RN 1/4W 7R5 F T/B A1 数据手册
RN series
PRECISION METAL FILM RESISTORS
Features
1. Low T.C. 25ppm 50ppm 100ppm.
2. High precision
0.25%
0.5%
1%
5%.
3. Temperature stable, low noise, good reliability.
4. 0.1% / 25ppm case by case.
1.
2.
3.
4.
25ppm
0.25%
50ppm
0.5%
100ppm
1%
5%
0.1% / 25ppm
ELECTRICAL AND MECHANICAL PERFORMANCE
Characteristics
Resistance Tolerance
Resistance Temp. Coeff.
Power Rating Load
Short Time Overload
Dielectric Withstanding Voltage
Insulation Resistance
Terminal Strength
Test Methods
Standards
1% ( F ) or
0.5% ( D )
25 ppm /
100 ppm /
50 ppm /
Surface temp. 175 Max.
175 , R/R
1%
-65
~ 175
Rated voltage for 30 minutes
/ 30
2.5 times of rated valtage
for 5 seconds.
2.5
/5
0.5%
No evidence of mechanical damage
or insulation breakdown.
10,000MÙ
Max. Overload Voltage for 1 min.
1
( RN 1 W & 1 WL AC 350V
RN 1/4 WS AC 300V )
DC 100V or 500V megger
No evidence of mechanical damage.
Minimum 95% coverage
95%
Resistance to Soldering Heat
, R/R
1%
Solder-ability
1 kg
235 5
for 2 seconds
270 5 for 10 1 seconds
350 10 for 3.5 0.5 seconds
ENVIRONMENTAL CHARACTERISTICS
Characteristics
Standards
Temp. Cycle
R/R
0.25%
Load Life
R/R
2%
Moisture-proof Load Life
R/R
1.5%
Nonflammability
Reference Standards
IEC 60115-1
JIS C 5201-1
not flamed
21
Test Methods
-65 ( 30 min.)
Room Temp.( 3 min.)
+175 ( 30 min.)
Room Temp.( 3 min.) / ( 5 cycles)
Rated power load 90 minutes ON
30 minutes OFF
70 1000 hours
30 minutes OFF
40 95% RH 1000 hours
16 times of rated wattage for 5 min.
(RN 1W & RN 1WL)
RN series
Unit mm
Dimensions
Rated
Wattage
1/8W
1/4WS
1/4W
1/2WS
0.6W
1/2W
1W
1WL
d
H
L
H
D
Resistance
H 3 d 0.1 Range(Ù)
1.7 0.2 3.7max. 28
0.45
10~1M
0.45
1.7 0.2 3.7max. 28
10~1M
28
0.6
2.4 0.5 6.4
10~2M
28
0.6
2.4 0.5 6.4
10~2M
28
0.6
2.4 0.5 6.4
10~2M
9
0.65
28
3.5
10~2M
11
0.8
28
4.5
10~2M
15
0.8
28
5.0
10~2M
D 1
60
40
80
120
140
160
175
Surface Temperature Rise
(OC)
Rated Load
150
1WL
70
80
150V
200V
250V
300V
350V
350V
500V
500V
For resistors operated in ambient temperatures above 70 ,
power rating must be derated in accordance with the curve
below.
-65
Max.
Working
Voltage
Note: 1. To prevent electric corrosion, the resistance over 100KÙ should be
limited at 50V.
2. Too low or too high ohmic values can be supplied only case by case.
3. Max. Overload Voltage is 2 times of Max. Working Voltage.
4. RN 1W & RN 1WL is coated by flameproof paint.
Derating Curve
100
L 1
Ambient Temp.
(OC)
100
1W
0.6W
1/2WS
1/2W
50
1/4WS
1/4W
1/8W
How to order
60
80
100
Rated Load
It is composed by Type, Rated Wattage, Nominal Resistance, Tolerance ,Temperature Coefficient
and Package. e.g.
RN
a.
1/4W
b.
10Ù
c.
F
d.
50ppm
e.
T/B
f.
a. Type(
): Precision Metal Film Resistohrs are Called "RN".
b. Rated Wattage(
) : Shown by "W", such as 1/8W,1/4WS,
1/4W,1/2WS,0.6W,1/2W,1W,1WL.
c. Nominal Resistance(
) : 10Ù.
d. Tolerance(
): 0.5%(D), 1%(F) .
e. Temperature Coefficient (
): 25ppm/OC, 50ppm/OC, Nil
f . Package (
T/R tape & reel (
); T/B tape in box(
); Nil Bulk(
22
100ppm/OC
RN 1/4W 7R5 F T/B A1 价格&库存
很抱歉,暂时无法提供与“RN 1/4W 7R5 F T/B A1”相匹配的价格&库存,您可以联系我们找货
