V14
CHB150W SERIES
99 - 150 WATT 4:1 INPUT
DC-DC CONVERTERS
SINGLE OUTPUT
FEATURES
* 99-150W Isolated Output
* Efficiency to 91%
* 250KHz Switching Frequency
* 4:1 Input Range
* Regulated Outputs
* Remote On/Off
* Over Temperature Protection
* Over Voltage/Current Protection
* Continuous Short Circuit Protection
* Half-Brick Size Meet Industrial Standard
* CE Mark Meets 2004/108/EC
* UL60950-1 Approval (Except 28&48 Vout)
OUTPUT OUTPUT CURRENT
VOLTAGE
MIN.
MAX.
MODEL
NUMBER
INPUT
VOLTAGE
CHB150W-24S3V3
9-36 VDC
3.3 VDC
0 mA
CHB150W-24S05
CHB150W-24S12
9-36 VDC
5.0 VDC
9-36 VDC
CHB150W-24S15
CHB150W-24S24
INPUT CURRENT
% EFF.
CAPACITOR
LOAD MAX.
NO LOAD
FULL LOAD
30 A
200 mA
4741 mA
87
30000uF
0 mA
30 A
200 mA
87
30000uF
12 VDC
0 mA
12.5 A
100 mA
7184 mA
7102 mA
88
12500uF
9-36 VDC
15 VDC
0 mA
10 A
100 mA
7184 mA
87
10000uF
9-36 VDC
24 VDC
0 mA
6.5 A
100 mA
7386 mA
88
1800uF
CHB150W-24S28
9-36 VDC
28 VDC
0 mA
5.4 A
100 mA
7325 mA
86
1800uF
CHB150W-24S48
9-36 VDC
48 VDC
0 mA
3.12 A
200 mA
7428 mA
84
1000uF
CHB150W-48S3V3 18-75 VDC
3.3 VDC
0 mA
30 A
100 mA
2344 mA
88
30000uF
CHB150W-48S05
CHB150W-48S12
18-75 VDC
5.0 VDC
0 mA
30 A
100 mA
30000uF
18-75 VDC
12 VDC
0 mA
12.5 A
50 mA
3472 mA
3434 mA
90
91
12500uF
CHB150W-48S15
CHB150W-48S24
18-75 VDC
15 VDC
0 mA
10 A
50 mA
3472 mA
90
10000uF
18-75 VDC
24 VDC
0 mA
6.5 A
50 mA
3611 mA
90
2200uF
CHB150W-48S28
18-75 VDC
28 VDC
0 mA
5.4 A
50 mA
3580 mA
88
2200uF
CHB150W-48S48
18-75 VDC
48 VDC
0 mA
3.12 A
100 mA
3633 mA
86
1000uF
NOTE: 1. Nominal Input Voltage 24, 48VDC
1
V14
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENRAL SPECIFICATIONS:
Input Voltage Range .........….......... 24V ....................... 9-36V
48V ................ 18-75V
Input Surge Voltage (100ms max.) …… 24V ….……….... 50Vdc max.
48V ................... 100Vdc max.
Under Voltage Lockout ………... 24Vin power up …..…...….……. 8.8V
24Vin power down …..……….…. 8.0V
48Vin power up ……….…….…. 17V
48Vin power down …...……….…. 16V
Positive Logic Remote On/Off (note4&5)
Input Filter ………………………………………………..….……... Pi Type
Efficiency .................…..................................……..........…....... See Table
Isolation Voltage .... Input/Output, Input/Case, Output/Case ... 1500VDC min..
7
Isolation Resistance ..............................…......................…….... 10 ohm min.
Isolation Capacitance ………………….......…….…………..…… 1000pF typ.
Switching Frequency ........……………………….........…………... 250KHz typ.
Operating Case Temperature ..………….........….....……........ -40℃ to 100℃
Storage Temperature …………………......…....……............ -55℃ to +105℃
Thermal Shutdown Case Temp. ……..…………….…….…..……. 110℃ typ.
Humidity ....................................................... 95% RH max. Non condensing
MTBF …… MIL-HDBK-217F, GB, 25℃, Full Load …………… 400Khrs typ.
OUTPUT SPECIFICATIONS:
Dimensions ....................……... 2.28x2.40x0.52 inches (57.9x61.0x13.2 mm)
Voltage Accuracy (note7) ..............................………….......... ±1.5% max.
Transient Response: 25% Step Load Change .……………………3.5VDC or open circuit
Module off ……….…………………..………………………..
很抱歉,暂时无法提供与“CHB150W-24S24”相匹配的价格&库存,您可以联系我们找货
