Adafruit NeoPixel LED Strip w/ Alligator
Clips - 30 LEDs/meter - 1 Meter - BLACK
PRODUCT ID: 3812
Adding glowy color to your projects has never been easier: no more soldering or
stripping wires, clip 'em on and glow! This Adafruit NeoPixel LED Strip with
Alligator Clips has 30 total LEDs in a "30 LED per meter" spacing, and is 1 meter
long, in classy Adafruit Black. Its not too long, but has lots of glowing action.
Perfect for use with a Circuit Playground, Circuit Playground Express, micro:bit
or any other microcontroller board where you don't want to noodle with a
breadboard and wires.
The strips come in a 1 meter reel with three 100mm long red/black/white
alligator clips on the end. The other end is sealed. The alligator clips are even
nicely color-coded: black for ground, white for signal, red for 3-5VDC power.
We use SK6812 LEDs on these strips so you don't need an inline resistor and
they work down to 3V logic+power.
NeoPixels are addressable LEDs. That means, there are 30 RGB LEDs per meter
and the strip is a full meter long so you get 30 individually-controlled RGB LEDs!
You can set the color of each LED's red, green and blue component with 8-bit
PWM precision (so 24-bit color per pixel). The LEDs are controlled by shift-
registers that are chained up down the strip so you can shorten the strip if you
like by cutting it. Only 1 digital output pin are required to send data down. The
PWM is built into each LED-chip so once you set the color you can stop talking
to the strip, and it will continue to PWM all the LEDs for you
The strip is made of flexible PCB material, and comes in a weatherproof
sheathing. You can cut this stuff pretty easily with wire cutters. Of course, you
can also connect strips together to make them longer, just watch how much
current you need! We have a 5V/2A supply that is able to drive this strip but
chances are you will power these short strips direct from your microcontroller
board. You must use a 3-5V DC power supply to power these strips, do not use
higher than 6V or you can destroy the entire strip– yikes!
These LEDs use about 4.8 Watts max (~1 Amps @ 5V) per meter. The max rating
is assuming all the LEDs are on full white, usually the actual current for colorful
design is less than 1/3 of the max current. A good power supply is key!
Our detailed NeoPixel Uberguide has everything you need to use NeoPixels in
any shape and size. Including ready-to-go library & example code for Arduino
compatibles. You can also use these strips with MakeCode or CircuitPython
using the NeoPixel software support.
TECHNICAL DETAILS
Dimensions with sheathing: 1000 x 12 x 4mm / 39.3" x 0.5" x 0.2"
30 LEDs per meter
Removable IP20/65 weatherproof casing
Maximum 5V @ 60mA draw per 1.3" strip segment (all LEDs on full
brightness)
5VDC power requirement (do not exceed 6VDC) - no polarity protection
1 integrated RGB LEDs per segment, individually controllable
LED type: SK6812
LED wavelengths: 630nm/530nm/475nm
Connector: 3 x 100mm long alligator clips
https://www.adafruit.com/product/3812 5‐11‐18
很抱歉,暂时无法提供与“3812”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+169.220731+20.46625
