SB® 350 Connectors
Up to 500 Amps
The SB® 350 is the largest connector in the series with
power capabilities up to 500 amps with a 350 mcm wire.
Wires ranging from 1/0 to 350 mcm (53.5 to 185 mm²)
fit into the one piece housing available in standard PC or
a chemical resistant PBT/PC blend. Silver plated wire or
busbar contacts minimize electrical resistance while
offering supreme durability and reliability.
• Up to 350 mcm (185 mm²) Wires
Allows UL rated currents up to 500 amps
• Chemical Resistant Housing Option
Extends temperature range down to -40°C, while offering
enhanced UV and chemical resistance
• Same Housings Used for Wire and Busbar Contacts
SB 350 ORDERING INFORMATION
Enables color-coded mechanically keyed wire to busbar
connections
SB® 350
SB® 350 Standard Housings
The largest SB® housings work with wire contacts up to 350 mcm (150 mm²) as well as busbar contacts.
Genderless design mates with itself. Mechanical keys are color-coded. NOTE: SB® 350 Black and Blue
Housings have the same keying features and can be intermated.
Description
Part Numbers
[ 107.9 ]
Minimum Quantity
50
25
4.25
Yellow 914-BK 914
Orange 932-BK 932
Red 913-BK 913
[ 69.9 ]
Gray 906-BK 906
2.75
Blue 912-BK 912
Green 931-BK 931
Black
2-7250G8
[ 28.6 ] [ 34.9 ]
1.38
1.13
SB® 350 Chemical Resistant Housings
Same features as the Standard SB® 350 but molded in a
chemical resistant PBT/ PC blend. Suitable for use to -40°C.
Description
Part Numbers
Minimum Quantity
50
25
Red
P913-BK P913
Gray
P906-BK P906
Bottom View
[ 6.6 ]
Ø 0.26
(2) PLC’S
MATERIAL ID
P = Chemical Resistant
[ 182.6 ]
7.19
[ 33.3 ]
1.31
Mated Length
SB® 350 Silver Plated Wire Contacts
Silver plated contacts offer superior electrical performance and durability up to 10,000 mating cycles.
See reducing bushings in accessory section for smaller wires.
Dimensions
Mating
-A-
- B -
-CAWG
mm²
Force
Loose Piece Part Numbers inches mm
inches mm
inches mm
Minimum Quantity
200
150
50
350 mcm 185
High -
910-BK 910 *
0.75 19.05 0.87 22.10 3.04
77.2
300 mcm 152
High -
910-BK 910 *
77.2
4/0
107.2 High 908-BK -
908 *
0.64 16.26 0.75 19.05 3.03
77.0
3/0
85
High 916-BK -
916 *
0.58 14.73 0.70 17.78 3.00
76.2
2/0
67.4
High 907-BK -
907 *
0.49 12.45 0.64 16.26 2.96
75.2
1/0
53.5
High 917-BK -
917 *
0.44 11.18 0.51 12.95 2.91
73.9
[ 32.8 ]
1.29 MIN
[ C ± 2.0 ]
C ± 0.08
A
B
[ 20.6 ]
0.81
* Sold as pairs. 2 parts shipped for every 1 part ordered.
- 96 -
www.andersonpower.com
All Data Subject To Change Without Notice
SB® 350 Silver Plated Busbar Contacts
[ 131.7 ]
5.19
Use 2 busbar contacts per housing to provide a quick disconnect input or output busbar
connection. Busbar contacts are for mating with wire contacts only. Part number 350BBS
includes lock nuts. Locknuts must be ordered separately for B01998P1.
# 3/8 - 16 THD
B
[ 17.0 ]
0.67
Mating
Type
Thread Force
Minimum Quantity
50
10
3/8-16
High
B01998P1
350BBS
Busbar
Lock Nut 3/8-16
H1216P9
110G73
See Busbar contact drawing on
website for further detail.
[ 22.3 ]
0.88
[ 2.5 ]
0.10
NOTE: Has not been tested by UL.
SB® 350 CONNECTOR TEMPERATURE CHARTS - Temperature rise charts are based on a 25°C
ambient temperature.
Current - Temperature Derating per IEC 60512-5-2 Test 5B
SB® 350
Temperature Rise at Constant Current
Ambient Temperature (°C)
125
50
40
30
75
50
25
50 100 150 200 250 300 350 400 450 500
Amperes Applied
350 MCM
300 MCM
3/0 AWG
2/0 AWG
4/0 AWG
1/0 AWG
SB® 350
Temperature Rise
Above Ambient (°C)
60
SB® 350
Derating vs. Ambient Temperature
0 50 100 150 200 250 300 350 400 450 500 550
350 MCM
3/0 AWG
Amperes Applied
300 MCM
2/0 AWG
4/0 AWG
1/0 AWG
SB® 350 CONNECTOR SPECIFICATIONS
ELECTRICAL
Current Rating Amperes
MECHANICAL
1
Wire-to-Wire (350 mcm)
UL 1977
CSA
500
325
AWG
Wire Contacts with Bushings
UL 1977
1/0 to 350 mcm
53.5 to 185
mm
1.100
27.900
°F
°C
Standard
-4° to 221°
-20° to 105°
Chemical Resistant
-40 to 221°
-40° to 105°
600
Operating Temperature ²
Dielectric Withstanding Voltage
Volts AC
2,200
1
2 1/2” of 300 mcm Wire
0.050
Hot Plug Current Rating Amperes - Wire & Busbar
250 cycles at 120V DC
100A
mm²
in.
Max. Wire Insulation Diameter
Voltage Rating AC/DC
Avg. Mated Contact Resistance Milliohms
Wire Size Range
Mating Cycles No Load by Plating
Silver (Ag)
10,000
Avg. Mating / Unmating Force
2 Pole
Min. Contact / Spring Retention Force
Lbf.
N
30
133
Lbf.
N
150
667
Specifications continued on next page
- 97 -
MATERIALS
Housing
Standard Plastic Resin
Polycarbonate
Chem. Resistant Resin
Polycarbonate / PBT blend
Contact Retention Spring
Stainless Steel
Housing Flammability Rating
UL94
V-0
Glow Wire
960°C (GWFI) / 800°C GWIT)
Wire & Busbar Contacts 4
Base
Copper Alloy
Plating
Silver
NOTE 1: See IEC 60664-1 for working voltage.
1 - Based on: 105°C rated or better cable of the largest size. Properly calibrated
APP® recommended tooling, and a 25°C ambient temperature. UL rating
not to exceed the maximum operating temperature. CSA rating below
a 30°C temperature rise.
2 - Limited by the thermal properties of the connector plastic housing.
3 - Use APP® recommended tooling only. Alternate tools may adversely affect
the performance of our connectors along with UL and CSA recognition.
4 - Has not been tested by UL.
Contact Termination Methods
Crimp ³
Wire Contacts
Hand Solder
Wire Contacts
Wrench / Socket
Busbar Contacts
SB® 350
IEC INFORMATION
Connector
Series
SB® 350
Creepage /
Configurations Clearance per
IEC 60950-1
Unmated
5.66 mm
Mated
5.66 mm
PROTECTION
Touch Safety with Wire Contacts
IEC 60529
IP10 unmated
Material
Group
IIIa
ATTRIBUTES
SB® 350
AMP Rating AC/DC
350
Voltage Rating AC/DC (Steady State)
500 V AC/DC (Operational)
Breaking Capacity - AMP Rating / Cycles
100 Amp / 10 cycles
Voltage Rating (Breaking Capacity)
125 VDC
Finger Safety - Mated Only
IEC 60529 - IP20
Wire Size Tested
120 mm²
Contact Series Tested
908
Climatic Testing (Cold, Heat & MFG)
IEC 60512 Test -11j, 11i & 11g
Cycle Life
IEC 60512 Test 9a - 5,000 Cycles
Mechanical Strength Impact
IEC 60512-5 @ 29.5 Inches Dropped 8 Times
Temperature Range
-20 °C to 105 °C
-4 °F to 221 °F
- 98 -
SB® 350 ACCESSORIES
Cable Clamps *
Durable metal cable clamps securely hold cables to prevent accidental strain or pulls
from dislodging wire or contacts from the housing. Cable clamps are recommended
for solder terminated wires.
Cable Size
Min / Max
Min / Max
Description
Inches O.D.
mm O.D.
Part Number
Minimum Quantity
10
1.00 to 0.35
25.4 to 8.8 996G1
Bolt On for Discrete Conductor
996G1
* Torque value 50 (in - lbs) / 5.6 (Nm)
[ 60.5 ]
2.38
NOTE: For assembly of clamp to housing only
The given wire O.D. information is an estimate.
Cable clamps should be evaluated for
performance with the actual wire to be used.
[ 65 ]
2.56
[ 76.1 ]
3.00
[ 10.8 ]
0.43
[ 1.5 ]
0.06
[ 2.1 ]
0.08
SB® 350
[ 11.9 ]
0.47
[ 61.9 ]
2.44
Handles *
Handles are made out of durable PC plastic.
Hardware to attach to connector body included in kits.
Description
Part Numbers
Minimum Quantity
100
25
Gray Handle Kit
995G2
Red Handle Kit
995G4
Handle Only, Gray
3-5074P1
Handle Only, Red
3-5074P3
Handle Only, Black
3-5074P5
Hardware Bag
106G7
Dust Cover
Prevents dust and dirt from entering the mating interface
of the connector when unmated. NOTE: Not a Hermetic Seal.
Description
Minimum Quantity
Dust Cover with Lanyard Strap, Red
Part Numbers
500
50
113890P3
134G3
Slide cover over
mating end.
SB® 350 Lockout
Works with standard lockout - tagout equipment to prevent access to
the mating interface of the connector. Made from durable PC plastic.
Description
Minimum Quantity
Red Lockout - Tagout Kit
Part Number
25
SB350-LOCKOUT
SB® 350 Connector
not included.
- 99 -
Manual Release Bracket - Mounting Side *
Works with the Locking Side to ease mating and unmating connectors.
Part Numbers
Description
Minimum Quantity
Bracket and Hardware Kit
Bracket Only
Hardware Bag
66
B00229P1
25
106G6
10
922G1
NOTE: For assembly of brackets to housing only
Mounting Plate
Hardware
Manual Release Bracket - Locking Side with Cable Clamp *
Works with the Mounting Side to ease mating and unmating connectors.
Cable Size
Min / Max
Min / Max
Description
Inches O.D.
Minimum Quantity
Bracket and Hardware Kit w/ Clamp Kit 0.94 to 0.61
mm O.D.
Part Number
23.7 to 15.5
10
919
NOTE: For assembly of bracket to housing only
The given wire O.D. information is an estimate. Cable clamps should be evaluated for
SB® 350
Manual Release Bracket - Locking Side no Cable Clamp *
Works with the Battery side to ease mating and unmating connectors.
Description
Part Number
Minimum Quantity
Bracket and Hardware Kit No Clamp Kit
10
919G1
* Torque value 50 (in lbs) / 5.6 (N - M)
Reducing Bushings: for Use with Contact Part Number 907
Use with contact part number 907-BK to allow a smaller wire to be used
with the connector. Electrical capability is derated with smaller wire.
Contact Barrel Size
Wire Size
AWG mm
AWG
Minimum Quantity
2/0
67.4
1/0
mm²
Part Numbers
53.5
500
5918-BK
100
5918
[ 28.4 ]
1.12
[ 11.1 ]
0.44
Wire Entrance
- 100 -
SB® Tooling Information
Wire Size
AWG
mm²
Loose Piece Part
Number
Silver Plating
Loose Piece Contact Crimp Tools
Hand Tool
OR
Pneumatic
Tool
Die
Locator
Number of
Crimps
SB® 50
6
13.3
8
8.4
1307
5900
5952
1388G6
1309G4
1387G1
Single
5953
10 to 12
5.3 to 3.3
1
42.4
1323G1
2
33.6
1319
4
21.2
1319G4
6
13.3
1319G6
1389G6
1388G7
5915
1389G7
SB® 120
1388G3
1368 Series
1387G1
1388G4
1389G4
Single
SB® TOOLING
SB® 175
1/0
53.5
1382
1
42.4
1347
2
33.6
1383
4
21.1
1384
6
13.3
1348
1368 Series
1387G2
1303G13
1304G32
Double
1387G1
1388G4
1389G3
Single
SB® 350
350 mcm
185
910
300 mcm
152
910
4/0
107.2
908
3/0
85
916
2/0
67.4
907
1/0
53.5
917
N/A
1303G3
1368 Series
1387G2
Double
1304G31
1303G12
NOTE: See website for the most current information.
SB® 2/0 Tooling Information
Wire Size
Loose Piece Part
Number
AWG
mm²
Silver Plating
Hand Tool
2/0
53.5
1328G1
1368
OR
Pneumatic
Tool
1387G2
Die
1303G12
Locator
Number of
Crimps
1304G32
Double
Your Best Connection™
2020-0055 DS-SB350
REV C7
Anderson™ will use reasonable efforts to include accurate and up-to-date content in the data sheet. All product information contained in the data sheet including ordering information,
illustrations, specifications, and dimensions, are believed to be reliable as of the date of publishing, but is subject to change without notice. Anderson™ makes no warranty or representation as
to its accuracy. Content in the data sheet may contain technical inaccuracies, typographical errors and may be changed or updated without notice. Anderson™ may also make improvements
and/or changes to the products and/or to the programs described in the content at any time without notice. Current sales drawings and specifications are available upon request.
©2020 Anderson Power Products, Inc. All rights reserved. APP®, A®, Anderson Power Products®, SB® and the APP Logo are registered trademarks of Anderson Power Products, Inc. Anderson™ and
Your Best Connection™ are trademarks of Anderson Power Products, Inc.
- 101 -
很抱歉,暂时无法提供与“906-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+89.406711+10.85355
- 10+86.2758410+10.47348
- 25+80.6155425+9.78634
- 国内价格 香港价格
- 1+129.674691+15.74189
- 10+112.3841710+13.64290
- 25+99.1619625+12.03779
- 50+88.7257050+10.77088
- 100+77.80303100+9.44492
