BT840XE
BT840XE
    FANSTEL
    BT840XE
BT840XE 数据手册
BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 BluNor BT840F is a powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) using Nordic nRF52840 SoC. With an ARM CortexTM M4F MCU, available 1MB flash, 256KB RAM, embedded 2.4GHz multiprotocol transceiver, and an integrated PCB trace antenna or u.FL connector for an external antenna. A power amplifier is integrated in BT840X and BT840XE to increase Bluetooth range. It allows faster time to market with reduced development cost. Bluetooth ranges are measured in environments with Low Multiple Path Interference (LMPI) and antenna at 5 feet (1.52 meters), typical height of thermostat in the USA. Ranges for LMPI, correlating to actual link budget, indicates the Bluetooth signal strength for penetrating walls in buildings. Specifications:
 nRF52840 QIAA, ARM Cortex M4F, 64 MHz ARM® TrustZone® Cryptocell-310 co-processor Complete RF solution with integrated antenna BLE 5 data rate: 2Mbps, 1Mbps, 500kbps, 125kbps. IEEE 802.15.4 Thread and Zigbee data rate: 250 Kbps 2.4 GHz proprietary data rate: 2 Mbps, 1 Mbps Integrated DC-DC converter, inductors on board. Direct powered by Lithium batteries or USB supply (up to 5.5V) Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 1MB/256KB. 48 General purpose I/O pins USB 2.0 full speed (12 Mbps) controller QSPI 32 MHz interface High speed 32 MHz SPI Type 2 NFC-A tag with wake-on field, Touch-topair support Programmable peripheral interconnect (PPI) 12 bit/200 Ksps ADC, 8 configurable channels with programmable gain 64 level comparator 15 level comparator with wake-up from OFF mode Temperature sensor 4x4-channel pulse width modulator (PWM) Audio peripherals: I2S, digital microphone interface (PDM) 5 x 32 bit timers with counter mode Up to 4x SPI masters/3x SPI slaves Up to 2x I2C compatible 2-wire masters/slaves 2x UART (CTS/RTS) Quadrature Demodulator (QDEC) 3x real time counters (RTC) 128-bit AES HW encryption SoC Receiver Sensitivity: -96 dBm at 1Mbps SoC TX power: programmable +8dBm to -20dBm. Up to +6 dBi antenna gain. Hybrid pins: 16 castellated and 45 LGA. Integrated PCB trace antenna or u.FL connector Operation voltage: 1.7V to 5.5V Operation temperature: - 4 0 ° C t o + 8 5 ° C QDID: 108621
 Model Summaries module SoC Size BT Antenna Peak TX 32.768 sleep crystal BT range,1 Mbps, LMPI BT range, 1Mbps, 1.52m BT range, 125 Kbps, LMPI. BT range, 125 kBps, 1.52m FCC ID IC ID CE Availability BT840F nRF52840-QIAA 15x20.8x1.9mm PCB trace BT840 nRF52840-QIAA 14x16x1.9mm PCB trace BT840E nRF52840-QIAA 14x16x1.9mm ANT002 External 1000 meters 390 meters 2300 meters 640 meters X8WBT840 4100A-BT840 Certified Production External 150 meters 120 meters 320 meters 210 meters X8WBT840 4100A-BT840 Certified Production External !1 X8WBT840 4100A-BT840 Certified Production BT840X nRF52840-QIAA 15x28.0x1.9mm PCB trace + PA +22.6 dBm Integrated 1170 meters 900 meters >4500 meters 1240 meters X8WBT840X 4100A-BT840X BT840XE nRF52840-QIAA 15x28.0x1.9mm PA+ANT000 +21.0 dBm Integrated 1170 meters 1170 meters >4500 meters 1920 meters X8WBT840X 4100A-BT840X Production Production BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Table Of Contents 1. Introduction ........................................................................................................................................................3 BT840F ..............................................................................................................................................................3 BT840 ................................................................................................................................................................4 BT840E..............................................................................................................................................................4 BT840X..............................................................................................................................................................4 BT840XE ........................................................................................................................................................... 4 2. Codes Development Using Nordic Tools ........................................................................................................... 5 Over-The-Air DFU .............................................................................................................................................5 SoftDevices ....................................................................................................................................................... 5 Development Tools ............................................................................................................................................5 3. Product Descriptions .........................................................................................................................................6 Block Diagram of nRF52840 .............................................................................................................................6 ARM Trustzone CryptoCell 310 .........................................................................................................................7 Mechanical Drawings ........................................................................................................................................ 9 Pin Assignments of BT840 .............................................................................................................................. 12 Pin Function..................................................................................................................................................... 14 Mounting BT840F on the Host PCB ................................................................................................................ 16 Host Board Design for Low Cost or Long Range ............................................................................................ 17 Control Skyworks Power Amplifier................................................................................................................... 18 4. Bluetooth Range Measurements .....................................................................................................................22 5. AT Commands .................................................................................................................................................24 6. BT840F Evaluation Board ...............................................................................................................................24 Nordic Development Tools............................................................................................................................... 25 Android OS Apps ............................................................................................................................................. 25 iOS Apps..........................................................................................................................................................25 BT840F V4 EvaluationBoard Schematics .......................................................................................................26 Suggestion for Battery Power Application .......................................................................................................27 7. Miscellaneous..................................................................................................................................................28 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 28 Cautions, Design Notes, and Installation Notes .............................................................................................. 28 Packaging and Lot Number ............................................................................................................................. 32 FCC Label ....................................................................................................................................................... 32 Revision History .................................................................................................................................................. 33 Contact Us ..........................................................................................................................................................34 !2 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 1. Introduction BluNor BT840F Series are powerful, highly flexible, ultra low power wireless modules using Nordic nRF52840 SoCs. With an ARM CortexTM M4F MCU, 1MB flash, 256KB RAM, embedded 2.4GHz multi-protocol transceiver, and an integrated antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BT840F. Antenna circuit and main clock are integrated. All 48 GPIOs of nRF52840 can be accessed from main board. For lower power consumption at idle state, a 32.768 kHz crystal can be added on the host board. Connection to an external NFC (Near Field Communication) antenna is provided. BlurNor BT840F is a sister module of BT832F. The physical size is the same. There are 21 additional LGA pins for additional GPIOs provided by nRF52840. There are 3 modules in the BT840F Series. BT840F • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated PCB trace range antenna. Bluetooth range is 1000 meters at 1Mbps and 2300 meters at 125 Kbps measured in environments with low RF and multiple path interferences. • Size: 15x20.8x1.9mm. !3 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840 • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated PCB trace range antenna. • Size: 14x16x1.9mm. BT840E • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • An u.FL connector for external antenna. Certified with Fanstel ANT020 antenna.. • Size: 14x16x1.9mm. BT840X • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated SKY66112 power amplifier • Integrated 32.768 KHz sleep crystal • Integrated PCB trace antenna • Size: 15x28x1.9mm. BT840XE • Uses an nRF52840 QIAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • Integrated SKY66112 power amplifier. • Integrated 32.768 KHz sleep crystal. • An u.FL connector for external antenna. Certified with Fanstel ANT000 antenna. • Size: 15x28x1.9mm.
 !4 Ver 1.11 May 2019 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used. Nordic development environment for nRF52840 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52840 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S140: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. Nordic software development tools can be downloaded from the following webpage. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/development/ nrf52_dev_kit.html&cp=1_1 !5 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 3. Product Descriptions Brief description of nRF52840 SoC is provided. For full description of the SoC, please download from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy Block Diagram of nRF52840 The following is a block diagram of Nordic nRF52840 Bluetooth Low Energy (BLE) SoC. Arrows with white heads indicate signals that share physical pins with other signals. !6 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +8dBm down to -20 dBm in 4dB steps. Sensitivity is increased to -96 dBm to -89 dBm, depending on data rate. Sensitivity for BLE is -96 dBm, and -92.5 dBm for ANT. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. ARM Trustzone CryptoCell 310 ARM® TrustZone® CryptoCell-310 co-processor is a security subsystem which provides Root of Trust (RoT) and cryptographic services for a device. CryptoCell services are available to the application through a software library API, not a hardware register interface. The following cryptographic features are provided. !7 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE • FIPS-140-2 certified True Random Number Generator (TRNG) • RSA asymmetric encryption Ver 1.11 May 2019 Up to 2048 bit key size PKCS#1 v2.1/v1.5 Optional CRT support • Elliptic curve cryptography (ECC) NIST FIPS 186-4 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-192, P-224, P-256, P-384, P-521 SEC 2 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-160, P-192, P-224, P-256, P-384, P-521 Koblitz curves using fixed parameters, up to 256 bits: ➢ Prime field: P-160, P-192, P-224, P-256 Edwards/Montgomery curves: ➢ Ed25519, Curve 25519 ECDH/ECDSA support • Secure remote password protocol (SRP) Up to 3072 bit operations • Hashing functions SHA-1, SHA-2 up to 256 bit size keyed-hash message authentication code (HMAC) • AES symmetric encryption General purpose AES engine (encrypt/decrypt, sign/verify) 128 bit key size Supported encryption modes: ECB, CBC, CMAC/CBC-MAC, CTR, CCM/CCM*. • ChaCha20/Poly1305 symmetric encryption Supported keyed size: 128 and 256 bits Authenticated encryption with associated data (AEAD) mode !8 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Mechanical Drawings The followings are mechanical drawings of BT840F and BT832F. The physical sizes of both are the same, 15x20.8x1.9mm. Except the 19 pins in solid black dots, BT840F and BT832F is hardware pin to pin compatible. Firmware configuration is required to perform the same function. Two types of pins are available to meet different application requirements. • 16 castellated pins for application needing limited number of IOs. SMT equipment is not required for soldering castellated pins. • 45 LGA (Land Grid Array) pins to access all 48 GPIOs of nRF52840 when needed. BT840F and BT832F Mechanical drawings, top view !9 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840 and BT840E mechanical drawings, top view. !10 Ver 1.11 May 2019 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840X and BT840XE mechanical drawings !11 Ver 1.11 May 2019 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Pin Assignments of BT840 The followings are BT840 pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52840 Product Specifications for detailed descriptions and features supported. https://www.nordicsemi.com/eng/Products/nRF52840 BT840F pins is a super set of that of BT832F. A PCB developed for BT832 Series can be used for BT840 Series and vice versa. BT832F pin assignments. !12 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE BT840F pin assignments !13 Ver 1.11 May 2019 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Pin Function BT840 52840 pin# pin# pin name G1 P0.26/SDA 1 1 BT832 52832 pin# pin# pin name Descriptions 38 P0.26 GPIO, configured as I2C SDA on EV-BT840 39 2 H2 P0.27/SCL 2 P0.27 GPIO, configured as I2C SCL on EV-BT840 3 D2 P0.00/XL1 3 2 P0.00/XL1 GPIO, connection for 32.768kHz crystal 4 F2 P0.01/XL2 4 3 P0.01/XL2 GPIO, connection for 32.768kHz crystal 5 A12 P0.02/AIN0 5 4 P0.02/AIN0 GPIO, Analog input 5 P0.03/AIN1 GPIO, Analog input 6 B13 P0.03/AIN1 6 7 L24 P0.09/NFC1 7 11 P0.09/NFC1 GPIO, NFC antenna connection 8 J24 P0.10/NFC2 8 12 P0.10/NFC2 GPIO, NFC antenna connection 13 9 B1 VDD 9 VDD DC supply 1.7V to 3.6V 10 B7 GND 10 45 VSS Ground 11 T2 P0.11 11 16 P0.13 GPIO 12 AD22 P1.00 12 21 P0.18 GPIO 23 13 AD8 P0.13 13 P0.20 GPIO 14 AC13 P0.18/RESET 14 24 P0.21/RESET GPIO, configurable as RESET pin 15 AA24 SWDCLK 15 25 SWDCLK Serial Wire Debug clock input 16 AC24 SWDIO 16 26 SWDIO Serial Wire Debug I/O Z0 B19 P1.11 GPIO Z1 B17 P1.12 GPIO Z2 A16 P1.13 GPIO Z3 B15 P1.14 GPIO Z4 A14 P1.15 GPIO Z5 A20 P1.10 GPIO Z6 R24 P1.06 GPIO A0 GND A0 45 VSS Ground A1 B11 P0.28/AIN4 A1 40 P0.28/AIN4 GPIO, Analog input A2 A10 P0.29/AIN5 A2 41 P0.29/AIN5 GPIO, Analog input A3 J1 P0.04/AIN2 A3 6 P0.04/AIN2 GPIO, Analog input A4 K2 P0.05/AIN3 A4 7 P0.05/AIN3 GPIO, Analog input A5 M2 P0.07 A5 9 P0.07 GPIO A6 P2 P1.08 B0 GPIO GND B0 45 VSS Ground B1 AC21 P0.25 B1 37 P0.25 GPIO B2 B9 P0.30/AIN6 B2 42 P0.30 GPIO B3 A8 P0.31/AIN7 B3 43 P0.31 GPIO B4 L1 P0.06 B4 8 P0.06 GPIO, NC for BT840X, BT840XE, PA control B5 N1 P0.08 B5 10 P0.08 GPIO, NC for BT840X, BT840XE, PA control B6 V23 P1.03 C0 GPIO GND C0 45 VSS Ground C1 AD20 P0.24 C1 29 P0.24 GPIO C2 AD18 P0.22 C2 27 P0.22 GPIO C3 AD12 P0.17 C3 20 P0.17 GPIO, NC for BT840X,BT840XE, PA control !14 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE C4 AD10 P0.15 C4 18 P0.15 GPIO C5 W24 P1.02 C5 15 P0.12 GPIO C6 U24 P1.04 GND D0 45 VSS Ground D0 Ver 1.11 May 2019 GPIO D1 AC19 P0.23 D1 28 P0.23 GPIO D2 AC15 P0.19 D2 22 P0.19 GPIO, NC for BT840 X,BT840XE, PA control D3 AC11 P0.16 D3 19 P0.16 GPIO D4 AC9 P0.14 D4 17 P0.14 GPIO D5 Y23 P1.01 D5 14 P0.11 GPIO D6 T23 P1.05 GPIO E0 P23 P1.07 GPIO E1 AD16 P0.20 GPIO E2 AC17 P0.21 GPIO E3 R1 P1.09 GPIO E4 AD6 D+ USB D+ E5 AD4 D- USB D- E6 U1 P0.12 GPIO F0 Ground pad F1 Ground pad F2 Ground pad F3 Ground pad F4 Y2 VDDH High Voltage Power Supply F5 AB2 DCCH DC to DC converter output F6 AD2 VBUS 5V DC power for USB 3.3V regulator !15 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Mounting BT840F on the Host PCB The following figure shows recommended mounting of BT840F module on the host PCB. • For the best Bluetooth range performance, the antenna area of module shall extend 9.8 mm outside the edge of host PCB board, or 9.8 mm outside the edge of a ground plane. • The next choice is to place a module on a corner of host PCB, the antenna area shall extend 9.8 mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • We don’t recommend mounting BT840F module in the middle of a host PCB. For the best Bluetooth range performance, keep all external metal at least 30mm from the antenna area. !16 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Host Board Design for Low Cost or Long Range On nRF52 series SoCs, Nordic offers various memory options and protocol supports. Fanstel offers various antenna and power amplifier options. A host board can be designed to accommodate these nRF52 modules. Our suggestions for host PCB design: If your main goal is minimum PCB cost, • use a 2-sided PCB. • Use library component from EV BT832 Gerber files, can be downloaded from http://www.fanstel.com/ download-document/. It has 16 castellated pins plus 24 LGA pins. BT840F library component can be used. However, signal routing can be difficult on a 2-sided PCB. • Be sure of no metal contact in the area of 21 additional BT840F pins. • BT840F can be mounted on a BT832 pad. If you main goal is maximum wireless range, • use a 4 or more layers PCB. • Use library component from EV BT840F V4 or newer Gerber files, can be downloaded from http:// www.fanstel.com/download-document/. It has 16 castellated pins plus 45 LGA pins. • As much ground plane under BT840F, on top side of host PCB as possible. Use EV BT840F V4 Gerber files as an example. • If your products may need wireless range of 1350 meters or more, allocate physical space for a 15x28x1.9mm module. This larger module size is required to accommodate Skyworks SKY66112 power amplifier. • Don’t use P0.06 (BT840F pin B4), P0.17 (BT840F pin C3), and P0.19 (BT840F pin D2) on the host board. These pins are used to control SKY66112 power amplifier in BT832X, BT832XE, BT840X and BT840XE. !17 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Control Skyworks Power Amplifier BT840X uses SKYWORKS SKY66112-11 power amplifier. The connection diagram with control signal pins is below. A firmware example to control Skyworks SKY66112 power amplifier is below. This firmware file can be downloaded from http://www.fanstel.com/download-document/. You can set nRF52840 TX to up to + 8 dBm. The conditions for passing FCC and Industrial Canada certification testings: • BT840X: Set nRF52840 TX to +2 dBm. • BT840XE: Set nRF52840 TX to +2 dB and use Fanstel antenna ANT000. Header files #ifndef PA_LNA_H__ #define PA_LNA_H__ #include "ble.h" #include "app_error.h" #include "nrf_drv_gpiote.h" #include "nrf_drv_ppi.h" void pa_lna_init(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin); #endif !18 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Main program. #include "pa_lna.h" #define APP_PA_LAN #ifdef APP_PA_LAN #define APP_PA_PIN #define APP_LNA_PIN 17 19 #define APP_CHL_PIN 8 #define APP_CPS_PIN 6 int main(void) { .... #ifdef APP_PA_LAN nrf_gpio_cfg_output(APP_CPS_PIN); nrf_gpio_cfg_output(APP_CHL_PIN); nrf_gpio_pin_set(APP_CHL_PIN); nrf_gpio_pin_clear(APP_CPS_PIN); //enable pa_lna_init(APP_PA_PIN,APP_LNA_PIN); #endif .... } SKY66112 control codes. #include #include #include "pa_lna.h" #include "ble.h" #include "app_error.h" #include "nrf_drv_gpiote.h" #include "nrf_drv_ppi.h" void pa_lna_init(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin) { ble_opt_t opt; uint32_t gpiote_ch = NULL; !19 Ver 1.11 May 2019 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 ret_code_t err_code; memset(&opt, 0, sizeof(ble_opt_t)); err_code = nrf_drv_gpiote_init(); if(err_code != NRF_ERROR_INVALID_STATE) APP_ERROR_CHECK(err_code); err_code = nrf_drv_ppi_init(); //if(err_code != MODULE_ALREADY_INITIALIZED) APP_ERROR_CHECK(err_code); nrf_ppi_channel_t ppi_set_ch; nrf_ppi_channel_t ppi_clr_ch; err_code = nrf_drv_ppi_channel_alloc(&ppi_set_ch); APP_ERROR_CHECK(err_code); err_code = nrf_drv_ppi_channel_alloc(&ppi_clr_ch); APP_ERROR_CHECK(err_code); nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false); if((gpio_pa_pin == NULL) && (gpio_lna_pin == NULL)) { err_code = NRF_ERROR_INVALID_PARAM; APP_ERROR_CHECK(err_code); } if(gpio_pa_pin != NULL) { if(gpiote_ch == NULL) { err_code = nrf_drv_gpiote_out_init(gpio_pa_pin, &config); APP_ERROR_CHECK(err_code); gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_pa_pin); } // PA config opt.common_opt.pa_lna.pa_cfg.active_high = 1; // Set the pin to be active high opt.common_opt.pa_lna.pa_cfg.enable = 1; // Enable toggling opt.common_opt.pa_lna.pa_cfg.gpio_pin = gpio_pa_pin; // The GPIO pin to toggle tx } if(gpio_lna_pin != NULL) { if(gpiote_ch == NULL) { err_code = nrf_drv_gpiote_out_init(gpio_lna_pin, &config); APP_ERROR_CHECK(err_code); !20 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_lna_pin); } // LNA config opt.common_opt.pa_lna.lna_cfg.active_high = 1; // Set the pin to be active high opt.common_opt.pa_lna.lna_cfg.enable = 1; // Enable toggling opt.common_opt.pa_lna.lna_cfg.gpio_pin = gpio_lna_pin; // The GPIO pin to toggle rx } // Common PA/LNA config opt.common_opt.pa_lna.gpiote_ch_id = (gpiote_ch - NRF_GPIOTE_BASE) >> 2; // GPIOTE channel used for radio pin toggling opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch; // PPI channel used for radio pin clearing opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch; // PPI channel used for radio pin setting err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt); APP_ERROR_CHECK(err_code); } !21 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 4. Bluetooth Range Measurements Bluetooth range measurement reports and hex codes used in measurements can be downloaded from Bluetooth Range Measurements section of this webpage. http://www.fanstel.com/download-document/ Bluetooth ranges are measured between 2 modules on evaluation boards for various height of antenna. On the first measurement, both antennas are pointing to sky and facing each other. The second antenna is rotated by 30 degrees clockwise after each measurement. Bluetooth range is specified as the average of 12 measurements with the least significant digit truncated. • 1.52 meters (60 inches) is typical height of thermostat in the USA. • 0.55 meter (21.5 inches) is typical height of antenna if an IoT device is plugged into a wall AC outlet in the USA. When USB840F USB dongle is plugged into a smart phone charger plugging into a wall AC outlet to collect Bluetooth sensor data or to be used as a Bluetooth signal repeater. • Low Multiple Path Interference (LMPI). For longer range measurement, antenna must be higher to have LMPI. To have LMPI, 60% clearance is required. For example, if transmitter and receiver is 1000 meters away, both antennas must be 3.33 meters above ground and away from any obstruction. !22 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 The followings are Bluetooth range measurement results. Antenna height LMPI 1.52 meters 0.55 meter BT840F Bluetooth range, 125Kbps 2300 meters 640 meters 210 meters BT840F Bluetooth range, 1Mbps 1000 meters 390 meters 140 meters BT840 Bluetooth range, 125 Kbps 320 meters 210 meters BT840 Bluetooth range, 1Mbps 150 meters 120 meters BT840X Bluetooth range, 125 Kbps >4500 meters 1240 meters BT840X Bluetooth range, 1Mbps 1170 meters 900 meters BT840XE with ANT000 range, 125 Kbps >4500 meters 1920 meters BT840XE with ANT000 range, 1Mbps 1170 meters 1170 meters • Bluetooth ranges of BT840X and BT840XE at 125 Kbps and LMPI, is verified to exceed 4500 meters, maximum range of test site used in May 2019. • Range of BT840XE with +21.0 dBm peak TX is longer than BT840X with +22.6 dBm peak TX. Antenna ANT000 is almost omni-directional. The integrated antenna of BT840X is not. Range is shorter for some angles. Result is the average of 12 measurements. !23 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 5. AT Commands AT command codes are used in production testing. They are not erased before shipping. If you develop your own codes, please do chiperase and reprogram with your codes. User manual and the newest AT Commands hex codes can be downloaded from AT Command Hex Codes, Bluetooth 5 section of this web page. http://www.fanstel.com/download-document/ AT commands can be used on UART interface and SPI interface. The preloaded codes use UART interface. 6. BT840F Evaluation Board An evaluation board consists of the followings: • Mini USB cable • Evaluation board • 10-conductor cable for connection to Nordic nRF52 DK (DK is not included) !24 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Nordic Development Tools A Nordic nRF52 DK is recommended for programming this evaluation board. Nordic development tools can be downloaded from: https://www.nordicsemi.com/eng/Products/nRF52840 Many application examples can be downloaded from Nordic website. Some firmware, Android OS, and iOS app codes can be downloaded from Bluetooth 5 Codes section of this Fanstel webpage. http://www.fanstel.com/download-document/ BT840 firmware can be used in all nRF52840 modules, e.g., BT840, BT840F, and BT840E. Android OS Apps The following Android OS apps are available for download from Google Play Store:
 BlueNor nrf5x: to use with Bluetooth 5 stacks, AT commands, or Slave firmware. Master firmware does not connect to a smartphone. Source codes can be downloaded from http://www.fanstel.com/download-document/ BlueNor Mesh: to use with BlueNor mesh firmware to send command to any node in a mesh. Node number is displayed when acknowledgement is received. Source codes will be uploaded to Fanstel website when supporting Bluetooth 5. iOS Apps The following iOS apps can be downloaded from Apple APP Store. BlueNor Mesh: to use with BlueNor mesh firmware to send command to any node in a mesh. Node number is displayed when acknowledgement is received.
 BlueNor nrf5x firmware, apps, and source codes will be uploaded when ready. !25 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 BT840F V4 EvaluationBoard Schematics Evaluation board schematics and Gerber files can be downloaded from http://www.fanstel.com/download-document/ 4 P000(P00) 3 P001(P01) 4 P002(P02) 5 P003(P03) 6 P009(P09) 7 P010(P10) 8 P26/SDA Z0 A0 B0 C0 D0 E0 Z1 A1 B1 C1 D1 E1 SWDIO P27/SCL SWCLK P00/XL1 P01/XL2 Z2 A2 B2 C2 D2 E2 Z3 A3 B3 C3 D3 E3 P18/RESET P13/LED P02/AIN0 P100_SWO P03/AIN1 P09/NFC1 Z4 A4 B4 C4 D4 E4 F4 Z5 A5 B5 C5 D5 E5 F5 Z6 A6 B6 C6 D6 E6 F6 P11/BUTTON 14 (P21) P018 13 (P20) P013 12 (P18) P100 SWO 11 (P13) P011 U1 GND 10uH DCCH Current measurement , SW6 all off VDD SW6 P102 P101 (P12) (P11) NC CTS RTS RXD TXD DSR DTR GND BAT-EN 1 2 3 4 5 6 7 2 4 120OHM 3 R7 3.01K BAT-ADC Y1 32.768KHz GND GND 14 13 12 11 10 9 8 CT1 10uF/10V C8 1uF GND (P23) 1 2 P113 1 (P25) 1 P115 1 C9 0.1uF GND J21 GND P101 P102 P011 P014 P015 P016 P017 P100 2 (ARDUINO) J13 J9 2 1 3 5 2 RESET 5VIN J4 2 4 6 P010 P009 P008 P007 P006 P005 P018 P001 P000 DETECT J15 1 2ICSP VDD J16 MICRO R10 47R 1/2W C3 47uF / 10V 3 2 1 S1 1 R13 100K GND VDD C 1 2 3 4 5 6 7 8 9 (P10) (P09) (P08) (P07) (P06) (P05) (P21) (P01) (P00) Q4 A42 L1 2 1 5VIN 120OHM 1 1 2 R12 100K 3 4 U2 TCR3DF33 VI VO NC 3 EN GND 3V3 5 4 C5 10uF / 10V 2 5 GND GND C GND GND SW7 pin2-3 off , 1 2 VDD SW7 4 3 1 3 5 7 9 VDD R15 1R 1% GND OFF ON J19 Current meter 1 3 5 7 9 2 4 6 8 10 2 4 6 8 10 SWDIO SWCLK SWO RESET 1 2 3 4 VDD DEBUG - IN JS2 1 2 3 4 CON4 GND A FANSTEL Corporation. 1 2 GND JS1 VDD J19 connect Current meter 3V3 3V3 R14 1K GND GND SW7 pin2-3 on , J20 connect Oscilloscope 3V GND A LED5 Current measurement , SW7 pin1-4 off B C4 10nF C6 10uF / 10V GND 3V 1 2 3 4 5 6 7 8 (D0 RX) (D1 TX) (D2) (D3) (D4) (D5) (D6) (D7) (P11) (P12) (P13) (P14) (P15) (P16) (P17) (P18) J11 R9 1M 1 2 4 J6 1 2 3 4 5 6 (A0) (A1) (A2) (A3) (A4) (A5) 2 GND R11 10K J18 External supply 1 2 J8 P003(P03) P004(P04) P028(P28) P029(P29) P030(P30) P031(P31) D GND GND 5 2 Q3 A92 GND GND GND J7 1 2 3 4 5 6 7 8 9 10 J5 AT_COM BAT-ADC BAT-EN GND 5V 1 RST GND 1 R8 1K 1% C2 12pF nop D- 2 P103 P104 P105 P106 P107 P012 P020 P021 J10 R6 10K A C7 0.1uF 1 P114 J2 P019(P19) (D8) P013(P20) (D9) P022(P22) (D10 SS) P023(P23) (D11 MOSI) P024(P24) (D12 MISO) P025(P25) (D13 SCK) GND P002(P02) (AREF) P026(P26) (SDA) P027(P27) (SCL) J12 D+ NC NC SUSPEND SUSPEND NC RST VBUS 1 5 + R16 10K / 1% (P24) Q2 2N7002/SOT ID DCD RI GND D+ DVDD REGIN 1 3 5 7 9 11 13 15 G NC NC NC NC NC NC NC 2 4 6 8 10 12 14 16 GND 1 2 3 4 5 6 7 8 VDD VDD RESET VDD 5V GND GND P018(P21) 5VIN 5VIN L2 VDD R4 1K R5 10K GND Q1 TP0610T S3 S1 22 23 24 25 26 27 28 29 U3 CP2102 21 20 19 18 17 16 15 J14 3V Battery S4 S2 GND P003(P03) AT_COM J17 mini USB (PC) P108 P109 P110 P111 P112 P113 P114 P115 2 J1 S2 S4 1 2 OFF ON 1 VDD R3 1K A RESET1 VDD R2 1K A 2 4 3 UART_TX UART_RX LED3 (P20) C A LED4 OFF ON C11 4.7uF B P013 GND 1 2 SW5 off , GPIO SW5 on , 32K768Hz OFF ON GND GND 3V3 C1 12pF nop 4 3 LED2 J14 input , J16 off 832X 2 VDDH L3 1 2 1 2 P001(P01) P000(P00) 2 (P19) C C10 DNP SW5 GND SW4 (P18) C P019 1 VDD R1 1K J3 VDD 1 SW8 4 3 VDD 2 P100 GND GND P023 (P23) P019 (P19) P016 (P16) P014 (P14) P101 (P11) P105 P107 P020 P021 P109 D+ DP012 VDDH DCCH VBUS P024 (P24) P022 (P22) P017 (P17) P015 (P15) P102 (P12) P104 P025 (P25) P030 (P30) P031 (P31) P006 (P06) P008 (P08) P103 P028 (P28) P029 (P29) P004 (P04) P005 (P05) P007 (P07) P108 L3 Open , SW8 ON (P16) 1 SWCLK Z0 Z1 Z2 Z3 Z4 Z5 Z6 A0 A1 A2 A3 A4 A5 A6 B0 B1 B2 B3 B4 B5 B6 C0 C1 C2 C3 C4 C5 C6 D0 D1 D2 D3 D4 D5 D6 E0 E1 E2 E3 E4 E5 E6 F4 F5 F6 P111 P112 P113 P114 P115 P110 P106 C P016 SWDIO 15 9 VDD (P15) 1 16 10 GND P10/NFC2 P015 2 SW3 A LED1 S1 S3 2 SW2 (P14) 1 (P17) C 5V 1 P027(P27) P014 F3 P017 GND D- P026(P26) F2 P111 P112 P113 P114 P115 P110 P106 VSS1 P28 P29 P04 P05 P07 P108 VSS2 P25 P30 P31 P06 P08 P103 VSS3 P24 P22 P17 P15 P102_TX P104 VSS4 P23 P19 P16 P14 P101_RX P105 P107 P20 P21 P109 D+ DP12 VDDH DCCH VBUS D F1 2 2 D+ GND F0 GND0 GND1 GND2 GND3 SW1 (P13) 1 ID F0 F1 F2 F3 3 P011 BT840 (832) 3 U1 G 5 Title NRF52832 EVM J20 Oscilloscope 3 1 2 2 Size B Document Number Date: Friday, July 14, 2017 Rev 1.0 BT840(832) EVM (UNO) Sheet 1 of 1 1 Evaluation board can be used as a reference design for using modules. EV BT840F V4 is designed for the BT840F soldering pads with 61 pins. These 21 pins in solid dark color are for BT840F. EV BT840F V4 evaluation board is developed for BT840F and BT832X. It can be used for BT832 and BT832F. Pins in solid color are used only for BT840F. Blue color pin names around U1 BT840(832) are for BT832/ BT832F/BT832X. Red color pin names are for BT840F/BT840/BT840E. Firmware pin configuration is required for a host board to accommodate BT840F/BT840/BT840E and BT832/BT832F/BT832X. Additional feature enhancements for version V4 evaluation board: 1. It has the same foot print as Arduino Uno R3. Additional connectors are added for connection to extra GPIO pins of BlueNor modules. 2. EV BT840F is not an UNO R3 compatible board. You can use Nordic develop tools to develop firmware for many UNO R3 compatible shields. !26 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 3. Portable smartphone charger can be used to power this board. The circuitry to the left of micro USB connector, J16 produces periodic load to prevent portable smartphone charger from shutting down. Suggestion for Battery Power Application Standby current consumption is important for battery-powered product. We suggest adding a 32.768 kHz crystal and 2 capacitors on host board. The 32MHz main clock won’t be active at idle state to save power. Two inductors required for on-board DC to DC converter are inside BT840F. You can enable DCDC converter to have lower power consumption. !27 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 7. Miscellaneous Soldering Temperature-Time Profile for Re-Flow Soldering Maximum number of cycles for re-flow is 2. No opposite side re-flow is allowed due to module weight. Cautions, Design Notes, and Installation Notes Failure to follow the guidelines set forth in this document may result in degrading of the product’s functions and damage to the product. Design Notes (1)Follow the conditions written in this specification, especially the control signals of this module. (2)The supply voltage has to be free of AC ripple voltage (for example from a battery or a low noise regulator output). For noisy supply voltages, provide a decoupling circuit (for example a ferrite in series connection and a bypass capacitor to ground of at least 47uF directly at the module). (3)This product should not be mechanically stressed when installed. (4)Keep this product away from heat. Heat is the major cause of decreasing the life of these products. (5)Avoid assembly and use of the target equipment in conditions where the products' temperature may exceed the maximum tolerance. (6)The supply voltage should not be exceedingly high or reversed. It should not carry noise and/or spikes. !28 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 (7)this product away from other high frequency circuits. Notes on Antenna and PCB Layout (1)Don’t use a module with internal antenna inside a metal case. (2)For PCB layout: • • • Avoid running any signal line below module whenever possible, No ground plane below antenna, If possible, cut-off the portion of main board PCB below antenna. Installation Notes (1)Reflow soldering is possible twice based on the time-temperature profile in this data sheets. Set up the temperature at the soldering portion of this product according to this reflow profile. (2)Carefully position the products so that their heat will not burn into printed circuit boards or affect the other components that are susceptible to heat. (3)Carefully locate these products so that their temperatures will not increase due to the effects of heat generated by neighboring components. (4)If a vinyl-covered wire comes into contact with the products, then the cover will melt and generate toxic gas, damaging the insulation. Never allow contact between the cover and these products to occur. (5)This product should not be mechanically stressed or vibrated when reflowed. (6)If you want to repair your board by hand soldering, please keep the conditions of this chapter. (7)Do not wash this product. (8)Refer to the recommended pattern when designing a board. (9)Pressing on parts of the metal cover or fastening objects to the metal will cause damage to the unit. (10)For more details on LGA (Land Grid Array) soldering processes refer to the application note. Usage Condition Notes (1)Take measures to protect the unit against static electricity. If pulses or other transient loads (a large load applied in a short time) are applied to the products, check and evaluate their operation before assembly on the final products. (2)Do not use dropped products. (3)Do not touch, damage or soil the pins. (4) Follow the recommended condition ratings about the power supply applied to this product. (5)Electrode peeling strength: Do not add pressure of more than 4.9N when soldered on PCB (6) Pressing on parts of the metal cover or fastening objects to the metal cover will cause damage. !29 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 (7) These products are intended for general purpose and standard use in general electronic equipment, such as home appliances, office equipment, information and communication equipment. Storage Notes (1)The module should not be stressed mechanically during storage. (2)Do not store these products in the following conditions or the performance characteristics of the product, such as RF performance will be adversely affected: • Storage in salty air or in an environment with a high concentration of corrosive gas. • Storage in direct sunlight • Storage in an environment where the temperature may be outside the range specified. • Storage of the products for more than one year after the date of delivery storage period. (3) Keep this product away from water, poisonous gas and corrosive gas. (4) This product should not be stressed or shocked when transported. (5) Follow the specification when stacking packed crates (max. 10). Safety Conditions These specifications are intended to preserve the quality assurance of products and individual components. Before use, check and evaluate the operation when mounted on your products. Abide by these specifications, without deviation when using the products. These products may short-circuit. If electrical shocks, smoke, fire, and/or accidents involving human life are anticipated when a short circuit occurs, then provide the following failsafe functions, as a minimum. (1)Ensure the safety of the whole system by installing a protection circuit and a protection device. (2)Ensure the safety of the whole system by installing a redundant circuit or another system to prevent a dual fault causing an unsafe status. Other Cautions (1)This specification sheet is copyrighted. Reproduction of this data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. (2)Do not use the products for other purposes than those listed. (3)Be sure to provide an appropriate failsafe function on your product to prevent an additional damage that may be caused by the abnormal function or the failure of the product. (4)This product has been manufactured without any ozone chemical controlled under the Montreal Protocol. (5)These products are not intended for other uses, other than under the special conditions shown below. Before using these products under such special conditions, check their performance and reliability under the said special conditions carefully to determine whether or not they can be used in such a manner. !30 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 • In liquid, such as water, salt water, oil, alkali, or organic solvent, or in places where liquid may splash. • In direct sunlight, outdoors, or in a dusty environment • In an environment where condensation occurs. • In an environment with a high concentration of harmful gas. (6) If an abnormal voltage is applied due to a problem occurring in other components or circuits, replace these products with new products because they may not be able to provide normal performance even if their electronic characteristics and appearances appear satisfactory. (7) When you have any question or uncertainty, contact Fanstel. !31 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Packaging and Lot Number Production modules are delivered in reel, 1000 modules in each reel. Lot number for modules made after May 2019, can be used to track silicon version of SoC, module PCB version, and production test code version. FCC LABEL The Original Equipment Manufacturer (OEM) must ensure that the OEM modular transmitter must be labeled with its own FCC ID number. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown below. If the FCC ID is not visible when the equipment is installed inside another device, then the outside of the device into which the equipment is installed must also display a label referring to the enclosed equipment The end product with this module may subject to perform FCC part 15 unintentional emission test requirement and be properly authorized. This device is intended for OEM integrator only. !32 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Ver 1.11 May 2019 Revision History • May 2018, Ver. 1.00: Initial release • August 2018, Version 1.10: Add BT840X and BT840XE with update. Add BT840F and BT840 range measurement results. Remove AT commands and refer to external document. • May 2019, Version 1.11: Add BT840X and BT840XE certifications, amplifier control codes, Bluetooth range. !33 BLE 5, Thread, Zigbee Modules, BT840/F/E/X/XE Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com !34 Ver 1.11 May 2019
BT840XE 价格&库存
很抱歉,暂时无法提供与“BT840XE”相匹配的价格&库存,您可以联系我们找货
