PDTC114YQAZ
PDTC114YQAZ
    NEXPERIA(安世)
    DFN1010D-3
    配备50 V、100 mA NPN电阻器的晶体管
PDTC114YQAZ 数据手册
PDTC143X/123J/143Z/114YQA series 50 V, 100 mA NPN resistor-equipped transistors Rev. 1 — 30 October 2015 Product data sheet 1. Product profile 1.1 General description 100 mA NPN Resistor-Equipped Transistor (RET) family in a leadless ultra small DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. Table 1. Product overview Type number R1 R2 Nexperia PNP complement PDTC143XQA 4.7 k 10 k PDTA143XQA PDTC123JQA 2.2 k 47 k DFN1010D-3 (SOT1215) PDTC143ZQA 4.7 k 47 k PDTA143ZQA PDTC114YQA 10 k 47 k PDTA114YQA PDTA123JQA 1.2 Features and benefits     100 mA output current capability Built-in bias resistors Simplifies circuit design Reduces component count     Reduced pick and place costs Low package height of 0.37 mm AEC-Q101 qualified Suitable for Automatic Optical Inspection (AOI) of solder joint 1.3 Applications  Digital applications  Cost saving alternative for BC847/BC857 series in digital applications  Controlling IC inputs  Switching loads 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 50 V IO output current - - 100 mA PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 2. Pinning information Table 3. Pinning Pin Symbol Description 1 I input (base) 2 GND GND (emitter) Simplified outline Graphic symbol O 1 3 O output (collector) 4 O output (collector) R1 I 4 3 R2 GND 2 aaa-019964 Transparent top view 3. Ordering information Table 4. Ordering information Type number PDTC143XQA PDTC123JQA PDTC143ZQA Package Name Description Version DFN1010D-3 plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body: 1.1  1.0  0.37 mm SOT1215 PDTC114YQA PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 2 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 4. Marking Table 5. Marking codes Type number Marking code PDTC143XQA 11 11 01 PDTC123JQA 10 11 11 PDTC143ZQA 11 00 11 PDTC114YQA 11 10 01 4.1 Binary marking code description READING DIRECTION MARKING CODE (EXAMPLE) YEAR DATE CODE VENDOR CODE PIN 1 INDICATION MARK MARK-FREE AREA READING EXAMPLE: 11 01 10 aaa-008041 Fig 1. SOT1215 binary marking code description 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). PDTC143X_123J_143Z_114YQA_SER Product data sheet Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 50 V VEBO emitter-base voltage PDTC143XQA - 7 V PDTC123JQA - 5 V PDTC143ZQA - 5 V PDTC114YQA - 6 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 3 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VI input voltage PDTC143XQA 7 +30 V PDTC123JQA 5 +12 V PDTC143ZQA 5 +30 V PDTC114YQA 6 +40 V output current IO Tamb  25 C total power dissipation Ptot - 100 mA [1] - 280 mW [2] - 440 mW Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. aaa-017637 500 Ptot (mW) (1) 400 300 (2) 200 100 0 -75 -25 25 75 125 175 Tamb (°C) (1) FR4 PCB, 4-layer copper, standard footprint (2) FR4 PCB, standard footprint Fig 2. PDTC143X_123J_143Z_114YQA_SER Product data sheet Power derating curves All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 4 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air Min Typ Max Unit [1] - - 446 K/W [2] - - 284 K/W [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, 4-layer copper, tin-plated and standard footprint. aaa-017638 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.50 102 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, single-sided copper, tin-plated and standard footprint Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-017639 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.50 0.33 0.20 0.10 0.05 10 0.02 0 0.01 1 10-5 10-4 10-3 10-2 10-1 1 10 102 103 tp (s) FR4 PCB, 4-layer copper, tin-plated and standard footprint. Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 5 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 7. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 50 V; IE = 0 A - - 100 nA ICEO collector-emitter cut-off VCE = 30 V; IB = 0 A current VCE = 30 V; IB = 0 A; Tj = 150 C - - 1 A - - 5 A IEBO emitter-base cut-off current - - 600 A PDTC123JQA - - 180 A PDTC143ZQA - - 170 A PDTC114YQA - - 150 A PDTC143XQA hFE VCEsat VI(off) DC current gain PDTC143XQA VCE = 5 V; IC = 10 mA 50 - - PDTC123JQA VCE = 5 V; IC = 10 mA 100 - - PDTC143ZQA VCE = 5 V; IC = 10 mA 100 - - PDTC114YQA VCE = 5 V; IC = 5 mA 100 - - collector-emitter saturation voltage PDTC143XQA IC = 10 mA; IB = 0.5 mA - - 100 mV PDTC123JQA IC = 5 mA; IB = 0.25 mA - - 100 mV PDTC143ZQA IC = 5 mA; IB = 0.25 mA - - 100 mV PDTC114YQA IC = 5 mA; IB = 0.25 mA - - 100 mV VCE = 5 V; IC = 100 A - 0.8 0.3 V off-state input voltage PDTC143XQA VI(on) R1 VEB = 5 V; IC = 0 A PDTC123JQA - 0.6 0.5 V PDTC143ZQA - 0.6 0.5 V PDTC114YQA - 0.7 0.5 V on-state input voltage PDTC143XQA VCE = 0.3 V; IC = 20 mA 2.5 1.5 - V PDTC123JQA VCE = 0.3 V; IC = 5 mA 1.1 0.75 - V PDTC143ZQA VCE = 0.3 V; IC = 5 mA 1.3 0.9 - V PDTC114YQA VCE = 0.3 V; IC = 1 mA 1.4 0.8 - V [1] bias resistor 1 (input) PDTC143XQA 3.3 4.7 6.1 k PDTC123JQA 1.54 2.2 2.86 k PDTC143ZQA 3.3 4.7 6.1 k PDTC114YQA 7 10 13 k PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 6 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors Table 8. Characteristics …continued Tamb = 25 C unless otherwise specified. Symbol R2/R1 Cc fT Parameter Conditions Min Typ Max PDTC143XQA 1.7 2.1 2.6 PDTC123JQA 17 21 26 PDTC143ZQA 8 10 12 PDTC114YQA 3.7 4.7 5.7 - - 2.5 pF - 230 - MHz bias resistor ratio collector capacitance transition frequency VCB = 10 V; IE = ie = 0 A; f = 1 MHz VCE = 5 V; IC = 10 mA; f = 100 MHz [1] See Section 8 “Test information” for resistor calculation and test conditions. [2] Characteristics of built-in transistor. PDTC143X_123J_143Z_114YQA_SER Product data sheet Unit [1] All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 [2] © Nexperia B.V. 2017. All rights reserved 7 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac841 103 (1) 0.70 mA 0.63 mA 0.56 mA 0.49 mA IC (A) (2) hFE aaa-018579 0.1 (3) 0.08 0.42 mA 102 0.35 mA 0.06 0.28 mA 0.04 0.21 mA 10 0.14 mA 0.02 IB = 0.07 mA 1 10-1 1 0 102 10 0 1 2 3 4 IC (mA) 5 VCE (V) Tamb = 25 C VCE = 5 V (1) Tamb = 100 C (2) Tamb = 25 C (3) Tamb = 40 C Fig 5. PDTC143XQA: DC current gain as a function of collector current; typical values Fig 6. 006aac842 1 PDTC143XQA: Collector current as a function of collector-emitter voltage; typical values 006aac843 10 VI(on) (V) VCEsat (V) (1) (1) (2) (3) 10-1 (2) 1 (3) 10-2 1 102 10 10-1 10-1 1 102 10 IC (mA) IC (mA) IC/IB = 20 VCE = 0.3 V (1) Tamb = 100 C (1) Tamb = 40 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 40 C (3) Tamb = 100 C Fig 7. PDTC143XQA: Collector-emitter saturation voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 8. PDTC143XQA: On-state input voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 8 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac844 10 006aac845 3 Cc (pF) VI(off) (V) 2 (1) 1 (2) (3) 1 10-1 10-1 0 1 10 0 10 20 30 40 50 VCB (V) IC (mA) f = 1 MHz; Tamb = 25 C VCE = 5 V (1) Tamb = 40 C (2) Tamb = 25 C (3) Tamb = 100 C Fig 9. PDTC143XQA: Off-state input voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 10. PDTC143XQA: Collector capacitance as a function of collector-base voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 9 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac805 103 hFE aaa-018580 0.1 0.60 mA 0.54 mA 0.48 mA IC (A) (1) (2) 0.08 0.42 mA 0.06 0.30 mA (3) 102 0.36 mA 0.24 mA 0.04 0.18 mA 10 0.12 mA 0.02 IB = 0.06 mA 1 10-1 1 102 10 0 0 1 2 3 4 IC (mA) 5 VCE (V) Tamb = 25 C VCE = 5 V (1) Tamb = 100 C (2) Tamb = 25 C (3) Tamb = 40 C Fig 11. PDTC123JQA: DC current gain as a function of collector current; typical values aaa-018584 1 Fig 12. PDTC123JQA: Collector current as a function of collector-emitter voltage; typical values 006aac811 10 VI(on) (V) VCEsat (V) 10-1 (1) 1 (2) (1) (3) (2) (3) 10-2 10-1 1 102 10 10-1 10-1 1 102 10 IC (mA) IC (mA) IC/IB = 20 VCE = 0.3 V (1) Tamb = 100 C (1) Tamb = 40 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 40 C (3) Tamb = 100 C Fig 13. PDTC123JQA: Collector-emitter saturation voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 14. PDTC123JQA: On-state input voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 10 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac812 1 006aac813 3 (1) Cc (pF) (2) VI(off) (V) (3) 2 1 10-1 10-1 0 1 10 0 10 20 30 40 50 VCB (V) IC (mA) f = 1 MHz; Tamb = 25 C VCE = 5 V (1) Tamb = 40 C (2) Tamb = 25 C (3) Tamb = 100 C Fig 15. PDTC123JQA: Off-state input voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 16. PDTC123JQA: Collector capacitance as a function of collector-base voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 11 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac819 103 aaa-018581 0.1 hFE (1) 0.63 mA 0.56 mA 0.70 mA IC (A) 0.08 (2) 0.49 mA 0.42 mA (3) 102 0.35 mA 0.06 0.28 mA 0.21 mA 0.04 10 0.14 mA 0.02 IB = 0.07 mA 1 10-1 1 102 10 0 0 1 2 3 4 IC (mA) 5 VCE (V) Tamb = 25 C VCE = 5 V (1) Tamb = 100 C (2) Tamb = 25 C (3) Tamb = 40 C Fig 17. PDTC143ZQA: DC current gain as a function of collector current; typical values aaa-018585 1 Fig 18. PDTC143ZQA: Collector current as a function of collector-emitter voltage; typical values 006aac821 10 VI(on) (V) VCEsat (V) (1) 10-1 1 (2) (3) (1) (2) (3) 10-2 10-1 1 102 10 10-1 10-1 1 102 10 IC (mA) IC (mA) IC/IB = 20 VCE = 0.3 V (1) Tamb = 100 C (1) Tamb = 40 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 40 C (3) Tamb = 100 C Fig 19. PDTC143ZQA: Collector-emitter saturation voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 20. PDTC143ZQA: On-state input voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 12 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac822 10 006aac823 3 Cc (pF) VI(off) (V) 2 1 (1) (2) (3) 10-1 10-1 1 0 1 10 0 10 20 30 40 50 VCB (V) IC (mA) f = 1 MHz; Tamb = 25 C VCE = 5 V (1) Tamb = 40 C (2) Tamb = 25 C (3) Tamb = 100 C Fig 21. PDTC143ZQA: Off-state input voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 22. PDTC143ZQA: Collector capacitance as a function of collector-base voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 13 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac784 103 0.50 mA IC (A) (1) hFE aaa-018582 0.1 (2) 0.45 mA 0.40 mA 0.08 0.35 mA (3) 0.30 mA 102 0.25 mA 0.06 0.20 mA 0.04 0.15 mA 10 0.10 mA 0.02 IB = 0.05 mA 1 10-1 1 102 10 0 0 1 2 3 4 IC (mA) 5 VCE (V) Tamb = 25 C VCE = 5 V (1) Tamb = 100 C (2) Tamb = 25 C (3) Tamb = 40 C Fig 23. PDTC114YQA: DC current gain as a function of collector current; typical values aaa-018586 1 Fig 24. PDTC114YQA: Collector current as a function of collector-emitter voltage; typical values 006aac786 10 VI(on) (V) VCEsat (V) (1) 10-1 1 (2) (3) (1) (2) (3) 10-2 10-1 1 102 10 10-1 10-1 1 102 10 IC (mA) IC (mA) IC/IB = 20 VCE = 0.3 V (1) Tamb = 100 C (1) Tamb = 40 C (2) Tamb = 25 C (2) Tamb = 25 C (3) Tamb = 40 C (3) Tamb = 100 C Fig 25. PDTC114YQA: Collector-emitter saturation voltage as a function of collector current; typical values PDTC143X_123J_143Z_114YQA_SER Product data sheet Fig 26. PDTC114YQA: On-state input voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 14 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 006aac787 10 006aac788 3 Cc (pF) VI(off) (V) 2 (1) 1 (2) (3) 1 10-1 10-1 0 1 10 0 10 20 30 40 50 VCB (V) IC (mA) f = 1 MHz; Tamb = 25 C VCE = 5 V (1) Tamb = 40 C (2) Tamb = 25 C (3) Tamb = 100 C Fig 27. PDTC114YQA: Off-state input voltage as a function of collector current; typical values Fig 28. PDTC114YQA: Collector capacitance as a function of collector-base voltage; typical values 006aac757 103 fT (MHz) 102 10 10-1 1 102 10 IC (mA) VCE = 5 V; Tamb= 25 C Fig 29. Transition frequency as a function of collector current; typical values of built-in transistor PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 15 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 8.2 Resistor calculation • Calculation of bias resistor 1 (R1): V  I I2  – V  I I1  R1 = -----------------------------------I I2 – I I1 • Calculation of bias resistor ratio (R2/R1): V  I I4  – V  I I3  R2 -–1 ------- = ----------------------------------R1 R1   I I4 – I 13  n.c. II1; II2 R1 II3; II4 R2 GND aaa-020082 Fig 30. Resistor test circuit 8.3 Resistor test conditions Table 9. PDTC143X_123J_143Z_114YQA_SER Product data sheet Resistor test conditions Type number R1 (k) R2 (k) Test conditions II1 II2 II3 II4 PDTC143XQA 4.7 10 350 A 450 A 350 A 450 A PDTC123JQA 2.2 47 90 A 140 A 55 A 105 A PDTC143ZQA 4.7 47 90 A 140 A 55 A 105 A PDTC114YQA 10 47 90 A 140 A 55 A 105 A All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 16 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 9. Package outline 0.87 0.95 0.75 1 0.95 1.05 2 0.34 0.40 Dimensions in mm 0.17 0.25 0.16 0.24 0.1 3 0.04 max 0.22 0.30 0.245 0.325 0.195 0.275 1.05 1.15 13-03-05 Fig 31. Package outline DFN1010D-3 (SOT1215) PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 17 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 10. Soldering Footprint information for reflow soldering of DFN1010D-3 package SOT1215 1.2 0.45 (2x) 0.3 1.1 0.35 (2x) 0.4 0.25 (2x) 0.75 0.3 0.5 1.5 1.4 0.4 0.5 0.4 0.3 0.5 1.3 0.4 0.3 0.4 0.5 1.3 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 12-11-23 13-03-06 sot1215_fr Fig 32. Reflow soldering footprint DFN1010D-3 (SOT1215) PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 18 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PDTC143X_123J_143Z_ 114YQA_SER v.1 20151030 Product data sheet - - PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 19 of 22 PDTC143X/123J/143Z/114YQA Nexperia 50 V, 100 mA NPN resistor-equipped transistors 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PDTC143X_123J_143Z_114YQA_SER Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 20 of 22 Nexperia PDTC143X/123J/143Z/114YQA 50 V, 100 mA NPN resistor-equipped transistors No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 12.4 Trademarks Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PDTC143X_123J_143Z_114YQA_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 October 2015 © Nexperia B.V. 2017. All rights reserved 21 of 22 Nexperia PDTC143X/123J/143Z/114YQA 50 V, 100 mA NPN resistor-equipped transistors 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 4.1 5 6 7 8 8.1 8.2 8.3 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Binary marking code description. . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . 16 Quality information . . . . . . . . . . . . . . . . . . . . . 16 Resistor calculation . . . . . . . . . . . . . . . . . . . . 16 Resistor test conditions . . . . . . . . . . . . . . . . . 16 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 17 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 19 Legal information. . . . . . . . . . . . . . . . . . . . . . . 20 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 20 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Contact information. . . . . . . . . . . . . . . . . . . . . 21 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 October 2015
PDTC114YQAZ 价格&库存
很抱歉,暂时无法提供与“PDTC114YQAZ”相匹配的价格&库存,您可以联系我们找货
