山东晶导微电子股份有限公司
S10AC THRU S10MC
Jingdao Microelectronics co.LTD
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
Forward Current - 10 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Top View
Marking Code: S10A~S10M
Simplified outline SMC and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S10AC
S10BC
S10DC
S10GC
S10JC
S10KC
S10MC
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
10
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
200
A
Maximum Instantaneous Forward Voltage at 10A
VF
1.0
V
IR
5
100
μA
Cj
100
pF
RθJA
10
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMC-A-S10AC~S10MC-10A1KV
Page 1 of 3
山东晶导微电子股份有限公司
S10AC THRU S10MC
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
14
12
10
8.0
6.0
4.0
2.0
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Fig.2 Typical Reverse Characteristics
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
percent of Rated Peak Reverse Voltage (%)
1.0
T J =25°C
100
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
240
200
160
120
80
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
S10AC THRU S10MC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
Type number
Marking code
S10AC
S10A
S10BC
S10B
S10DC
S10D
S10GC
S10G
S10JC
S10J
S10KC
S10K
S10MC
S10M
mm
Unit :
(mil)
2017.01
JD703211B50
Page 3 of 3
很抱歉,暂时无法提供与“S10GC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31651
- 100+0.29541
- 300+0.27431
- 500+0.25321
- 2000+0.24266
- 5000+0.23633
