BC840
BC840
    FANSTEL
    SMD64
    BC840
BC840 数据手册
BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 BluNor BC840 is a powerful, highly flexible, ultra low power Bluetooth Low Energy (BLE) using Nordic nRF52840 SoC. With an ARM CortexTM M4F MCU, available 1MB flash, 256KB RAM, embedded 2.4GHz multiprotocol transceiver, and an integrated PCB trace antenna. It allows faster time to market with reduced development cost. • BC840 is an ultra compact(7.0x9.0x1.5mm) and ultra short range (10 meters with an Android phone) module for wearable application. • BC832M is compact in size. Its range is measured at 135 meters for 1Mbps data rate. • BC840E is an ultra compact (7.0x12x1.8mm) module with ultra long range (3400 meters at 125 Kbps, Low Multiple Path Interference). Per FCC test reports, the peak TX power with ANT060 antenna is +15.38 dBm. Specifications:
 nRF52840 CKAA, ARM Cortex M4F, 64 MHz ARM® TrustZone® Cryptocell-310 co-processor Complete RF solution with integrated antenna BLE 5 data: 2Mbps,1Mbps,500kbps,125kbps. IEEE 802.15.4 Thread, Zigbee data: 250 Kbps 2.4 GHz proprietary data rate: 2 Mbps, 1 Mbps DC-DC converter, inductors on board. Direct powered by Lithium batteries or USB supply (up to 5.5V) 32 MHz main crystal on board. Serial Wire Debug (SWD) Nordic SoftDevice Ready Over-the-Air (OTA) firmware update Flash/RAM: 1MB/256KB. 48 General purpose I/O pins USB 2.0 full speed (12 Mbps) controller QSPI 32 MHz interface High speed 32 MHz SPI Type 2 NFC-A tag with wake-on field, Touch-topair support Programmable peripheral interconnect (PPI) 12 bit/200 Ksps ADC, 8 configurable channels with programmable gain 64 level comparator 15 level comparator with wake-up from OFF mode Temperature sensor 4x4-channel pulse width modulator (PWM) Audio peripherals: I2S, digital microphone interface (PDM) 5 x 32 bit timers with counter mode Up to 4x SPI masters/3x SPI slaves Up to 2x I2C compatible 2-wire masters/slaves 2x UART (CTS/RTS) Quadrature Demodulator (QDEC) 3x real time counters (RTC) 128-bit AES HW encryption SoC Receiver Sensitivity: -96 dBm at 1Mbps SoC TX power: programmable +8dBm to -20dBm. LGA, 64 pins. Integrated PCB trace antenna Operation voltage: 1.7V to 5.5V Operation temperature: - 4 0 ° C t o + 8 5 ° C QDID: 108621 FCC ID: X8WBC840M IC IC: 4100A-BC840M CE: Certified Japan TELEC: 201-190140 Australia RCM: Certified.
 Model Summaries module SoC Size, mm BT Antenna BT range,1 Mbps, LMPI BT range, 1Mbps, 1.52m BT range, 125 Kbps, LMPI. BT range, 125 kBps, 1.52m Availability BC840 nRF52840-CKAA 7.0x9.0x1.5 PCB trace BC840M nRF52840-CKAA 7.0(10, ant. area)x12.0x1.5 PCB trace 4 meters 135 meters 400 meters 8 meters Production Production !1 BC840E (FCC, IC) nRF52840-CKAA 7.0x12.0x1.5 ANT060 1150 meters 850 meters 3400 meters 1400 meters Production BC840E (CE,RCM,TELEC) nRF52840-CKAA 7.0x12.0x1.5 ANT020 Production BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Table Of Contents 1. Introduction ........................................................................................................................................................3 BC840 Block Diagram ....................................................................................................................................... 3 BC840, ultra compact and ultra short range module for wearable ....................................................................4 BC840M, compact and good range module ......................................................................................................4 BC840E, ultra compact and ultra long range module ........................................................................................4 2. Codes Development Using Nordic Tools ........................................................................................................... 5 Easy, fast and safe code development.............................................................................................................. 5 Over-The-Air DFU .............................................................................................................................................5 SoftDevices ....................................................................................................................................................... 5 Development Tools ............................................................................................................................................5 3. Product Descriptions .........................................................................................................................................6 Block Diagram of nRF52840 .............................................................................................................................6 ARM Trustzone CryptoCell 310 .........................................................................................................................7 Mechanical Drawings ........................................................................................................................................ 9 Pin Assignments of BC840, BC840M, and BC840E........................................................................................ 12 Pin Function..................................................................................................................................................... 13 Mounting BC840 and BC840M on the Host PCB ............................................................................................ 15 Host Board Layout ...........................................................................................................................................15 4. Bluetooth Range Measurements .....................................................................................................................16 Measurement Results...................................................................................................................................... 16 Deployment Recommendations ......................................................................................................................16 5. BC840 Evaluation Board .................................................................................................................................17 Nordic Development Tools............................................................................................................................... 17 Android OS Apps ............................................................................................................................................. 18 iOS Apps..........................................................................................................................................................18 BC840 EvaluationBoard Schematics............................................................................................................... 19 Suggestion for Battery Power Application .......................................................................................................20 6. Production .......................................................................................................................................................21 Preloaded Firmware ........................................................................................................................................21 AT Command Codes ....................................................................................................................................... 21 Soldering Temperature-Time Profile for Re-Flow Soldering ............................................................................ 22 Cautions, Design Notes, and Installation Notes .............................................................................................. 22 Packaging ........................................................................................................................................................ 25 FCC Label ....................................................................................................................................................... 25 Revision History .................................................................................................................................................. 26 7. Contact Us .......................................................................................................................................................27 !2 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 1. Introduction BluNor BC840 Series are powerful, highly flexible, ultra low power wireless modules using Nordic nRF52840 SoCs. With an ARM CortexTM M4F MCU, 1MB flash, 256KB RAM, embedded 2.4GHz multi-protocol transceiver, and an integrated antenna, it allows faster time to market with reduced development cost. The following is a block diagram of BC840. Antenna circuit and main clock are integrated. All 48 GPIOs of nRF52840 can be accessed from main board. For lower power consumption at idle state, a 32.768 kHz crystal can be added on the host board. Connection to an external NFC (Near Field Communication) antenna is provided. BC840 Block Diagram BlueNor BC840M is a sister module of BC840. The physical size is slightly larger to accommodate longer range PCB trace antenna. BC840E is with an u.FL connector for an external antenna. BC840 and BC840M common features: • nRF52840 CKAA with Cortex M4F MCU • 1MB flash, 256 KB RAM • Supports NFC • 64 LGA pins • 48 GPIOs !3 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 BC840, ultra compact and ultra short range module for wearable • At 1Mbps, range is 4 meters between modules and 10 meters with an Android phone. • Size: 7.0x9.0x1.5 mm. BC840M, compact and good range module • Range is 400 meters at 125 Kbps and 135 meters at 1Mbps. • Size: 7.0x12.0x1.5mm. Antenna area width is 10.0mm. BC840E, ultra compact and ultra long range module • With an u.FL connector for external antenna. • Size: 7.0x12.0x1.5 mm. • Certified with Fanstel ANT060 antenna for FCC and IC. • Certified with Fanstel ANT020 antenna for CE, RCM, and TELEC. !4 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 2. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used . Easy, fast and safe code development Nordic development environment for nRF52840 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52840 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum flexibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S140: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. Nordic software development tools can be downloaded from the following webpage. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/development/ nrf52_dev_kit.html&cp=1_1 !5 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 3. Product Descriptions Brief description of nRF52840 SoC is provided. For full description of the SoC, please download from Nordic Semiconductor website. https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy Block Diagram of nRF52840 The following is a block diagram of Nordic nRF52840 Bluetooth Low Energy (BLE) SoC. Arrows with white heads indicate signals that share physical pins with other signals. !6 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 The 32 bit ARM Cortex M4F MCU with hardware supports for DSP instructions and floating point operations, code density and execution speed are higher than other Cortex M MCU. The Programmable Peripheral Interconnect (PPI) system provides a 20-channel bus for direct and autonomous system peripheral communication without CPU intervention. This brings predictable latency times for peripheral to peripheral interaction and power saving benefits associated with leaving CPU idle. The device has 2 global power modes ON/OFF, but all system blocks and peripherals have individual power management control which allows for an automatic switching RUN/IDLE for system blocks based only on those required/not required to achieve particular tasks. The radio supports Bluetooth low energy and ANT. Output power is scalable from a maximum of +8dBm down to -20 dBm in 4dB steps. Sensitivity is increased to -96 dBm to -89 dBm, depending on data rate. Sensitivity for BLE is -96 dBm, and -92.5 dBm for ANT. The NFC block supports NFC-A tags with proximity detection and Wake-on-field from low power mode. The NFC enables Out-Of-Band (OOB) Bluetooth pairing of devices and thus greatly simplifying deployment. ARM Trustzone CryptoCell 310 ARM® TrustZone® CryptoCell-310 co-processor is a security subsystem which provides Root of Trust (RoT) and cryptographic services for a device. CryptoCell services are available to the application through a software library API, not a hardware register interface. !7 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 The following cryptographic features are provided. • FIPS-140-2 certified True Random Number Generator (TRNG) • RSA asymmetric encryption Up to 2048 bit key size PKCS#1 v2.1/v1.5 Optional CRT support • Elliptic curve cryptography (ECC) NIST FIPS 186-4 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-192, P-224, P-256, P-384, P-521 SEC 2 recommended curves using pseudo-random parameters, up to 521 bits: ➢ Prime field: P-160, P-192, P-224, P-256, P-384, P-521 Koblitz curves using fixed parameters, up to 256 bits: ➢ Prime field: P-160, P-192, P-224, P-256 Edwards/Montgomery curves: ➢ Ed25519, Curve 25519 ECDH/ECDSA support • Secure remote password protocol (SRP) Up to 3072 bit operations • Hashing functions SHA-1, SHA-2 up to 256 bit size keyed-hash message authentication code (HMAC) • AES symmetric encryption General purpose AES engine (encrypt/decrypt, sign/verify) 128 bit key size Supported encryption modes: ECB, CBC, CMAC/CBC-MAC, CTR, CCM/CCM*. • ChaCha20/Poly1305 symmetric encryption Supported keyed size: 128 and 256 bits Authenticated encryption with associated data (AEAD) mode !8 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Mechanical Drawings The followings are mechanical drawings of BC840. Size is 7.0x9.0mm. It has 64 LGA pins on a 8x8 matrix, top view of module: !9 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules BC840M mechanical drawings, top view. !10 Ver 1.00, April 2019 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules BC840E technical drawings, top view. !11 Ver 1.00, April 2019 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Pin Assignments of BC840, BC840M, and BC840E The followings are BC840/BC840M/BC820E pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF52840 Product Specifications for detailed descriptions and features supported. https://www.nordicsemi.com/eng/Products/nRF52840 BC840, BC840M, and BC840E pin assignments !12 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Pin Function BC840 52840 CKAA pin# pin# pin name Descriptions A0 J1 P1.01 GPIO A1 K2 P0.25 GPIO A2 K4 P0.19 GPIO A3 J6 P0.17 GPIO A4 K8 D+ USB D+ A5 J8 D- USB D- A6 H9 DCCH DC to DC converter output A7 J10 VDDH High Voltage Power Supply B0 H1 P1.04 GPIO B1 J2 SWDIO Serial Wire Debug Data I/O B2 K3 P0.22 GPIO B3 K7 P0.15 GPIO B4 K6 P0.18 GPIO P0.18/reset B5 J9 VBUS 5V DC power for USB 3.3V regulator B6 F9 P0.07 GPIO B7 G10 P0.12 GPIO C0 G1 P1.07 GPIO C1 H2 SWDCLK Serial Wire Debug clock input C2 J5 P0.20 GPIO C3 J4 P0.21 GPIO C4 J7 P0.14 GPIO C5 G9 P1.08 GPIO C6 F10 P1.09 GPIO C7 E10 P0.08 GPIO D0 J3 P1.00 GPIO D1 G2 P1.05 GPIO D2 F1 P0.09 GPIO, NFC antenna connection D3 H6 P0.16 GPIO D4 H7 P0.13 GPIO D5 H8 P0.11 GPIO D6 D9 P0.27 GPIO, configured as I2C SCL on EV-BC840 D7 E9 P0.06 GPIO E0 F3 P1.03 GPIO E1 E3 P1.06 GPIO E2 E2 P0.10 GPIO, NFC antenna connection E3 C6 P1.15 GPIO E4 C7 P0.29/AIN5 GPIO, analog input 5 E5 C8 P0.31/AIN6 GPIO, analog input 6 E6 C9 P0.26/SDA GPIO, configured as I2C SDA on EV-BC840 E7 C10 P0.04/AIN2 GPIO, analog input 2 F0 H5 P0.23 GPIO !13 Ver 1.00, April 2019 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules F1 H4 P0.24 GPIO F2 G3 P1.02 GPIO F3 C5 P1.12 GPIO F4 B6 P0.02/AIN0 GPIO, analog input 0 F5 B8 VDD DC supply in, 1.7 to 3.6V F6 B9 P0.00/XL1 GPIO, connection for 32.768 kHz sleep crystal F7 B10 P0.01/XL2 GPIO, connection for 32.768 kHz sleep crystal G0 B7 GND Ground G1 A7 P0.30/AIN7 GPIO, analog input 7 G2 A3 P1.11 GPIO G3 A4 P1.13 GPIO G4 GND Ground G5 GND Ground G6 GND Ground G7 D10 P0.05/AIN3 GPIO, analog input 3 H0 A5 P0.03/AIN1 GPIO, analog input 1 H1 A6 P0.28/AIN4 GPIO, analog input 4 H2 B4 P1.10 GPIO H3 B5 P1.14 GPIO H4 GND Ground F5 GND Ground H6 GND Ground H7 GND Ground !14 Ver 1.00, April 2019 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Mounting BC840 and BC840M on the Host PCB The following figure shows recommended mounting of BC840 and BC840M module on the host PCB. • For the best Bluetooth range performance, the antenna area of BC840M module shall extend 5.5 mm outside the edge of host PCB board, or 5.5 mm outside the edge of a ground plane. • For the best Bluetooth range performance, the antenna area of BC840 module shall extend 2.5 mm outside the edge of host PCB board, or 2.5 mm outside the edge of a ground plane. • The next choice is to place BC840M on a corner of host PCB, the antenna area shall extend 5.5 mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • The next choice is to place BC840 on a corner of host PCB, the antenna area shall extend 2.5 mm from the edge of ground plane. Ground plane shall be at least 5 mm from the edge of the antenna area of module. • We don’t recommend mounting BC840 module in the middle of a host PCB. For the best Bluetooth range performance, keep all external metal at least 30mm from the antenna area. Host Board Layout Library components for some PCB layout software are available. Or, it can be extracted from EV-BC840 evaluation board Gerber files. Gerber files can be downloaded from: http://www.fanstel.com/download-document/. !15 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 4. Bluetooth Range Measurements Bluetooth range measurement hex codes can be downloaded from Bluetooth Range Measurements section of this webpage. http://www.fanstel.com/download-document/ Description of measurement site, measurement methods, and range raw data are available at: https://www.fanstel.com/testreport/ Measurement Results Bluetooth ranges are measured for antennas at two heights. • 1.52 meters or 5 feet, the typical height of thermostat in the USA. • Low Multiple Path Interference (LMPI) or 60% Fresnel zone clearance. Data rate/Antenna height, meters BC840 BC840M 1Mbps/1.52 meters, between modules 4 125Kbps/1.52 meters, between modules 8 135 BC840EANT060* BC840EANT020 850 1400 1Mbps/LMPI, between modules 1150 125Kbps/LMPI, between modules 400 1Mbps/1.52 meters with an Android phone 3400 10 * Because of availability of nRF52840 CKAA SoC, Bluetooth range is measured from BC840E-ANT060 to BT840E-ANT060. Ranges will be re-measured between two BC840Es when additional SoCs are received. Deployment Recommendations Sizes of modules of BC840 Series are similar. Measured ranges are from 4 meters to 1150 meters at 1Mbps. Different applications are targeted. • To have the best Bluetooth data reception, direct line of sight between 2 devices should be away from ground or wall. • BC840 is an ultra short range module for wearable applications. • With larger PCB trace antenna, BC840M range is 400 meters at 125 Kbps. It can be used in a wide range of applications, wearable, home automation, beacon, medical devices etc.. • Peak TX for BC840E with ANT060 is 15.38 dBm and range is measured at 3400 meters at 125 Kbps. It is an ideal module for long range, battery powered applications. • If one device must be installed closer to ground or a wall, install other devices far away from a wall or ground. • Indoor condition is different for different building. We suggest testing Bluetooth data reception in the building with the worst case condition. • B840 Series modules have compatible soldering pad footprint. Bluetooth range can be upgraded by replacing module. No hardware change to the host board is required if your enclosure can accommodate the longer module. !16 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 5. BC840 Evaluation Board An evaluation board consists of the followings: • Mini USB cable • Evaluation board • 10-conductor cable for connection to Nordic nRF52 DK (DK is not included) Nordic Development Tools A Nordic nRF52840 DK is recommended for programming this evaluation board. Nordic development tools can be downloaded from: https://www.nordicsemi.com/eng/Products/nRF52840 Many application examples can be downloaded from Nordic website. Some firmware, Android OS, and iOS app codes can be downloaded from Bluetooth 5 Codes section of this Fanstel webpage. http://www.fanstel.com/download-document/ !17 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 BT840 firmware can be used in all nRF52840 modules, e.g., BT840, BT840F, BT840E, BC840, and BC840M. Android OS Apps The following Android OS apps are available for download from Google Play Store:
 BlueNor nrf5x: to use with Bluetooth 5 stacks, AT commands, or Slave firmware. Master firmware does not connect to a smartphone. Source codes can be downloaded from http://www.fanstel.com/download-document/ BlueNor Mesh: to use with BlueNor mesh firmware to send command to any node in a mesh. Node number is displayed when acknowledgement is received. Source codes will be uploaded to Fanstel website when supporting Bluetooth 5. iOS Apps The following iOS apps can be downloaded from Apple APP Store. BlueNor Mesh: to use with BlueNor mesh firmware to send command to any node in a mesh. Node number is displayed when acknowledgement is received.
 BlueNor nrf5x firmware, apps, and source codes will be uploaded when ready. !18 P109 P008 P027 P006 P026 P004 P000/XL1 P001/XL2 B6 B7 A7 21 20 19 18 17 16 15 GND VDD D2 D3 D4 D5 D6 D7 C2 C3 C4 C5 C6 C7 F1 F2 F3 F4 F5 F6 F7 E1 E2 E3 E4 E5 E6 E7 L3 10uH DCCH G7 G6 G5 G4 G3 G2 G1 G0 GND GND 5 GND C8 1uF 1 2 3 4 5 6 7 CP2102 U3 1 2 GND C9 0.1uF GND + 5VIN CT1 10uF/10V 2 P1.02 P1.01 120OHM 1 L2 UART_TX UART_RX GND P1.03 P1.06 P0.10 P1.15 P0.29 P0.31 E0 E1 E2 E3 E4 E5 P0.01 P0.00 P0.23 P0.24 P1.02 P1.12 P0.02 VDD F0 F1 F2 F3 F4 F5 4 1 2 3 4 5 J17 mini USB (PC) P103 P106 P010 P115 P029 P031 P023 P024 P102 P112 P002 VDD GND 5V C7 0.1uF RST SW6 OFF ON DCD RI GND D+ DVDD REGIN 4 3 H7 H6 H5 H4 H3 H2 H1 H0 D- GND NC NC NC NC NC NC NC 1 2 D1 C1 F0 E0 Current measurement , SW6 all off OFF ON SW8 D0 C0 P0.03 P0.28 P1.10 P1.14 H0 H1 H2 H3 H4 H5 H6 H7 D+ R16 10K / 1% GND C11 4.7uF VDDH 4 3 B5 B4 B3 A6 L3,SW8 ON for Dongle C6 C7 D6 D7 E6 E7 F6 F7 P1.09 P0.08 P0.27 P0.06 P0.26 P0.04 P0.00 P0.01 A5 P104 SWDIO A3 P022 P015 P018/RESET A4 VBUS P007 P012 B2 B1 A1 A2 B0 A0 P003 P028 P110 P114 VSS VSS VSS VSS 4 ID A B C B0 B1 B2 B3 B4 B5 B6 B7 P1.04 SWDIO P0.22 P0.15 P0.18 VBUS P0.07 P0.12 22 23 24 25 26 27 28 29 OFF ON SW5 4 3 AT_COM SW4 SW3 SW2 3 2 2 2 2 GND GND GND GND GND 2 S1 R11 10K 1 3 C2 12pF NP0 GND GND R6 10K GND Y1 32.768KHz C1 12pF NP0 BAT-EN J14 3V Battery 1 2 GND R8 1K 1% BAT-ADC R7 3.01K R13 100K C3 47uF / 10V Q3 A92 1 Not Installed GND Q2 2N7002/SOT R5 10K 3V3 C C C C Q1 TP0610T P0.13 P0.19 P1.00 P0.17 1 2 3V J18 GND External supply 3V J19 Current meter 1 2 3 1 2 OFF ON SW7 J20 Oscilloscope 3V3 1 2 4 3 VDD J19 connect Current meter SW7 pin2-3 on , J20 connect Oscilloscope SW7 pin2-3 off , P1.08 P1.09 P1.10 P1.11 P1.12 P1.13 P1.14 P1.15 LED4 LED3 LED2 LED1 Q4 A42 R15 1R 1% VDD 2 4 6 8 10 12 14 16 A A A A R10 47R 1/2W GND Current measurement , SW7 pin1-4 off P0.03 VDD 1 1 1 1 SW1 J14 input , J16 off SW5 off , GPIO SW5 on , 32K768Hz 1 2 GND P0.16 P0.15 P0.14 P0.11 2 U1 P100 P105 P009 P016 P013 P011 P101 P025 P019 P017 D+ DDCCH VDDH P107 SWDCLK P020 P021 P014 P108 NC CTS RTS RXD TXD DSR DTR GND 1 D A0 A1 A2 A3 A4 A5 A6 A7 P1.01 P0.25 P0.19 P0.17 D+ DDCCH VDDH P0.30 P1.11 P1.13 D0 D1 D2 D3 D4 D5 SWO P1.00 P1.05 P0.09 P0.16 P0.13 P0.11 VSS P030 P111 P113 VSS VSS VSS P005 G0 G1 G2 G3 G4 G5 G6 G7 P0.05 C0 C1 C2 C3 C4 C5 P1.07 SWCLK P0.20 P0.21 P0.14 P1.08 NC NC SUSPEND SUSPEND NC RST VBUS G 14 13 12 11 10 9 8 S4 S2 S3 S1 3 2 1 3 5 7 9 11 13 15 J21 GND GND 5 3 GND 2 1 2 1 3 5 7 9 GND 2 4 6 8 10 2 4 6 8 10 NC GND VDD GND EN VO J5 2 4 5 GND 1 2 3 4 5 6 J1 1 2 3 4 JS2 1 2 3 4 Tuesday, September 04, 2018 Date: BC840 EV BC840 Document Number GND R14 1K GND C5 10uF / 10V 3V3 A C4 10nF LED5 1 Sheet 1 1 2 3 4 5 6 7 8 J6 J2 VTG of R17 1K 1 1 2 3 4 5 6 7 8 9 1 2 3 4 5 J4 Rev 1.2 JS3 3V3 (ARDUINO) (D0 RX) (D1 TX) (D2) (D3) (D4) (D5) (D6) (D7) (D8) (D9) (D10 (D11 (D12 (D13 1 2 SS) 3 MOSI) 4 MISO) 5 SCK) 6 7 GND (AREF) 8 (SDA) 9 (SCL) 10 P0.10 P0.09 P0.08 P0.07 P0.06 P0.05 P0.18 P0.01 P0.00 P1.01 P1.02 P0.11 P0.14 P0.15 P0.16 P0.17 P1.00 P0.02 P0.26 P0.27 P0.19 P0.13 P0.22 P0.23 P0.24 P0.25 1 Not Installed C GND GND FANSTEL Corporation. RESET SWDIO SWCLK SWO 3 VI U2 TCR3DF33 5VIN (A0) (A1) (A2) (A3) (A4) (A5) 1 2 3 4 5 6 7 8 2 Size B Title DEBUG - IN 1 3 5 7 9 JS1 1 120OHM L1 RESET1 VDD VDD RESET VDD 5V GND GND VDD 1 5VIN VDD C6 10uF / 10V 2 R9 1M 1 P0.03 P0.04 P0.28 P0.29 P0.30 P0.31 DETECT 4 GND 2ICSP 2 4 6 R12 100K J15 1 3 5 J13 AT_COM BAT-ADC BAT-EN 5VIN P0.18 2 1 VDD GND 1 P1.03 P1.04 P1.05 P1.06 P1.07 P0.12 P0.20 P0.21 VDD VDD VDD VDD 2 P1.15 RESET P1.14 P1.13 J16 MICRO GND J3 R4 1K R3 1K R2 1K R1 1K S1 S3 5V DD+ ID G !19 S2 S4 5 A B C D BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 BC840 EvaluationBoard Schematics BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Evaluation board can be used as a reference design for using modules.. Suggestion for Battery Power Application Standby current consumption is important for battery-powered product. We suggest adding a 32.768 kHz crystal and 2 capacitors on host board. The 32MHz main clock won’t be active at idle state to save power. Two inductors required for on-board DC to DC converter are inside BC840 and BC840M. You can enable DCDC converter to have lower power consumption. !20 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 6. Production Preloaded Firmware Production testing codes are not erased before shipping from factory. To load your firmware, please erase the entire chip and re-program using instruction below. //program BT840 Bootloader+Softdevice+Application hex nrfjprog -f NRF52 --program BT840_AT_3in1PC181113.hex --chiperase --reset //The file BT840_AT_3in1PC181113.hex = softdevice S140v6.1.1+BT840_AT_UARTwithout32K+bootloader AT Command Codes AT command codes are used for production testing. Up to date codes can be downloaded from: https://www.fanstel.com/download-document/ You can erase and reprogram with your codes. Or, use AT command codes as preloaded. If you need a special version of codes, programming services are available with MOQ and programming charges. !21 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 Soldering Temperature-Time Profile for Re-Flow Soldering Maximum number of cycles for re-flow is 2. No opposite side re-flow is allowed due to module weight. Cautions, Design Notes, and Installation Notes Failure to follow the guidelines set forth in this document may result in degrading of the product’s functions and damage to the product. Design Notes (1)Follow the conditions written in this specification, especially the control signals of this module. (2)The supply voltage has to be free of AC ripple voltage (for example from a battery or a low noise regulator output). For noisy supply voltages, provide a decoupling circuit (for example a ferrite in series connection and a bypass capacitor to ground of at least 47uF directly at the module). (3)This product should not be mechanically stressed when installed. (4)Keep this product away from heat. Heat is the major cause of decreasing the life of these products. (5)Avoid assembly and use of the target equipment in conditions where the products' temperature may exceed the maximum tolerance. (6)The supply voltage should not be exceedingly high or reversed. It should not carry noise and/or spikes. (7)this product away from other high frequency circuits. Notes on Antenna and PCB Layout (1)Don’t use a module with internal antenna inside a metal case. (2)For PCB layout: !22 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules • • • Ver 1.00, April 2019 Avoid running any signal line below module whenever possible, No ground plane below antenna, If possible, cut-off the portion of main board PCB below antenna. Installation Notes (1)Reflow soldering is possible twice based on the time-temperature profile in this data sheets. Set up the temperature at the soldering portion of this product according to this reflow profile. (2)Carefully position the products so that their heat will not burn into printed circuit boards or affect the other components that are susceptible to heat. (3)Carefully locate these products so that their temperatures will not increase due to the effects of heat generated by neighboring components. (4)If a vinyl-covered wire comes into contact with the products, then the cover will melt and generate toxic gas, damaging the insulation. Never allow contact between the cover and these products to occur. (5)This product should not be mechanically stressed or vibrated when reflowed. (6)If you want to repair your board by hand soldering, please keep the conditions of this chapter. (7)Do not wash this product. (8)Refer to the recommended pattern when designing a board. (9)Pressing on parts of the metal cover or fastening objects to the metal will cause damage to the unit. (10)For more details on LGA (Land Grid Array) soldering processes refer to the application note. Usage Condition Notes (1)Take measures to protect the unit against static electricity. If pulses or other transient loads (a large load applied in a short time) are applied to the products, check and evaluate their operation before assembly on the final products. (2)Do not use dropped products. (3)Do not touch, damage or soil the pins. (4) Follow the recommended condition ratings about the power supply applied to this product. (5)Electrode peeling strength: Do not add pressure of more than 4.9N when soldered on PCB (6) Pressing on parts of the metal cover or fastening objects to the metal cover will cause damage. (7) These products are intended for general purpose and standard use in general electronic equipment, such as home appliances, office equipment, information and communication equipment. Storage Notes (1)The module should not be stressed mechanically during storage. !23 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Ver 1.00, April 2019 (2)Do not store these products in the following conditions or the performance characteristics of the product, such as RF performance will be adversely affected: • Storage in salty air or in an environment with a high concentration of corrosive gas. • Storage in direct sunlight • Storage in an environment where the temperature may be outside the range specified. • Storage of the products for more than one year after the date of delivery storage period. (3) Keep this product away from water, poisonous gas and corrosive gas. (4) This product should not be stressed or shocked when transported. (5) Follow the specification when stacking packed crates (max. 10). Safety Conditions These specifications are intended to preserve the quality assurance of products and individual components. Before use, check and evaluate the operation when mounted on your products. Abide by these specifications, without deviation when using the products. These products may short-circuit. If electrical shocks, smoke, fire, and/or accidents involving human life are anticipated when a short circuit occurs, then provide the following failsafe functions, as a minimum. (1)Ensure the safety of the whole system by installing a protection circuit and a protection device. (2)Ensure the safety of the whole system by installing a redundant circuit or another system to prevent a dual fault causing an unsafe status. Other Cautions (1)This specification sheet is copyrighted. Reproduction of this data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. (2)Do not use the products for other purposes than those listed. (3)Be sure to provide an appropriate failsafe function on your product to prevent an additional damage that may be caused by the abnormal function or the failure of the product. (4)This product has been manufactured without any ozone chemical controlled under the Montreal Protocol. (5)These products are not intended for other uses, other than under the special conditions shown below. Before using these products under such special conditions, check their performance and reliability under the said special conditions carefully to determine whether or not they can be used in such a manner. • In liquid, such as water, salt water, oil, alkali, or organic solvent, or in places where liquid may splash. • In direct sunlight, outdoors, or in a dusty environment • In an environment where condensation occurs. !24 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules • Ver 1.00, April 2019 In an environment with a high concentration of harmful gas. (6) If an abnormal voltage is applied due to a problem occurring in other components or circuits, replace these products with new products because they may not be able to provide normal performance even if their electronic characteristics and appearances appear satisfactory. (7) When you have any question or uncertainty, contact Fanstel. Packaging Production modules are delivered in reel, 1000 modules in each reel. FCC LABEL The Original Equipment Manufacturer (OEM) must ensure that the OEM modular transmitter must be labeled with its own FCC ID number. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown below. If the FCC ID is not visible when the equipment is installed inside another device, then the outside of the device into which the equipment is installed must also display a label referring to the enclosed equipment The end product with this module may subject to perform FCC part 15 unintentional emission test requirement and be properly authorized. This device is intended for OEM integrator only. !25 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules Revision History • September 2018 Version 0.20: initial draft release. • April 2019, Version 1.00: Initial release. !26 Ver 1.00, April 2019 BC840/M/E, Compact BLE 5, Thread, Zigbee Modules 7. Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com !27 Ver 1.00, April 2019
BC840 价格&库存
很抱歉,暂时无法提供与“BC840”相匹配的价格&库存,您可以联系我们找货
