SPEC Pak
Sealed Power For Environmental Connections
Marine
Machine Tool
Wind Power
Lighting
Industrial Automation
Transportation
Motor
Pumps
Solar Power
Ground Support
Harsh Environments
Anderson Power Products
-1www.andersonpower.com
Rugged and Sealed
(IP68) Plugs and Receptacles
For Use with APP® Powerpole® Signal, Power & Ground Contacts & Housings
APP®’s SPEC Pak® Connector Series uses rugged and environmentally sealed (IP68) shells to protect existing APP® Powerpole® contacts and
housings. Customer configured SPEC Pak® Connectors may be used anywhere a rugged and waterproof high-power interconnect with signal and
ground capabilities is required such as in; mass transportation, off-road vehicles, factory automation, oil and petrochemical exploration, agricultural
equipment, and many more.
The core APP® Powerpole® technology within the SPEC Pak® is proven reliable and cost effective. The broad selection of touch safe, color-coded
Powerpole® housings with power, signal and ground contacts accept a broad range of wire gauges, #24 to #10 AWG (0.25 to 4.0 mm²), giving users
thousands of flexible design solutions in a single interconnect.
14
15
1
2
3 4 5
6
7
13
8
9
10
1 - Industry Standard Panel Cut Out
(Same as 26482 & 5015 shell size 24)
2 - IP68 Panel Mount Sealing Gasket
3 - Touch Safe Housings (UL1977, Section 10.2)
4 - IP68 Interfacial Sealing Gasket
5 - Latch (top or bottom of plug or receptacle)
6 - Power Contacts (up to 45 amps)
12
11
9 - First Mate / Last Break Ground Contacts
10 - Color Coded Housings to Match Wire Color
11 - UV & Chemical Resistant Ruggedized Shells
Additional Features Available on the Right Angle Include:
12 - Uses Industry Standard PG Gland
(PG gland compatible - size 21 or 29)
7 - Signal Contacts (4 contacts per PPMX housing)
13 - Right Angle Backshell Lockable in 8 Directions for
Cable Routing
8 - Uses Industry Standard Sealing Components
14 - Integrated Strain Relief
(PG gland compatible - size 21)
-2-
15 - Ruggedized Right Angle Plug Shell
Specifications
SPEC Pak® Shell / Components
Electrical
UL Voltage Rating (AC/DC)
Dielectric Withstanding Voltage (AC)
Operating Temperature (°C)
(°F)
Flammability Rating of SPEC Shells
600
3000
-40° to 105°
-40° to 221°
UL 94V-0
Mechanical
Shells / Latch Mating Cycles
Connect / Disconnect (lbf)
(N)
IP Rating
UL50 Sec 30 Sealing Requirement
1500 Min
18 Max
80 Max
IP68
Pass
Material
Shells (Plug / Receptacle)
Latch
Holder
PBT
Nylon
Polycarbonate
PPMX (4800 Series) Powerpole® Signal Contact
Ratings for SPEC Pak® Use
Electrical
UL Current Rating (Amperes)
Contact Barrel Wire Size (AWG)
(mm²)
Contact Retention Force (lbf)
(N)
Insertion Force (lbf)
(N)
(°F)
7
300
#20 to #24
0.5 to 0.25
12.0
53.0
4.5 Max
20.0 Max
-20° to 105°
-4° to 221°
Mechanical
Mating Cycles (No load)
1500
Material
Housing Material
Contact Material
Contact Plating
Powerpole ® Power (1327FP Series) &
Ground (1827 Series) Contacts
Electrical
CSA (30°C Rise) (Amperes)
Contact Barrel Wire Size (AWG) - Power
- Ground
(mm²) - Power
- Ground
Average Contact Resistance (micro-ohms)
(N)
(°F)
Flammability Rating
Mechanical
Mating Cycles
No Load
- Tin
- Silver
Under Load (Hot Plug 250 mating cycles @ 120V) *
(Hot Plug 250 mating cycles @ 72V) *
Mechanical Shock (50 g)
Vibration (10 g)
15 to 45
10 to 29
600
20 to 10
14 to 10
0.5 to 4.0
1.5 to 4.0
600
25
111
-20° to 105°
-4° to 221°
UL94 V-0
1,500
10,000
30A
45A
Mil Standard
202 213 Cond. A
Mil Standard
202 204 Cond. A
Material
Housing Material
Touch Safe (Power / Signal Housing)
Contact Material
Contact Plating
Polycarbonate
UL1977 Sec. 10.2
Copper
Tin or Silver
* Hot Plug testing completed with individual Powerpole ® housings
NOTE: Agency approvals - TUV (contact customer service) / Patents
PBT
Copper Alloy
Gold, 50 Micro-inches
NOTE: PPMX Contacts, up to 4 per housing
-3-
Part Number Configurator
PART NUMBER PLAN
SPEC Pak® Series
Shell Color
Shell Style
(1 fixed character)
(1 character)
(1 character)
S
K
2
S = SPEC Pak® Series
K = Black
PLUG
KIT
Dash
RIGHT ANGLE
PLUG KIT
(3 characters)
053
Interfacial
Sealing Gasket
O-Ring
Plug Holder
Locking Nut
Interfacial
Sealing Gasket
B06 = PP15/45 Housing (any type), 6 Pole
PANEL MOUNT
RECEPTACLE KIT
Panel Mount Gasket
Panel Mount
Receptacle Shell
Retaining
Pin
B06
053 = 53 mm - 6 Pole Shell
A53 = 53 mm - 6 Pole Right
Angle Shell, PG 21
B53 = 53 mm - 6 Pole Right
Angle Shell, PG 29
Right Angle
Plug Shell
Plug
Powerpole®
Holder
Insert Arrangement
2 = Panel Mount Receptacle
6 = Straight Plug
8 = Right Angle Plug
9 = Cover
Plug Shell
Retaining Pin
Shell Size
(mm) (3 characters)
Latch
RECEPTACLE
COVER KIT
IP68 Sealing Cover
Interfacial
Sealing Gasket
Retaining
Pin
Receptacle
Powerpole®
Holder
Lanyard
NOTE:
- Mounting hardware (4 each - M3.5 or #6 screws) not included
- Recommended torque for mounting hardware is 3½ to 5 in-lbf (0.4 to 0.56 Nm)
KIT ORDERING INFORMATION
SPEC Pak® Kits
Part
Number
SK6-053B06
SK8-A53B06
SK8-B53B06
-4-
Description
Plug kit
- Plug shell (includes interfacial
sealing gasket)
- Powerpole® holder for plug
- Retaining pin
Right angle plug kit for PG 21
- Right angle backshell for PG 21
- Locking nut
- O-ring
- Plug shell
- Retaining pin
Right angle plug kit for PG 29
- Right angle backshell for PG 29
- Locking nut
- O-ring
- Plug shell
- Retaining pin
SPEC Pak® Kits
Part
Number
SK2-053B06
SK9-053
Description
Receptacle kit
- Panel mount gasket for receptacle
- Receptacle shell with latch
- Retention pin
- Powerpole® holder for receptacle
Cover kit (receptacle only)
- Protective sealing (IP68) cover for
receptacle with lanyard
Component Replacement Parts
Part
Number
114765P1
2-8658P1
2-8654P1
114915P2
Description
6 position latch
Right angle locking nut
Right angle O-ring
PART NUMBER PLAN
Wire Protection
Housing
Arrangement
See pages 6 & 7
(4 characters)
For more information see pages 8 & 9
(1 character)
(2 characters)
PS
00 = None
PS = Plastic Short
PF = Plastic With Flex Spring
PM = Plastic Multi Hole
CT = Conduit Adapter Thread
CA = Conduit Adapter Push-in
Dash
01
00 = None
01- 99 = Varies By Gland Type
NOTE:
(1) See PG Gland charts on page
6 & 7 for details.
(2) Panel mount receptacle side
is always “00”.
(3) For right angle; only PS and
PM types available.
Contact
00
0 = Custom Configuration - Use Next Section
A = AC, Single Phase
B = AC, 3 Phase, 3 Wire
C = DC, 2 Circuit, 4 Wire
D = DC, 2 Circuit, 4 Wire, With Ground
E = AC, 3 Phase, 4 Wire
F = AC, 3 Phase, 5 Wire
G = DC, 2 Circuit, 6 Wire
H = DC, 2 Circuit, 4 Wire With 8 Signal
J = AC, Single Phase With Signal
K = AC, 3 Phase, 3 Wire With 4 Signal
L = DC, 2 Circuit, 4 Wire, With 4 Signal
M = AC, 3 Phase, 3 Wire With 8 Signal
N = DC, 2 Circuit, 4 Wire, With Ground & 4 Signal
P = AC, 3 Phase, 4 Wire With 4 Signal
X = All Signal
Dash
APP® Content
(3 characters)
A01
Custom Configuration*
Contact Factory
00 = Custom Configuration - Use Next Section
01 = 261G2 Contact for #10 to #14 AWG (4.0 to 1.5 mm²) Wire
02 = 200G1L Contact for #10 to #14 AWG (4.0 to 1.5 mm²) Wire
03 = 261G1 Contact for #12 to #16 AWG (2.5 to 1.0 mm²) Wire
04 = 1331 Contact for #12 to #16 AWG (2.5 to 1.0 mm²) Wire
05 = 262G1 Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire
06 = 1332 Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire
07 = 200G2L Contact for #16 to #20 AWG (1.0 to 0.5 mm²) Wire
99 = All Signal
Amperage Ratings are available on Page 9.
Part Numbering Notes:
1) To order SPEC Pak® “Shell Kits Only” (no internal Powerpole® housings or contacts), use part numbering on page 4 only. Plug Shell Kit
Example: SK6-053B06 Powerpole® housings, contacts and wire protection may be ordered separately, see pages 6, 7 and 10 for information.
2) To order complete standard configured SPEC Pak® connector kits (including internal Powerpole® housings and contacts) use Part Number
Plan across the top of pages 4 and 5. Standard SPEC Pak® Plug Connector Kit Configuration Example: SK6-053B06PS01-D02
3) To order a custom configuration which is not listed on page 8 and 9, use APP® custom part number configurator on the APP® website,
www.andersonpower.com, or contact factory.
* Custom configurations may not be UL Recognized.
-5-
Wire Protection - PG Gland
SPECIFICATIONS
Material (Push-in Conduit)
Shell
Nylon PA
Gasket
TPE
Color
Black
Mechanical
Operating Temp
IP Rating
Thread Type
Material (All Others)
Shell
Nylon PA 66 (UL94 V-2)*
Gasket
EPDM
Color
Black
Mechanical
-30°C to 100°C (-22°F to 212°F) Operating Temp
IP68
IP Rating
PG
UV Rating
Thread Type
Torque Requirements
Cable Gland Body to Plug Housing
- Hand tighten until snug, tighten additional 1/8 - 1/4 turn with wrench
Sealing Nut to Cable
-40°C to 105°C (-40°F to 221°F) - Hand tighten until snug, tighten additional 1/2 - 3/4 turn with wrench
IP68
Equivalent to UL746C F1
PG
* Contact factory for UL94 V-0 material
NOTE: Only UL listed cable glands are UL recognized components when used with SPEC Pak® connector(s).
STRAIGHT PLASTIC SHORT THREAD TYPE - STD PACK 50 / UL LISTED
Straight Gland Kit
Right Angle Gland Kit
C1
Lock Nut
APP®
P/N
Right Angle
RPS1P21-16X
RPS1P21-18X
RPS1P29-22X
RPS1P29-25X
APP®
P/N
Straight
PS1P21-16X
PS1P21-18X
N/A
N/A
Washer
Wire Protection
Designation
(4 Characters)
PS01
PS02
PS11
PS12
C2
PG Gland
Size
21
21
29
29
Body
Number
of Holes
1
1
1
1
Seal
Cable Range
Wire Outer Dia. mm (in)
16.2 - 10.5 (0.64 - 0.41)
18.5 - 13 (0.73 - 0.51)
22 - 16 (0.86 - 0.63)
25 - 18 (0.98 - 0.71)
Sealing Nut
Thread O. D.
C1 mm (in)
28.3 (1.11)
28.3 (1.11)
37 (1.46)
37 (1.46)
Seal
Panel Mounting
Hole mm (in)
28.3 - 28.7 (1.11 - 1.13)
37 - 37.4 (1.46 - 1.47)
Claw
Thread
Length
C2 mm (in)
12 (0.47)
12 (0.47)
12 (0.47)
12 (0.47)
Sealing Nut
Wrench Size
Lock Nut (mm)
36
36
46
46
STRAIGHT PLASTIC WITH FLEX SPRING - STD PACK 50 / UL LISTED
C1
Washer
APP®
P/N
Straight
PF1P21-16X
Wire Protection
Designation
Cable Range
(4 Characters) Wire Outer Dia. mm (in)
PF01
15.8 - 10.5 (0.62 - 0.41)
LOCK NUT FOR PG 21
CABLE GLANDS
APP® P/N
Lock Nut
-6-
124G30
Wrench Size
Lock Nut (mm)
36
Std. Pkg.
Size
50
C2
Body
Thread O. D.
C1 mm (in)
28.3 (1.11)
Seal
Panel Mounting
Hole mm (in)
Sealing Nut
Thread
Length
C2 mm (in)
12 (0.47)
Wrench Size
Lock Nut (mm)
36
Wrench Size
Sealing Nut (mm)
33
Wrench Size
Sealing
Nut (mm)
33
33
42
42
STRAIGHT PLASTIC MULTI-HOLE TYPE - STD PACK 50 / NOT UL LISTED
Straight Gland Kit
C1
Lock Nut
APP® P/N
Right Angle
RPS2P21-5X
RPS2P21-6X
RPS2P21-8X
RPS3P21-5X
RPS3P21-6X
RPS3P21-8X
RPS4P21-3X
RPS4P21-4X
RPS4P21-5X
RPS4P21-7X
RPS5P21-3X
RPS5P21-4X
RPS5P21-6X
RPS6P21-3X
RPS6P21-5X
APP® P/N
Straight
PS2P21-5X
PS2P21-6X
PS2P21-8X
PS3P21-5X
PS3P21-6X
PS3P21-8X
PS4P21-3X
PS4P21-4X
PS4P21-5X
PS4P21-7X
PS5P21-3X
PS5P21-4X
PS5P21-6X
PS6P21-3X
PS6P21-5X
Washer
Wire Protection
Designation
(4 Characters)
PM21
PM22
PM23
PM31
PM32
PM33
PM41
PM42
PM43
PM44
PM51
PM52
PM53
PM61
PM62
C2
PG Gland
Size
21
21
21
21
21
21
21
21
21
21
21
21
21
21
21
Body
Number
of Holes
2
2
2
3
3
3
4
4
4
4
5
5
5
6
6
Seal
Claw
Cable Range
Wire Outer Dia. mm(in)
5.2 - 3.6 (0.20 - 0.14)
6.5 - 5.1 (0.26 - 0.20)
8.7 - 6.4 (0.34 - 0.25)
6.2 - 4.8 (0.24 - 0.19)
8.0 - 6.2 (0.31 - 0.24)
3.1 - 2.0 (0.12 - 0.08)
4.1 - 3.0 (0.16 - 0.12)
5.2 - 3.8 (0.20 - 0.15)
7.3 - 5.6 (0.29 - 0.22)
3.6 - 2.6 (0.14 - 0.10)
4.6 - 3.6 (0.18 - 0.14)
6.0 - 4.6 (0.24 - 0.18)
Sealing Nut
Thread O.D.
C1 mm (in)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
Seal
Panel Mounting
Hole mm (in)
Claw
Thread
Length
C2 mm (in)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
12.5 (0.49)
Sealing Nut
Wrench Size
Lock Nut
(mm)
36
36
36
36
36
36
36
36
36
36
36
36
36
36
36
Wrench Size
Sealing Nut
(mm)
33
33
33
33
33
33
33
33
33
33
33
33
33
33
33
STRAIGHT CONDUIT ADAPTER THREAD TYPE - STD PACK 50 / NOT UL LISTED
F1
C1
Washer
APP® P/N
CT1P21-21X
CT1P21-26X
CT1P21-28X
Wire Protection
Designation
(4 Characters)
CT02
CT03
CT04
Max. Joint
F1 mm (in)
22.0 (0.87)
26.5 (1.04)
28.5 (1.12)
C2
Thread O.D.
C1 mm (in)
28.3 (1.11)
28.3 (1.11)
28.3 (1.11)
Body
Seal
Sealing Nut
Panel Mounting
Hole mm (in)
Corrugated
Thread Length
C2 mm (in)
12 (0.47)
12 (0.47)
12 (0.47)
Wrench Size
Lock Nut (mm)
36
36
36
APP® Conduit P/N
NGN - 17B
NGN - 22B
NGN - 23B
Conduit O. D.
21.2 (0.83)
26.2 (1.03)
28.5 (1.12)
STRAIGHT CONDUIT PUSH-IN TYPE - STD PACK 50 / NOT UL LISTED
C1
Washer
APP® P/N
CAP21-28X
Wire Protection
Designation
(4 Characters)
CA04
C2
Body
Thread O.D. Panel Mounting
C1 mm (in) Hole mm (in)
28.3 (1.11) 28.3 - 28.7 (1.11 - 1.13)
Seal
Thread Length
C2 mm (in)
12 (0.5)
Wrench Size
Lock Nut (mm)
36
APP®
Conduit P/N
NGN - 23B
TUBING CUTTER
CORRUGATED NYLON PLASTIC TUBING
APP® P/N
NGN - 17B
NGN - 22B
NGN - 23B
Conduit I. D.
mm (in)
16.7 (0.66)
21.2 (0.83)
21.7 (0.85)
Conduit O. D.
mm (in)
21.2 (0.83)
26.2 (1.03)
28.5 (1.12)
Conduit Size
1/2”
3/4”
Trade Size
(mm)
OD21.2
OD28.5
Std. Pkg.
Meters (Feet)
50 (164)
50 (164)
50 (164)
Conduit O. D.
28.5 (1.12)
APP® P/N
TM0002
Description
Corrugated Plastic Tubing Cutter
Range (mm)
Up to OD 34.5
-7-
Standard Housing Arrangements & Contacts
HOUSING ARRANGEMENTS FOR POWER, SIGNAL & GROUND CONNECTORS
ARRANGEMENTS REPRESENT FRONT VIEW OF RECEPTACLE
Custom configurations may be created using APP’s part number configurator at www.andersonpower.com
E = Empty
A
B
C
D
1327 Series = Power
AC Single Phase
1327G6FP
E
1327G7FP
E
1827G1
E
AC 3 Phase, 3 Wire
1327G6FP
1327G7FP
1327FP
DC 2 Circuit, 4 Wire
1327G6FP
E
1327FP
1327G6FP
E
1327FP
With Ground
1327G6FP
E
1327FP
1327G6FP
1327G7FP
1327FP
G
1327G6FP
1327G7FP
1327FP
J
1327G8FP
1827G1
E
1327G8FP
1827G1
1327G16FP
K
L
1327G6FP
1327G6FP
1327G6FP
M
N
1327G6FP
4827G6
1327FP
1327G6FP
4827G6
1327FP
AC Single Phase With 4 Signal
1327G6FP
E
1327G7FP
E
1827G1
4827G6
1327G6FP
1327G7FP
1327FP
E
1827G1
4827G6
With 4 Signal
1327G6FP
E
1327FP
1327G6FP
4827G6
1327FP
1327FP
4827G6
1327G6FP
1327G7FP
4827G6
1827G1
1327G6FP
4827G6
1327FP
1327G6FP
1827G1
1327FP
AC 3 Phase, 4 Wire
With 4 Signal
P
X
-8-
With 8 Signal
AC 3 Phase, 3 Wire
With 8 Signal
DC 2 Circuit, 6 Wire
1327FP
1327FP
1327FP
4800 Series = Signal
AC 3 Phase, 3 Wire
With 4 Signal
1327G6FP
1827G1
1327FP
AC 3 Phase, 5 Wire
F
H
E
1827G1
E
AC 3 Phase, 4 Wire
E
1827 Series = Ground
1327G6FP
1327G7FP
1327FP
1327G8FP
1827G1
4827G6
All Signal
4827G6
4827G6
4827G6
4827G6
4827G6
4827G6
CONTINUOUS CURRENT RATINGS - POWER CONTACT CODE SELECTION
NOTES:
1. Current ratings:
• First number represents current rating per pole for 30°C temperature rise (29 / 40)
• Second number is the maximum recommended current per pole based on a 25°C ambient (29 / 40)
2. Configuration H - P based on signal contacts crimped to #20 AWG wire and carrying 1 amp
3.
Denotes wire size not appropriate for power contact
4. Shaded boxes
are
pending.
5. 1827G1 housing with 1830G1 or 1830G2 ground contact depending on primary contacts (see chart above). All signal housing kits (4850G6) come
with two 4802G3 and two 4802G3 contacts.
HOLDER LOCATIONS (VIEWS)
Back
Front
Plug
Front
Back
Front
SPEC Pak® (6) Pole - Temperature Rise
Based on 261G2 Contact
Back
Temperature (°C)
Receptacle
Front
TEMPERATURE CHART
Back
70
60
50
40
30
#10 AWG
4 Corners
Amperes
#12 AWG
4 Corners
40
50
#12 AWG
6 Positions
-9-
Individual Components
POWERPOLE® HOUSINGS & CONTACTS
Fingerproof PP15/45 Housing Only
Package Quantity:
Standard, 100 pieces - Bulk, 1,000 pieces
Standard
Part Number
1327FP
1327G5FP
1327G6FP
1327G7FP
1327G8FP
1327G16FP
Bulk
Part Number
1327FP-BK
1327G5FP-BK
1327G6FP-BK
1327G7FP-BK
1327G8FP-BK
1327G16FP-BK
Description
Red Housing
Green Housing
Black Housing
White Housing
Blue Housing
Yellow Housing
Standard PP 15/45 Housing Only
Package Quantity:
Standard
Part Number
1327
1327G5
1327G6
1327G7
1327G8
1327G16
1327G17
1327G18
1327G21
1327G22
1327G23
Bulk
Part Number
1327-BK
1327G5-BK
1327G6-BK
1327G7-BK
1327G8-BK
1327G16-BK
1327G17-BK
1327G18-BK
1327G21-BK
1327G22-BK
1327G23-BK
Description
Red Housing
Green Housing
Black Housing
White Housing
Blue Housing
Yellow Housing
Orange Housing
Gray Housing
Brown Housing
Pink Housing
Purple Housing
Premate Ground PP15/45 Housing Only
15/45 Powerpole® Contacts
Loose Piece
Package Quantity:
Standard
Bulk
Part Number
Part Number
1332
1332-BK
262G1-LPBK
262G2-LPBK
Individual-LD-Silver Plate
Singulated Reel-LD-Tin Plate
Singulated Reel-LD-Silver Plate
1331
1331-BK
261G1-LPBK
#10 to #14 AWG (4 to 1.5 mm²)
261G2-LPBK
261G3-LPBK
200G1L-LPBK -
Superflex, Sing. Reel-LD-Tin Plate
Description
Reel - 15/45 Powerpole® Contacts
Package Quantity 5,000
Part
Number
Description
262G1
Reel-LD-Tin Plate
262G2
Package Quantity:
261G1
Reel-LD-Tin Plate
Standard
Part Number
1827G1
261G2
Reel-LD-Tin Plate
261G3
Bulk
Part Number
1827G1-BK
Description
Green Housing
Premate Ground Contacts
Loose Piece
Package Quantity 100
Part
Number
Description
1830G1-LPBK Singulated-LD-Tin Plate
1830G2-LPBK Singulated-LD-Silver Plate
#10 to #14 AWG (6 to 1.5mm²)
200G1L
SuperFlex, Reel-LD-Tin Plate
NOTE:
LD - Low Detent
For additional housing colors please contact customer service.
CONTACT STYLES
Reel
Part
Number
Description
1830G1
Reel-LD-Tin Plate
1830G2
- 10 -
Individual
Singulated Open Barrel
On a Reel
PP15/45 POWERPOLE® HOUSING STYLES
PPMX (4800 SERIES) HOUSING & CONTACTS
PPMX Housing
Powerpole®
Fingerproof Housing
Rib Feature
Package Quantity
Standard, 25 pieces - Bulk, 1,000 pieces
Standard
Part Number
4827G6
Bulk
Part Number
4827G6-BK
1327FP Series
Description
Black two piece housing
PPMX Contacts
Powerpole®
Standard Housing
Closed Nose
Package Quantity
Standard, 50 pieces - Bulk, 2,000 pieces
1327 Series
Loose Piece
#20 to #24 AWG (0.50 to 0.25 mm²)
Standard
Part Number
4802G3
4803G3
Bulk
Part Number
4802G3-BK
4803G3-BK
Powerpole®
Premate Ground Housing
Open Nose
Description
Socket, Gold, 50 Micro-inches
Pin, Gold, 50 Micro-inches
PPMX Housing & Contact Kits
PPMX Housing
2 Socket & 2 Pin Contacts
Open Nose
Package Quantity
1827 Series
4800 Series
1 Black two piece housing, 2 Male Contacts,
2 Female Contacts
Standard
Part Number
4850G6
Bulk
Part Number
Description
50 Micro-inches Gold Plated Contacts - Pin & Socket
APPLICATION TOOLING - POWERPOLE® 15 / 45 CONTACTS
Loose Piece Tin
Part Number
Loose Piece
Silver Part
Number
N/A
1332
N/A
1331
262G1-LPBK
262G2-LPBK
200G2L-LPBK
200G4L-LPBK
261G1-LPBK
261G4-LPBK
261G2-LPBK
261G3-LPBK
200G1L-LPBK
200G3L-LPBK
1830G1-LPBK
1830G2-LPBK
Hand Tool
or
1309G2 or
1309G8
1309G3 or
1309G8
Reeled Tin Part
Number
Pneumatic Tool
1367G1
N/A
1309G6 or
1309G8
Reeled Silver
Part Number
ATS Applicator
N/A
N/A
N/A
N/A
N/A
N/A
261G1
262G2
1385520
200G2L
200G4L
TBD
261G1
261G4
1385520
261G2
261G3
1385458
200G1L
200G3L
1385460
1830G1
1830G2
1385460
* All Hand and Pneumatic Tools for use with Loose Piece contacts only. All reeled contacts can be ordered singulated, (Loose Piece) with the suffix “- LPBK”
** 1309G8 is a hand tool kit- includes dies and locators to make up 1309G2, 1309G3, &1309G6
APPLICATION TOOLING - PPMX CONTACTS
Contact
Part Number
4802G3
4803G3
APP® Hand Tool or
PM1000G1
Mil Std.Hand
Tool
(APP Part #)
M22520/1-01
(TM0001)
Positioner
No Mil Std.
(TL0005)
Pneumatic Tool
for Locator /
Turret
TP0001
- 11 -
Dimensions
PLUG 6 POSITION FOR PP15/45 HOUSINGS
Top View
Front View
[ 42.2 ]
1.66
Side View
INTERFACIAL
GASKET
[ 76.2 ]
3.00
Mated Side View
[ 103.1 ]
4.01
[ 48.0 ]
1.89
[ 57.2 ]
2.25
[ 53.3 ]
2.10
RIGHT ANGLE PLUG 6 POSITION FOR PP15/45 - GLAND SIZE PG 21
Top View
Front View
Side View
[ 42.2 ]
1.66
Mated Side View
[ 118.7 ]
4.67
PR
[ 91.6 ]
3.60
A
B
PG
-AGland mm
in.
PG 21 104.7 4.12
PG 29 105.5 4.15
[ 53.2 ]
2.10
-Bmm
in.
36.4 1.43
47.4 1.86
R1.73 LATCH SWEEP
For PG 29 dimensions, please see APP website
RECEPTACLE 6 POSITION FOR PP15/45 HOUSINGS
Panel Cut Out
[ 34.9 ]
1.38
[ 34.9 ]
1.38
Front View
Side View
[ 49.8 ]
1.96
[ 3.73 ]
Ø 0.147 (4)
CL
[ 39.7 ]
Ø 1.56
[ 53.3 ]
2.10
[ 44.5 ]
1.75
[ 44.0 ] R1.73
LATCH SWEEP
[ 55.1 ]
2.17
[ 41.7 ]
1.64
CL
PANEL CUT OUT CL
(SAME AS 26482 & 5015 SHELL SIZE 24)
Back View
[ 36.6 ]
1.44
[ 44.5 ]
1.75
[ 39.1 ]
1.54
[ 38.1 ]
Ø 1.50
[ 46.0 ]
1.81
NOTE: Mounting hardware #6 screw / torque receptacle to panel 3½ to 5 in-lbf (0.4 to 0.56 Nm)
PG GLANDS
PS
CT
Plastic Short
[ 107 ]
4.2
PF
Thread Conduit Adapter
[ 107 ]
4.2
Plastic Flex PG
Push-in Conduit Adapter
[ 112 ]
4.4
[ 178 ]
7.0
[ 48.0 ]
1.89
[ 48.0 ]
1.89
CA
[ 48.0 ]
1.89
[ 48.0]
1.89
RECEPTACLE COVER KIT
Front View
Side View
Mated Side View
[ 17.3 ]
0.68
[ 42.2 ]
1.66
[ 50.4 ]
1.98
[ 55.6 ]
2.19
[ 59.7 ]
2.35
[ 24.9 ]
0.98
[ 53.3 ]
2.10
All Data Subject To Change Without Notice
Patents
15052
HEADQUARTERS: Anderson Power Products®, 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128
DS-SPAK REV06
EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203
ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036
CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218
- 12 - www.andersonpower.com
TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460
