identify features") elif i == adafruit_fingerprint.INVALIDIMAGE: print("Image invalid") else: print("Other error") return False if fingerimg == 1: print("Remove finger") time.sleep(1) while i != adafruit_fingerprint.NOFINGER: i = finger.get_image() print("Creating model...", end="", flush=True) i = finger.create_model() if i == adafruit_fingerprint.OK: print("Created") else: if i == adafruit_fingerprint.ENROLLMISMATCH: print("Prints did not match") else: print("Other error") return False print("Storing model #%d..." % location, end="", flush=True) i = finger.store_model(location) if i == adafruit_fingerprint.OK: print("Stored") else: if i == adafruit_fingerprint.BADLOCATION: print("Bad storage location") elif i == adafruit_fingerprint.FLASHERR: print("Flash storage error") else: print("Other error") return False return True ################################################## def get_num(): """Use input() to get a valid number from 1 to 127. Retry till success!""" ©Adafruit Industries Page 23 of 27 i = 0 while (i > 127) or (i < 1): try: i = int(input("Enter ID # from 1-127: ")) except ValueError: pass return i while True: print("----------------") if finger.read_templates() != adafruit_fingerprint.OK: raise RuntimeError("Failed to read templates") print("Fingerprint templates:", finger.templates) print("e) enroll print") print("f) find print") print("d) delete print") print("----------------") c = input("> ") if c == "e": enroll_finger(get_num()) if c == "f": if get_fingerprint(): print("Detected #", finger.finger_id, "with confidence", finger.confidence) else: print("Finger not found") if c == "d": if finger.delete_model(get_num()) == adafruit_fingerprint.OK: print("Deleted!") else: print("Failed to delete") It's fairly long but it will help you set-up and test your sensor! When you first start up, you should get something like this: If you get an error like RuntimeError: Failed to read data from sensor it means something went wrong - check your wiring and baud rate! This menu system is fairly simple, you have three things you can do • Enroll print - you will use your finger to take images and 'store' the model in the sensor • Find print - determine whether a fingerprint is known and stored • Delete print - clear out a model ©Adafruit Industries Page 24 of 27 Enrolling Prints Enrolling a finger print is easy. Type e to start the process. You'll need to select a location. The sensor can store up to 127 print locations. Pick a valid number, then place your finger twice to enroll. Note that after success, the Fingerprint templates: [...] printout will include the new template id. If an error occurs, the sensor will give you an error, such as if the two prints don't match, or if it failed to store or generate a model: Finding Prints Once you've enrolled fingerprints you can then test them. Run the find command, and try various fingers! Once the fingerprint id identified it will tell you the location number, in this case #5 ©Adafruit Industries Page 25 of 27 Deleting Fingerprints If you made a mistake you can remove fingerprint models from the database. For example, here's how to delete #5. Note the Fingerprint templates: [...] printout changes! Python Docs Python Docs (https://adafru.it/C4C) Downloads • Arduino interface library on github (https://adafru.it/aRz) • User Manual (https://adafru.it/C4D) • Datasheet (its not really a great datasheet and its in Chinese, but its better than nothing) (https://adafru.it/aRB) ©Adafruit Industries Page 26 of 27 • English version of the User Manual (https://adafru.it/C4D) • "SFGDemo" Windows-only test software (https://adafru.it/aRC) ©Adafruit Industries Page 27 of 27
很抱歉,暂时无法提供与“751”相匹配的价格&库存,您可以联系我们找货
    • 1+437.26101
