IN-PI42TAS(X)R(X)G(X)B
4020 Side View RGB LED 4-Pin with Integrated IC
Features
Description
4020 with integrated high quality constant
current IC and RGB LED chip.
Built-in IC, with high precision of constant
current and internal RGB chips spectral
processing in advance.
Single line data transmission (return to zero
code).
Specific Shaping Transmit Technology - number
of LED stacked is not restricted.
Cascading Enhancement Technology - any 2 LED
spacing can be up to 10 meters
Data transfer rate of 800 kbp/s at 30 frames per
second.
RGB output port PWM control can achieve 256
grey level adjustments.
Upon powering up, IC performs self-inspection
then lights connection on the pin B lamp.
SA-I Anti-interference patent technology for
single line data transmission.
Built-in power supply reverse connect protection
module, reversed power input will not damage
the IC.
The IN-PI42TAS(X)R(X)G(X)B is 4.0*2.0*1.5mm RGB
LED with integrated IC. It is a SMD type LED which
can be used in various applications.
Applications
Full color LED string light
LED full color module
LED guardrail tube
LED scene lighting
LED point light
LED pixel screen
LED shaped screen
Package Outline Dimensions & Pin Configuration
Figure 1. IN-PI42TAS(X)R(X)G(X)B Package Outline Dimensions
Inolux Corporation
Proprietary & Confidential
Page 1
July 1, 2018
www.inolux-corp.com
Pin Configuration
Figure 2. IN-PI42TAS(X)R(X)G(X)B Pin Configuration
Notes:
1. Dimension in millimeter, tolerance is ±0.1mm unless otherwise noted.
Number
Symbol
Function Description
1
DIN
Control data signal input
2
VDD
Power supply LED
3
DOUT
Control data signal output
4
GND
Ground
Soldering Pad Size
Pad Size
Inolux Corporation
Page 2
July 1, 2018
www.inolux-corp.com
Absolute Maximum Rating (Ta = 25 ℃, VSS=0V)
Parameter
Symbol
Range
Unit
Logic supply voltage
VDD
+3.5~+5.5
V
Logic input voltage
VIN
-0.5 ~VDD+0.5
V
Operating temperature
TOPT
−45 ~ +85
°C
Storage temperature
TSTG
−50 ~ +150
°C
ESD pressure(HBM)
VESD
4K
V
ESD pressure(DM)
VESD
200
V
LED Characteristics (Ta = 25°C)
5mA
12mA
Color
Wavelength(nm)
Light Intensity(mcd)
Wavelength(nm)
Red
620-630
50-150
620-630
300-500
Green
520-535
200-400
515-530
700-1500
Blue
460-475
50-100
460-475
200-300
Inolux Corporation
Page 3
July 1, 2018
www.inolux-corp.com
Recommended Operating Ranges (unless otherwise specified, Ta= -20 ~ +70 ℃, VDD=4.5 ~ 5.5V,VSS=0V)
Parameter
Symbol
Min.
Typ.
Max
Unit
Test conditions
VDD
5.2
V
VDS, MAX
26
V
DOUT drive capability
IDOH
49
mA
maximum source
current
IDOL
-50
mA
maximum sink current
High level input voltage
VIH
0.7*VDD
V
VDD=5.0V
Low level input voltage
VIL
0.3*VDD
V
VDD=5.0V
The frequency of PWM
FPWM
1.2
KHZ
IDD
1
mA
Supply voltage
R/G/B port pressure
Static power consumption
Inolux Corporation
Page 4
July 1, 2018
www.inolux-corp.com
Switching Characteristics (unless otherwise specified, Ta=25 ℃)
Parameter
The speed of data transmission
Symbol
Min.
Typ.
Max
Unit
Test conditions
FDIN
800
KHZ
The duty ratio of 67%
(data 1)
TPLH
500
ns
DOUT transmission delay
TPHL
500
Tr
100
IOUT Rise/Drop Time
Tf
100
ns
DIN→DOUT
ns
ns
VDS=1.5V
IOUT=5/13mA
Timing Waveforms
1. Input Code
Inolux Corporation
Page 5
July 1, 2018
www.inolux-corp.com
2. The data transmission time (TH+TL=1.25µs±600ns):
Name
Description
Min.
T
Period
1.2
T0H
0 code, high level time
T0L
Typ. value
Max.
Unit
0.2
0.32
0.4
μs
μs
0 code, low level time
0.8
μs
T1H
1 code, high level time
0.62
0.64
1.0
μs
T1L
1 code, low level time
0.2
μs
Trst
Reset code, low level time
>80
μs
3. Connection Scheme
4. Data Transfer Format(Ta=25℃)
Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit.
5. 24-bit data format
Note: high starting, in order to send data (G7 - G6 - ...... ..B0)
Inolux Corporation
Page 6
July 1, 2018
www.inolux-corp.com
Typical Application Circuit
Product signal input and output must be connected in series with protection resistor R1. R1 depends on the size of the cascade amount,
the greater the number of cascade, the smaller R1. The general recommended value is between 200-2KΩ, usually the recommended
value is typical 500Ω.
Inolux Corporation
Page 7
July 1, 2018
www.inolux-corp.com
LED Performance Graph
Inolux Corporation
Page 8
July 1, 2018
www.inolux-corp.com
Ordering Information
Product
Emission Color
IV(mcd)
R
50-150
G
200-400
B
50-100
R
300-500
G
700-1500
B
200-300
IN-PI42TAS5R5G5B
IN-PI42TASPRPGPB
Orderable
Part Number
IN-PI42TAS5R5G5B
IN-PI42TASPRPGPB
Label Specifications
Inolux P/N:
I
N
PI
Product
Inolux
42
T
A
S
(X)
R
(X)
G
(X)
B
Package
Die
Qty.
Variation
Orientation
Current
Color
Current
Color
Current
Color
S = Side
Mount
P=12mA
5 = 5mA
R = 624
nm
P=12mA
5 = 5mA
G=
520
nm
P=12mA
5 = 5mA
B=
470
nm
PI- Single trace IC
42TA= 40 x 20 x 1.5 mm
PC- Clock Function IC
- X
X
X
Customized
Stamp-off
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
Page 9
01
24
001
Month
Date
Serial
July 1, 2018
www.inolux-corp.com
X
Precautions
Please read the following notes before using the product:
1. Storage
1.1 Do not open moisture proof bag before the products are ready to use.
1.2 Before opening the package, the LEDs should be kept at 30℃ or less and 80%RH or less.
1.3 The LEDs should be used within a year.
1.4 After opening the package, the LEDs should be kept at 30℃ or less and 60%RH or less.
1.5 The LEDs should be used within 24 hours (1 days) after opening the package.
1.6 If the moisture adsorbent material has fabled away or the LEDs have exceeded the storage time,
baking treatment should be performed using the following conditions. Baking treatment: 60±5℃ for
24 hours.
Inolux Corporation
Page 10
July 1, 2018
www.inolux-corp.com
2. Soldering Condition
Recommended soldering conditions:
Profile Feature
Lead-Free Solder
Average Ramp-Up Rate (Ts
max
to Tp )
3℃/second max.
Preheat: Temperature Min (Ts
min)
150℃
max)
200℃
Preheat: Time ( ts
min to
ts
max
60-180 seconds
Time Maintained Above: Temperature (TL)
217 ℃
Time Maintained Above: Time (t L)
60-150 seconds
Peak/Classification Temperature (T P)
240 ℃
Time Within 5℃ of Actual Peak Temperature ( tp)
很抱歉,暂时无法提供与“IN-PI42TASPRPGPB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.343351+0.77006
- 10+4.1325110+0.50167
- 100+2.70484100+0.32836
- 国内价格 香港价格
- 1500+2.068641500+0.25113
- 3000+2.058973000+0.24995
- 4500+2.058934500+0.24995
- 6000+2.058886000+0.24994
- 7500+2.058847500+0.24994
- 国内价格 香港价格
- 1500+1.888761500+0.22929
- 3000+1.879943000+0.22822
- 国内价格 香港价格
- 1500+2.135641500+0.25926
- 3000+1.993273000+0.24198
- 7500+1.922087500+0.23333
- 10500+1.8936010500+0.22988
- 37500+1.8508937500+0.22469
