MMBT5551
MMBT5551
    YONGYUTAI(永裕泰)
    SOT-23
    SOT-23 160V 0.6A
MMBT5551 数据手册
MMBT5551 SOT-23 Plastic-Encapsulate Transistors MMBT5551 TRANSISTOR (NPN) FEATURES Complimentary to MMBT5401 MARKING:G1 MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units (符号) (参数名称) (额定值) (单位) VCBO Collector-Base Voltage (集电极-基极电压) 180 V VCEO Collector-Emitter Voltage (集电极-发射极电压) 160 V VEBO Emitter-Base Voltage (发射极-基极电压) 5 V IC Collector Current -Continuous (集电极电流) 0.6 A PC Collector Power Dissipation (耗散功率) 0.3 W Tj Junction Temperature (结温) 150 ℃ Tstg Storage Temperature (储存温度) -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter (参数名称) Symbol (符号) Test conditions (测试条件) MIN TYP MAX (最小值) (典型值) (最大值) UNIT (单位) Collector-base breakdown voltage 集电极-基极击穿电压 V(BR)CBO IC= 100μA, IE=0 180 V Collector-emitter breakdown voltage 集电极-发射极击穿电压 V(BR)CEO IC= 1mA, IB=0 160 V Emitter-base breakdown voltage 发射极-基极击穿电压 V(BR)EBO IE=100μA, IC=0 5 V Collector cut-off current 集电极-基极截止电流 ICBO VCB=120 V , IE=0 1 μA Collector cut-off current 集电极-发射极截止电流 ICEO VCE=120V , 10 μA Emitter cut-off current 发射极-基极截止电流 IEBO VEB=5V , IC=0 1 μA DC current gain 直流电流增益 hFE VCE=5V, IC= 10mA IB=0 100 400 Collector-emitter saturation voltage 集电极-发射极饱和压降 VCE(sat) IC=50mA, IB= 5mA 0.5 V Base-emitter saturation voltage 发射极-基极饱和压降 VBE(sat) IC=50mA, IB= 5mA 1 V CLASSIFICATION OF Range www.yongyutai.com 100-200 hFE 200-300 300-400 PAGE 1 MMBT5551 Typical Characteristics www.yongyutai.com MMBT5551 PAGE 2
MMBT5551 价格&库存
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
MMBT5551
    • 50+0.05822
    • 500+0.04612
    • 3000+0.03899
    • 6000+0.03500
    • 24000+0.03143
    • 51000+0.02960
    库存:54480
    MMBT5551
      • 1+0.03886
      • 100+0.03623
      • 300+0.03361
      • 500+0.03098
      • 2000+0.02967
      • 5000+0.02888
      库存:5011
