1CX M.2 Module - Datasheet
Document status: Preliminary
Copyright 2019 © Embedded Artists AB
1CX M.2 Module
Datasheet
Get Up-and-Running Quickly and
Start Developing Your Application On Day 1!
EA2-DS-1901 Rev A
Page 2
Embedded Artists AB
Jörgen Ankersgatan 12
211 45 Malmö
Sweden
http://www.EmbeddedArtists.com
Copyright 2019 © Embedded Artists AB. All rights reserved.
No part of this publication may be reproduced, transmitted, transcribed, stored in a retrieval system, or
translated into any language or computer language, in any form or by any means, electronic,
mechanical, magnetic, optical, chemical, manual or otherwise, without the prior written permission of
Disclaimer
Embedded Artists AB makes no representation or warranties with respect to the contents hereof and
specifically disclaim any implied warranties or merchantability or fitness for any particular purpose. The
information has been carefully checked and is believed to be accurate, however, no responsibility is
assumed for inaccuracies.
Information in this publication is subject to change without notice and does not represent a
commitment on the part of Embedded Artists AB.
Feedback
We appreciate any feedback you may have for improvements on this document.
Trademarks
All brand and product names mentioned herein are trademarks, services marks, registered
trademarks, or registered service marks of their respective owners and should be treated as such.
Page 3
Table of Contents
1 Document Revision History
4
2 Introduction
5
2.1
Benefits of Using an M.2 Module to get Wi-Fi/BT Connectivity
5
2.2
More M.2 Related Information
5
2.3
ESD Precaution and Handling
5
2.4
Product Compliance
5
3 Specification
6
3.1
Power Up Sequence
7
3.2
External Sleep Clock
7
3.3
Mechanical Dimensions
7
3.4
M.2 Pinning
8
3.5
Test Points
11
3.6
VDDIO Override Feature
11
4 Antenna
12
5 Regulatory
13
6 Disclaimers
14
6.1
Definition of Document Status
15
Page 4
Revision
Date
Description
PA1
2019-04-30
First version.
Page 5
2 Introduction
This document is a datasheet that specifies and describes the 1CX M.2 module mainly from a
hardware point of view. Software related issues, like the Linux driver, are not addressed. There are
separate documents for that.
2.1
There are several benefit to use an M.2 module to add connectivity to an embedded design:
Drop-in, certified solution!
Modular and flexible approach to evaluate different Wi-Fi/BT solutions - with different tradeoffs around performance, cost, power consumption, longevity, etc.
Access to maintained software drivers (Linux) with responsive support from Murata.
Supported by Embedded Artists' Developer's Kits for i.MX 6/7/8 development, including
advanced debugging support on carrier boards
One component to buy, instead of 50+
No RF expertise is required
Developed in close collaboration with Murata and Cypress
2.2
For more information about the M.2 standard and Embedded Artists' adaptation, see: M.2 Primer
For more general information about the M.2 standard, see: https://en.wikipedia.org/wiki/M.2
The official M.2 specification (PCI Express M.2 Specification) is available from: www.pcisig.com
2.3
Please note that the M.2 module come without any case/box and all
components are exposed for finger touches – and therefore extra attention must
be paid to ESD (electrostatic discharge) precaution, for example use of staticfree workstation and grounding strap. Only qualified personnel shall handle the
product.
Make it a habit always to first touch the mounting hole (which is grounded)
for a few seconds with both hands before touching any other parts of the
boards. That way, you will have the same potential as the board and therefore minimize the risk for
ESD.
In general touch as little as possible on the boards in order to minimize the risk of ESD damage. The
only reasons to touch the board are when mounting/unmounting it on a carrier board.
Note that Embedded Artists does not replace modules that have been damaged by ESD.
2.4
Product Compliance
Visit Embedded Artists' website at http://www.embeddedartists.com/product_compliance for up to date
information about product compliances such as CE, RoHS2, Conflict Minerals, REACH, etc.
Page 6
3 Specification
This chapter lists some of the more important characteristics of the M.2 module, but it is not a full
specification of performance and timing. The main component in the design is Murata's 1CX module
(full part number: LBEH5UL1CX), which in turn is based around Cypress CYW4356 chipset.
For a full specification, see on Murata's 1CX Module (LBEH5UL1CX) see Murata’s 1CX product page
(https://wireless.murata.com/eng/type-1cx.html) and the 1CX datasheet (url TBD).
Module / Chipset
Murata module
LBEH5UL1CX
Chipset
Cypress CYW4356
Wi-Fi
Standards
802.11a/b/g/n/ac 2x MIMO
Network
AP and STA dual mode
Frequency
2.4GHz and 5 GHz band
Data rates
11, 54, 65, 150, 866 Mbps
Host interface
PCIe
Bluetooth
Standards
5.0 BR/EDR/LE
Power Class
Class 1
Host interface
4-wire UART@3MBaud
Audio interface
PCM for audio
Powering
Supply voltage to M.2 module
Min
Typ
Max
Note: Do not exceed minimum
or maximum voltage. Module
will be permanently damaged
above this limit!
TBD minimum
3.3 RF specification
3.3V 3.6V
Receive mode current (WLAN)
170 mA typical max
Transmit mode current (WLAN)
450 mA typical max
Environmental Specification
Operational Temperature
-20 to +75 degrees Celsius
Storage Temperature
-40 to +85 degrees Celsius
Relative Humidity (RH),
operating and storage
10 - 90% non-condensing
Functionally ok, but specification is
derated at temperature extremes
3.1
Page 7
Power Up Sequence
The supply voltage shall not rise (10 - 90%) faster than 40 microseconds and not slower than 100
milliseconds.
Signals WL_REG_ON or BT_REG_ON must be held low for at least 700 microseconds after supply
voltage has reached specification level before pulled high. 2 clock cycles of the 32.678kHz clock must
also have passed before any of the signals is pulled high. These clock cycles will typically occur during
the 700 microseconds but if the clock signal has a long delay during power-up, the 700 microsecond
period can be extended.
3.2
The sleep clock signals can be applied to a powered and unpowered M.2 module.
Clock Specification
Frequency
32.768 kHz
Frequency accuracy
±200 ppm
Duty cycle
30 - 70%
Clock jitter
很抱歉,暂时无法提供与“EAR00321”相匹配的价格&库存,您可以联系我们找货
