Metal Oxide Varistors
20D Series
Features
l Wide operating voltage (V1mA) range from 18V to 1800V
l Fast responding to transient over-voltage.
l Large absorbing transient energy capability.
l Low clamping ratio and no following-on current.
General Information
l Surge protection in consumer electronics
General Characteristics
l Surge protection in industrial electronics
l Relay and electromagnetic valve surge absorption
l Body: Nickel Plated
l Transistor, diode, IC, thyristor or triac semiconductor
l Devices with No Leads: Nickel Plated
l Operating Temperature: -40ºC to +85ºC
protection
l Storage Temperature: -40 ºC to +125ºC
l Surge protection in electronic home appliances, gas
l Axial Devices: Tin Plated
and petroleum appliances
Part Number Code
2
Element Diameter
D
Type
4
7
1
K
Surge Series
Nominal Varistor Voltage
D:Disk
J
1
No Suffix:Standard
Type
471=47*10 V
Varistor Voltage
Tolerance
J:High Surge Type
K = ±10 %
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2018-07-17
Page:1
20D Series
Electrical Characteristics
Type Number
Varistor
Voltage
Max. Allowable
Voltage
Max. Energy
(2ms)
VAC(V) VDC(V)
(J)
(J)
Standard High Surge
Standard
High
Surge
V1mA(V)
20D180K
16~20
11
14
5.4
20D220K
20~24
14
18
20D270K
24~30
17
20D330K
30~36
20D390K
35~43
20D470K
20D560K
Max. Clamping
Voltage
(8/20μs)
Withstanding Surge
Current(8/20μs)
I(A)
I(A)
Standard High Surge
IP(A)
VC(V)
25
38
2000
6.6
25
43
22
8.1
25
26
9.9
25
25
31
11.7
42~52
30
38
14.1
50~62
35
45
20D680K
61~75
40
20D820K
20D820KJ
74~90
20D101K
20D101KJ
20D121K
Typical
Rated
Capacitance
Power
(Reference)
(W)
@1KHz(pf)
0.2
39000
2000
0.2
32000
53
2000
0.2
22000
65
2000
0.2
18000
25
77
2000
0.2
16000
25
93
2000
0.2
14000
16.8
25
110
2000
0.2
12000
56
20.4
25
135
2000
0.2
10000
50
65
24.6
30.8
100
135
6500
10000
1.0
5800
90~110
60
85
30.0
37.5
100
165
6500
10000
1.0
4800
20D121KJ
108~132
75
100
36.0
45.0
100
200
6500
10000
1.0
3800
20D151K
20D151KJ
135~165
95
125
45.0
56.3
100
250
6500
10000
1.0
3000
20D181K
20D181KJ
162~198
115
150
54.0
67.5
100
300
6500
10000
1.0
2600
20D201K
20D201KJ
185~225
130
170
60.0
75.0
100
340
6500
10000
1.0
2400
20D221K
20D221KJ
198~242
140
180
66.0
82.5
100
360
6500
10000
1.0
1800
20D241K
20D241KJ
216~264
150
200
72.0
90.0
100
395
6500
10000
1.0
1500
20D271K
20D271KJ
243~297
175
225
81.0
101.3
100
455
6500
10000
1.0
1400
20D301K
20D301KJ
270~330
195
250
90.0
112.5
100
505
6500
10000
1.0
1350
20D331K
20D331KJ
297~363
210
275
99.0
123.8
100
550
6500
10000
1.0
1300
20D361K
20D361KJ
324~396
230
300
108.0
135.0
100
595
6500
10000
1.0
1250
20D391K
20D391KJ
351~429
250
320
117.0
146.3
100
650
6500
10000
1.0
1180
20D431K
20D431KJ
387~473
275
350
129.0
161.3
100
710
6500
10000
1.0
1100
20D471K
20D471KJ
423~517
300
385
141.0
176.3
100
775
6500
10000
1.0
1050
20D511K
20D511KJ
459~561
320
418
153.0
191.3
100
842
6500
10000
1.0
1000
20D561K
20D561KJ
504~616
350
460
168.0
210.0
100
920
6500
10000
1.0
970
20D621K
20D621KJ
558~682
385
505
186.0
232.5
100
1025
6500
10000
1.0
950
20D681K
20D681KJ
612~748
420
560
186.0
232.5
100
1120
6500
10000
1.0
900
20D751K
20D751KJ
675~825
460
615
186.0
232.5
100
1240
6500
10000
1.0
850
20D781K
20D781KJ
702~858
485
640
187.2
234.0
100
1290
6500
10000
1.0
750
20D821K
20D821KJ
738~902
510
670
196.8
246.0
100
1355
6500
10000
1.0
700
20D911K
20D911KJ
819~1001
550
745
218.4
273.0
100
1500
6500
10000
1.0
600
20D951K
20D951KJ
855~1045
580
780
228.0
285.0
100
1570
6500
10000
1.0
580
20D102K
20D102KJ
900~1100
625
825
240.0
300.0
100
1650
6500
10000
1.0
500
20D112K
20D112KJ
990~1210
680
895
264.0
330.0
100
1815
6500
10000
1.0
450
20D122K
20D122KJ
1080~1320
740
975
288
360
100
2010
6500
10000
1.0
440
20D152K
20D152KJ
1350~1650
900
1220
359.0
449.0
100
2475
6500
10000
1.0
400
20D182K
20D182KJ
1620~1980
1000
1465
432.0
540.0
100
2970
6500
10000
1.0
220
Note: The energy (10/1000μs) is about 1.4 times of energy(2ms)
Revised: 2018-07-17
Page:2
20D Series
Electrical Ratings
Items
Test Condition/Description
Requirement
Varistor Voltage
The voltage between two terminals with the specified measuring current 1mA.DC applied is called
Vb.
Maximum Allowable
Voltage
The recommended maximum sine wave voltage (RMS) or the Maximum DC voltage can be
applied continuously.
The maximum voltage between two terminals with the specification standard impulse current.
Applied waveform: 8/20μs
I
1.0
0.9
Maximum Clamping
Voltage
B
0.5
To meet the
Specified value
T2
0.1
0.0
C
O1
T
t
30% max.
T1
T1=1.25*T=8μs±20%
T2=20μs±20%
Rated Wattage
The maximum average power that can be applied within the specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when one impulse of 10/1000μs
or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10% with the standard impulse
current (8/20μs) applied one time.
The change of Vb shall be measured after the impulse listed below which is applied 10,000 times
continuously with the interval of ten seconds at room temperature.
Surge Life
180K to 680K
100A (8/20μs)
820K to 182K
200A (8/20μs)
20Φ series
Revised: 2018-07-17
ΔVb
≤ ±10%
Vb
Page:3
20D Series
Soldering Recommendation
Wave Lead Free Soldering Recommendation
Item
Conditions
Peak Temperature
265ºC
Dipping Time
10 seconds (max.)
Soldering
1 time
300
Maximum Wave 265°C
Preheating
Soldering
Cooling
Temperature(°C)
250
200
150
100
50
1
1.5
2
2.5
Time(minutes)
3
3.5
4
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360ºC (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Dimensions
TABLE 1
Symbol
Millimeter
Inches
H(max)
26.0
1.024
L(min)
15.0
0.591
D(max)
23.0
0.906
D1(±1.0)
10.0
0.394
T(max)
TABLE 2
d(±0.1)
1.0
0.039
Packaging Quantity: 250pcs/bag
TABLE 2---T(max.)
Model
Millimeters
Inches
Model
Millimeters
Inches
180K~390K
8.5
0.335
431K~561K
11.0
0.433
470K~680K
9.0
0.354
621K~781K
11.5
0.453
820K~151K
9.5
0.374
821K~122K
12.0
0.472
181K~271K
10.0
0.394
152K
12.5
0.492
331K~391K
10.5
0.413
182K
13.0
0.512
Revised: 2018-07-17
Page:4
很抱歉,暂时无法提供与“20D751K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.28777
- 50+1.83870
- 250+1.56060
- 500+1.32041
- 2500+1.21349
- 5000+1.14934
- 国内价格
- 1+1.17000
- 10+1.08000
- 30+1.06200
- 100+1.00800
