Antenna ANT020 with an Adaptor Cable
Since 1990
ANT020 Antenna
ANT020 antenna can be used with Fanstel module with an u.FL connector. It consists of:
• an antenna with an SMA connector and + 3 dBi peak gain
• an SMA connector to u.FL connector adaptor cable.
• panel mounting hardware at SMA connector side of adaptor cable.
Specifications
• Frequency range: 2400 to 2500 MHz.
• Peak Gain: 3 dBi at 2.45 GHz
• Impedance: 50 ohm
• Antenna size: 30mm x 17mm x 9mm
• Adaptor cable size: 100mm x 9mm.
• Shell material: silicone rubber
• Operating temperature: -30o C to + 60o C.
ANT020 Radiation pattern
Fanstel Corp. | 7466 E. Monte Cristo Ave. Scottsdale, AZ 85260 USA| t: 1 480.948.4928 | e: info@fanstel.com | w: http://www.fanstel.com
V1.0, Sep., 2018
很抱歉,暂时无法提供与“ANT020”相匹配的价格&库存,您可以联系我们找货
