VAA505
VAA505
    COSEL
    VAA505
VAA505 数据手册
AC-DC Power Supplies PCB Mount Type VAA5 Ordering information VAA 1 5 2 05 3 1 Series name 2 Output wattage 3 Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT VAA505 5.0 VOLTAGE[V] 5 CURRENT[A] 1.0 VAA512 5.4 12 0.45 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] FREQUENCY[Hz] INRUSH CURRENT[A] *1 LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +55C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +55C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 TEMPERATURE COEFFICIENT[mV] -10 to +55C *3 DRIFT[mV] OUTPUT VOLTAGE ADJUSTMENT RANGE START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE SETTING[V] *1 OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE CASE SIZE/WEIGHT COOLING METHOD VAA505 AC85 - 132 1f or DC110 - 170 0.13typ (ACIN 100V, Io=100%) VAA512 75typ 77typ 47 - 440 or DC 15typ (ACIN 100V, Io=100%) 0.5max (60Hz According to UL and DEN-AN) 5 12 1.0 0.45 20max 48max 40max 100max 80max 120max 140max 160max 120max 150max 160max 180max 50max 120max 20max 48max Fixed 200max (ACIN 85V, Io=100%) 10typ (ACIN 85V, Io=100%), 20typ (ACIN 100V, Io=100%) 4.90 - 5.30 11.40 - 12.60 Works over 105% of rating and recovers automatically Works over 115% of rating (by zener diode clamping) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 19.6m/s2 10 - 55Hz, 3minutes period, 60minutes each along X, Y and Z axis (Non operating) 196.1m/s2 11ms, once each X, Y and Z axis (Non operating) UL60950-1, C-UL Complies with DEN-AN (External Fuse is required) Complies with FCC-B, additional capacitors required for meeting VCCI class B 32X18X65mm [1.26X0.71X2.56 inches] (WXHXD) / 30g max Convection *1 Rated input/output Ta=25C *2 This is the value that measured on measuring board with capacitor of 22mF. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the charge in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. VAA-2 March 13, 2019 VAA5 External view 35 Recommended size for processing PCB (TOP VIEW) [1.38] AC FG Outline 35 [0.05] 12 [0.47] 7.5 [0.3] 27 [1.06] 2.5 [0.1] 12 [0.47] 7.5 [0.3] 27 [1.06] 32 [1.26] [1.38] 2.5 [0.1] AC 4.5 [0.18] Name Plate 57 [2.24] 65 [2.56] 4.5 57 [0.18] [2.24] ¶ Dimensions in mm, [ ¶ Unit: 2mm 4 [0.53] Input/Output Pin bottom cover [0.07] [0.04] bottom cover [0.07] [0.16] (13.5) 4 [0.16] [0.71] (TOP VIEW) [0.04] ]= inches ¶ Weight: 30g max ¶ Tolerance: ± 0.5 [±0.02] ¶ PCB material: CEM-3 ¶ PCB thickness: t=1.0 [0.04] ¶ Pin material: CPW with solder plated ¶ Recommended hole dia. to PCB: º1.3 ¶ Dimensions in mm, [ ]= inches Performance data ¡RISE TIME & FALL TIME (VAA512) OUTPUT VOLTAGE 5V/DIV ¡STATIC CHARACTERISTICS (VAA512) DC Output Input Voltage AC 85V Input Voltage AC132V 12.07 12.05 AC Input 12.03 ACIN 85V Io=100% 0 0.25 0.50 0.75 20ms/DIV OUTPUT CURRENT ¡OVERCURRENT CHARACTERISTICS (VAA512) ¡DERATING CURVE 14 12 LOAD FACTOR OUTPUT VOLTAGE 100 10 8 6 Input Voltage AC 85V Input Voltage AC132V 4 ACIN85 115V ACIN116 132V 60 40 20 0 -10 0 10 20 30 40 50 60 70 AMBIENT TEMPERATURE 2 0 80 0.25 0.50 0.75 OUTPUT CURRENT March 13, 2019 VAA-3 AC-DC Power Supplies PCB Mount Type VAA10 Ordering information VAA 10 1 2 05 3 1 Series name 2 Output wattage 3 Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT VAA1005 10.0 VOLTAGE[V] 5 CURRENT[A] 2.0 VAA1012 10.8 12 0.9 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS MODEL VOLTAGE[V] *1 CURRENT[A] *1 EFFICIENCY[%] FREQUENCY[Hz] INRUSH CURRENT[A] *1 LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +55C *2 RIPPLE[mVp-p] -10 - 0C *2 0 to +55C *2 RIPPLE NOISE[mVp-p] -10 - 0C *2 TEMPERATURE COEFFICIENT[mV] -10 to +55C *3 DRIFT[mV] OUTPUT VOLTAGE ADJUSTMENT RANGE START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE SETTING[V] *1 OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CONDUCTED NOISE CASE SIZE/WEIGHT COOLING METHOD VAA1005 VAA1012 AC85 - 132 1f or DC110 - 170 0.3typ (ACIN 100V, Io=100%) 76typ 77typ 47 - 440 or DC 15typ (ACIN 100V, Io=100%) 0.5max (60Hz According to UL and DEN-AN) 5 12 2.0 0.9 20max 48max 40max 100max 80max 120max 140max 160max 120max 150max 160max 180max 50max 120max 20max 48max Fixed 200max (ACIN 85V, Io=100%) 10typ (ACIN 85V, Io=100%), 20typ (ACIN 100V, Io=100%) 4.90 - 5.30 11.40 - 12.60 Works over 105% of rating and recovers automatically Works over 115% of rating (by zener diode clamping) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) -10 to +70C, 20 - 90%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing), 9,000m (30,000feet) max 19.6m/s2 10 - 55Hz, 3minutes period, 60minutes each along X, Y and Z axis (Non operating) 196.1m/s2 11ms, once each X, Y and Z axis (Non operating) UL60950-1, C-UL Complies with DEN-AN (External Fuse is required) Complies with FCC-B, additional capacitors required for meeting VCCI class B 32X18X72.5mm [1.26X0.71X2.85 inches] (WXHXD) / 35g max Convection *1 Rated input/output Ta=25C *2 This is the value that measured on measuring board with capacitor of 22mF. Measured by 20MHz oscilloscope or Ripple-Noise meter (Equivalent to KEISOKU-GIKEN: RM101). *3 Drift is the charge in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. VAA-4 March 13, 2019 VAA10 External view Recommended size for processing PCB (TOP VIEW) 72.5 [2.85] 64.5 4.5 42.5 [2.54] 42.5 5- 1.3 [1.67] [0.05] Outline 27 12 [1.06] FG [0.3] 7.5 32 [1.26] [1.06] 12 [0.47] 7.5 [0.3] V [0.1] 2.5 27 V 64.5 [2.54] ¶ Dimensions in mm, [ ¶ Unit: 2mm 1.7 4 18 Input/Output Pin bottom cover [0.71] 1 [0.1] [0.53] (TOP VIEW) (13.5) Name Plate 2.5 AC 4.5 [0.18] 4 5- 1.0 [0.04] (stopper 1.7 [0.07] ) bottom cover [0.16] [0.07] ]= inches ¶ Weight: 35g max ¶ Tolerance: ±0.5 [±0.02] ¶ PCB material: CEM-3 ¶ PCB thickness: t=1.0 [0.04] ¶ Pin material: CPW with solder plated ¶ Recommended hole dia. to PCB: º1.3 ¶ Dimensions in mm, [ ]= inches [0.16] AC [0.47] [1.67] [0.18] 1.0 [0.04] Performance data ¡RISE TIME & FALL TIME (VAA1012) OUTPUT VOLTAGE 5V/DIV ¡STATIC CHARACTERISTICS (VAA1012) DC Output Input Voltage AC 85V Input Voltage AC132V 12.07 12.05 AC Input 12.03 ACIN 85V Io=100% 0 0.5 1.0 1.5 20ms/DIV OUTPUT CURRENT ¡OVERCURRENT CHARACTERISTICS (VAA1012) ¡DERATING CURVE 14 12 LOAD FACTOR OUTPUT VOLTAGE 100 10 8 6 Input Voltage AC 85V Input Voltage AC132V 4 ACIN85 115V ACIN116 132V 60 40 20 0 -10 0 10 20 30 40 50 60 70 AMBIENT TEMPERATURE 2 0 80 0.5 1.0 1.5 OUTPUT CURRENT March 13, 2019 Powered by TCPDF (www.tcpdf.org) VAA-5
VAA505 价格&库存
很抱歉,暂时无法提供与“VAA505”相匹配的价格&库存,您可以联系我们找货
