Mini LED Arcade Button - 24mm
Translucent Yellow
PRODUCT ID: 3431
Description
A button is a button, and a switch is a switch, but these translucent arcade buttons are in a class of their
own. Particularly because they have LEDs built right in! That's right, you'll be button-mashing amidst a
wash of beautiful light with these lil' guys. They're the same size as common miniature arcade controls, and
require a 24mm diameter hole for mounting. Thus they are sometimes referred to as 24mm diameter.
The buttons screw in place, so you can use with up to ~15mm thick material, and will cover up if the hole if
it isn't perfectly round and clean. The action is smooth, without a strong click, yet you can definitely feel
when the button is pressed. A tiny micro-switch is pre-installed, with gold plated contacts.
Even unlit, they look fantastic: all of the colors have a crystal translucent glossy look. As noted they have
two surface mount LEDs with resistors built in, buried in the button body. Next to the switch contacts are
two additional contacts for powering/controlling the LEDs. The two LEDs are connected in series with a
~1K resistor, so you can power the LED from a microcontroller pin or direct from 5V (say USB) with 5mA
draw.
Note that the Red and Yellow versions of these mini LED buttons cannot run at 3.3V because the LEDs are
in series! 5V or higher is required.
This is the Translucent Yellow version of our Mini 24mm LED arcade buttons.
Technical Details
o
o
Supply Voltage: 5V @ 5mA
Weight: 10.3g
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3431 6‐14‐17
很抱歉,暂时无法提供与“3431”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 42+12.2632342+1.48644
