TAI-TECH
TBM01-121000657
Multilayer Common Mode Choke Coils
P1.
MCF1210NF2-900T01
1. Scope
This specification applies to Multilayer Common Mode Choke Coil,
MCF Series Its Application is limited for the High speed differential
transmission line like as followings.
USB, LVDS, MIPI, MDDI, MHL, HDMI, DVI.
Halogen
Pb
Halogen-free
Pb-free
2. Dimensions
Chip Size
Size
A
B
C
P
D1
1210
1.25±0.15
1.0±0.15
0.55 ±0.10
0.55±0.10
D2
0.30±0.10 0.25+0.15/-0.1
Units: mm
3. Part Numbering
MCF
1210
NF2
A
B
C
900
T
01
D
E
F
Normal-mode
(Differential-mode)
Common-mode
A: Series
B: Dimension
AxB
C: Material
Lead Free Code
D: Impedance
Common Mode Impedance
E: Packaging
T=Taping and Reel , B=Bulk(Bags)
F: Rated Current
01=100mA
1
2
1
2
4
3
4
3
900=90Ω
HP-4291A
HP-4291A
4. Specification
Tai-Tech
Part Number
Common Mode Test Frequency
Impedance (Ω)
(MHz)
MCF1210NF2-900T01
90±25%
Insulation
Resistance
(MΩ) min.
DC Resistance
(Ω) max.
Rated Current
(mA) max.
5
100
4.5
100
100
Impedance-Frequency Characteristics
MCF1210NF2-900T01
10000
IMPEDANCE(Ohm)
Rated Voltage
(Vdc) max.
1000
Common Mode
100
Differential Mode
10
1
1
10
100
1000
FREQUENCY(MHz)
www.tai-tech.com.tw
10000
TAI-TECH
TBM01-121000657
P2.
5. Reliability and Test Condition
Item
Performance
MCF
-40~+85℃
(Including self-generated heat)
Series No.
Operating Temperature
Test Condition
Transportation
Storage Temperature
-40~+85℃
For long storage conditions, please see the
Application Notice
Measuring equipment:4291A or its equivalent
Measuring jig: 16192A(or its equivalent)
Impedance (Z)
Measuring points: ○
1 to○
2 or ○
3 to○
4
Measuring voltage: Rated voltage
Insulation Resistance
Within the specified tolerance
Measuring points: ○
1 to○
2 or ○
3 to○
4
DC Resistance
Rated Current
Test sample shall be soldered to test board and the
test shall be conducted under the conditions shown
in Table 2.
Table 2
Per table 1.
Table 1
Appearance
Vibration
Commom
Impedance change
rate
Insulation
resistance
Solderability
No remarkable Defect
Within±20%
100mΩ min
Vibraiton frequency
range
Overall amplitude
1 cycle
Time
10Hz to 55Hz
1.5mm
1min.(10→55→10Hz)
2 hours
X
each
Y
Z
More than 75% of terminal electrode shall be covered with fresh solder.
Test sample shall be immersed into molten solder
under the conditions shown in Table 3 after
immersed into flux.
After this, test samples shall be taken out and
visually checked.
The speed for immersion and taking out shall be 25
mm/s.
Table 3
Solder temperature
Immersion time
Resistance to
Soldering Heat
245℃±3℃
4s±1s
after immersed into flux and preheated under the
conditions shown in Table 4.
measured after kept at room temperature for 2 to 3
hours.(Note 1)
25mm/s.
Table 4
Per table 1.
Preheating
Resistance to
Soldering Heat
150℃, 3min.
260℃±5℃
Immersion time
10s±0.5s
Steps 1 to 4 shown in Table 5 as one cycle shall be
repeated 5 times.
After the test, keep the test sample at a normal
temperature with a normal humidity for 2 to 2 hours,
them measurement shall be conducted.(Note 1)
Table 5
Thermal Shock
Resistance to Humidity
High Temperature Load
Life Test
Per table 1.
Step
Temperature(℃)
Duration (min)
1
2
-40℃+0/-3℃
Normal temp
30±3
2~3
3
4
+85℃+3/-0℃
Normal temp
30±3
2~3
Test board shall be kept in a thermo hygrostat at
temperature of 40℃±2℃ and relative humidity of
90% to 95% for 500+24/-0 hours.
temperature with a normal humidity for 2 to 3 hours,
then measurement shall be conducted.(Note 1)
Per table 1.
Test board shall be kept in a thermostatic oven with
temperature of 85℃±2℃ for 500+24/-0 hours while
1 to ○
2 and ○
3 -○
4 with rated current.
supplying ○
Per table 1.
www.tai-tech.com.tw
TAI-TECH
TBM01-121000657
Item
Performance
Test Condition
Test board shall be kept in an atmosphere with
temperature of 85℃±2℃ for 500+24/-0 hours.
High Temperature Life Test Per table 1.
Warp : 2mm(1210),1mm(0806)
Testing board : Glass epoxy-resin substrate
Thickness : 0.8mm
Appearance:
No mechanical damage.
Bending Strength
P3.
(Note 1) If question is found in the result of measurement, another measurement shall be conducted after test samples shall be kept for 48+/-2 hours.
6. Soldering and Mounting
6-1. Recommended PC Board Pattern
Land Patterns For
Reflow Soldering
Chip Size
Type
A
B
C
D1
0806
0.85±0.05
0.65±0.05
0.40 ±0.05
0.27±0.10
0.20+0.05/-0.1 0.25~0.35 0.25~0.35 0.25~0.35
D2
E
F
0.5
1210
1.25±0.15
1.0±0.15
0.55 ±0.10
0.30±0.10
0.25+0.15/-0.1 0.45~0.55
0.55
0.7~0.8
G
0.25~0.35
H
Units: mm
PC board should be designed so that products can prevent damage from
mechanical stress when warping the board.
Products shall be positioned in the sideway direction against the mechanical
stress to prevent failure.
6-2. Soldering
Mildly activated rosin fluxes are preferred. The terminations are suitable for re-flow soldering systems. If hand soldering
cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
Note.
If wave soldering is used ,there will be some risk.
Re-flow soldering temperatures below 240 degrees, there will be non-wetting risk
6-2.1 Lead Free Solder re-flow:
Recommended temperature profiles for lead free re-flow soldering in Figure 1.
www.tai-tech.com.tw
TBM01-121000657 P4.
TAI-TECH
6-2.2 Soldering Iron:
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a
soldering iron must be employed the following precautions are recommended. for Iron Soldering in Figure 2.
•Preheat circuit and products to 150℃
•350℃ tip temperature (max)
•Never contact the ceramic with the iron tip
•1.0mm tip diameter (max)
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
20~40s
PRE-HEATING
NATURAL
COOLING
TEMPERATURE(° C)
217
60~150s
200
150
SOLDERING
within 4~5s
TP(260° C / 40s max.)
•Use a 20 watt soldering iron with tip diameter of 1.0mm
•Limit soldering time to 4~5sec.
60~180s
NATURAL
COOLING
350
150
Over 60s
480s max.
Gradual cooling
25
TIME(sec.)
TIME( sec.)
Reflow times: 3 times max
Fig.1
Iron Soldering times:1 times max
Fig.2
6-2.3 Solder Volume:
Upper limit
Recommendable
Accordingly increasing the solder volume, the mechanical stress to
product is also increased. Exceeding solder volume may cause the
failure of mechanical or electrical performance. Solder shall be used
not to be exceed as shown in right side:
Minimum fillet height = soldering thickness + 25% product height
t
7.Packaging Information
7-1. Reel Dimension
Code
ψA
ψB
ψC
ψD
E
W
t
R
Dimension
178±2.0
50 min
13±0.2
21±0.8
2.0±0.5
10±1.5
2.5 max
1.0
Units: mm
www.tai-tech.com.tw
TAI-TECH
TBM01-121000657
7-2. Tape Dimension (paper)
Po:4±0.1
1.
D:
.1
t
A
:1
D1
F:3.5±0.05
P
A
Bo
W:8.0±0.1
E:1.75±0.1
P2:2±0.05
Ko
1
0.
Ao
SECTION A-A
Series
Bo
Ao
Ko
P
t
0806
0.95±0.05 0.75±0.05 0.55±0.05
4.0±0.10
0.3 max
1210
1.40±0.05 1.15±0.05 0.65±0.05
4.0±0.10
0.3 max
Units: mm
7-3. Packaging Quantity
Chip size
0806
1210
Chip /Reel
10000
5000
Inner box
50000
25000
Middle box
250000
125000
Carton
500000
250000
7-4. Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 15 to 60 grams
in the arrow direction under the following conditions.
165° to180°
Base tape
Room Temp.
Room Humidity
Room atm
Tearing Speed
(hPa)
mm/min
5~35
45~85
860~1060
300
Application Notice
•Storage Conditions
To maintain the solder ability of terminal electrodes:
1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months from the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
•Transportation
1.Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.tai-tech.com.tw
P5.
很抱歉,暂时无法提供与“MCF1210NF2-900T01”相匹配的价格&库存,您可以联系我们找货
