TXR™ 4 Series SMD HSC Compatible Receptacle
Part No:
RECE.20449.001E.01
Description:
TXR™ 4 Series HSC Compatible Receptacle
Compatible with I-PEX MHF ®4, I-PEX MHF ®4L, and Murata HSC
Features:
Mating Height: 1.2mm Max
15000pcs per reel
Dimensions: 2 x 2 x 0.6 mm
Diameter: 1.4mm
RoHS & Reach Compliant
SPE-16-8-034-E
1.
Introduction
3
2.
Specifications
4
3.
Connector Data
6
4.
Mechanical Drawing
7
5.
Solder Reflow Profile
8
6.
Packaging
9
Changelog
11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-16-8-034-E
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
the Taoglas TXR™ Series of receptacles, the TXR™ 4 RECE.20449.001E.01 is a 3-pad type wire-to-board
1.Part ofIntroduction
SMT Receptacle solution that is ultra-small, lightweight and low profile, 1.6mm max. with an operational
frequency range of DC to 6 GHz the TXR™ 4 RECE.20449.001E.01 is gold plated to provide superior
performance and allow easy mounting of the male RF connector.
on tape and reel, this receptacle is designed to be placed with automatic “pick and place” equipment
1.Packaged
Introduction
for ease of installation.
The TXR™ 4 RECE.20449.001E.01 acts as a 50 Ohm transmission line to connect the micro-miniature RF
connector to the printed circuit board. It is fully compatible with I-PEX MHF ®4, I-PEX MHF ®4L, Murata HSC
and all other available HSC compatible connectors.
1.
Introduction
Applicable Technologies:
TXR™ 4 RECE.20449.001E.01 receptacles are commonly integrated into GSM module, GPS module, Wireless
LAN modules. Many 5G modules are currently using these compatible receptacles for the next generation of
cellular applications.
1.
Introduction
For further information, please contact your regional Taoglas customer support team.
SPE-16-8-034-E
www.taoglas.com
3
2.
Specifications
Electrical
3.
Operation Frequency
Antenna
Characteristics2.
DC to 6 GHz
Specifications
1.3 Max at DC~3 GHz
VSWR
1.4 Max at 3~6 GHz
3.
4.
Nominal Impedance
Antenna
Characteristics
50 Ohm
Rated Voltage
60V AC
Rated Current
1A Max.
Subject mated contacts assembled in housing to
Contact Resistance
Antenna
Radiation Patterns3.Antenna
20mV Max. open circuit at 10mA Max
Withstand Voltage
Characteristics2.
Specifications
Insulation Resistance
AC 200V/minute
Impressed voltage 100V DC for 1min
Initial:500MΩ Min. Final:100MΩ Min.
Dielectric Withstanding Voltage
3.
200V AC for 1 minute
Current leakage
Antenna
Characteristics2.
0.5mA Max
Specifications
Temperature
3.
4.
-40 to +90°C
Antenna
Characteristics
Outer Contact
Material
Copper Alloy (Au plating)
Centre Contact
Insulator
LCP UL94-V0
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-16-8-034-E
Specifications
www.taoglas.com
4
Environmental
Durability per EIA-364-09C (2-3 cycles per min @ 30 cycles)
Vibration
10Hz -> 100Hz -> 10Hz for 20 mins.
Peak value of acceleration
1.5mm or 59m/s2 (6G)
Direction
3 axis 3 Cycles
Mechanical Shock
Accelerate Velocity
735m/s2 (75G)
Waveform
Half-sine shock plus.
Duration
11m sec.
Direct Current
1mA
Direction
In ±X,±Y and ±Z axes.
Cycle
3 cycles for each direction, totally 18 cycles
Thermal Shock (40°C for 30mins to 5~35°C for 5 minutes to 90°C for 30mins to 5~35°C for 5 minutes)
Transition Time
5 minutes
Cycles
5
Humidity
90~95% RH
Temperature
40+/- 2°C
Duration
96 hours
Salt Water Spray
Temperature
35+/- 2°C
Salt Water Density
5+/-1% (by weight)
Duration
48 Hours
High temperature life
90+/- 2°C for 96 hours
Cold temperature life
-40+/- 2°C for 96 hours
H2S gas
Temperature
40+/-2°C
Relative Humidity
80 +/-5% RH
Gas H2S
3+/-1 ppm
Duration
96 Hours
Moister Sensitivity Level
3
SPE-16-8-034-E
www.taoglas.com
5
3.
Connector Data
3.1
6.
VSWR
Packaging5.
Mechanical Drawing
5.0
6. 4.0 Packaging
7. 3.0 Application Note6. Packaging5.
Mechanical
Drawing
2.0
6. 1.0 Packaging5.
0.50
1.00
1.50
Mechanical Drawing
2.00
2.50
3.00
3.50
4.00
4.50
5.00
5.50
6.00
Frequency [GHz]
Sample_S11
6.
3.2
Sample_S22
Packaging
Insertion Loss
7.
Application Note
-1
7.
-2
7.
0.50
1.00
1.50
2.00
2.50
3.00
3.50
4.00
4.50
Application
Note6.
Packaging5.
Mechanical
Frequency [GHz]
Drawing
6.
Packaging5.
SPE-16-8-034-E
5.00
5.50
6.00
Sample_S12
Mechanical Drawing
www.taoglas.com
6
4.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-16-8-034-E
Mechanical Drawing
www.taoglas.com
7
5.
Solder Reflow
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-16-8-034-E
www.taoglas.com
8
8.
6.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-16-8-034-E
Mechanical Drawing
www.taoglas.com
9
SPE-16-8-034-E
www.taoglas.com
10
Changelog for the datasheet
SPE-16-8-034 - RECE.20369.001E.01
Revision: E (Current Version)
Date:
Changes:
Changes Made by:
2022-07-05
Updated drawing
Cesar Sousa
Previous Revisions
Revision: D
Date:
Changes:
Changes Made by:
2022-03-08
Updated Packaging
Gary West
Revision: C
Date:
Changes:
Changes Made by:
2021-07-15
Updated Solder Reflow Diagram & Adding MSL.
Gary West
Revision: B
Date:
Changes:
Changes Made by:
2021-02-03
Following EC-20-8-036
Jack Conroy
Revision: A (Original First Release)
Date:
Notes:
2016-04-21
Author:
Jack Conroy
SPE-16-8-034-E
www.taoglas.com
11
www.taoglas.com
SPE-16-8-034-E
© Taoglas 12
www.taoglas.com
很抱歉,暂时无法提供与“RECE.20449.001E.01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.393501+0.89760
- 10+5.7258010+0.69510
- 100+5.35270100+0.64980
- 500+4.93290500+0.59890
- 15000+4.9329015000+0.59890
- 国内价格 香港价格
- 15000+5.2651715000+0.63873
