Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
PDTC144T series
NPN resistor-equipped transistors;
R1 = 47 kΩ, R2 = open
Product data sheet
Supersedes data of 2004 Apr 06
2004 Aug 17
NXP Semiconductors
Product data sheet
FEATURES
PDTC144T series
QUICK REFERENCE DATA
• Built-in bias resistors
SYMBOL
• Simplified circuit design
VCEO
• Reduction of component count
• Reduced pick and place costs.
APPLICATIONS
PARAMETER
TYP.
MAX.
UNIT
collector-emitter
voltage
50
V
IO
output current (DC)
100
mA
R1
bias resistor
47
kΩ
R2
open
• General purpose switching and amplification
• Inverter and interface circuits
DESCRIPTION
• Circuit driver.
NPN resistor-equipped transistor (see “Simplified outline,
symbol and pinning” for package details).
PRODUCT OVERVIEW
PACKAGE
TYPE NUMBER
MARKING CODE
PNP COMPLEMENT
PHILIPS
EIAJ
PDTC144TE
SOT416
SC-75
43
PDTA144TE
PDTC144TEF
SOT490
SC-89
33
PDTA144TEF
PDTC144TK
SOT346
SC-59
53
PDTA144TK
PDTC144TM
SOT883
SC-101
E4
PDTA144TM
PDTC144TS
SOT54 (TO-92)
SC-43
TC144T
PDTA144TS
PDTC144TT
SOT23
*41(1)
PDTA144TT
PDTC144TU
SOT323
SC-70
*41(1)
PDTA144TU
Note
1. * = p: Made in Hong Kong.
* = t: Made in Malaysia.
* = W: Made in China.
2004 Aug 17
2
NXP Semiconductors
Product data sheet
PDTC144T series
SIMPLIFIED OUTLINE, SYMBOL AND PINNING
PINNING
TYPE NUMBER
SIMPLIFIED OUTLINE AND SYMBOL
PIN
PDTC144TS
handbook, halfpage
2
1
DESCRIPTION
1
base
2
collector
3
emitter
1
base
2
emitter
3
collector
1
base
2
emitter
3
collector
R1
1
2
3
3
MAM361
PDTC144TE
PDTC144TEF
PDTC144TK
handbook, halfpage
3
3
R1
PDTC144TT
1
PDTC144TU
2
2
1
Top view
MDB270
PDTC144TM
handbook, halfpage
3
R1
2
1
3
1
2
Bottom view
MHC507
2004 Aug 17
3
NXP Semiconductors
Product data sheet
PDTC144T series
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
NAME
DESCRIPTION
VERSION
PDTC144TE
plastic surface mounted package; 3 leads
SOT416
PDTC144TEF
SOT490
PDTC144TK
SOT346
PDTC144TM
leadless ultra small plastic package; 3 solder lands; body
1.0 × 0.6 × 0.5 mm
SOT883
PDTC144TS
plastic single-ended leaded (through hole) package; 3 leads
SOT54
PDTC144TT
SOT23
PDTC144TU
SOT323
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCBO
collector-base voltage
open emitter
50
V
VCEO
collector-emitter voltage
open base
50
V
VEBO
emitter-base voltage
open collector
5
V
IO
output current (DC)
100
mA
ICM
peak collector current
100
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
SOT54
note 1
500
mW
SOT23
note 1
250
mW
SOT346
note 1
250
mW
SOT323
note 1
200
mW
SOT490
notes 1 and 2
250
mW
SOT883
notes 2 and 3
250
mW
SOT416
note 1
150
mW
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
operating ambient temperature
−65
+150
°C
Notes
1. Refer to standard mounting conditions.
2. Reflow soldering is the only recommended soldering method.
3. Refer to SOT883 standard mounting conditions; FR4 with 60 μm copper strip line.
2004 Aug 17
4
NXP Semiconductors
Product data sheet
PDTC144T series
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
Rth(j-a)
CONDITIONS
thermal resistance from junction to ambient
VALUE
UNIT
in free air
SOT54
note 1
250
K/W
SOT23
note 1
500
K/W
SOT346
note 1
500
K/W
SOT323
note 1
625
K/W
SOT490
notes 1 and 2
500
K/W
SOT883
notes 2 and 3
500
K/W
SOT416
note 1
833
K/W
Notes
CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
PARAMETER
CONDITIONS
MIN.
TYP.
MAX.
UNIT
ICBO
collector-base cut-off current
VCB = 50 V; IE = 0 A
100
nA
ICEO
collector-emitter cut-off current
VCE = 30 V; IB = 0 A
1
μA
VCE = 30 V; IB = 0 A; Tj = 150 °C
50
μA
nA
IEBO
emitter-base cut-off current
VEB = 5 V; IC = 0 A
100
hFE
DC current gain
VCE = 5 V; IC = 1 mA
100
VCEsat
collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA
150
mV
R1
input resistor
33
47
61
kΩ
Cc
collector capacitance
2.5
pF
2004 Aug 17
IE = ie = 0 A; VCB = 10 V;
f = 1 MHz
5
NXP Semiconductors
Product data sheet
PDTC144T series
PACKAGE OUTLINES
Plastic surface-mounted package; 3 leads
SOT490
D
E
B
A
X
HE
v M A
3
A
1
c
2
e1
bp
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
bp
c
D
E
e
e1
HE
Lp
v
w
mm
0.8
0.6
0.33
0.23
0.2
0.1
1.7
1.5
0.95
0.75
1.0
0.5
1.7
1.5
0.5
0.3
0.1
0.1
OUTLINE
VERSION
SOT490
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
SC-89
6
EUROPEAN
PROJECTION
ISSUE DATE
05-07-28
06-03-16
NXP Semiconductors
Product data sheet
PDTC144T series
SOT346
E
D
A
B
X
HE
v M A
3
Q
A
A1
1
c
2
e1
bp
Lp
w M B
e
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.3
1.0
0.1
0.013
0.50
0.35
0.26
0.10
3.1
2.7
1.7
1.3
1.9
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
OUTLINE
VERSION
SOT346
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
TO-236
SC-59A
7
EUROPEAN
PROJECTION
ISSUE DATE
04-11-11
06-03-16
NXP Semiconductors
Product data sheet
PDTC144T series
Leadless ultra small plastic package; 3 solder lands; body 1.0 x 0.6 x 0.5 mm
L
SOT883
L1
2
b
3
e
b1
1
e1
A
A1
E
D
1 mm
scale
UNIT
A (1)
A1
max.
b
b1
D
E
e
e1
L
L1
mm
0.50
0.46
0.03
0.20
0.12
0.55
0.47
0.62
0.55
1.02
0.95
0.35
0.65
0.30
0.22
0.30
0.22
Note
1. Including plating thickness
OUTLINE
VERSION
SOT883
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
SC-101
8
EUROPEAN
PROJECTION
ISSUE DATE
03-02-05
03-04-03
NXP Semiconductors
Product data sheet
PDTC144T series
Plastic single-ended leaded (through hole) package; 3 leads
SOT54
c
E
d
A
L
b
1
e1
2
D
e
3
b1
L1
5 mm
scale
UNIT
A
b
b1
c
D
d
E
mm
5.2
5.0
0.48
0.40
0.66
0.55
0.45
0.38
4.8
4.4
1.7
1.4
4.2
3.6
e
2.54
e1
L
L1(1)
1.27
14.5
12.7
2.5
max.
Note
1. Terminal dimensions within this zone are uncontrolled to allow for flow of plastic and terminal irregularities.
OUTLINE
VERSION
SOT54
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
TO-92
SC-43A
9
EUROPEAN
PROJECTION
ISSUE DATE
04-06-28
04-11-16
NXP Semiconductors
Product data sheet
PDTC144T series
SOT23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
bp
c
w M B
Lp
e
detail X
2 mm
scale
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
OUTLINE
VERSION
SOT23
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
TO-236AB
10
NXP Semiconductors
Product data sheet
PDTC144T series
SOT323
D
E
B
A
X
HE
y
v M A
3
Q
A
A1
c
1
2
e1
bp
Lp
w M B
e
detail X
2 mm
scale
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.8
0.1
0.4
0.3
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
SOT323
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
SC-70
11
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
NXP Semiconductors
Product data sheet
PDTC144T series
SOT416
D
E
B
A
X
HE
v M A
3
Q
A
1
A1
2
e1
c
bp
w M B
Lp
e
detail X
1 mm
scale
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
0.95
0.60
0.1
0.30
0.15
0.25
0.10
1.8
1.4
0.9
0.7
1
0.5
1.75
1.45
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
SOT416
2004 Aug 17
REFERENCES
IEC
JEDEC
JEITA
SC-75
12
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
NXP Semiconductors
Product data sheet
PDTC144T series
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
DISCLAIMERS
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2004 Aug 17
13
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal
definitions and disclaimers. No changes were made to the technical content, except for package outline
drawings which were updated to the latest version.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R75/05/pp14
Date of release: 2004 Aug 17
Document order number: 9397 750 13679
