SEN-15436
SEN-15436
    SPARKFUNELECTRONICS
    SEN-15436
SEN-15436 数据手册
  SparkFun Ambient Light Sensor - VEML6030 (Qwiic) SEN-15436 Looking for an option to sense ambient light? The VEML6030 Qwiic board is a great starter option. The VEML6030 is a high accuracy ambient light sensor with 16-bit resolution. Even more impressive is that it can detect light similar to the human eye response. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"spaced pins in case you prefer to use a breadboard. The SparkFun Ambient Light Sensor reads ambient light in lux and boasts a number of nice features including: the ability to set high and low thresholds for an optional interrupt, power saving features that enable single digit micro-amp current draw, and a readable range from zero to 120,000 lux. We've also written an Arduino library that gives full access to all features and includes example code demonstrating all its abilities. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES       Floor life: 72h, MSL 4, according to J-STD-020 Low stand by current consumption: typically 0.5uA Configurable I2C address (Default: 0x48) Removable pull-up resistors Removable power LED Qwiic Connectors https://www.sparkfun.com/products/15436 /7‐22‐19
SEN-15436 价格&库存
很抱歉,暂时无法提供与“SEN-15436”相匹配的价格&库存,您可以联系我们找货
