55040R-10
55040R-10
    ECHELON
    55040R-10
55040R-10 数据手册
Control Point Module (CPM) 5000 ® The Next-generation Neuron Chip for LonWorks® Control Networks The CPM 5000 decreases product time-to-market for LonWorks® based devices. It includes all the components needed to implement a control node using the FT 5000 Smart Transceiver — the smallest, fastest, highest performance, lowest cost twisted pair LONWORKS transceiver on the market. The FT 5000 Smart Transceiver based control module integrates the high-performance Free Topology FT 5000 Smart Transceiver with the low-cost FT-X3 Communications Transformer, a crystal and inexpensive serial memory, to deliver a lower-cost, higher-performance LonWorks solution that dramatically reduces design time and enables a superior time-to-market. FEATURES (of the CPM 5000) • On-board FT 5000 Smart Transceiver Chip. • Differential Manchester encoded signaling for polarity insensitive network wiring. • Transformer-isolation. • Supported Data Rate - 78 kilobits per second. • Distances up to 500 meters max for free topology. • Distances up to 2700 meters max for doubly terminated bus topology. • Includes 64 KB Serial EEPROM memory. • In-circuit programming of the I2C serial EEPROM. • Low power consumption. • Designed to comply with FCC Level B radiated EMI requirements. • CSA, TÜV Recognized component. • LonMark® certifiable. • 3.3 Volt Support. • Compact Vertical Mount Configuration. www.echelon.com ® Description Control modules provide a simple, costeffective method of adding LonWorks® technology to any control system. The CPM 5000 consists of a miniature circuit card containing an FT 5000 Smart Transceiver chip, Communications Transformer, crystal, serial EEPROM memory, and a connector for power, I/O, In-Circuit Programming and the network. The Smart Transceiver uses differential Manchester encoding, and in conjunction with the FT-X3 communications transformer, creates a Free Topology network device that supports a 78kbps data rate. The small size of the control modules permits it to be mounted on or inside an OEM’s product, directly adjacent to the sensors, outputs, or displays that the module will control. Designing end products with the control modules, which have been fully designed, tested, and qualified to industry standard quality requirements, can save hundreds of hours of development time compared with designing custom modules. The control module is designed to comply with FCC Level B requirements, which can dramatically minimize time-consuming and expensive laboratory testing, component selection, and layout redesign work. The CPM 5000 - Model 55040R-10 is compliant with the European Directive 2002/95/EC with regards to the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment. The control module is offered in a compact vertical mount configuration (dimension 1.7”W x 1.175”H x 0.63”D) to enable customers to deliver a compact product that do not take up a lot of space. The control module is economically priced for both low- and high-volume users and communicates at 78kbps to provide a high speed throughput to meet a wide range of control applications. The FT-X3 communications transformer, together with the FT 5000 Smart Transceiver, provides excellent network isolation. The isolation delivers very good common mode rejection and permits the system to operate well in electrically noisy environments. It also reduces the susceptibility of the system to ground loops caused by the use of multiple node power supplies that float relative to ground. This architecture lends itself well to communicating over long distances in industrial environments. Additionally Echelon offers a comprehensive range of development tools, network interfaces, routers, and network services tools to simplify the task of designing and commissioning products using the control modules. Customers who require technical support regarding the control module can contact Echelon’s technical support. Pin Number 11 Signal Name Description IO0 IO0 for I/O objects 12 IO1 IO1 for I/O objects 13 IO2 IO2 for I/O objects 14 IO3 IO3 for I/O objects 15 IO4 IO4 for I/O objects 16 IO5 IO5 for I/O objects • Supports up to 254 network variables (NVs). 17 IO6 IO6 for I/O objects • User-programmable interrupts provide faster response time to external events. 18 IO7 IO7 for I/O objects • 7mm x 7mm 48-pin QFN package. 19 IO8 IO8 for I/O objects • Supports polarity-insensitive, free topology star, daisy chain, bus, loop, or mixed topology wiring. 20 IO9 IO9 for I/O objects 21 IO10 IO10 for I/O objects 22 IO11 IO11 for I/O objects 23 • Supports up to 42KB of application code. MOV_ GND Return (ground) for MOV ESD clamp 24 GND Ground • 64KB of RAM (44KB for application code and data) and 16KB of ROM on-chip memory. 25 FT_ NETA FT_ NETB FT network connection Features (of the FT 5000 Smart Transceiver) • 3.3V operation. • Serial interface for inexpensive external EEPROM and flash non-volatile memory devices. • 12 I/O pins with 35 programmable standard I/O modes. • Provides exceptional immunity from magnetic and high-frequency common-mode noise. • Complies with worldwide communications standards. • ISO/IEC 14908-1 and 14908-2 • ANSI 709.1 and ANSI 709.3 • -40°C to +85°C operating temperature range. Pin Number Signal Name Description 1 GND Ground 2 RST~ Reset (active low) 3 4 CP3_ RXLED CP2_ TXLED RxActive for network activity LED TxActive for network activity LED 5 NC No Connect 6 VDD3V3 3.3 V Input Power 7 GND Ground 8 SCL 9 SDA_ CS1~ I2C serial clock for external memory I2C serial data for external memory 10 SVC~ Service (active low) 26 FT network connection Specifications CPM 5000 Echelon FT 5000 Smart Transceiver. Echelon FT-X3 Communications Transformer. Control Module Can be programmed to run at 5, 10, 20, 40 or 80 MHz. Memory Type Serial I2C EEPROM. Data Communication Type Differential Manchester encoding. Transceiver Type Transformer-isolated. Isolation Between Network and FT 5000 chip 0-60 Hz (60 seconds) 1000 VRMS. Electrostatic Discharge Designed to comply with EN61000-4-2. EMI Designed to comply with FCC Part 15 Level B. www.echelon.com ® Transceiver Bit Rate 78kbps. Parameter Maximum Nodes Per Channel Agency Spec or Standard 64 (-40 to +85°C). Network Length in Free Topology only ESD 1000m (3280 feet) \maximum total wire with one repeater.\500m (1640 feet) maximum total wire with no repeaters. Network Bus Polarity Insensitive. Power-down Network Protection High impedance when unpowered. Supply Voltage 3.0V to 3.6V. Double row 0.1” center connector for I/O, power, and communications. Radiated EM susceptibility Fast Transient Burst Immunity Surge Immunity Common Mode Noise Immunity Radiated EMI High Voltage Isolation 0–60 Hz Network Termination One terminator in free topology. Two terminators in bus topology. Operating Temperature -40°C to +85°C. IEC1000-4-2 Level 4 (20 MHz and greater) 4 (20 MHz and greater) 3 (10 MHz) 3 (10 MHz) Method Air Discharge kV kV kV Network Cable Clamp BCI clamp on Network Cable EN55022 FCC Part 15 B B HIPOT (0.5 mA max leakage) 60s 10 V/m 2 kV 2 kV 10 Vrms Disconnect MOV 2.4 Contin. Shock 3 ms half-sine Vibration 8 Hz – 2 kHz Non-operating Temperature kV Air Discharge 8 Contact Discharge 6 IEC1000-4-5 3 IEC1000-4-6 15 Unit Contact Discharge 8 IEC1000-4-3 3 IEC1000-4-4 4 Limit kVrms 277 Vrms 100 g (peak) 1.5 peak- g to-peak -40 to +85°C. Operating Humidity 25 to 90% RH @ 50°C, non-condensing. Non-operating Humidity 95% RH @ 50°C, non-condensing. Dimensions 1.7”W x 1.175”H x 0.63”D. variations in node distribution, node temperature, node voltage, wire characteristics, and FT 5000 Smart Transceiver characteristics, and allow for an average wire temperature of up to +55°C. 2. Safety agency hazardous voltage barrier requirements are not supported. 3. The I/O pins of P1 connect directly to the FT 5000 Chip and do not contain additional protection beyond what is available with a typical advanced CMOS device. 4. For ESD protection at 5 MHz and 10 MHz operations, your design should include ferrite beads in series with the network pins. An example part that meets the requirements is a Fair-Rite Products Corp 2743007112 bead on lead. Beads are not required for operations at 20 MHz or higher. 5. For wire specifications, see Junction Box and Wiring Guidelines for Twisted Pair LonWorks Networks, 005-0023-01 Rev D or later. 6. FT 5000 Smart Transceivers and Control Modules were not designed for use in equipment or systems which involve danger to human health or safety or a risk of property damage, and Echelon assumes no responsibility or liability for use of the FT 5000 Smart Transceivers or Control Modules in such applications. ORDERING INFORMATION CPM 5000 55040R-10 (RoHS-compliant) LonWorks Twisted Pair Control Module User’s Guide 078-0015-01 (to be ordered separately – not shipped with product) Notes 2014 Echelon, LonWorks, and the Echelon logo are trademarks of Echelon Corporation registered in the United States and other 1. Maximum distance figures are based© on countries.IzoT is a trademark of Echelon Corporation. Content subject to change without notice. www.echelon.com
55040R-10 价格&库存
很抱歉,暂时无法提供与“55040R-10”相匹配的价格&库存,您可以联系我们找货
