BVW Lead Acid Fast Chargers
Features
100-240 VAC
In Case IEC 320
Automatic Fast/Float Function
LED Indicators
Charges Lead Acid Batteries
Optimizes Battery Life
Meets Safety Agency Requirements
Complies with EMI-RFI Regulations
Impact Resistant Polycarbonate Enclosure
Private Label Marking Available
3 Year Warranty
Modified and Custom Designs Also Available
Ault Model
Battery
Voltage DC
Output
Amps
Switchover
Amps
Fast Charge
Volts DC
Float Charge
Volts DC
Maximum
Watts
BVW-06380-0003A
BVW-12225-0003A
BVW-24125-0003A
6
12
24
3.80
2.25
1.25
0.205
0.165
0.120
7.35
14.70
29.40
6.90
13.80
27.60
28
33
37
Input
Voltage
Line Frequency
Current
Protection
Configuration
Electrical
Topology
Dielectric
Withstand
Leakage Current
EMI
CE
MTBF
Protection
Safety Approvals
Agency Listings
100-250 VAC -10%, +6%
47 - 63 Hz
0.80A - 0.35A (Lower current
with higher voltage)
Internal primary current fuse
Inrush limiting
In Case IEC320 with ground
Switching - DC battery charger
3000 VAC, 4243 VDC primarysecondary
1500 VAC, 2150 VDC primaryground
500 DC secondary-ground
Less than 0.5mA
change typical
Complies with EMC Directives
CE Compliant
100,000 calculated hours
Foldback overcurrent.
Short circuit protection
CSA223; NRTL/C
(ANSI/UL1310); TUV TO
EN60065
LED Indicators
Indicator #1
(Green)
Indicator #2
Amber)
Environment
Operating
Temperature
Storage
Temperature
Relative Humidity
Altitude
Cooling
Mechanical
Case Dimensions
Case Material
Weight
Cords and
Connectors
On (unit energized)
Off (unit de-energized)
On (battery discharged)
Off (battery charged
5° to 40° C with no derating
-30° to +85° C
5% to 95% non-condensing
0-10,000 feet
Convectional - non vented case
LP7 - Desktop
5.08 L x 3.05 W x 1.59 H (in)
129 L x 77 W x 40 H (mm)
Black 94V0 polycarbonate
13 ounces, 370 grams
(excluding cord)
6 ft., 2 conductor, 18 AWG, Ault
#3 connector. Other connectors
are also available.
THREE YEAR WARRANTY
Ault Incorporated, 7105 Northland Terrace, Minneapolis, MN 55428
Contact Ault Inc. for all your custom design requirements. Phone: 763.592.1900 • Fax 763.592.1911
很抱歉,暂时无法提供与“BVW241250003A”相匹配的价格&库存,您可以联系我们找货
