C1005X5R334KDTS
C1005X5R334KDTS
    DARFON(达方)
    贴片电容(MLCC) 0402
C1005X5R334KDTS 数据手册
MLCC CONTENT (MLCC) E STANDARD NUMBER ................................................................................................................................................................ 3 STRUCTURE ................................................................................................................................................................................ 4 GENERAL PURPOSE .................................................................................................................................................................... 5 CLASS I: TEMPERATURE COMPENSATING TYPE ............................................................................................................................ 6 CLASS II: HIGH DIELECTRIC CONSTANT TYPE ............................................................................................................................. 12 X5R Series .................................................................................................................................................................. 12 X6S Series .................................................................................................................................................................. 17 X7R Series .................................................................................................................................................................. 19 X7S Series .................................................................................................................................................................. 28 X7T Series .................................................................................................................................................................. 29 X7U Series.................................................................................................................................................................. 30 Y5V Series .................................................................................................................................................................. 31 TEST SPEC. ........................................................................................................................................................................ 33 PACKAGE .................................................................................................................................................................................. 37 OTHERS .................................................................................................................................................................................... 41 E Standard Number E3 1.0 E6 E12 2.2 1.0 1.0 1.5 1.2 1.5 4.7 2.2 1.8 2.2 3.3 2.7 3.3 4.7 3.9 4.7 6.8 5.6 6.8 8.2 E24 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 3 Rev. 201710 MLCC ORDERING CODE ........................................................................................................................................................................ 4 Structure Ordering Code C 1005 NP0 101 J G T S △ PRODUCT CODE C = MLCC SIZE in mm (EIA CODE, in inch) 0402(01005) 3216 (1206) 0603(0201) 3225(1210) 1005 (0402) 4520 (1808) 1608 (0603) 4532 (1812) 2012 (0805) T. C. NP0: 0 ± 30ppm/℃ -55℃ to +125℃ X5R: ±15% -55℃ to +85℃ X7R: ±15% X7S:±22% X7T: +22%/-33% X7U: +22%/-56% -55℃ to +125℃ X6S: ±22% -55℃ to +105℃ Y5V: +22%/-82% -30℃ to +85℃ CAPACITANCE CODE Examples: Expressed in pico-farads and identified by a three-digit number. First two digits represent significant figures. Last digit specifies the number of zeros. (Use 9 for 1.0 through 9.9pF; Use 8 for 0.20 through 0.99pF) Code Cap (pF) 478 0.47 229 2.2 101 100 102 1000 TOLERANCE CODE A: ± 0.05pF J: ±5% B: ± 0.1pF K: ±10% C: ± 0.25pF M: ±20% D: ± 0.5pF Z: +80/-20% F: ±1% G: ±2% G: 50V R: 3KV H: 100V S: 4KV VOLTAGE CODE B: 4V J: 200V C: 6.3V K: 250V D: 10V E: 16V L: 500V M: 630V F: 25V P: 1KV N: 35V Q: 2KV PACKAGING CODE T: Paper tape reel Ø180mm (7”) N: Paper tape reel Ø250mm (10”) A: Paper tape reel Ø330mm (13”) W: Special Packing P: Embossed tape reel Ø180mm (7”) D: Embossed tape reel Ø250mm (10”) E: Embossed tape reel Ø330mm (13”) Application Code S: Standard Q: High Q/Low ESR F: Microwave A: Automotive Infotainment with AEC-Q200 Thickness Code Code Thick (mm) Code Thick(mm) Code Thick (mm) Code Thick (mm) (blank) Standard Thick M 0.70 G 1.25 S 1.90 Z 0.20 D 0.80 H 1.50 -- -- A 0.30 E 0.85 L 1.60 -- -- Q 0.45 I 0.95 N 2.00 -- -- B 0.50 J 1.00 P 2.50 -- -- C 0.60 F 1.15 R 3.20 -- -- 4 General Purpose External Dimensions MLCC  C0603 (0201) C1005 (0402) C1608 (0603) C2012 (0805) C3216 (1206) C3225 (1210) Dimension (mm) Kind Standard Special (1) Special (2) Standard Special (1) Special (2) Special (3) Standard Special (1) Special (2) Special (3) Standard Special (1) Standard Special (1) Special (2) Standard Special (1) L (Length) W (Width) 0.6 ± 0.6 ± 0.6 ± 1.0 ± 1.0 ± 1.0 ± 1.0 ± 1.6 ± 1.6 ± 1.6 ± 1.6 ± 2.0 ± 2.0 ± 3.2 ± 3.2 ± 3.2 ± 3.2 ± 3.2 ± 0.30 ± 0.03 0.30 ± 0.05 0.30 ± 0.09 0.50 ± 0.05 0.50 ± 0.10 0.50 ± 0.15 0.50 ± 0.20 0.80 ± 0.10 0.80 ± 0.15 0.80 ± 0.20 0.80 ± 0.25 1.25 ± 0.15 1.25 ± 0.20 1.60 ±0.15 1.60 ±0.20 1.60 ±0.30 2.50 ± 0.20 2.50 ± 0.30 0.03 0.05 0.09 0.05 0.10 0.15 0.20 0.10 0.15 0.20 0.25 0.15 0.20 0.15 0.20 0.30 0.30 0.40 T (Max.) 0.33 0.35 0.39 0.55 0.60 0.65 0.70 0.90 0.95 1.00 1.05 1.45 1.45 1.80 1.90 1.90 2.80 2.80 g (Min) 0.15 General Purpose TYPE Size (EIA Size) A (Min/Max) 0.10 / 0.20 0.10 / 0.25 0.30 0.15 / 0.35 0.50 0.25 / 0.65 0.70 0.25 / 0.75 1.50 0.25 / 0.75 1.50 0.3 / 0.90 For special parts, please see the “Part Number & Characteristic” for detail specification. 5 Rev. 201710  Class I: Temperature Compensating Type  Feature  Application 1. 2. 3. 4. 5. 6. 7. Ultra-stable Tight tolerance available Low ESR (Frequency is within 800MHz) Good frequency performance No aging of capacitance RoHS compliant Halogen Free 1. 2. 3. LC and RC tuned circuit Filtering Timing   Part Number & Characteristic C0603NP0_S Series (EIA0201) RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C0603NP0208□GTS C0603NP0308□GTS C0603NP0408□GTS C0603NP0508□GTS C0603NP0608□GTS C0603NP0708□GTS C0603NP0758□GTS C0603NP0808□GTS C0603NP0908□GTS C0603NP0109□GTS C0603NP0119□GTS C0603NP0129□GTS C0603NP0139□GTS C0603NP0159□GTS C0603NP0169□GTS C0603NP0189□GTS C0603NP0209□GTS C0603NP0229□GTS C0603NP0249□GTS C0603NP0279□GTS C0603NP0309□GTS C0603NP0339□GTS C0603NP0359□GTS C0603NP0399□GTS C0603NP0409□GTS C0603NP0439□GTS C0603NP0479□GTS C0603NP0509□GTS C0603NP0519□GTS C0603NP0569□GTS C0603NP0609□GTS C0603NP0629□GTS C0603NP0689□GTS C0603NP0709□GTS C0603NP0759□GTS C0603NP0809□GTS C0603NP0829□GTS C0603NP0909□GTS C0603NP0100□GTS C0603NP0120□GTS C0603NP0150□GTS C0603NP0180□GTS C0603NP0200□GTS C0603NP0220□GTS C0603NP0270□GTS C0603NP0330□GTS C0603NP0390□GTS C0603NP0470□GTS C0603NP0560□GTS C0603NP0680□GTS C0603NP0820□GTS C0603NP0101□GTS C0603NP0208□GT C0603NP0308□GT C0603NP0408□GT C0603NP0508□GT C0603NP0608□GT C0603NP0708□GT C0603NP0758□GT C0603NP0808□GT C0603NP0908□GT C0603NP0109□GT C0603NP0119□GT C0603NP0129□GT C0603NP0139□GT C0603NP0159□GT C0603NP0169□GT C0603NP0189□GT C0603NP0209□GT C0603NP0229□GT C0603NP0249□GT C0603NP0279□GT C0603NP0309□GT C0603NP0339□GT C0603NP0359□GT C0603NP0399□GT C0603NP0409□GT C0603NP0439□GT C0603NP0479□GT C0603NP0509□GT C0603NP0519□GT C0603NP0569□GT C0603NP0609□GT C0603NP0629□GT C0603NP0689□GT C0603NP0709□GT C0603NP0759□GT C0603NP0809□GT C0603NP0829□GT C0603NP0909□GT C0603NP0100□GT C0603NP0120□GT C0603NP0150□GT C0603NP0180□GT C0603NP0200□GT C0603NP0220□GT C0603NP0270□GT C0603NP0330□GT C0603NP0390□GT C0603NP0470□GT C0603NP0560□GT C0603NP0680□GT C0603NP0820□GT C0603NP0101□GT 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.20 0.30 0.40 0.50 0.60 0.70 0.75 0.80 0.90 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.5 3.9 4.0 4.3 4.7 5.0 5.1 5.6 6.0 6.2 6.8 7.0 7.5 8.0 8.2 9.0 10 12 15 18 20 22 27 33 39 47 56 68 82 100 pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF pF Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) Standard Packing ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Paper,15Kpcs □ Tolerance Code: A=±0.05 pF, B=±0.1pF, C=±0.25pF ,D=±0.5pF, F=±1%, G=±2%, J=±5%; Special tolerance on the request. 6 25V 16V DARFON P/N 2 C0603NP0208□FTS C0603NP0308□FTS C0603NP0408□FTS C0603NP0508□FTS C0603NP0608□FTS C0603NP0708□FTS C0603NP0758□FTS C0603NP0808□FTS C0603NP0908□FTS C0603NP0109□FTS C0603NP0129□FTS C0603NP0139□FTS C0603NP0159□FTS C0603NP0169□FTS C0603NP0189□FTS C0603NP0209□FTS C0603NP0229□FTS C0603NP0279□FTS C0603NP0309□FTS C0603NP0339□FTS C0603NP0359□FTS C0603NP0399□FTS C0603NP0409□FTS C0603NP0439□FTS C0603NP0479□FTS C0603NP0509□FTS C0603NP0519□FTS C0603NP0569□FTS C0603NP0609□FTS C0603NP0629□FTS C0603NP0689□FTS C0603NP0709□FTS C0603NP0759□FTS C0603NP0809□FTS C0603NP0829□FTS C0603NP0909□FTS C0603NP0919□FTS C0603NP0100□FTS C0603NP0120□FTS C0603NP0150□FTS C0603NP0180□FTS C0603NP0200□FTS C0603NP0220□FTS C0603NP0240□FTS C0603NP0270□FTS C0603NP0300JFTS C0603NP0330□FTS C0603NP0390□FTS C0603NP0470□FTS C0603NP0560□FTS C0603NP0680□FTS C0603NP0820□FTS C0603NP0101□FTS C0603NP0279□ETS C0603NP0330□ETS C0603NP0208□FT C0603NP0308□FT C0603NP0408□FT C0603NP0508□FT C0603NP0608□FT C0603NP0708□FT C0603NP0758□FT C0603NP0808□FT C0603NP0908□FT C0603NP0109□FT C0603NP0129□FT C0603NP0139□FT C0603NP0159□FT C0603NP0169□FT C0603NP0189□FT C0603NP0209□FT C0603NP0229□FT C0603NP0279□FT C0603NP0309□FT C0603NP0339□FT C0603NP0359□FT C0603NP0399□FT C0603NP0409□FT C0603NP0439□FT C0603NP0479□FT C0603NP0509□FT C0603NP0519□FT C0603NP0569□FT C0603NP0609□FT C0603NP0629□FT C0603NP0689□FT C0603NP0709□FT C0603NP0759□FT C0603NP0809□FT C0603NP0829□FT C0603NP0909□FT C0603NP0919□FT C0603NP0100□FT C0603NP0120□FT C0603NP0150□FT C0603NP0180□FT C0603NP0200□FT C0603NP0220□FT C0603NP0240□FT C0603NP0270□FT C0603NP0300JFT C0603NP0330□FT C0603NP0390□FT C0603NP0470□FT C0603NP0560□FT C0603NP0680□FT C0603NP0820□FT C0603NP0101□FT C0603NP0279□ET C0603NP0330□ET Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.20 pF 0.30 pF 0.40 pF 0.50 pF 0.60 pF 0.70 pF 0.75 pF 0.80 pF 0.90 pF 1.0 pF 1.2 pF 1.3 pF 1.5 pF 1.6 pF 1.8 pF 2.0 pF 2.2 pF 2.7 pF 3.0 pF 3.3 pF 3.5 pF 3.9 pF 4.0 pF 4.3 pF 4.7 pF 5.0 pF 5.1 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 7.5 pF 8.0 pF 8.2 pF 9.0 pF 9.1 pF 10 pF 12 pF 15 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 39 pF 47 pF 56 pF 68 pF 82 pF 100 pF 2.7 pF 33 pF Available Tolerance ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±0.25pF,±0.1pF ±5%,±2%,±1% 7 Thick. (mm) 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Tolerance(mm) L/W Thick. ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 DF (max.) 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.17% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.22% 0.10% Standard Packing MLCC DARFON P/N Paper,15Kpcs Paper,15Kpcs Rev. 201710 General Purpose RV  C1005NP0_S Series (EIA0402) RV DARFON P/N DARFON P/N 2 50V C1005NP0208□GTS C1005NP0308□GTS C1005NP0408□GTS C1005NP0508□GTS C1005NP0608□GTS C1005NP0688□GTS C1005NP0708□GTS C1005NP0808□GTS C1005NP0828□GTS C1005NP0908□GTS C1005NP0109□GTS C1005NP0129□GTS C1005NP0139□GTS C1005NP0159□GTS C1005NP0189□GTS C1005NP0209□GTS C1005NP0229□GTS C1005NP0249□GTS C1005NP0259□GTS C1005NP0279□GTS C1005NP0309□GTS C1005NP0339□GTS C1005NP0369□GTS C1005NP0399□GTS C1005NP0409□GTS C1005NP0439□GTS C1005NP0479□GTS C1005NP0509□GTS C1005NP0519□GTS C1005NP0569□GTS C1005NP0609□GTS C1005NP0629□GTS C1005NP0689□GTS C1005NP0709□GTS C1005NP0759□GTS C1005NP0809□GTS C1005NP0829□GTS C1005NP0909□GTS C1005NP0919□GTS C1005NP0100□GTS C1005NP0110□GTS C1005NP0120□GTS C1005NP0150□GTS C1005NP0160□GTS C1005NP0180□GTS C1005NP0200□GTS C1005NP0220□GTS C1005NP0240□GTS C1005NP0270□GTS C1005NP0300□GTS C1005NP0330□GTS C1005NP0360□GTS C1005NP0390□GTS C1005NP0430□GTS C1005NP0470□GTS C1005NP0510□GTS C1005NP0560□GTS C1005NP0620□GTS C1005NP0680□GTS C1005NP0750□GTS C1005NP0820□GTS C1005NP0910□GTS C1005NP0101□GTS C1005NP0121□GTS C1005NP0151□GTS C1005NP0181□GTS C1005NP0201□GTS C1005NP0221□GTS C1005NP0208□GT C1005NP0308□GT C1005NP0408□GT C1005NP0508□GT C1005NP0608□GT C1005NP0688□GT C1005NP0708□GT C1005NP0808□GT C1005NP0828□GT C1005NP0908□GT C1005NP0109□GT C1005NP0129□GT C1005NP0139□GT C1005NP0159□GT C1005NP0189□GT C1005NP0209□GT C1005NP0229□GT C1005NP0249□GT C1005NP0259□GT C1005NP0279□GT C1005NP0309□GT C1005NP0339□GT C1005NP0369□GT C1005NP0399□GT C1005NP0409□GT C1005NP0439□GT C1005NP0479□GT C1005NP0509□GT C1005NP0519□GT C1005NP0569□GT C1005NP0609□GT C1005NP0629□GT C1005NP0689□GT C1005NP0709□GT C1005NP0759□GT C1005NP0809□GT C1005NP0829□GT C1005NP0909□GT C1005NP0919□GT C1005NP0100□GT C1005NP0110□GT C1005NP0120□GT C1005NP0150□GT C1005NP0160□GT C1005NP0180□GT C1005NP0200□GT C1005NP0220□GT C1005NP0240□GT C1005NP0270□GT C1005NP0300□GT C1005NP0330□GT C1005NP0360□GT C1005NP0390□GT C1005NP0430□GT C1005NP0470□GT C1005NP0510□GT C1005NP0560□GT C1005NP0620□GT C1005NP0680□GT C1005NP0750□GT C1005NP0820□GT C1005NP0910□GT C1005NP0101□GT C1005NP0121□GT C1005NP0151□GT C1005NP0181□GT C1005NP0201□GT C1005NP0221□GT Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Value Unit 0.20 pF 0.30 pF 0.40 pF 0.50 pF 0.60 pF 0.68 pF 0.70 pF 0.80 pF 0.82 pF 0.90 pF 1.0 pF 1.2 pF 1.3 pF 1.5 pF 1.8 pF 2.0 pF 2.2 pF 2.4 pF 2.5 pF 2.7 pF 3.0 pF 3.3 pF 3.6 pF 3.9 pF 4.0 pF 4.3 pF 4.7 pF 5.0 pF 5.1 pF 5.6 pF 6.0 pF 6.2 pF 6.8 pF 7.0 pF 7.5 pF 8.0 pF 8.2 pF 9.0 pF 9.1 pF 10 pF 11 pF 12 pF 15 pF 16 pF 18 pF 20 pF 22 pF 24 pF 27 pF 30 pF 33 pF 36 pF 39 pF 43 pF 47 pF 51 pF 56 pF 62 pF 68 pF 75 pF 82 pF 91 pF 100 pF 120 pF 150 pF 180 pF 200 pF 220 pF Available Tolerance ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.25pF,±0.1pF,±0.05pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±0.5pF,±0.25pF,±0.1pF ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±10% ,±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% ±5%,±2%,±1% Thick. (mm) 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 0.25% 0.25% 0.25% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.18% 0.18% 0.17% 0.17% 0.17% 0.16% 0.16% 0.14% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% □ Tolerance Code: A=±0.05 pF, B=±0.1pF, C=±0.25pF ,D=±0.5pF, F=±1%, G=±2%, J=±5%; Special tolerance on the request. 8 Standard Packing Paper, 10Kpcs 25V 16V 10V  DARFON P/N 2 C1005NP0271□GTS C1005NP0301□GTS C1005NP0331□GTS C1005NP0391□GTS C1005NP0471□GTS C1005NP0561□GTS C1005NP0681□GTS C1005NP0821□GTS C1005NP0102□GTS C1005NP0208□FTS C1005NP0308□FTS C1005NP0120□FTS C1005NP0221JFTS C1005NP0102JFTS C1005NP0470□ETS C1005NP0331□ETS C1005NP0220□DTS C1005NP0271□GT C1005NP0301□GT C1005NP0331□GT C1005NP0391□GT C1005NP0471□GT C1005NP0561□GT C1005NP0681□GT C1005NP0821□GT C1005NP0102□GT C1005NP0208□FT C1005NP0308□FT C1005NP0120□FT C1005NP0221JFT C1005NP0102JFT C1005NP0470□ET C1005NP0331□ET C1005NP0220□DT Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz Capacitance Thick. Available Tolerance (mm) Value Unit 270 pF ±5%,±2%,±1% 0.50 300 pF ±5%,±2% 0.50 330 pF ±5%,±2% 0.50 390 pF ±5%,±2%,±1% 0.50 470 pF ±5%,±2% 0.50 560 pF ±5%,±2% 0.50 680 pF ±5%,±2%,±1% 0.50 820 pF ±5%,±2% 0.50 1.0 nF ±5%,±2% 0.50 0.2 pF ±0.25pF,±0.1pF,±0.05pF 0.50 0.3 pF ±0.25pF,±0.1pF,±0.05pF 0.50 12 pF ±5%,±2%,±1% 0.50 220 pF ±5% 0.50 1.0 nF ±5% 0.50 47 pF ±5%,±2%,±1% 0.50 330 pF ±5%,±2% 0.50 22 pF ±5%,±2%,±1% 0.50 Tolerance(mm) L/W Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.25% 0.25% 0.16% 0.10% 0.10% 0.10% 0.10% 0.12% Capacitance Thick. Available Tolerance Value Unit (mm) 0.30 pF ±0.25pF,±0.1pF,±0.05pF 0.80 0.50 pF ±0.25pF,±0.1pF,±0.05pF 0.80 0.75 pF ±0.25pF,±0.1pF,±0.05pF 0.80 1.0 pF ±0.25pF,±0.1pF 0.80 1.2 pF ±0.25pF,±0.1pF 0.80 1.5 pF ±0.25pF,±0.1pF 0.80 1.8 pF ±0.25pF,±0.1pF 0.80 2.0 pF ±0.25pF,±0.1pF 0.80 2.2 pF ±0.25pF,±0.1pF 0.80 2.4 pF ±0.25pF,±0.1pF 0.80 2.7 pF ±0.25pF,±0.1pF 0.80 3.0 pF ±0.25pF,±0.1pF 0.80 3.3 pF ±0.25pF,±0.1pF 0.80 3.9 pF ±0.25pF,±0.1pF 0.80 4.0 pF ±0.25pF,±0.1pF 0.80 4.7 pF ±0.25pF,±0.1pF 0.80 5.0 pF ±0.5pF,±0.25pF,±0.1pF 0.80 5.6 pF ±0.5pF,±0.25pF,±0.1pF 0.80 6.0 pF ±0.5pF,±0.25pF,±0.1pF 0.80 6.2 pF ±0.5pF,±0.25pF,±0.1pF 0.80 6.8 pF ±0.5pF,±0.25pF,±0.1pF 0.80 7.0 pF ±0.5pF,±0.25pF,±0.1pF 0.80 8.2 pF ±0.5pF,±0.25pF,±0.1pF 0.80 9.0 pF ±0.5pF,±0.25pF,±0.1pF 0.80 10 pF ±5%,±2%,±1% 0.80 11 pF ±5%,±2%,±1% 0.80 12 pF ±5%,±2%,±1% 0.80 15 pF ±5%,±2%,±1% 0.80 18 pF ±5%,±2%,±1% 0.80 20 pF ±5%,±2%,±1% 0.80 22 pF ±5%,±2%,±1% 0.80 24 pF ±5%,±2%,±1% 0.80 27 pF ±5%,±2%,±1% 0.80 30 pF ±5%,±2%,±1% 0.80 33 pF ±5%,±2%,±1% 0.80 36 pF ±5%,±2%,±1% 0.80 39 pF ±5%,±2%,±1% 0.80 43 pF ±5%,±2%,±1% 0.80 47 pF ±5%,±2%,±1% 0.80 56 pF ±5%,±2%,±1% 0.80 62 pF ±5%,±2%,±1% 0.80 68 pF ±5%,±2%,±1% 0.80 75 pF ±5%,±2%,±1% 0.80 82 pF ±5%,±2%,±1% 0.80 91 pF ±5%,±2%,±1% 0.80 100 pF ±5%,±2%,±1% 0.80 120 pF ±5%,±2%,±1% 0.80 150 pF ±5%,±2%,±1% 0.80 180 pF ±5%,±2%,±1% 0.80 200 pF ±5%,±2%,±1% 0.80 220 pF ±5%,±2%,±1% 0.80 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 DF (max.) 0.25% 0.24% 0.24% 0.24% 0.24% 0.23% 0.23% 0.23% 0.23% 0.22% 0.22% 0.22% 0.21% 0.21% 0.21% 0.20% 0.20% 0.20% 0.19% 0.19% 0.19% 0.19% 0.18% 0.17% 0.17% 0.16% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs C1608NP0_S Series (EIA0603) RV DARFON P/N DARFON P/N 2 50V C1608NP0308□GTS C1608NP0508□GTS C1608NP0758□GTS C1608NP0109□GTS C1608NP0129□GTS C1608NP0159□GTS C1608NP0189□GTS C1608NP0209□GTS C1608NP0229□GTS C1608NP0249□GTS C1608NP0279□GTS C1608NP0309□GTS C1608NP0339□GTS C1608NP0399□GTS C1608NP0409□GTS C1608NP0479□GTS C1608NP0509□GTS C1608NP0569□GTS C1608NP0609□GTS C1608NP0629□GTS C1608NP0689□GTS C1608NP0709□GTS C1608NP0829□GTS C1608NP0909□GTS C1608NP0100□GTS C1608NP0110□GTS C1608NP0120□GTS C1608NP0150□GTS C1608NP0180□GTS C1608NP0200□GTS C1608NP0220□GTS C1608NP0240□GTS C1608NP0270□GTS C1608NP0300□GTS C1608NP0330□GTS C1608NP0360□GTS C1608NP0390□GTS C1608NP0430□GTS C1608NP0470□GTS C1608NP0560□GTS C1608NP0620□GTS C1608NP0680□GTS C1608NP0750□GTS C1608NP0820□GTS C1608NP0910□GTS C1608NP0101□GTS C1608NP0121□GTS C1608NP0151□GTS C1608NP0181□GTS C1608NP0201□GTS C1608NP0221□GTS C1608NP0308□GT C1608NP0508□GT C1608NP0758□GT C1608NP0109□GT C1608NP0129□GT C1608NP0159□GT C1608NP0189□GT C1608NP0209□GT C1608NP0229□GT C1608NP0249□GT C1608NP0279□GT C1608NP0309□GT C1608NP0339□GT C1608NP0399□GT C1608NP0409□GT C1608NP0479□GT C1608NP0509□GT C1608NP0569□GT C1608NP0609□GT C1608NP0629□GT C1608NP0689□GT C1608NP0709□GT C1608NP0829□GT C1608NP0909□GT C1608NP0100□GT C1608NP0110□GT C1608NP0120□GT C1608NP0150□GT C1608NP0180□GT C1608NP0200□GT C1608NP0220□GT C1608NP0240□GT C1608NP0270□GT C1608NP0300□GT C1608NP0330□GT C1608NP0360□GT C1608NP0390□GT C1608NP0430□GT C1608NP0470□GT C1608NP0560□GT C1608NP0620□GT C1608NP0680□GT C1608NP0750□GT C1608NP0820□GT C1608NP0910□GT C1608NP0101□GT C1608NP0121□GT C1608NP0151□GT C1608NP0181□GT C1608NP0201□GT C1608NP0221□GT Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 9 MLCC 50V DARFON P/N Standard Packing Paper, 4Kpcs Rev. 201710 General Purpose RV RV 50V 25V 16V  RV 50V 16V DARFON P/N DARFON P/N 2 C1608NP0271□GTS C1608NP0331□GTS C1608NP0391□GTS C1608NP0471□GTS C1608NP0561□GTS C1608NP0681□GTS C1608NP0821□GTS C1608NP0102□GTS C1608NP0122JGTS C1608NP0152JGTS C1608NP0182JGTS C1608NP0222JGTS C1608NP0272JGTS C1608NP0332JGTS C1608NP0103JGTS C1608NP0152JFTS C1608NP0682JFTS C1608NP0103JFTS C1608NP0180□ETS C1608NP0300JETS C1608NP0152JETS C1608NP0272JETS C1608NP0332JETS C1608NP0271□GT C1608NP0331□GT C1608NP0391□GT C1608NP0471□GT C1608NP0561□GT C1608NP0681□GT C1608NP0821□GT C1608NP0102□GT C1608NP0122JGT C1608NP0152JGT C1608NP0182JGT C1608NP0222JGT C1608NP0272JGT C1608NP0332JGT C1608NP0103JGT C1608NP0152JFT C1608NP0682JFT C1608NP0103JFT C1608NP0180□ET C1608NP0300JET C1608NP0152JET C1608NP0272JET C1608NP0332JET Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz Capacitance Value Unit 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 10 nF 1.5 nF 6.8 nF 10 nF 18 pF 30 pF 1.5 nF 2.7 nF 3.3 nF Available Tolerance ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5%,±2%,±1% ±5% ±5% ±5% ±5% Thick. (mm) 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.13% 0.10% 0.10% 0.10% 0.10% Thick. (mm) 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 1.25 1.25 1.25 1.25 1.25 1.25 1.25 0.85 1.25 0.60 Tolerance(mm) L/W Thick. ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.10 ±0.15 ±0.20 ±0.15 ±0.15 DF (max.) 0.17% 0.16% 0.14% 0.13% 0.13% 0.12% 0.11% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.11% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs C2012NP0_S Series (EIA0805) DARFON P/N DARFON P/N 2 C2012NP0100□GTS C2012NP0120□GTS C2012NP0150□GTS C2012NP0180□GTS C2012NP0200□GTS C2012NP0220□GTS C2012NP0270□GTS C2012NP0300□GTS C2012NP0330□GTS C2012NP0360□GTS C2012NP0470□GTS C2012NP0680□GTS C2012NP0820□GTS C2012NP0101□GTS C2012NP0121JGTS C2012NP0151JGTS C2012NP0201JGTS C2012NP0221JGTS C2012NP0271JGTS C2012NP0331JGTS C2012NP0391JGTS C2012NP0471JGTS C2012NP0561JGTS C2012NP0681JGTS C2012NP0821JGTS C2012NP0102JGTS C2012NP0122JGTS C2012NP0152JGTS C2012NP0182JGTS C2012NP0222JGTS C2012NP0272JGTS C2012NP0332JGTS C2012NP0392JGTS C2012NP0472JGTS C2012NP0272JGPS C2012NP0332JGPS C2012NP0392JGPS C2012NP0472JGPS C2012NP0562JGPS C2012NP0682JGPS C2012NP0822JGPS C2012NP0103JGTS C2012NP0103JGPS C2012NP0270□ETS C2012NP0100□GT C2012NP0120□GT C2012NP0150□GT C2012NP0180□GT C2012NP0200□GT C2012NP0220□GT C2012NP0270□GT C2012NP0300□GT C2012NP0330□GT C2012NP0360□GT C2012NP0470□GT C2012NP0680□GT C2012NP0820□GT C2012NP0101□GT C2012NP0121JGT C2012NP0151JGT C2012NP0201JGT C2012NP0221JGT C2012NP0271JGT C2012NP0331JGT C2012NP0391JGT C2012NP0471JGT C2012NP0561JGT C2012NP0681JGT C2012NP0821JGT C2012NP0102JGT C2012NP0122JGT C2012NP0152JGT C2012NP0182JGT C2012NP0222JGT C2012NP0272JGT C2012NP0332JGT C2012NP0392JGT C2012NP0472JGT C2012NP0272JGP C2012NP0332JGP C2012NP0392JGP C2012NP0472JGP C2012NP0562JGP C2012NP0682JGP C2012NP0822JGP C2012NP0103JGT C2012NP0103JGP C2012NP0270□GT Measuring Condition 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1MHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1MHz Capacitance Value Unit 10 pF 12 pF 15 pF 18 pF 20 pF 22 pF 27 pF 30 pF 33 pF 36 pF 47 pF 68 pF 82 pF 100 pF 120 pF 150 pF 200 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 10 nF 27 pF Available Tolerance ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5%,±2% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5%,±2% □ Tolerance Code: F=±1%, G=±2%, J=±5%; Special tolerance on the request. 10 Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Emobssed,3Kpcs Paper, 4Kpcs 50V 16V DARFON P/N DARFON P/N 2 C3216NP0103JGPS C3216NP0123JGPS C3216NP0153JGPS C3216NP0183JGPS C3216NP0223JGPS C3216NP0273JGPS C3216NP0333JGPS C3216NP0393JGPS C3216NP0473JGPS C3216NP0104JGPS C3216NP0123JEPS C3216NP0153JEPS C3216NP0183JEPS C3216NP0223JEPS C3216NP0273JEPS C3216NP0333JEPS C3216NP0393JEPS C3216NP0103JGP C3216NP0123JGP C3216NP0153JGP C3216NP0183JGP C3216NP0223JGP C3216NP0273JGP C3216NP0333JGP C3216NP0393JGP C3216NP0473JGP C3216NP0104JGP C3216NP0123JEP C3216NP0153JEP C3216NP0183JEP C3216NP0223JEP C3216NP0273JEP C3216NP0333JEP C3216NP0393JEP Measuring Condition 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz 1V, 1kHz Capacitance Value Unit 10 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 47 nF 100 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF Available Tolerance ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% Thick. (mm) 1.25 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.15 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 Tolerance(mm) L/W Thick. ±0.15 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 DF (max.) 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% Standard Packing Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs □ Tolerance Code: F=±1%, G=±2%, J=±5%; Special tolerance on the request. 11 MLCC RV C3216NP0_S Series (EIA1206) General Purpose  Rev. 201710  Class II: High Dielectric Constant Type  Feature  Application 1. 2. 3. 4. High volumetric efficiency High insulation resistance RoHS compliant Halogen Free 1. 2. 3. 4. 5. 6. Blocking Coupling Timing Bypassing Frequency discriminating Flittering    Part Number & Characteristic X5R Series C0603X5R Series(EIA0201) Capacitance RV DARFON P/N DARFON P/N 2 Measuring Condition 50V C0603X5R102□GTS C0603X5R151KFTS C0603X5R102□GT C0603X5R151KFT 1V , 1kHz 1V , 1kHz 1.0 nF 150 C0603X5R102□FTS C0603X5R103□FTS C0603X5R102□FT C0603X5R103□FT 1V , 1kHz 1V , 1kHz C0603X5R223□FTS C0603X5R104□FTS C0603X5R474MFTS C0603X5R103□ETS C0603X5R223□ETS C0603X5R473□ETS C0603X5R104□ETS C0603X5R224□ETS C0603X5R105METS C0603X5R222□DTS C0603X5R332□DTS C0603X5R472□DTS C0603X5R562□DTS C0603X5R682□DTS C0603X5R822□DTS C0603X5R103□DTS C0603X5R153□DTS C0603X5R223□DTS C0603X5R333□DTS C0603X5R473□DTS C0603X5R563□DTS C0603X5R683□DTS C0603X5R823□DTS C0603X5R104□DTS C0603X5R224□DTS C0603X5R474□DTS C0603X5R105MDTS C0603X5R222□CTS C0603X5R332□CTS C0603X5R472□CTS C0603X5R562□CTS C0603X5R682□CTS C0603X5R822□CTS C0603X5R103□CTS C0603X5R223□CTS C0603X5R333□CTS C0603X5R473□CTS C0603X5R563□CTS C0603X5R683□CTS C0603X5R823□CTS C0603X5R104□CTS C0603X5R224□CTS C0603X5R334□CTS C0603X5R474□CTS C0603X5R105□CTS C0603X5R225MCTS C0603X5R224□BTS C0603X5R474□BTS C0603X5R105□BTS C0603X5R223□FT C0603X5R104□FT C0603X5R474MFT C0603X5R103□ET C0603X5R223□ET C0603X5R473□ET C0603X5R104□ET C0603X5R224□ET C0603X5R105MET C0603X5R222□DT C0603X5R332□DT C0603X5R472□DT C0603X5R562□DT C0603X5R682□DT C0603X5R822□DT C0603X5R103□DT C0603X5R153□DT C0603X5R223□DT C0603X5R333□DT C0603X5R473□DT C0603X5R563□DT C0603X5R683□DT C0603X5R823□DT C0603X5R104□DT C0603X5R224□DT C0603X5R474□DT C0603X5R105MDT C0603X5R222□CT C0603X5R332□CT C0603X5R472□CT C0603X5R562□CT C0603X5R682□CT C0603X5R822□CT C0603X5R103□CT C0603X5R223□CT C0603X5R333□CT C0603X5R473□CT C0603X5R563□CT C0603X5R683□CT C0603X5R823□CT C0603X5R104□CT C0603X5R224□CT C0603X5R334□CT C0603X5R474□CT C0603X5R105□CT C0603X5R225MCT C0603X5R224□BT C0603X5R474□BT C0603X5R105□BT 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 25V 16V 10V 6.3V 4V Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±10% , ±20% ±10% 0.30 0.30 ± 0.03 ± 0.03 ± 0.03 ± 0.03 5.0% 5.0% Paper, 15Kpcs pF (I) (I) 1.0 10 nF nF ±10% , ±20% ±10% , ±20% 0.30 0.30 ± 0.03 ± 0.03 ± 0.03 ± 0.03 5.0% 5.0% 22 100 470 10 22 47 100 220 1.0 2.2 3.3 4.7 5.6 6.8 8.2 10 15 22 33 47 56 68 82 100 220 470 1.0 2.2 3.3 4.7 5.6 6.8 8.2 10 22 33 47 56 68 82 100 220 330 470 1.0 2.2 220 470 1.0 nF nF nF nF nF nF nF nF uF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF uF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF uF uF nF nF uF ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 ± 0.03 ± 0.03 ± 0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.05 ±0.09 ± 0.03 ± 0.03 ±0.05 ± 0.03 ± 0.03 ± 0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.09 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ±0.05 ±0.09 ± 0.03 ± 0.03 ±0.05 7.5% 10.0% 10.0% 5.0% 10.0% 10.0% 10.0% 10.0% 12.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 20.0% 10.0% 12.5% 10.0% Value Unit 12 Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs (I) (II)* (II)* (II) (II)* (II) (II)* (II) (II) (II) (II)* (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II)* (II) (II)* (II)* 50V 35V 25V 16V 10V 6.3V 4V Capacitance DARFON P/N DARFON P/N 2 Measuring Condition C1005X5R103KGTS C1005X5R103KGT 1V , 1kHz 10 C1005X5R473KGTS C1005X5R104□GTS C1005X5R473KGT C1005X5R104□GT 1V , 1kHz 1V , 1kHz 47 100 C1005X5R474□GTS C1005X5R105KGTS C1005X5R105□NTS C1005X5R225KNTS C1005X5R103KFTS C1005X5R223KFTS C1005X5R473KFTS C1005X5R683KFTS C1005X5R104□FTS C1005X5R224□FTS C1005X5R474□FTS C1005X5R105□FTS C1005X5R225□FTS C1005X5R153□ETS C1005X5R223□ETS C1005X5R333□ETS C1005X5R473□ETS C1005X5R563□ETS C1005X5R683□ETS C1005X5R823□ETS C1005X5R104□ETS C1005X5R124□ETS C1005X5R154□ETS C1005X5R184□ETS C1005X5R224□ETS C1005X5R684□ETS C1005X5R105□ETS C1005X5R225□ETS C1005X5R153□DTS C1005X5R223□DTS C1005X5R333□DTS C1005X5R473□DTS C1005X5R563□DTS C1005X5R683□DTS C1005X5R823□DTS C1005X5R104□DTS C1005X5R124□DTS C1005X5R154□DTS C1005X5R184□DTS C1005X5R224□DTS C1005X5R334□DTS C1005X5R394□DTS C1005X5R474□DTS C1005X5R684□DTS C1005X5R105□DTS C1005X5R225□DTS C1005X5R475□DTS C1005X5R106MDTS C1005X5R223KCTS C1005X5R224□CTS C1005X5R334□CTS C1005X5R474□CTS C1005X5R684□CTS C1005X5R105MCTSA C1005X5R105□CTS C1005X5R225MCTSA C1005X5R225□CTS C1005X5R475MCTSA C1005X5R475□CTS C1005X5R106MCTS C1005X5R226MCTS C1005X5R105□BTS C1005X5R225□BTS C1005X5R225MBTSA C1005X5R475□BTS C1005X5R106MBTS C1005X5R226MBTS C1005X5R474□GT C1005X5R105KGT C1005X5R105□NT C1005X5R225KNT C1005X5R103KFT C1005X5R223KFT C1005X5R473KFT C1005X5R683KFT C1005X5R104□FT C1005X5R224□FT C1005X5R474□FT C1005X5R105□FT C1005X5R225□FT C1005X5R153□ET C1005X5R223□ET C1005X5R333□ET C1005X5R473□ET C1005X5R563□ET C1005X5R683□ET C1005X5R823□ET C1005X5R104□ET C1005X5R124□ET C1005X5R154□ET C1005X5R184□ET C1005X5R224□ET C1005X5R684□ET C1005X5R105□ET C1005X5R225□ET C1005X5R153□DT C1005X5R223□DT C1005X5R333□DT C1005X5R473□DT C1005X5R563□DT C1005X5R683□DT C1005X5R823□DT C1005X5R104□DT C1005X5R124□DT C1005X5R154□DT C1005X5R184□DT C1005X5R224□DT C1005X5R334□DT C1005X5R394□DT C1005X5R474□DT C1005X5R684□DT C1005X5R105□DT C1005X5R225□DT C1005X5R475□DT C1005X5R106MDT C1005X5R223KCT C1005X5R224□CT C1005X5R334□CT C1005X5R474□CT C1005X5R684□CT 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 470 1 1.0 2.2 10 22 47 68 100 220 470 1.0 2.2 15 22 33 47 56 68 82 100 120 150 180 220 680 1.0 2.2 15 22 33 47 56 68 82 100 120 150 180 220 330 390 470 680 1.0 2.2 4.7 10 22 220 330 470 680 1.0 1.0 2.2 2.2 4.7 4.7 10 22 1.0 2.2 2.2 4.7 10.0 22 C1005X5R105□CT C1005X5R225□CT C1005X5R475□CT C1005X5R106MCT C1005X5R226MCT C1005X5R105□BT C1005X5R225□BT C1005X5R475□BT C1005X5R106MBT C1005X5R226MBT Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) nF ±10% 0.50 ±0.05 ±0.05 5.0% nF nF ±10% ±10% , ±20% 0.50 0.50 ±0.05 ±0.05 ±0.05 ±0.05 5.0% 10.0% nF uF uF uF nF nF nF nF nF nF nF uF uF nF nF nF nF nF nF nF nF nF nF nF nF nF uF uF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF uF uF uF uF nF nF nF nF nF uF uF uF uF uF uF uF uF uF uF uF uF uF uF ±10% , ±20% ±10% ±10% , ±20% ±10% ±10% ±10% ±10% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.30 0.50 0.30 0.50 0.30 0.50 0.50 0.50 0.50 0.50 0.30 0.50 0.50 0.50 ±0.10 ±0.20 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.15 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.20 ±0.15 ±0.20 ±0.20 ±0.05 ±0.05 ±0.05 ±0.15 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.15 ±0.20 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.03 ±0.05 ±0.03 ±0.05 ±0.03 ±0.15 ±0.20 ±0.20 ±0.05 ±0.05 ±0.03 ±0.15 ±0.20 ±0.20 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 12.5% 12.5% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 7.5% 7.5% 7.5% 10.0% 12.5% 12.5% 12.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 7.5% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% 15.0% 10.0% 10.0% 10.0% 15.0% 15.0% Value Unit Standard Packing Test Spec. (I) (I) Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 15Kpcs Paper, 10Kpcs Paper, 15Kpcs Paper, 10Kpcs Paper, 15Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 15Kpcs Paper, 10Kpcs (II) (II) (II) (II)* (II)* (I) (I) (I) (I) (I) (II) (II) (II)* (II) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (II)* (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (II) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (II) (II) (II) (II) (II)* (II) (II)* (II)* (II)* (II)* (II)* (II)* (II) (II) (II) (II) (II) (II)* □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request. (II)* High temperature load life test are applicable in rated voltage *100% 13 Rev. 201710 MLCC RV C1005X5R Series (EIA0402) General Purpose   RV 50V 35V 25V 16V 10V 6.3V 4V C1608X5R Series (EIA0603) DARFON P/N C1608X5R102KGTS C1608X5R103KGTS C1608X5R333KGTS C1608X5R224KGTS C1608X5R474□GTS C1608X5R105□GTS C1608X5R225□GTS C1608X5R105□NTS C1608X5R225□NTS C1608X5R475□NTS C1608X5R106MNTS C1608X5R104□FTS C1608X5R224□FTS C1608X5R334KFTS C1608X5R474□FTS C1608X5R105□FTS C1608X5R105□FTSB C1608X5R225□FTS C1608X5R475□FTS C1608X5R106MFTS C1608X5R104□ETS C1608X5R224□ETS C1608X5R334□ETS C1608X5R474□ETS C1608X5R684□ETS C1608X5R105□ETS C1608X5R105□ETSB C1608X5R225□ETS C1608X5R475□ETS C1608X5R106□ETS C1608X5R104□DTS C1608X5R224□DTS C1608X5R334□DTS C1608X5R474□DTS C1608X5R684□DTS C1608X5R105□DTS C1608X5R105□DTSB C1608X5R225□DTS C1608X5R225□DTSB C1608X5R335□DTS C1608X5R475□DTS C1608X5R475□DTSB C1608X5R106□DTS C1608X5R226MDTS C1608X5R226MDWS C1608X5R104□CTS C1608X5R105□CTS C1608X5R225□CTS C1608X5R335KCTS C1608X5R475□CTS C1608X5R106MCTSB C1608X5R106□CTS C1608X5R226MCTS C1608X5R476MCTS C1608X5R106MBTS C1608X5R226MBTS C1608X5R476MBTS DARFON P/N 2 C1608X5R102KGT C1608X5R103KGT C1608X5R333KGT C1608X5R224KGT C1608X5R474□GT C1608X5R105□GT C1608X5R225□GT C1608X5R105□NT C1608X5R225□NT C1608X5R475□NT C1608X5R106MNT C1608X5R104□FT C1608X5R224□FT C1608X5R334KFT C1608X5R474□FT C1608X5R105□FT C1608X5R225□FT C1608X5R475□FT C1608X5R106MFT C1608X5R104□ET C1608X5R224□ET C1608X5R334□ET C1608X5R474□ET C1608X5R684□ET C1608X5R105□ET C1608X5R225□ET C1608X5R475□ET C1608X5R106□ET C1608X5R104□DT C1608X5R224□DT C1608X5R334□DT C1608X5R474□DT C1608X5R684□DT C1608X5R105□DT C1608X5R225□DT C1608X5R335□DT C1608X5R475□DT C1608X5R106□DT C1608X5R226MDT C1608X5R226MDW C1608X5R104□CT C1608X5R105□CT C1608X5R225□CT C1608X5R335KCT C1608X5R475□CT C1608X5R106□CT C1608X5R226MCT C1608X5R476MCT C1608X5R106MBT C1608X5R226MBT C1608X5R476MBT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 120Hz Capacitance 1.0 10 33 220 470 1.0 2.2 1.0 2.2 4.7 10 100 220 330 470 1.0 1.0 2.2 4.7 10 100 220 330 470 680 1.0 1.0 2.2 4.7 10 100 220 330 470 680 1.0 1.0 2.2 2.2 3.3 4.7 4.7 10 22 22 100 1.0 2.2 3.3 4.7 10 10 22 47 10 22 47 nF nF nF nF nF uF uF uF uF uF uF nF nF nF nF uF uF uF uF uF nF nF nF nF nF uF uF uF uF uF nF nF nF nF nF uF uF uF uF uF uF uF uF uF uF nF uF uF uF uF uF uF uF uF uF uF uF Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) ±10% ±10% ±10% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ,±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±20% ±20% ±20% 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.50 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.50 0.80 0.80 0.80 0.80 0.80 0.80 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.10 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.15 ±0.10 ±0.15 ±0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10/±0.15 ±0.10 ±0.15 ±0.15 ±0.20 ±0.20 ±0.25 ±0.20 ±0.10 ±0.10 ±0.10 ±0.15 ±0.10 ±0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.10 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.10 ±0.15 ±0.10 ±0.15 +0/-0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0/-0.10 ±0.10 ±0.15 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0/-0.10 ±0.15 +0/-0.10 ±0.15 ±0.15 ±0.05 ±0.20 ±0.25 ±0.20 ±0.10 ±0.10 ±0.10 ±0.15 ±0.10 ±0.10 ±0.15 ±0.20 ±0.20 ±0.10 ±0.20 ±0.20 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 5.0% 7.5% 5.0% 10.0% 12.5% 10.0% 10.0% 10.0% 5.0% 5.0% 5.0% 3.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 7.5% 7.5% 7.5% 7.5% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 12.5% 10.0% 10.0% 12.5% Value Unit 14 Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4kpcs Embossed, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (II) (II) (II) (II) (II) (II)* (II)* (II)* (I) (I) (I) (II) (II) (II)* (II) (II) (II) (I) (I) (I) (II) (II) (II) (II) (II) (II)* (II)* (I) (I) (I) (I) (I) (II) (II) (II) (II)* (II) (II) (II) (II)* (II)* (II)* (I) (II) (II) (II) (II) (II)* (II)* (II)* (II)* (II) (II)* (II)* 50V 35V 25V 16V 10V 6.3V 4V DARFON P/N C2012X5R105□GTS C2012X5R225□GTS C2012X5R105□GPS C2012X5R225□GPS C2012X5R475□GPS C2012X5R106MGPS C2012X5R106KNPS C2012X5R105□FTS C2012X5R105□FPS C2012X5R225□FTS C2012X5R225□FPS C2012X5R475□FTS C2012X5R475□FPS C2012X5R106□FTS C2012X5R106□FPS C2012X5R226MFPS C2012X5R226MFWS C2012X5R105□ETS C2012X5R105□EPS C2012X5R225□EPS C2012X5R335□EPS C2012X5R475□ETS C2012X5R475□EPS C2012X5R106□ETS C2012X5R106□EPS C2012X5R226METS C2012X5R225□DTS C2012X5R335□DPS C2012X5R475□DPS C2012X5R106□DTS C2012X5R106□DPS C2012X5R226MDTS C2012X5R476MDPS C2012X5R225KCTS C2012X5R475□CPS C2012X5R106□CTS C2012X5R106□CPS C2012X5R226MCTS C2012X5R226□CPS C2012X5R476MCTS C2012X5R476MCPS C2012X5R107MCPS C2012X5R107MBPS DARFON P/N 2 C2012X5R105□GT C2012X5R225□GT C2012X5R105□GP C2012X5R225□GP C2012X5R475□GP C2012X5R106MGP C2012X5R106KNP C2012X5R105□FT C2012X5R105□FP C2012X5R225□FT C2012X5R225□FP C2012X5R475□FT C2012X5R475□FP C2012X5R106□FT C2012X5R106□FP C2012X5R226MFP C2012X5R226MFW C2012X5R105□ET C2012X5R105□EP C2012X5R225□EP C2012X5R335□EP C2012X5R475□ET C2012X5R475□EP C2012X5R106□ET C2012X5R106□EP C2012X5R226MET C2012X5R225□DT C2012X5R335□DP C2012X5R475□DP C2012X5R106□DT C2012X5R106□DP C2012X5R226MDT C2012X5R476MDP C2012X5R225KCT C2012X5R475□CP C2012X5R106□CT C2012X5R106□CP C2012X5R226MCT C2012X5R226□CP C2012X5R476MCT C2012X5R476MCP C2012X5R107MCP C2012X5R107MBP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance 1.0 2.2 1.0 2.2 4.7 10.0 10.0 1.0 1.0 2.2 2.2 4.7 4.7 10 10 22 22 1.0 1.0 2.2 3.3 4.7 4.7 10 10 22 2.2 3.3 4.7 10 10 22 47 2.2 4.7 10 10 22 22 47 47 100 100 uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±20% ±20% ±20% ±20% 0.85 0.85 1.25 1.25 1.25 1.25 1.25 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 1.25 0.85 1.25 1.25 1.25 0.85 1.25 0.85 1.25 0.85 0.85 1.25 1.25 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 0.85 1.25 1.25 1.25 ±0.15 ±0.20 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.20 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.10 ±0.20 ±0.10 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.10 ±0.20 ±0.15 ±0.20 ±0.10 ±0.20 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.20 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 12.5% 12.5% 15.0% 15.0% 10.0% 5.0% 5.0% 10.0% 10.0% 7.5% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% Value Unit Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Test Spec. (II) (II) (II) (II) (II) (II)* (II)* (II) (I) (II) (II) (II)* (II) (II)* (II)* (II) (II) (II) (I) (II) (II) (II) (II) (II)* (II)* (II)* (II) (II) (II) (II) (II) (II)* (II)* (II) (I) (II) (II) (II) (II) (II)* (II)* (II)* (II)* □ Tolerance Code: K=±10%, M=±20% ;(II)* High temperature load life test are applicable in rated voltage *100% 15 Rev. 201710 MLCC RV C2012X5R Series (EIA0805) General Purpose   RV 50V 35V 25V 16V 10V 6.3V 4V  RV 50V 35V 25V 16V 10V 6.3V  RV 50V C3216X5R Series (EIA1206) DARFON P/N C3216X5R225□GTS C3216X5R475□GTS C3216X5R475□GPS C3216X5R106□GPS C3216X5R106□NTS C3216X5R106□NPS C3216X5R105KFTSE C3216X5R225□FPS C3216X5R475□FPS C3216X5R106□FPS C3216X5R226MFTSE C3216X5R226□FPSL C3216X5R225□EPS C3216X5R475□EPS C3216X5R106□EPS C3216X5R226□EPS C3216X5R226METSE C3216X5R476MEPS C3216X5R225□DPS C3216X5R475□DPS C3216X5R106□DPS C3216X5R226□DPS C3216X5R226MDTSE C3216X5R476□DPS C3216X5R106KCPS C3216X5R226□CPS C3216X5R476MCPS C3216X5R107MCPS C3216X5R226□BPS C3216X5R476MBPS C3216X5R107MBPS C3216X5R227MBPSL Measuring Condition DARFON P/N 2 C3216X5R225□GT C3216X5R475□GT C3216X5R475□GP C3216X5R106□GP C3216X5R106□NT C3216X5R106□NP C3216X5R225□FP C3216X5R475□FP C3216X5R106□FP C3216X5R226MFT C3216X5R226□FP C3216X5R225□EP C3216X5R475□EP C3216X5R106□EP C3216X5R226□EP C3216X5R226MET C3216X5R476MEP C3216X5R225□DP C3216X5R475□DP C3216X5R106□DP C3216X5R226□DP C3216X5R226MDT C3216X5R476□DP C3216X5R106KCP C3216X5R226□CP C3216X5R476MCP C3216X5R107MCP C3216X5R226□BP C3216X5R476MBP C3216X5R107MBP C3216X5R227MBP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance 2.2 4.7 4.7 10 10 10 1.0 2.2 4.7 10 22 22 2.2 4.7 10 22 22 47 2.2 4.7 10 22 22 47 10 22 47 100 22 47 100 220 uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF Tolerance(mm) Available Tolerance Thick. (mm) L/W Thick. DF (max.) ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% ±10% , ±20% ±20% ±20% ±10% , ±20% ±20% ±20% ±20% 0.85 0.85 1.60 1.60 0.85 1.60 0.85 1.60 1.60 1.60 0.85 1.60 1.60 1.60 1.60 1.60 0.85 1.60 1.60 1.60 1.60 1.60 0.85 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 1.60 ±0.15 ±0.15 ±0.20 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 ±0.30 ±0.10 ±0.10 ±0.30 ±0.20 ±0.10 ±0.30 ±0.10 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 3.5% 5.0% 5.0% 10.0% 10.0% 10.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 7.5% 7.5% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% 10.0% 15.0% 15.0% 15.0% 15.0% 15.0% Available Tolerance Thick. (mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±20% ±10% , ±20% ±10% , ±20% ±20% 2.50 2.50 2.00 2.00 2.50 2.00 2.00 2.50 2.50 1.90 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 2.50 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30/±0.20 ±0.30 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 ±0.20 +0.1/-0.2 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 ±0.20 ±0.20 ±0.30 5.0% 5.0% 10.0% 10.0% 10.0% 5.0% 5.0% 15.0% 15.0% 15.0% 15.0% 15.0% 10.0% 10.0% 10.0% 10.0% 10.0% 15.0% 15.0% Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 2Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 2Kpcs Embossed,0.5Kpcs Embossed, 1Kpcs Embossed,2Kpcs Embossed,0.5Kpcs (II) (I) (I) (I) (II) (I) (I) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) (II) Available Tolerance Thick. (mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±10% 1.60 ±0.30 ±0.20 10.0% Embossed, 1Kpcs (II)* Value Unit Standard Packing Paper, 4Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed,2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Test Spec. (II) (II) (II) (II) (II)* (II) (I) (I) (I) (II) (II)* (II) (I) (I) (II) (II) (II)* (II) (I) (I) (II) (II) (II)* (II) (II) (II) (II) (II) (II) (II) (II) (II) C3225X5R Series (EIA1210) DARFON P/N C3225X5R106□GPS C3225X5R106□NPS C3225X5R475□FWS C3225X5R106□FPS C3225X5R226□FPS C3225X5R475□EWS C3225X5R106□EPS C3225X5R226□EWS C3225X5R226□EPS C3225X5R476MEPSS C3225X5R476□EWS C3225X5R476□EPS C3225X5R107MEPS C3225X5R226□DPS C3225X5R476□DPS C3225X5R107MDPS C3225X5R226□CPS C3225X5R476□CPS C3225X5R107MCPS Measuring Condition DARFON P/N 2 C3225X5R106□GP C3225X5R106□NP C3225X5R475□FW C3225X5R106□FP C3225X5R226□FP C3225X5R475□EW C3225X5R106□EP C3225X5R226□EW C3225X5R226□EP C3225X5R476MEP C3225X5R476□EW C3225X5R476□EP C3225X5R107MEP C3225X5R226□DP C3225X5R476□DP C3225X5R107MDP C3225X5R226□CP C3225X5R476□CP C3225X5R107MCP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance Value Unit 10 10 4.7 10 22 4.7 10 22 22 47 47 47 100 22 47 100 22 47 100 uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF uF Tolerance(mm) Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 1Kpcs C4532X5R Series (EIA1812) DARFON P/N C4532X5R225KGPS DARFON P/N 2 C4532X5R225KGP Measuring Condition 1V , 1kHz Capacitance Value Unit 2.2 uF □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.; (II)* High temperature load life test are applicable in rated voltage *100% 16 Tolerance(mm)  C0603X6S Series (EIA0201) Capacitance Value Unit DARFON P/N 2 Measuring Condition C0603X6S103KFTS C0603X6S103KFT 1V , 1kHz 10 nF ±10% 0.30 ± 0.03 ±0.03 5.0% C0603X6S104KFTS C0603X6S103KETS 16V C0603X6S104□ETS C0603X6S104KDTS 10V C0603X6S224□DTS C0603X6S103□CTS C0603X6S473□CTS 6.3V C0603X6S104□CTS C0603X6S224□CTS C0603X6S105MCTS C0603X6S104□BTS C0603X6S224□BTS 4V C0603X6S474MBTS C0603X6S105MBTS C0603X6S104KFT C0603X6S103KET C0603X6S104□ET C0603X6S104KDT C0603X6S224□DT C0603X6S103□CT C0603X6S473□CT C0603X6S104□CT C0603X6S224□CT C0603X6S105MCT C0603X6S104□BT C0603X6S224□BT C0603X6S474MBT C0603X6S105MBT 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 0.5V , 1kHz 100 10 100 100 220 10 47 100 220 1 100 220 470 1 nF nF nF nF nF nF nF nF nF uF nF nF nF uF ±10% ±10% ±10%, ±20% ±10% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±10%, ±20% ±20% ±10%, ±20% ±10%, ±20% ±20% ±20% 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ±0.03 ± 0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ±0.03 ± 0.09 ±0.03 ±0.03 ±0.03 ± 0.09 10.0% 5.0% 10.0% 10.0% 10.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 10.0% 25V  RV DARFON P/N C1005X6S104KFTS C1005X6S224KFTS C1005X6S105□FTS C1005X6S224KETS 16V C1005X6S105□ETS C1005X6S225METS C1005X6S105□DTS 10V C1005X6S225□DTS C1005X6S224KCTS C1005X6S105□CTS 6.3V C1005X6S225□CTS C1005X6S475MCTS C1005X6S106MCTS 4V C1005X6S106MBTS RV 0.03 0.03 0.03 0.03 0.03 0.03 0.03 0.03 0.03 0.09 0.03 0.03 0.03 0.09 Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (II)* (I) (II) (II) (II) (I) (I) (II)* (II)* (II)* (II) (II) (II) (II)* C1005X6S Series (EIA0402) 25V  Available Tolerance Thick. Tolerance(mm) DF (mm) L/W Thick. (max.) DARFON P/N RV DARFON P/N 2 C1005X6S104KFT C1005X6S224KFT C1005X6S105□FT C1005X6S224KET C1005X6S105□ET C1005X6S225MET C1005X6S105□DT C1005X6S225□DT C1005X6S224KCT C1005X6S105□CT C1005X6S225□CT C1005X6S475MCT C1005X6S106MCT C1005X6S106MBT Measuring Capacitance Available Thick. Tolerance(mm) DF Condition Value Unit Tolerance (mm) L/W Thick. (max.) 1V , 1kHz 100 nF ±10% 0.50 ±0.05 ±0.05 10.0% 1V , 1kHz 220 nF ±10% 0.50 ±0.05 ±0.05 10.0% 0.5V , 1kHz 1.0 uF ±10%, ±20% 0.50 ±0.10 ±0.10 10.0% 1V , 1kHz 220 nF ±10% 0.50 ±0.05 ±0.05 10.0% 0.5V , 1kHz 1.0 uF ±10%, ±20% 0.50 ±0.10 ±0.10 12.5% 1V , 1kHz 2.2 uF ±20% 0.50 ±0.20 ±0.20 10.0% 0.5V , 1kHz 1.0 uF ±10%, ±20% 0.50 ±0.05 ±0.05 12.5% 1V , 1kHz 2.2 uF ±10%, ±20% 0.50 ±0.20 ±0.20 10.0% 1V , 1kHz 220 nF ±10% 0.50 ±0.05 ±0.05 10.0% 0.5V , 1kHz 1.0 uF ±10%, ±20% 0.50 ±0.05 ±0.05 10.0% 0.5V , 1kHz 2.2 uF ±10%, ±20% 0.50 ±0.05 ±0.05 10.0% 0.5V , 1kHz 4.7 uF ±20% 0.50 ±0.15 ±0.15 10.0% 0.5V , 1kHz 10 uF ±20% 0.50 ±0.20 ±0.20 10.0% 0.5V , 1kHz 10 uF ±20% 0.50 ±0.20 ±0.20 10.0% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (II) (II) (II)* (II) (II)* (II) (II)* (II) (II) (II)* (II)* (II)* (II)* (II)* C1608X6S Series (EIA0603) DARFON P/N 25V C1608X6S475□FTS C1608X6S105KETS C1608X6S225KETS 16V C1608X6S475KETS C1608X6S106METS C1608X6S225DTS 10V C1608X6S475KDTS C1608X6S106MDTS C1608X6S475□CTS 6.3V C1608X6S106MCTS C1608X6S226MCTS C1608X6S106MBTS 4V C1608X6S226MBTS C1608X6S475□FT C1608X6S105KET C1608X6S225KET C1608X6S475KET C1608X6S106MET C1608X6S225KDT C1608X6S475KDT C1608X6S106MDT C1608X6S475□CT C1608X6S106MCT C1608X6S226MCT C1608X6S106MBT Measuring Capacitance Available Thick. Tolerance(mm) DF Condition Value Unit Tolerance (mm) L/W Thick. (max.) 1V , 1kHz 4.7 uF ±10%,±20% 0.80 ±0.20 ±0.20 10.0% 1V , 1kHz 1.0 uF ±10% 0.80 ±0.15 ±0.15 10.0% 1V , 1kHz 2.2 uF ±10% 0.80 ±0.10 ±0.10 10.0% 1V , 1kHz 4.7 uF ±10% 0.80 ±0.20 ±0.20 10.0% 1V , 1kHz 10 uF ±20% 0.80 ±0.20 ±0.20 10.0% 1V , 1kHz 2.2 uF ±10% 0.80 ±0.10 ±0.10 10.0% 1V , 1kHz 4.7 uF ±10% 0.80 ±0.15 ±0.15 10.0% 1V , 1kHz 10 uF ±20% 0.80 ±0.20 ±0.20 10.0% 1V , 1kHz 4.7 uF ±10%,±20% 0.80 ±0.10 ±0.10 10.0% 0.5V , 120Hz 10 uF ±20% 0.80 ±0.20 ±0.20 10.0% 0.5V , 120Hz 22 uF ±20% 0.80 ±0.20 ±0.20 10.0% 0.5V , 120Hz 10 uF ±20% 0.80 ±0.20 ±0.20 10.0% C1608X6S226MBT 0.5V , 120Hz DARFON P/N 2 22 uF 17 ±20% 0.80 ±0.20 ±0.20 10.0% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Test Spec. (II)* (II) (II) (II) (II) (II) (II) (II) (II)* (II) (II)* (II) (II)* Rev. 201710 MLCC X6S Series General Purpose   RV C2012X6S Series (EIA0805) DARFON P/N 50V C2012X6S475KGPS 25V C2012X6S106KFPS C2012X6S106KEPS 16V C2012X6S226MEPS C2012X6S106KDPS 10V C2012X6S226MDPS C2012X6S106MCPS 6.3V C2012X6S226MCPS C2012X6S106MBPS C2012X6S226MBPS 4V C2012X6S476MBPS C2012X6S107MBPS  RV RV Measuring Condition C2012X6S475KGP C2012X6S106KFP C2012X6S106KEP C2012X6S226MEP C2012X6S106KDP C2012X6S226MDP C2012X6S106MCP C2012X6S226MCP C2012X6S106MBP C2012X6S226MBP C2012X6S476MBP C2012X6S107MBP 1V , 1kHz 0.5V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 0.5V , 120Hz Capacitance Value Unit 4.7 uF 10 uF 10 uF 22 uF 10 uF 22 uF 10 uF 22 uF 10 uF 22 uF 47 uF 100 uF Available Tolerance ±10% ±10% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Thick. Tolerance(mm) DF (mm) L/W Thick. (max.) 1.25 ±0.20 ±0.20 10.0% 1.25 ±0.15 ±0.20 12.5% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.20 ±0.20 10.0% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.20 ±0.20 10.0% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.15 ±0.15 10.0% 1.25 ±0.20 ±0.20 10.0% 1.25 ±0.20 ±0.20 10.0% Standard Packing Test Spec. Embossed, 3Kpcs Embossed, 3Kpcs (II) (II)* (II) (II)* (II)* (II) (II)* (II)* (II) (II) (II)* (II)* Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Embossed, 3Kpcs C3216X6S Series (EIA1206) DARFON P/N 35V C3216X6S106KNPS C3216X6S106KFPS 25V C3216X6S226□FPS 16V C3216X6S226MEPS 10V C3216X6S476MDPS 6.3V C3216X6S476MCPS C3216X6S226MBTS 4V C3216X6S107MBPS  DARFON P/N 2 DARFON P/N 2 C3216X6S106KNP C3216X6S106KFP C3216X6S226□FP C3216X6S226MEP C3216X6S476MDP C3216X6S476MCP C3216X6S226MBT C3216X6S107MBP Measuring Capacitance Available Thick. Tolerance(mm) DF Condition Value Unit Tolerance (mm) L/W Thick. (max.) 1V , 1kHz 10 uF ±10% 1.60 ±0.20 ±0.20 10.0% 1V , 1kHz 10 uF ±10% 1.60 ±0.20 ±0.20 10.0% 0.5V , 120Hz 22 uF ±10%,±20% 1.60 ±0.30 ±0.30 10.0% 0.5V , 120Hz 22 uF ±20% 1.60 ±0.20 ±0.20 10.0% 0.5V , 120Hz 47 uF ±20% 1.60 ±0.30 ±0.30 10.0% 0.5V , 120Hz 47 uF ±20% 1.60 ±0.20 ±0.20 10.0% 0.5V , 120Hz 22 uF ±20% 0.85 ±0.20 ±0.10 10.0% 0.5V , 120Hz 100 uF ±20% 1.60 ±0.20 ±0.20 10.0% Standard Packing Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 2Kpcs Test Spec. (II) (II) (II) (II) (II) (II) (II) (II) Standard Packing Embossed, 1Kpcs Embossed, 1Kpcs Test Spec. (II)* (II) Embossed, 2Kpcs C3225X6S Series (EIA1210) DARFON P/N DARFON P/N 2 16V C3225X6S476MEPS C3225X6S476MEP 6.3V C3225X6S107MCPS C3225X6S107MCP Measuring Capacitance Condition Value Unit 0.5V , 120Hz 47 uF 0.5V , 120Hz 100 uF □ Tolerance Code: K=±10%, M=±20% ;Special tolerance on the request.; (II)* High temperature load life test are applicable in rated voltage *100% 18 Available Tolerance ±20% ±20% Thick. Tolerance(mm) DF (mm) L/W Thick. (max.) 2.50 ±0.30 ±0.20 10.0% 2.50 ±0.30 ±0.30 10.0%  C0603X7R Series(EIA0201) RV 50V 25V 16V 10V 6.3V DARFON P/N C0603X7R101□GTS C0603X7R121KGTS C0603X7R151KGTS C0603X7R181KGTS C0603X7R221□GTS C0603X7R271KGTS C0603X7R331KGTS C0603X7R391KGTS C0603X7R471KGTS C0603X7R561KGTS C0603X7R681□GTS C0603X7R821KGTS C0603X7R102KGTS C0603X7R122KGTS C0603X7R152KGTS C0603X7R182KGTS C0603X7R222KGTS C0603X7R101KFTS C0603X7R121KFTS C0603X7R151KFTS C0603X7R181KFTS C0603X7R221KFTS C0603X7R271KFTS C0603X7R331KFTS C0603X7R391KFTS C0603X7R471□FTS C0603X7R561KFTS C0603X7R681KFTS C0603X7R821KFTS C0603X7R102KFTS C0603X7R122KFTS C0603X7R152KFTS C0603X7R182KFTS C0603X7R222KFTS C0603X7R332KFTS C0603X7R682KFTS C0603X7R103KFTS C0603X7R101KETS C0603X7R221KETS C0603X7R331KETS C0603X7R471KETS C0603X7R681□ETS C0603X7R821□ETS C0603X7R102□ETS C0603X7R152□ETS C0603X7R222KETS C0603X7R272□ETS C0603X7R332KETS C0603X7R392KETS C0603X7R472KETS C0603X7R562KETS C0603X7R682KETS C0603X7R822KETS C0603X7R103KETS C0603X7R182KDTS C0603X7R222KDTS C0603X7R272□DTS C0603X7R332KDTS C0603X7R392KDTS C0603X7R472KDTS C0603X7R562KDTS C0603X7R682KDTS C0603X7R822KDTS C0603X7R103KDTS C0603X7R103KCTS DARFON P/N 2 C0603X7R101□GT C0603X7R121KGT C0603X7R151KGT C0603X7R181KGT C0603X7R221□GT C0603X7R271KGT C0603X7R331KGT C0603X7R391KGT C0603X7R471KGT C0603X7R561KGT C0603X7R681□GT C0603X7R821KGT C0603X7R102KGT C0603X7R122KGT C0603X7R152KGT C0603X7R182KGT C0603X7R222KGT C0603X7R101KFT C0603X7R121KFT C0603X7R151KFT C0603X7R181KFT C0603X7R221KFT C0603X7R271KFT C0603X7R331KFT C0603X7R391KFT C0603X7R471□FT C0603X7R561KFT C0603X7R681KFT C0603X7R821KFT C0603X7R102KFT C0603X7R122KFT C0603X7R152KFT C0603X7R182KFT C0603X7R222KFT C0603X7R332KFT C0603X7R682KFT C0603X7R103KFT C0603X7R101KET C0603X7R221KET C0603X7R331KET C0603X7R471KET C0603X7R681□ET C0603X7R821□ET C0603X7R102□ET C0603X7R152□ET C0603X7R222KET C0603X7R272□ET C0603X7R332KET C0603X7R392KET C0603X7R472KET C0603X7R562KET C0603X7R682KET C0603X7R822KET C0603X7R103KET C0603X7R182KDT C0603X7R222KDT C0603X7R272□DT C0603X7R332KDT C0603X7R392KDT C0603X7R472KDT C0603X7R562KDT C0603X7R682KDT C0603X7R822KDT C0603X7R103KDT C0603X7R103KCT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Available Tolerance Value Unit 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 100 pF 120 pF 150 pF 180 pF 220 pF 270 pF 330 pF 390 pF 470 pF 560 pF 680 pF 820 pF 1.0 nF 1.2 nF 1.5 nF 1.8 nF 2.2 nF 3.3 nF 6.8 nF 10 nF 100 pF 220 pF 330 pF 470 pF 680 pF 820 pF 1.0 nF 1.5 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 1.8 nF 2.2 nF 2.7 nF 3.3 nF 3.9 nF 4.7 nF 5.6 nF 6.8 nF 8.2 nF 10 nF 10 nF ±10%, ±5% ±10% ±10% ±10% ±10%, ±5% ±10% ±10% ±10% ±10% ±10% ±10%, ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±5% ±10%, ±5% ±10%, ±5% ±10%, ±5% ±10% ±10%, ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±5% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% Thick. (mm) 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Tolerance(mm) L/W ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 Thick. ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 ± 0.03 DF (max.) 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% Standard Packing Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Paper, 15Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request. 19 Rev. 201710 MLCC X7R Series General Purpose   RV 50V 25V 16V C1005X7R Series (EIA0402) DARFON P/N DARFON P/N 2 Measuring Condition C1005X7R101□GTS C1005X7R121KGTS C1005X7R151KGTS C1005X7R181KGTS C1005X7R221KGTS C1005X7R271KGTS C1005X7R331KGTS C1005X7R391KGTS C1005X7R471KGTS C1005X7R561KGTS C1005X7R681KGTS C1005X7R751KGTS C1005X7R821KGTS C1005X7R102□GTS C1005X7R122KGTS C1005X7R152KGTS C1005X7R182KGTS C1005X7R222□GTS C1005X7R272□GTS C1005X7R332□GTS C1005X7R392KGTS C1005X7R472KGTS C1005X7R562KGTS C1005X7R682KGTS C1005X7R822KGTS C1005X7R103KGTS C1005X7R123KGTS C1005X7R153KGTS C1005X7R223KGTS C1005X7R333KGTS C1005X7R473KGTS C1005X7R104KGTS C1005X7R101KFTS C1005X7R121KFTS C1005X7R151KFTS C1005X7R181KFTS C1005X7R221KFTS C1005X7R271KFTS C1005X7R331KFTS C1005X7R391KFTS C1005X7R471KFTS C1005X7R561KFTS C1005X7R681KFTS C1005X7R821KFTS C1005X7R102KFTS C1005X7R122KFTS C1005X7R152KFTS C1005X7R182KFTS C1005X7R222KFTS C1005X7R272KFTS C1005X7R332□FTS C1005X7R392KFTS C1005X7R472KFTS C1005X7R562KFTS C1005X7R682KFTS C1005X7R822KFTS C1005X7R103□FTS C1005X7R123KFTS C1005X7R153□FTS C1005X7R183KFTS C1005X7R223□FTS C1005X7R273KFTS C1005X7R333KFTS C1005X7R473KFTS C1005X7R563KFTS C1005X7R683KFTS C1005X7R104KFTS C1005X7R224KFTS C1005X7R101KETS C1005X7R121KETS C1005X7R151KETS C1005X7R181KETS C1005X7R221KETS C1005X7R101□GT C1005X7R121KGT C1005X7R151KGT C1005X7R181KGT C1005X7R221KGT C1005X7R271KGT C1005X7R331KGT C1005X7R391KGT C1005X7R471KGT C1005X7R561KGT C1005X7R681KGT C1005X7R751KGT C1005X7R821KGT C1005X7R102□GT C1005X7R122KGT C1005X7R152KGT C1005X7R182KGT C1005X7R222□GT C1005X7R272□GT C1005X7R332□GT C1005X7R392KGT C1005X7R472KGT C1005X7R562KGT C1005X7R682KGT C1005X7R822KGT C1005X7R103KGT C1005X7R123KGT C1005X7R153KGT C1005X7R223KGT C1005X7R333KGT C1005X7R473KGT C1005X7R104KGT C1005X7R101KFT C1005X7R121KFT C1005X7R151KFT C1005X7R181KFT C1005X7R221KFT C1005X7R271KFT C1005X7R331KFT C1005X7R391KFT C1005X7R471KFT C1005X7R561KFT C1005X7R681KFT C1005X7R821KFT C1005X7R102KFT C1005X7R122KFT C1005X7R152KFT C1005X7R182KFT C1005X7R222KFT C1005X7R272KFT C1005X7R332□FT C1005X7R392KFT C1005X7R472KFT C1005X7R562KFT C1005X7R682KFT C1005X7R822KFT C1005X7R103□FT C1005X7R123KFT C1005X7R153□FT C1005X7R183KFT C1005X7R223□FT C1005X7R273KFT C1005X7R333KFT C1005X7R473KFT C1005X7R563KFT C1005X7R683KFT C1005X7R104KFT C1005X7R224KFT C1005X7R101KET C1005X7R121KET C1005X7R151KET C1005X7R181KET C1005X7R221KET 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 100 pF ±10%, ±5% 0.50 120 pF ±10% 0.50 150 pF ±10% 0.50 180 pF ±10% 0.50 220 pF ±10% 0.50 270 pF ±10% 0.50 330 pF ±10% 0.50 390 pF ±10% 0.50 470 pF ±10% 0.50 560 pF ±10% 0.50 680 pF ±10% 0.50 750 pF ±10% 0.50 820 pF ±10% 0.50 1.0 nF ±10%, ±5% 0.50 1.2 nF ±10% 0.50 1.5 nF ±10% 0.50 1.8 nF ±10% 0.50 2.2 nF ±10%, ±5% 0.50 2.7 nF ±10%, ±5% 0.50 3.3 nF ±10%, ±5% 0.50 3.9 nF ±10% 0.50 4.7 nF ±10% 0.50 5.6 nF ±10% 0.50 6.8 nF ±10% 0.50 8.2 nF ±10% 0.50 10 nF ±10% 0.50 12 nF ±10% 0.50 15 nF ±10% 0.50 22 nF ±10% 0.50 33 nF ±10% 0.50 47 nF ±10% 0.50 100 nF ±10% 0.50 100 pF ±10% 0.50 120 pF ±10% 0.50 150 pF ±10% 0.50 180 pF ±10% 0.50 220 pF ±10% 0.50 270 pF ±10% 0.50 330 pF ±10% 0.50 390 pF ±10% 0.50 470 pF ±10% 0.50 560 pF ±10% 0.50 680 pF ±10% 0.50 820 pF ±10% 0.50 1.0 nF ±10% 0.50 1.2 nF ±10% 0.50 1.5 nF ±10% 0.50 1.8 nF ±10% 0.50 2.2 nF ±10% 0.50 2.7 nF ±10% 0.50 3.3 nF ±10%, ±5% 0.50 3.9 nF ±10% 0.50 4.7 nF ±10% 0.50 5.6 nF ±10% 0.50 6.8 nF ±10% 0.50 8.2 nF ±10% 0.50 10 nF ±10%, ±5% 0.50 12 nF ±10% 0.50 15 nF ±10%, ±5% 0.50 18 nF ±10% 0.50 22 nF ±10%, ±5% 0.50 27 nF ±10% 0.50 33 nF ±10% 0.50 47 nF ±10% 0.50 56 nF ±10% 0.50 68 nF ±10% 0.50 100 nF ±10% 0.50 220 nF ±10% 0.50 100 pF ±10% 0.50 120 pF ±10% 0.50 150 pF ±10% 0.50 180 pF ±10% 0.50 220 pF ±10% 0.50 20 Tolerance(mm) L/W Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.10 ±0.10 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 10.0% 10.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 3.5% 3.5% 3.5% 3.5% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (I) (I) (I) (I) 16V 10V 6.3V DARFON P/N 2 C1005X7R271KETS C1005X7R331KETS C1005X7R391KETS C1005X7R471KETS C1005X7R561KETS C1005X7R681KETS C1005X7R821KETS C1005X7R102KETS C1005X7R122KETS C1005X7R152KETS C1005X7R182KETS C1005X7R222KETS C1005X7R272KETS C1005X7R332KETS C1005X7R392KETS C1005X7R472KETS C1005X7R562KETS C1005X7R682KETS C1005X7R822KETS C1005X7R103KETS C1005X7R123KETS C1005X7R153KETS C1005X7R183KETS C1005X7R223KETS C1005X7R273KETS C1005X7R333KETS C1005X7R393KETS C1005X7R473KETS C1005X7R563KETS C1005X7R683KETS C1005X7R823KETS C1005X7R104□ETS C1005X7R154KETS C1005X7R224KETS C1005X7R101KDTS C1005X7R121KDTS C1005X7R151KDTS C1005X7R181KDTS C1005X7R221KDTS C1005X7R271KDTS C1005X7R331KDTS C1005X7R391KDTS C1005X7R471KDTS C1005X7R561KDTS C1005X7R681KDTS C1005X7R821KDTS C1005X7R102KDTS C1005X7R122KDTS C1005X7R152KDTS C1005X7R182KDTS C1005X7R222KDTS C1005X7R272KDTS C1005X7R332KDTS C1005X7R392KDTS C1005X7R472KDTS C1005X7R562KDTS C1005X7R682KDTS C1005X7R822KDTS C1005X7R103KDTS C1005X7R123KDTS C1005X7R153KDTS C1005X7R183KDTS C1005X7R223KDTS C1005X7R273KDTS C1005X7R333KDTS C1005X7R393KDTS C1005X7R473KDTS C1005X7R563KDTS C1005X7R683KDTS C1005X7R823KDTS C1005X7R104□DTS C1005X7R224KDTS C1005X7R474KDTS C1005X7R103KCTS C1005X7R473KCTS C1005X7R104KCTS C1005X7R474□CTS C1005X7R105□CTS C1005X7R271KET C1005X7R331KET C1005X7R391KET C1005X7R471KET C1005X7R561KET C1005X7R681KET C1005X7R821KET C1005X7R102KET C1005X7R122KET C1005X7R152KET C1005X7R182KET C1005X7R222KET C1005X7R272KET C1005X7R332KET C1005X7R392KET C1005X7R472KET C1005X7R562KET C1005X7R682KET C1005X7R822KET C1005X7R103KET C1005X7R123KET C1005X7R153KET C1005X7R183KET C1005X7R223KET C1005X7R273KET C1005X7R333KET C1005X7R393KET C1005X7R473KET C1005X7R563KET C1005X7R683KET C1005X7R823KET C1005X7R104□ET C1005X7R154KET C1005X7R224KET C1005X7R101KDT C1005X7R121KDT C1005X7R151KDT C1005X7R181KDT C1005X7R221KDT C1005X7R271KDT C1005X7R331KDT C1005X7R391KDT C1005X7R471KDT C1005X7R561KDT C1005X7R681KDT C1005X7R821KDT C1005X7R102KDT C1005X7R122KDT C1005X7R152KDT C1005X7R182KDT C1005X7R222KDT C1005X7R272KDT C1005X7R332KDT C1005X7R392KDT C1005X7R472KDT C1005X7R562KDT C1005X7R682KDT C1005X7R822KDT C1005X7R103KDT C1005X7R123KDT C1005X7R153KDT C1005X7R183KDT C1005X7R223KDT C1005X7R273KDT C1005X7R333KDT C1005X7R393KDT C1005X7R473KDT C1005X7R563KDT C1005X7R683KDT C1005X7R823KDT C1005X7R104□DT C1005X7R224KDT C1005X7R474KDT C1005X7R103KCT C1005X7R473KCT C1005X7R104KCT C1005X7R474□CT C1005X7R105□CT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 270 pF ±10% 0.50 330 pF ±10% 0.50 390 pF ±10% 0.50 470 pF ±10% 0.50 560 pF ±10% 0.50 680 pF ±10% 0.50 820 pF ±10% 0.50 1.0 nF ±10% 0.50 1.2 nF ±10% 0.50 1.5 nF ±10% 0.50 1.8 nF ±10% 0.50 2.2 nF ±10% 0.50 2.7 nF ±10% 0.50 3.3 nF ±10% 0.50 3.9 nF ±10% 0.50 4.7 nF ±10% 0.50 5.6 nF ±10% 0.50 6.8 nF ±10% 0.50 8.2 nF ±10% 0.50 10 nF ±10% 0.50 12 nF ±10% 0.50 15 nF ±10% 0.50 18 nF ±10% 0.50 22 nF ±10% 0.50 27 nF ±10% 0.50 33 nF ±10% 0.50 39 nF ±10% 0.50 47 nF ±10% 0.50 56 nF ±10% 0.50 68 nF ±10% 0.50 82 nF ±10% 0.50 100 nF ±10%,±20% 0.50 150 nF ±10% 0.50 220 nF ±10% 0.50 100 pF ±10% 0.50 120 pF ±10% 0.50 150 pF ±10% 0.50 180 pF ±10% 0.50 220 pF ±10% 0.50 270 pF ±10% 0.50 330 pF ±10% 0.50 390 pF ±10% 0.50 470 pF ±10% 0.50 560 pF ±10% 0.50 680 pF ±10% 0.50 820 pF ±10% 0.50 1.0 nF ±10% 0.50 1.2 nF ±10% 0.50 1.5 nF ±10% 0.50 1.8 nF ±10% 0.50 2.2 nF ±10% 0.50 2.7 nF ±10% 0.50 3.3 nF ±10% 0.50 3.9 nF ±10% 0.50 4.7 nF ±10% 0.50 5.6 nF ±10% 0.50 6.8 nF ±10% 0.50 8.2 nF ±10% 0.50 10 nF ±10% 0.50 12 nF ±10% 0.50 15 nF ±10% 0.50 18 nF ±10% 0.50 22 nF ±10% 0.50 27 nF ±10% 0.50 33 nF ±10% 0.50 39 nF ±10% 0.50 47 nF ±10% 0.50 56 nF ±10% 0.50 68 nF ±10% 0.50 82 nF ±10% 0.50 100 nF ±10%, ±5% 0.50 220 nF ±10% 0.50 470 nF ±10% 0.50 10 nF ±10% 0.50 47 nF ±10% 0.50 100 nF ±10% 0.50 470 nF ±10%, ±20% 0.50 1.0 uF ±10%, ±20% 0.50 Tolerance(mm) L/W Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 5.0% 5.0% 5.0% 10.0% 12.5% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (I) (I) (II) (II)* □ Tolerance Code: J=±5%, K=±10%, M=±20%. 21 Rev. 201710 MLCC DARFON P/N General Purpose RV  RV 50V 35V 25V C1608X7R Series (EIA0603) DARFON P/N DARFON P/N 2 C1608X7R101KGTS C1608X7R121KGTS C1608X7R151KGTS C1608X7R181KGTS C1608X7R221KGTS C1608X7R271KGTS C1608X7R331KGTS C1608X7R391KGTS C1608X7R471KGTS C1608X7R561KGTS C1608X7R681KGTS C1608X7R821KGTS C1608X7R102KGTS C1608X7R122KGTS C1608X7R152KGTS C1608X7R182KGTS C1608X7R202KGTS C1608X7R222KGTS C1608X7R272KGTS C1608X7R332KGTS C1608X7R392KGTS C1608X7R472KGTS C1608X7R562KGTS C1608X7R682KGTS C1608X7R822KGTS C1608X7R103□GTS C1608X7R123KGTS C1608X7R153KGTS C1608X7R183□GTS C1608X7R223KGTS C1608X7R273KGTS C1608X7R333KGTS C1608X7R393KGTS C1608X7R473KGTS C1608X7R563KGTS C1608X7R683KGTS C1608X7R823KGTS C1608X7R104KGTS C1608X7R224KGTS C1608X7R474KGTS C1608X7R105KGTS C1608X7R474KNTS C1608X7R105KNTS C1608X7R101KFTS C1608X7R121KFTS C1608X7R151KFTS C1608X7R181KFTS C1608X7R221KFTS C1608X7R271KFTS C1608X7R331KFTS C1608X7R391KFTS C1608X7R471KFTS C1608X7R561KFTS C1608X7R681KFTS C1608X7R821KFTS C1608X7R102KFTS C1608X7R122KFTS C1608X7R152KFTS C1608X7R182KFTS C1608X7R222KFTS C1608X7R272KFTS C1608X7R332KFTS C1608X7R392KFTS C1608X7R472KFTS C1608X7R562KFTS C1608X7R682KFTS C1608X7R822KFTS C1608X7R103KFTS C1608X7R101KGT C1608X7R121KGT C1608X7R151KGT C1608X7R181KGT C1608X7R221KGT C1608X7R271KGT C1608X7R331KGT C1608X7R391KGT C1608X7R471KGT C1608X7R561KGT C1608X7R681KGT C1608X7R821KGT C1608X7R102KGT C1608X7R122KGT C1608X7R152KGT C1608X7R182KGT C1608X7R202KGT C1608X7R222KGT C1608X7R272KGT C1608X7R332KGT C1608X7R392KGT C1608X7R472KGT C1608X7R562KGT C1608X7R682KGT C1608X7R822KGT C1608X7R103□GT C1608X7R123KGT C1608X7R153KGT C1608X7R183□GT C1608X7R223KGT C1608X7R273KGT C1608X7R333KGT C1608X7R393KGT C1608X7R473KGT C1608X7R563KGT C1608X7R683KGT C1608X7R823KGT C1608X7R104KGT C1608X7R224KGT C1608X7R474KGT C1608X7R105KGT C1608X7R474KNT C1608X7R105KNT C1608X7R101KFT C1608X7R121KFT C1608X7R151KFT C1608X7R181KFT C1608X7R221KFT C1608X7R271KFT C1608X7R331KFT C1608X7R391KFT C1608X7R471KFT C1608X7R561KFT C1608X7R681KFT C1608X7R821KFT C1608X7R102KFT C1608X7R122KFT C1608X7R152KFT C1608X7R182KFT C1608X7R222KFT C1608X7R272KFT C1608X7R332KFT C1608X7R392KFT C1608X7R472KFT C1608X7R562KFT C1608X7R682KFT C1608X7R822KFT C1608X7R103KFT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 100 pF ±10% 0.80 120 pF ±10% 0.80 150 pF ±10% 0.80 180 pF ±10% 0.80 220 pF ±10% 0.80 270 pF ±10% 0.80 330 pF ±10% 0.80 390 pF ±10% 0.80 470 pF ±10% 0.80 560 pF ±10% 0.80 680 pF ±10% 0.80 820 pF ±10% 0.80 1.0 nF ±10% 0.80 1.2 nF ±10% 0.80 1.5 nF ±10% 0.80 1.8 nF ±10% 0.80 2.0 nF ±10% 0.80 2.2 nF ±10% 0.80 2.7 nF ±10% 0.80 3.3 nF ±10% 0.80 3.9 nF ±10% 0.80 4.7 nF ±10% 0.80 5.6 nF ±10% 0.80 6.8 nF ±10% 0.80 8.2 nF ±10% 0.80 10 nF ±10%,±5% 0.80 12 nF ±10% 0.80 15 nF ±10% 0.80 18 nF ±10%,±5% 0.80 22 nF ±10% 0.80 27 nF ±10% 0.80 33 nF ±10% 0.80 39 nF ±10% 0.80 47 nF ±10% 0.80 56 nF ±10% 0.80 68 nF ±10% 0.80 82 nF ±10% 0.80 100 nF ±10% 0.80 220 nF ±10% 0.80 470 nF ±10% 0.80 1.0 uF ±10% 0.80 470 nF ±10% 0.80 1.0 uF ±10% 0.80 100 pF ±10% 0.80 120 pF ±10% 0.80 150 pF ±10% 0.80 180 pF ±10% 0.80 220 pF ±10% 0.80 270 pF ±10% 0.80 330 pF ±10% 0.80 390 pF ±10% 0.80 470 pF ±10% 0.80 560 pF ±10% 0.80 680 pF ±10% 0.80 820 pF ±10% 0.80 1.0 nF ±10% 0.80 1.2 nF ±10% 0.80 1.5 nF ±10% 0.80 1.8 nF ±10% 0.80 2.2 nF ±10% 0.80 2.7 nF ±10% 0.80 3.3 nF ±10% 0.80 3.9 nF ±10% 0.80 4.7 nF ±10% 0.80 5.6 nF ±10% 0.80 6.8 nF ±10% 0.80 8.2 nF ±10% 0.80 10 nF ±10% 0.80 □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request. 22 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 ±0.15 ±0.15 ±0.20 ±0.20 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 DF (max.) 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 2.5% 3.0% 3.0% 3.0% 3.0% 3.0% 3.5% 10.0% 10.0% 10.0% 10.0% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (II) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) 16V DARFON P/N 2 C1608X7R123KFTS C1608X7R153KFTS C1608X7R183KFTS C1608X7R223□FTS C1608X7R273□FTS C1608X7R333KFTS C1608X7R393KFTS C1608X7R473KFTS C1608X7R563KFTS C1608X7R683KFTS C1608X7R823KFTS C1608X7R104KFTS C1608X7R124KFTS C1608X7R154KFTS C1608X7R184KFTS C1608X7R224KFTS C1608X7R334KFTS C1608X7R474KFTS C1608X7R105KFTS C1608X7R101KETS C1608X7R121KETS C1608X7R151KETS C1608X7R181KETS C1608X7R221KETS C1608X7R271KETS C1608X7R331KETS C1608X7R391KETS C1608X7R471KETS C1608X7R561KETS C1608X7R681KETS C1608X7R821KETS C1608X7R102KETS C1608X7R122KETS C1608X7R152KETS C1608X7R182KETS C1608X7R222KETS C1608X7R272KETS C1608X7R332KETS C1608X7R392KETS C1608X7R472KETS C1608X7R562KETS C1608X7R682KETS C1608X7R822KETS C1608X7R103KETS C1608X7R123KETS C1608X7R153KETS C1608X7R183KETS C1608X7R223KETS C1608X7R273KETS C1608X7R333KETS C1608X7R393KETS C1608X7R473KETS C1608X7R563KETS C1608X7R683KETS C1608X7R823KETS C1608X7R104KETS C1608X7R154KETS C1608X7R184KETS C1608X7R224KETS C1608X7R334KETS C1608X7R474KETS C1608X7R684KETS C1608X7R105□ETS C1608X7R225KETS C1608X7R123KFT C1608X7R153KFT C1608X7R183KFT C1608X7R223□FT C1608X7R273□FT C1608X7R333KFT C1608X7R393KFT C1608X7R473KFT C1608X7R563KFT C1608X7R683KFT C1608X7R823KFT C1608X7R104KFT C1608X7R124KFT C1608X7R154KFT C1608X7R184KFT C1608X7R224KFT C1608X7R334KFT C1608X7R474KFT C1608X7R105KFT C1608X7R101KET C1608X7R121KET C1608X7R151KET C1608X7R181KET C1608X7R221KET C1608X7R271KET C1608X7R331KET C1608X7R391KET C1608X7R471KET C1608X7R561KET C1608X7R681KET C1608X7R821KET C1608X7R102KET C1608X7R122KET C1608X7R152KET C1608X7R182KET C1608X7R222KET C1608X7R272KET C1608X7R332KET C1608X7R392KET C1608X7R472KET C1608X7R562KET C1608X7R682KET C1608X7R822KET C1608X7R103KET C1608X7R123KET C1608X7R153KET C1608X7R183KET C1608X7R223KET C1608X7R273KET C1608X7R333KET C1608X7R393KET C1608X7R473KET C1608X7R563KET C1608X7R683KET C1608X7R823KET C1608X7R104KET C1608X7R154KET C1608X7R184KET C1608X7R224KET C1608X7R334KET C1608X7R474KET C1608X7R684KET C1608X7R105□ET C1608X7R225KET Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance Value Unit (mm) 12 nF ±10% 0.80 15 nF ±10% 0.80 18 nF ±10% 0.80 22 nF ±10%,±5% 0.80 27 nF ±10%,±5% 0.80 33 nF ±10% 0.80 39 nF ±10% 0.80 47 nF ±10% 0.80 56 nF ±10% 0.80 68 nF ±10% 0.80 82 nF ±10% 0.80 100 nF ±10% 0.80 120 nF ±10% 0.80 150 nF ±10% 0.80 180 nF ±10% 0.80 220 nF ±10% 0.80 330 nF ±10% 0.80 470 nF ±10% 0.80 1.0 uF ±10% 0.80 100 pF ±10% 0.80 120 pF ±10% 0.80 150 pF ±10% 0.80 180 pF ±10% 0.80 220 pF ±10% 0.80 270 pF ±10% 0.80 330 pF ±10% 0.80 390 pF ±10% 0.80 470 pF ±10% 0.80 560 pF ±10% 0.80 680 pF ±10% 0.80 820 pF ±10% 0.80 1.0 nF ±10% 0.80 1.2 nF ±10% 0.80 1.5 nF ±10% 0.80 1.8 nF ±10% 0.80 2.2 nF ±10% 0.80 2.7 nF ±10% 0.80 3.3 nF ±10% 0.80 3.9 nF ±10% 0.80 4.7 nF ±10% 0.80 5.6 nF ±10% 0.80 6.8 nF ±10% 0.80 8.2 nF ±10% 0.80 10 nF ±10% 0.80 12 nF ±10% 0.80 15 nF ±10% 0.80 18 nF ±10% 0.80 22 nF ±10% 0.80 27 nF ±10% 0.80 33 nF ±10% 0.80 39 nF ±10% 0.80 47 nF ±10% 0.80 56 nF ±10% 0.80 68 nF ±10% 0.80 82 nF ±10% 0.80 100 nF ±10% 0.80 150 nF ±10% 0.80 180 nF ±10% 0.80 220 nF ±10% 0.80 330 nF ±10% 0.80 470 nF ±10% 0.80 680 nF ±10% 0.80 1.0 uF ±10%, ±20% 0.80 2.2 uF ±10% 0.80 23 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.20 DF (max.) 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 7.0% 10.0% 10.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) Rev. 201710 MLCC 25V DARFON P/N General Purpose RV RV 10V 6.3V DARFON P/N DARFON P/N 2 C1608X7R101KDTS C1608X7R121KDTS C1608X7R151KDTS C1608X7R181KDTS C1608X7R221KDTS C1608X7R271KDTS C1608X7R331KDTS C1608X7R391KDTS C1608X7R471KDTS C1608X7R561KDTS C1608X7R681KDTS C1608X7R821KDTS C1608X7R102KDTS C1608X7R122KDTS C1608X7R152KDTS C1608X7R182KDTS C1608X7R222KDTS C1608X7R272KDTS C1608X7R332KDTS C1608X7R392KDTS C1608X7R472KDTS C1608X7R562KDTS C1608X7R682KDTS C1608X7R822KDTS C1608X7R103KDTS C1608X7R123KDTS C1608X7R153KDTS C1608X7R183KDTS C1608X7R223KDTS C1608X7R273KDTS C1608X7R333KDTS C1608X7R393KDTS C1608X7R473KDTS C1608X7R563KDTS C1608X7R683KDTS C1608X7R823KDTS C1608X7R104KDTS C1608X7R224KDTS C1608X7R334KDTS C1608X7R474KDTS C1608X7R684KDTS C1608X7R105KDTS C1608X7R225KDTS C1608X7R104KCTS C1608X7R105KCTS C1608X7R225KCTS C1608X7R475KCTS C1608X7R106MCTS C1608X7R101KDT C1608X7R121KDT C1608X7R151KDT C1608X7R181KDT C1608X7R221KDT C1608X7R271KDT C1608X7R331KDT C1608X7R391KDT C1608X7R471KDT C1608X7R561KDT C1608X7R681KDT C1608X7R821KDT C1608X7R102KDT C1608X7R122KDT C1608X7R152KDT C1608X7R182KDT C1608X7R222KDT C1608X7R272KDT C1608X7R332KDT C1608X7R392KDT C1608X7R472KDT C1608X7R562KDT C1608X7R682KDT C1608X7R822KDT C1608X7R103KDT C1608X7R123KDT C1608X7R153KDT C1608X7R183KDT C1608X7R223KDT C1608X7R273KDT C1608X7R333KDT C1608X7R393KDT C1608X7R473KDT C1608X7R563KDT C1608X7R683KDT C1608X7R823KDT C1608X7R104KDT C1608X7R224KDT C1608X7R334KDT C1608X7R474KDT C1608X7R684KDT C1608X7R105KDT C1608X7R225KDT C1608X7R104KCT C1608X7R105KCT C1608X7R225KCT C1608X7R475KCT C1608X7R106MCT Measuring Capacitance Thick. Available Tolerance Condition Value Unit (mm) 1V , 1kHz 100 pF ±10% 0.80 1V , 1kHz 120 pF ±10% 0.80 1V , 1kHz 150 pF ±10% 0.80 1V , 1kHz 180 pF ±10% 0.80 1V , 1kHz 220 pF ±10% 0.80 1V , 1kHz 270 pF ±10% 0.80 1V , 1kHz 330 pF ±10% 0.80 1V , 1kHz 390 pF ±10% 0.80 1V , 1kHz 470 pF ±10% 0.80 1V , 1kHz 560 pF ±10% 0.80 1V , 1kHz 680 pF ±10% 0.80 1V , 1kHz 820 pF ±10% 0.80 1V , 1kHz 1.0 nF ±10% 0.80 1V , 1kHz 1.2 nF ±10% 0.80 1V , 1kHz 1.5 nF ±10% 0.80 1V , 1kHz 1.8 nF ±10% 0.80 1V , 1kHz 2.2 nF ±10% 0.80 1V , 1kHz 2.7 nF ±10% 0.80 1V , 1kHz 3.3 nF ±10% 0.80 1V , 1kHz 3.9 nF ±10% 0.80 1V , 1kHz 4.7 nF ±10% 0.80 1V , 1kHz 5.6 nF ±10% 0.80 1V , 1kHz 6.8 nF ±10% 0.80 1V , 1kHz 8.2 nF ±10% 0.80 1V , 1kHz 10 nF ±10% 0.80 1V , 1kHz 12 nF ±10% 0.80 1V , 1kHz 15 nF ±10% 0.80 1V , 1kHz 18 nF ±10% 0.80 1V , 1kHz 22 nF ±10% 0.80 1V , 1kHz 27 nF ±10% 0.80 1V , 1kHz 33 nF ±10% 0.80 1V , 1kHz 39 nF ±10% 0.80 1V , 1kHz 47 nF ±10% 0.80 1V , 1kHz 56 nF ±10% 0.80 1V , 1kHz 68 nF ±10% 0.80 1V , 1kHz 82 nF ±10% 0.80 1V , 1kHz 100 nF ±10% 0.80 1V , 1kHz 220 nF ±10% 0.80 1V , 1kHz 330 nF ±10% 0.80 1V , 1kHz 470 nF ±10% 0.80 1V , 1kHz 680 nF ±10% 0.80 1V , 1kHz 1.0 uF ±10% 0.80 1V , 1kHz 2.2 uF ±10% 0.80 1V , 1kHz 100 nF ±10% 0.80 1V , 1kHz 1.0 uF ±10% 0.80 1V , 1kHz 2.2 uF ±10% 0.80 1V , 1kHz 4.7 uF ±10% 0.80 0.5V , 1kHz 10 uF ±20% 0.80 □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request. 24 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.10 ±0.20 ±0.20 ±0.20 ±0.20 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% 5.0% 10.0% 10.0% 10.0% 10.0% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (II) (II) (II) (II)* RV DARFON P/N DARFON P/N 2 C2012X7R101KGT 50V C2012X7R101KGTS C2012X7R151KGTSC C2012X7R151KGTS C2012X7R181KGTSC C2012X7R181KGTS C2012X7R221KGTSC C2012X7R221KGTS C2012X7R271KGTSC C2012X7R271KGTS C2012X7R331KGTSC C2012X7R331KGTS C2012X7R391KGTSC C2012X7R391KGTS C2012X7R471KGTSC C2012X7R471KGTS C2012X7R561KGTSC C2012X7R561KGTS C2012X7R681KGTSC C2012X7R681KGTS C2012X7R821KGTSC C2012X7R821KGTS C2012X7R102KGTSC C2012X7R102KGTS C2012X7R122KGTSC C2012X7R122KGTS C2012X7R152KGTSC C2012X7R152KGTS C2012X7R182KGTSC C2012X7R182KGTS C2012X7R222KGTSC C2012X7R222KGTS C2012X7R272KGTSC C2012X7R272KGTS C2012X7R332KGTSC C2012X7R332KGTS C2012X7R392KGTSC C2012X7R392KGTS C2012X7R472KGTSC C2012X7R472KGTS C2012X7R562KGTSC C2012X7R562KGTS C2012X7R682KGTSC C2012X7R682KGTS C2012X7R682KGPSG C2012X7R822KGTSC C2012X7R822KGTS C2012X7R103KGTSC C2012X7R103KGTS C2012X7R123KGTSC C2012X7R123KGTS C2012X7R153KGTSC C2012X7R153KGTS C2012X7R183KGTSC C2012X7R183KGTS C2012X7R223KGTSC C2012X7R223KGTSD C2012X7R273KGTSC C2012X7R273KGTS C2012X7R333KGTSC C2012X7R333KGTS C2012X7R393KGTSC C2012X7R393KGTS C2012X7R473KGTS C2012X7R563KGTS C2012X7R683KGTS C2012X7R823KGTS C2012X7R104□GTSD C2012X7R124KGTS C2012X7R154KGTS C2012X7R184KGPSG C2012X7R224KGTS C2012X7R224KGPS C2012X7R334KGPS C2012X7R474KGPS C2012X7R105KGPSG C2012X7R225KGPSG C2012X7R151KGT C2012X7R181KGT C2012X7R221KGT C2012X7R271KGT C2012X7R331KGT C2012X7R391KGT C2012X7R471KGT C2012X7R561KGT C2012X7R681KGT C2012X7R821KGT C2012X7R102KGT C2012X7R122KGT C2012X7R152KGT C2012X7R182KGT C2012X7R222KGT C2012X7R272KGT C2012X7R332KGT C2012X7R392KGT C2012X7R472KGT C2012X7R562KGT C2012X7R682KGT C2012X7R822KGT C2012X7R103KGT C2012X7R123KGT C2012X7R153KGT C2012X7R183KGT C2012X7R223KGT C2012X7R273KGT C2012X7R333KGT C2012X7R393KGT C2012X7R473KGT C2012X7R563KGT C2012X7R683KGT C2012X7R823KGT C2012X7R124KGT C2012X7R154KGT C2012X7R224KGT C2012X7R224KGP C2012X7R334KGP C2012X7R474KGP C2012X7R105KGP C2012X7R225KGP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 100 pF ±10% 0.85 150 pF ±10% 0.60 150 pF ±10% 0.85 180 pF ±10% 0.60 180 pF ±10% 0.85 220 pF ±10% 0.60 220 pF ±10% 0.85 270 pF ±10% 0.60 270 pF ±10% 0.85 330 pF ±10% 0.60 330 pF ±10% 0.85 390 pF ±10% 0.60 390 pF ±10% 0.85 470 pF ±10% 0.60 470 pF ±10% 0.85 560 pF ±10% 0.60 560 pF ±10% 0.85 680 pF ±10% 0.60 680 pF ±10% 0.85 820 pF ±10% 0.60 820 pF ±10% 0.85 1.0 nF ±10% 0.60 1.0 nF ±10% 0.85 1.2 nF ±10% 0.60 1.2 nF ±10% 0.85 1.5 nF ±10% 0.60 1.5 nF ±10% 0.85 1.8 nF ±10% 0.60 1.8 nF ±10% 0.85 2.2 nF ±10% 0.60 2.2 nF ±10% 0.85 2.7 nF ±10% 0.60 2.7 nF ±10% 0.85 3.3 nF ±10% 0.60 3.3 nF ±10% 0.85 3.9 nF ±10% 0.60 3.9 nF ±10% 0.85 4.7 nF ±10% 0.60 4.7 nF ±10% 0.85 5.6 nF ±10% 0.60 5.6 nF ±10% 0.85 6.8 nF ±10% 0.60 6.8 nF ±10% 0.80 6.8 nF ±10% 1.25 8.2 nF ±10% 0.60 8.2 nF ±10% 0.85 10 nF ±10% 0.60 10 nF ±10% 0.85 12 nF ±10% 0.60 12 nF ±10% 0.85 15 nF ±10% 0.60 15 nF ±10% 0.85 18 nF ±10% 0.60 18 nF ±10% 0.85 22 nF ±10% 0.60 22 nF ±10% 0.80 27 nF ±10% 0.60 27 nF ±10% 0.85 33 nF ±10% 0.60 33 nF ±10% 0.85 39 nF ±10% 0.60 39 nF ±10% 0.85 47 nF ±10% 0.85 56 nF ±10% 0.85 68 nF ±10% 0.85 82 nF ±10% 0.85 100 nF ±10%,±5% 0.80 120 nF ±10% 0.85 150 nF ±10% 0.85 180 nF ±10% 1.25 220 nF ±10% 0.85 220 nF ±10% 1.25 330 nF ±10% 1.25 470 nF ±10% 1.25 1.0 uF ±10% 1.25 2.2 uF ±10% 1.25 25 Tolerance(mm) L/W Thick. ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.20 ±0.20 DF Standard Test (max.) Packing Spec. 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) Paper, 4Kpcs 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% Embossed, 3Kpcs (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% Paper, 4Kpcs (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 2.5% (I) 3.0% Embossed, 3Kpcs (I) 3.0% Paper, 4Kpcs (I) 3.0% (I) 3.0% (I) 3.5% Embossed, 3Kpcs (I) 10.0% (II) 10.0% (II) Rev. 201710 MLCC C2012X7R Series (EIA0805) General Purpose  RV DARFON P/N DARFON P/N 2 35V C2012X7R474KNPS C2012X7R102KFTSC C2012X7R102KFTS C2012X7R122KFTSC C2012X7R122KFTS C2012X7R152KFTSC C2012X7R152KFTS C2012X7R182KFTSC C2012X7R182KFTS C2012X7R222KFTSC C2012X7R222KFTS C2012X7R272KFTSC C2012X7R272KFTS C2012X7R332KFTSC C2012X7R332KFTS C2012X7R392KFTSC C2012X7R392KFTS C2012X7R472KFTSC C2012X7R472KFTS C2012X7R562KFTSC C2012X7R562KFTS C2012X7R682KFTSC C2012X7R682KFTS C2012X7R822KFTSC C2012X7R103KFTSC C2012X7R103KFTS C2012X7R123KFTSC C2012X7R123KFTS C2012X7R153KFTSC C2012X7R153KFTS C2012X7R183KFTSC C2012X7R183KFTS C2012X7R223KFTSC C2012X7R223KFTS C2012X7R273KFTSC C2012X7R273KFTS C2012X7R333KFTSC C2012X7R333KFTS C2012X7R393KFTSC C2012X7R393KFTS C2012X7R473KFTS C2012X7R563KFTS C2012X7R683KFTS C2012X7R823KFTS C2012X7R104KFTS C2012X7R124KFTS C2012X7R154KFTS C2012X7R184KFTS C2012X7R224KFTS C2012X7R334KFPS C2012X7R474KFPS C2012X7R105□FPS C2012X7R225KFPS C2012X7R475KFPS C2012X7R123KETS C2012X7R104KETS C2012X7R224KETS C2012X7R224KEPS C2012X7R334KEPS C2012X7R474KEPS C2012X7R684KEPS C2012X7R105□EPS C2012X7R225KEPS C2012X7R475KEPS C2012X7R105□DPS C2012X7R225KDPS C2012X7R475KDPS C2012X7R106KDPS C2012X7R475KCPS C2012X7R106□CPS C2012X7R106□BPS C2012X7R474KNP 25V 16V 10V 6.3V 4V C2012X7R102KFT C2012X7R122KFT C2012X7R152KFT C2012X7R182KFT C2012X7R222KFT C2012X7R272KFT C2012X7R332KFT C2012X7R392KFT C2012X7R472KFT C2012X7R562KFT C2012X7R682KFT C2012X7R103KFT C2012X7R123KFT C2012X7R153KFT C2012X7R183KFT C2012X7R223KFT C2012X7R273KFT C2012X7R333KFT C2012X7R393KFT C2012X7R473KFT C2012X7R563KFT C2012X7R683KFT C2012X7R823KFT C2012X7R104KFT C2012X7R124KFT C2012X7R154KFT C2012X7R184KFT C2012X7R224KFT C2012X7R334KFP C2012X7R474KFP C2012X7R105□FP C2012X7R225KFP C2012X7R475KFP C2012X7R123KET C2012X7R104KET C2012X7R224KET C2012X7R224KEP C2012X7R334KEP C2012X7R474KEP C2012X7R684KEP C2012X7R105□EP C2012X7R225KEP C2012X7R475KEP C2012X7R105□DP C2012X7R225KDP C2012X7R475KDP C2012X7R106KDP C2012X7R475KCP C2012X7R106□CP C2012X7R106□BP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Thick. Available Tolerance (mm) Value Unit 470 nF ±10% 1.25 1.0 nF ±10% 0.60 1.0 nF ±10% 0.85 1.2 nF ±10% 0.60 1.2 nF ±10% 0.85 1.5 nF ±10% 0.60 1.5 nF ±10% 0.85 1.8 nF ±10% 0.60 1.8 nF ±10% 0.85 2.2 nF ±10% 0.60 2.2 nF ±10% 0.85 2.7 nF ±10% 0.60 2.7 nF ±10% 0.85 3.3 nF ±10% 0.60 3.3 nF ±10% 0.85 3.9 nF ±10% 0.60 3.9 nF ±10% 0.85 4.7 nF ±10% 0.60 4.7 nF ±10% 0.85 5.6 nF ±10% 0.60 5.6 nF ±10% 0.85 6.8 nF ±10% 0.60 6.8 nF ±10% 0.85 8.2 nF ±10% 0.60 10 nF ±10% 0.60 10 nF ±10% 0.85 12 nF ±10% 0.60 12 nF ±10% 0.85 15 nF ±10% 0.60 15 nF ±10% 0.85 18 nF ±10% 0.60 18 nF ±10% 0.85 22 nF ±10% 0.60 22 nF ±10% 0.85 27 nF ±10% 0.60 27 nF ±10% 0.85 33 nF ±10% 0.60 33 nF ±10% 0.85 39 nF ±10% 0.60 39 nF ±10% 0.85 47 nF ±10% 0.85 56 nF ±10% 0.85 68 nF ±10% 0.85 82 nF ±10% 0.85 100 nF ±10% 0.85 120 nF ±10% 0.85 150 nF ±10% 0.85 180 nF ±10% 0.85 220 nF ±10% 0.85 330 nF ±10% 1.25 470 nF ±10% 1.25 1.0 uF ±10%, ±20% 1.25 2.2 uF ±10% 1.25 4.7 uF ±10% 1.25 12 nF ±10% 0.85 100 nF ±10% 0.85 220 nF ±10% 0.85 220 nF ±10% 1.25 330 nF ±10% 1.25 470 nF ±10% 1.25 680 nF ±10% 1.25 1.0 uF ±10%, ±20% 1.25 2.2 uF ±10% 1.25 4.7 uF ±10% 1.25 1.0 uF ±10%, ±20% 1.25 2.2 uF ±10% 1.25 4.7 uF ±10% 1.25 10 uF ±10% 1.25 4.7 uF ±10% 1.25 10 uF ±10%, ±20% 1.25 10 uF ±10%, ±20% 1.25 26 Tolerance(mm) L/W Thick. ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.10 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 ±0.15 ±0.20 DF Standard Test (max.) Packing Spec. 3.5% Embossed, 3Kpcs (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) Paper, 4Kpcs 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 3.5% (I) 5.0% (I) 5.0% (I) 10.0% Embossed, 3Kpcs (II) 10.0% (II) 12.5% (II)* 3.5% (I) Paper, 4Kpcs 3.5% (I) 3.5% (I) 3.0% (I) 5.0% (I) 5.0% (I) 5.0% Embossed, 3Kpcs (I) 5.0% (I) 10.0% (I) 10.0% (II) 5.0% (I) 10.0% (II) Embossed, 3Kpcs 10.0% (II) 10.0% (II) 10.0% (II) Embossed, 3Kpcs 15.0% (II) 15.0% Embossed, 3Kpcs (II) 50V 35V 25V 16V 10V 6.3V  RV 50V 35V 25V 16V 10V DARFON P/N DARFON P/N 2 C3216X7R102KGTS C3216X7R562□GTS C3216X7R103□GTS C3216X7R123KGTS C3216X7R153KGTS C3216X7R183KGTS C3216X7R223KGTS C3216X7R273KGTS C3216X7R333KGTS C3216X7R393KGTS C3216X7R473KGTS C3216X7R563KGTS C3216X7R683KGTS C3216X7R823KGTS C3216X7R104KGTS C3216X7R224KGPS C3216X7R334□GPS C3216X7R474KGPSG C3216X7R474KGPS C3216X7R684KGPS C3216X7R105KGPSG C3216X7R105KGPS C3216X7R225KGPSL C3216X7R475KGPS C3216X7R106KGPSL C3216X7R106KNPSL C3216X7R224KFPS C3216X7R334KFPS C3216X7R474KFPS C3216X7R105□FPS C3216X7R225KFPS C3216X7R475KFPS C3216X7R106KFPS C3216X7R104KETS C3216X7R474KEPS C3216X7R105KEPS C3216X7R225KEPS C3216X7R475□EPS C3216X7R106□EPS C3216X7R225KDPS C3216X7R106□DPS C3216X7R102KGT C3216X7R562□GT C3216X7R103□GT C3216X7R123KGT C3216X7R153KGT C3216X7R183KGT C3216X7R223KGT C3216X7R273KGT C3216X7R333KGT C3216X7R393KGT C3216X7R473KGT C3216X7R563KGT C3216X7R683KGT C3216X7R823KGT C3216X7R104KGT C3216X7R224KGP C3216X7R334□GP Measuring Condition Capacitance Value Unit Available Tolerance Thick. (mm) Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. C3216X7R105KGP C3216X7R225KGP C3216X7R475KGP C3216X7R106KGP C3216X7R106KNP C3216X7R224KFP C3216X7R334KFP C3216X7R474KFP C3216X7R105□FP C3216X7R225KFP C3216X7R475KFP C3216X7R106KFP C3216X7R104KET C3216X7R474KEP C3216X7R105KEP C3216X7R225KEP C3216X7R475□EP C3216X7R106□EP C3216X7R225KDP C3216X7R106□DP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1.0 5.6 10 12 15 18 22 27 33 39 47 56 68 82 100 220 330 470 470 680 1.0 1.0 2.2 4.7 10 10 220 330 470 1.0 2.2 4.7 10 100 470 1.0 2.2 4.7 10 2.2 10 nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF nF uF uF uF uF uF uF nF nF nF uF uF uF uF nF nF uF uF uF uF uF uF ±10% ±5%, ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±5%, ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10%, ±20% ±10%, ±20% ±10% ±10%, ±20% 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.85 0.95 1.25 1.25 1.60 1.60 1.25 1.60 1.60 1.60 1.60 1.60 0.95 0.95 1.25 1.25 1.60 1.60 1.60 0.85 1.25 1.25 1.60 1.60 1.60 1.60 1.60 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 ±0.15 +0.3/-0.1 ±0.15 ±0.30 ±0.20 ±0.30 ±0.20 ±0.20 ±0.15 ±0.15 ±0.15 ±0.15 ±0.30 ±0.30 ±0.30 ±0.15 ±0.15 ±0.15 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.20 +0.3/-0.1 ±0.15 ±0.30 ±0.20 ±0.30 ±0.20 ±0.20 ±0.10 ±0.10 ±0.20 ±0.20 ±0.30 ±0.30 ±0.30 ±0.10 ±0.20 ±0.20 ±0.30 ±0.30 ±0.30 ±0.30 ±0.30 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 3.5% 10.0% 10.0% 10.0% 10.0% 3.5% 3.5% 3.5% 3.5% 5.0% 10.0% 10.0% 3.5% 5.0% 5.0% 10.0% 10.0% 10.0% 10.0% 10.0% C3216X7R226□DPS C3216X7R226□DP 0.5V , 120Hz 22 uF ±10%, ±20% 1.60 ±0.30 ±0.30 10.0% (II) C3216X7R226KCPS C3216X7R226KCP 0.5V , 120Hz 22 uF ±10% 1.60 ±0.30 ±0.30 10.0% (II) Available Tolerance Thick. (mm) C3216X7R474KGP C3216X7R684KGP Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 2Kpcs (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (II) (II) (II) (I) (I) (I) (I) (I) (I) (II) (I) (I) (I) (I) (I) (II)* (I) (II) C3225X7R Series (EIA1210) Capacitance DARFON P/N DARFON P/N 2 Measuring Condition C3225X7R225MGPS C3225X7R475KGPS C3225X7R106KGWS C3225X7R106□GPS C3225X7R106KNPS C3225X7R225MGP C3225X7R475KGP C3225X7R106KGW C3225X7R106□GP C3225X7R106KNP 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 2.2 4.7 10 10 10 uF uF uF uF uF ±20% ±10% ±10% ±10%, ±20% ±10% C3225X7R475KFPS C3225X7R106KFPS C3225X7R226□FPS C3225X7R475KEPS C3225X7R106KEPS C3225X7R226□EPS C3225X7R226KDPS C3225X7R475KFP C3225X7R106KFP C3225X7R226□FP C3225X7R475KEP C3225X7R106KEP C3225X7R226□EP C3225X7R226KDP 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 0.5V , 120Hz 4.7 10 22 4.7 10 22 22 uF uF uF uF uF uF uF C3225X7R476□DPS C3225X7R476□DP 0.5V , 120Hz 47 uF Value Unit Tolerance(mm) L/W Thick. DF (max.) Standard Packing 2.50 2.50 2.00 2.50 2.50 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.30 ±0.30 ±0.20 ±0.20 ±0.20 ±0.30 ±0.30 5.0% 10.0% Embossed, 1Kpcs 15.0% 10.0% 10.0% Embossed, 1Kpcs (II) (II) (II) (II) (II) ±10% ±10% ±10%, ±20% ±10% ±10% ±10%, ±20% ±10% 2.00 2.00 2.50 2.50 2.00 2.50 2.50 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.3/±0.2 ±0.20 ±0.30 ±0.20 ±0.20 ±0.20 ±0.30 ±0.20 10.0% 10.0% 10.0% 5.0% 10.0% 10.0% 10.0% (I) (II) (II) (II) (I) (II) (II) ±10%, ±20% 2.50 ±0.3/±0.2 ±0.20 10.0% Embossed, 2Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Embossed, 2Kpcs Embossed, 1Kpcs Embossed, 1Kpcs Test Spec. (II) □ Tolerance Code: J=±5%, K=±10%, M=±20%; Special tolerance on the request. (II)* High temperature load life test are applicable in rated voltage *100% 27 Rev. 201710 MLCC RV C3216X7R Series (EIA1206) General Purpose   X7S Series  C0603X7S Series (EIA0201) RV DARFON P/N DARFON P/N 2 Measuring Condition Capacitance Value Unit Available Tolerance Thick. (mm) Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. 16V C0603X7S104□ETS C0603X7S104□ET 1V , 1kHz 100 nF ±10%,±20% 0.30 ± 0.03 ±0.03 10.0% Paper, 15Kpcs (II)* 10V C0603X7S104KDTS C0603X7S104KDT 1V , 1kHz 100 nF ±10% 0.30 ± 0.03 ±0.03 10.0% Paper, 15Kpcs (II) 6.3V C0603X7S104KCTS C0603X7S104KCT 1V , 1kHz 100 nF ±10% 0.30 ± 0.03 ±0.03 10.0% Paper, 15Kpcs (II) Capacitance Value Unit 1.0 uF 2.2 uF 2.2 uF Available Tolerance Thick. (mm) DF (max.) Standard Packing Test Spec. ±10% ±10% ±10% 0.50 0.50 0.50 Tolerance(mm) L/W Thick. ± 0.10 ±0.10 ± 0.20 ±0.20 ± 0.20 ±0.20 10.0% 10.0% 10.0% Paper, 10Kpcs (II) (II) (II) Available Tolerance Thick. (mm) Standard Packing Test Spec. ±10% ±10% ±10% 0.80 0.80 0.80 Tolerance(mm) L/W Thick. ± 0.20 ±0.20 ± 0.20 ±0.20 ± 0.15 ±0.15 DF (max.) 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 2.2 uF 4.7 uF 4.7 uF 10.0% 10.0% 10.0% Paper, 4Kpcs (II) (II) (II) Measuring Condition Capacitance Value Unit Available Tolerance Thick. (mm) Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. ±10% ±10% ±10%,±20% 1.25 1.25 1.25 ± 0.20 ± 0.15 ± 0.20 10.0% 10.0% Embossed, 3Kpcs 10.0%  C1005X7S Series (EIA0402) RV DARFON P/N 10V 6.3V  DARFON P/N 2 C1005X7S105KDTS C1005X7S105KDT C1005X7S225KDTS C1005X7S225KDT C1005X7S225KCTS C1005X7S225KCT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz C1608X7S Series (EIA0603) RV DARFON P/N 16V 10V  DARFON P/N 2 C1608X7S225KETS C1608X7S225KET C1608X7S475KETS C1608X7S475KET C1608X7S475KDTS C1608X7S475KDT Measuring Condition C2012X7S Series (EIA0805) RV DARFON P/N 50V 25V  DARFON P/N 2 C2012X7S475KGPS C2012X7S475KGP C2012X7S225KFPS C2012X7S225KFP C2012X7S106□FPS C2012X7S106□FP 1V , 1kHz 1V , 1kHz 1V , 1kHz 4.7 2.2 10 uF uF uF ±0.20 ±0.15 ±0.20 (II) (II) (II)* C3225X7S Series (EIA1210) RV 6.3V Measuring Condition 0.5V , C3225X7S107MCPS C3225X7S107MCP 120Hz DARFON P/N DARFON P/N 2 Capacitance Value Unit Available Tolerance Thick. (mm) 100 uF ±20% 2.50 □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request. (II)* High temperature load life test are applicable in rated voltage *100% 28 Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. ± 0.30 ±0.30 10.0% Embossed,1Kpcs (II)* X7T Series  C1608X7T Series (EIA0603) Capacitance RV DARFON P/N DARFON P/N 2 Measuring Condition Value Unit Available Tolerance Thick. (mm) 6.3V C1608X7T106MCTS C1608X7T106MCT 1V , 1kHz 10 uF ±20% 0.80 Measuring Condition Value Unit Available Tolerance Thick. (mm)  Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. ± 0.20 ±0.20 10.0% Paper, 4Kpcs (II) Tolerance(mm) Standard Packing Test Spec. C2012X7T Series (EIA0805) RV DARFON P/N DARFON P/N 2 Capacitance L/W Thick. DF (max.) C2012X7T226MDPS C2012X7T226MDP 0.5V , 120Hz 22 uF ±20% 1.25 ± 0.20 ±0.20 10.0% Embossed, 3Kpcs (II)* C2012X7T226MCPS C2012X7T226MCP 0.5V , 120Hz 22 uF ±20% 1.25 ± 0.20 ±0.20 10.0% Embossed, 3Kpcs (II) General Purpose 10V 6.3V MLCC  □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request. (II)* High temperature load life test are applicable in rated voltage *100% 29 Rev. 201710  X7U Series  C3216X7U Series (EIA1206) RV DARFON P/N DARFON P/N 2 Measuring Condition Capacitance Value Unit Available Tolerance Thick. (mm) Tolerance(mm) L/W Thick. DF (max.) Standard Packing Test Spec. 6.3V C3216X7U476MCPS C3216X7U476MCP 0.5V , 120Hz 47 uF ±20% 1.60 ± 0.30 ±0.30 15.0% Embossed, 2Kpcs (II)* 4V C3216X7U107MBPS C3216X7U107MBP 0.5V , 120Hz 100 uF ±20% 1.60 ± 0.30 ±0.30 15.0% Embossed, 2Kpcs (II)* □ Tolerance Code: K=±10%, M=±20%; Special tolerance on the request. (II)* High temperature load life test are applicable in rated voltage *100% 30  C1005Y5V Series (EIA0402) RV 50V 25V 16V 10V 6.3V  RV 50V 25V 16V DARFON P/N DARFON P/N 2 C1005Y5V103ZGTS C1005Y5V223ZGTS C1005Y5V103ZFTS C1005Y5V223ZFTS C1005Y5V473ZFTS C1005Y5V104□FTS C1005Y5V473ZETS C1005Y5V224ZETS C1005Y5V474ZETS C1005Y5V224ZDTS C1005Y5V334ZDTS C1005Y5V474ZDTS C1005Y5V105ZDTS C1005Y5V224ZCTS C1005Y5V334ZCTS C1005Y5V474ZCTS C1005Y5V105ZCTS C1005Y5V103ZGT C1005Y5V223ZGT C1005Y5V103ZFT C1005Y5V223ZFT C1005Y5V473ZFT C1005Y5V104□FT C1005Y5V473ZET C1005Y5V224ZET C1005Y5V474ZET C1005Y5V224ZDT C1005Y5V334ZDT C1005Y5V474ZDT C1005Y5V105ZDT C1005Y5V224ZCT C1005Y5V334ZCT C1005Y5V474ZCT C1005Y5V105ZCT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 10 nF 22 nF 10 nF 22 nF 47 nF 100 nF 47 nF 220 nF 470 nF 220 nF 330 nF 470 nF 1.0 uF 220 nF 330 nF 470 nF 1.0 uF Available Tolerance +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% ±20%, +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% Thick. (mm) 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 0.50 Tolerance(mm) L/W Thick. ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 ±0.05 DF (max.) 7.0% 9.0% 9.0% 9.0% 9.0% 9.0% 9.0% 9.0% 12.5% 12.5% 16.0% 16.0% 16.0% 12.5% 16.0% 16.0% 16.0% Thick. (mm) 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.15 ±0.15 ±0.15 ±0.15 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 DF (max.) 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 7.0% 9.0% 9.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 5.0% 7.0% 9.0% 9.0% 9.0% 10.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 7.0% 9.0% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% Standard Packing Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Paper, 10Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (II) (II) (I) (I) (I) (II) (I) (I) (I) (I) C1608Y5V Series (EIA0603) DARFON P/N DARFON P/N 2 C1608Y5V103ZGTS C1608Y5V123ZGTS C1608Y5V153ZGTS C1608Y5V183ZGTS C1608Y5V223ZGTS C1608Y5V273ZGTS C1608Y5V333ZGTS C1608Y5V393ZGTS C1608Y5V473ZGTS C1608Y5V563ZGTS C1608Y5V683ZGTS C1608Y5V823ZGTS C1608Y5V104ZGTS C1608Y5V224ZGTS C1608Y5V474ZGTS C1608Y5V103ZFTS C1608Y5V123ZFTS C1608Y5V153ZFTS C1608Y5V183ZFTS C1608Y5V223ZFTS C1608Y5V273ZFTS C1608Y5V333ZFTS C1608Y5V393ZFTS C1608Y5V473ZFTS C1608Y5V563ZFTS C1608Y5V683ZFTS C1608Y5V823ZFTS C1608Y5V104ZFTS C1608Y5V224ZFTS C1608Y5V334ZFTS C1608Y5V684ZFTS C1608Y5V105ZFTS C1608Y5V103ZETS C1608Y5V123ZETS C1608Y5V153ZETS C1608Y5V183ZETS C1608Y5V223ZETS C1608Y5V273ZETS C1608Y5V333ZETS C1608Y5V393ZETS C1608Y5V473ZETS C1608Y5V563ZETS C1608Y5V683ZETS C1608Y5V823ZETS C1608Y5V104ZETS C1608Y5V224ZETS C1608Y5V334ZETS C1608Y5V474ZETS C1608Y5V684ZETS C1608Y5V824ZETS C1608Y5V105ZETS C1608Y5V225ZETS C1608Y5V103ZGT C1608Y5V123ZGT C1608Y5V153ZGT C1608Y5V183ZGT C1608Y5V223ZGT C1608Y5V273ZGT C1608Y5V333ZGT C1608Y5V393ZGT C1608Y5V473ZGT C1608Y5V563ZGT C1608Y5V683ZGT C1608Y5V823ZGT C1608Y5V104ZGT C1608Y5V224ZGT C1608Y5V474ZGT C1608Y5V103ZFT C1608Y5V123ZFT C1608Y5V153ZFT C1608Y5V183ZFT C1608Y5V223ZFT C1608Y5V273ZFT C1608Y5V333ZFT C1608Y5V393ZFT C1608Y5V473ZFT C1608Y5V563ZFT C1608Y5V683ZFT C1608Y5V823ZFT C1608Y5V104ZFT C1608Y5V224ZFT C1608Y5V334ZFT C1608Y5V684ZFT C1608Y5V105ZFT C1608Y5V103ZET C1608Y5V123ZET C1608Y5V153ZET C1608Y5V183ZET C1608Y5V223ZET C1608Y5V273ZET C1608Y5V333ZET C1608Y5V393ZET C1608Y5V473ZET C1608Y5V563ZET C1608Y5V683ZET C1608Y5V823ZET C1608Y5V104ZET C1608Y5V224ZET C1608Y5V334ZET C1608Y5V474ZET C1608Y5V684ZET C1608Y5V824ZET C1608Y5V105ZET C1608Y5V225ZET Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 10 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 470 nF 10 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 330 nF 680 nF 1.0 uF 10 nF 12 nF 15 nF 18 nF 22 nF 27 nF 33 nF 39 nF 47 nF 56 nF 68 nF 82 nF 100 nF 220 nF 330 nF 470 nF 680 nF 820 nF 1.0 uF 2.2 uF Available Tolerance +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% Standard Packing Paper, 4Kpcs Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (I) (II) □ Tolerance Code: M=±20%; Special tolerance on the request. 31 Rev. 201710 MLCC Y5V Series General Purpose  RV 10V 6.3V  RV 50V 25V 16V 10V  RV 50V 35V 25V 16V 10V  DARFON P/N DARFON P/N 2 C1608Y5V104ZDTS C1608Y5V224ZDTS C1608Y5V334ZDTS C1608Y5V474ZDTS C1608Y5V105ZDTS C1608Y5V225ZDTS C1608Y5V475ZDTS C1608Y5V104ZCTS C1608Y5V224ZCTS C1608Y5V334ZCTS C1608Y5V474ZCTS C1608Y5V105ZCTS C1608Y5V225ZCTS C1608Y5V475ZCTS C1608Y5V104ZDT C1608Y5V224ZDT C1608Y5V334ZDT C1608Y5V474ZDT C1608Y5V105ZDT C1608Y5V225ZDT C1608Y5V475ZDT C1608Y5V104ZCT C1608Y5V224ZCT C1608Y5V334ZCT C1608Y5V474ZCT C1608Y5V105ZCT C1608Y5V225ZCT C1608Y5V475ZCT Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 100 nF 220 nF 330 nF 470 nF 1.0 uF 2.2 uF 4.7 uF 100 nF 220 nF 330 nF 470 nF 1.0 uF 2.2 uF 4.7 uF Available Tolerance +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% Thick. (mm) 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 0.80 Tolerance(mm) L/W Thick. ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 +0.15/-0.10 DF (max.) 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% Standard Packing Thick. (mm) 0.60 0.60 0.80 0.80 1.25 0.60 0.60 0.80 0.85 1.25 1.25 0.60 0.60 0.80 0.85 0.85 1.25 1.25 1.25 1.25 Tolerance(mm) L/W Thick. ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.20 ±0.20 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.20 ±0.15 ±0.15/±0.10 ±0.20 ±0.20 ±0.20 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.15/±0.10 ±0.10 ±0.20 ±0.15 ±0.20 ±0.15 ±0.15/±0.10 ±0.10 ±0.20 ±0.20 ±0.15/±0.10 ±0.10 ±0.20 ±0.20 DF (max.) 5.0% 5.0% 5.0% 7.0% 9.0% 5.0% 5.0% 7.0% 9.0% 7.0% 10.0% 5.0% 5.0% 7.0% 9.0% 12.5% 12.5% 12.5% 12.5% 12.5% Thick. Tolerance(mm) (mm) L/W Thick. 0.95 ±0.15/±0.20 ±0.15 1.60 ±0.30 ±0.30 1.15 ±0.20 ±0.15 0.95 ±0.15/±0.20 ±0.15 1.15 ±0.20 ±0.15 1.60 ±0.30 ±0.30 0.85 ±0.30/±0.20 ±0.10 1.15 ±0.20 ±0.15 1.15 ±0.20 ±0.20 1.60 ±0.30 ±0.30 1.15 ±0.20 ±0.15 1.60 ±0.30 ±0.30 DF (max.) 7.0% 9.0% 12.5% 9.0% 9.0% 12.5% 12.5% 12.5% 12.5% 12.5% 12.5% 20.0% Standard Packing Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Embossed, 3Kpcs Embossed, 2Kpcs Test Spec. (I) (I) (II)* (I) (I) (II) (II) (I) (I) (I) (I) (II) Thick. Tolerance(mm) (mm) L/W Thick. 1.60 ±0.20 ±0.20 2.00 ±0.40/±0.30 ±0.20 DF (max.) 9.0% 20.0% Standard Packing Embossed, 2Kpcs Embossed, 1Kpcs Test Spec. (I) (II) Paper, 4Kpcs Paper, 4Kpcs Test Spec. (I) (II) (II) (II) (II) (II) (II)* (I) (I) (I) (I) (I) (I) (II) C2012Y5V Series (EIA0805) DARFON P/N DARFON P/N 2 C2012Y5V104ZGTS C2012Y5V224ZGTS C2012Y5V334ZGTS C2012Y5V474ZGTS C2012Y5V105ZGPS C2012Y5V104ZFTS C2012Y5V224ZFTS C2012Y5V474ZFTS C2012Y5V105ZFTS C2012Y5V105ZFPS C2012Y5V225ZFPS C2012Y5V104ZETS C2012Y5V224ZETS C2012Y5V474ZETS C2012Y5V105ZETS C2012Y5V225ZETS C2012Y5V475ZEPS C2012Y5V106ZEPS C2012Y5V475ZDPS C2012Y5V106ZDPS C2012Y5V104ZGT C2012Y5V224ZGT C2012Y5V334ZGT C2012Y5V474ZGT C2012Y5V105ZGP C2012Y5V104ZFT C2012Y5V224ZFT C2012Y5V474ZFT C2012Y5V105ZFT C2012Y5V105ZFP C2012Y5V225ZFP C2012Y5V104ZET C2012Y5V224ZET C2012Y5V474ZET C2012Y5V105ZET C2012Y5V225ZET C2012Y5V475ZEP C2012Y5V106ZEP C2012Y5V475ZDP C2012Y5V106ZDP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz Capacitance Value Unit 100 nF 220 nF 330 nF 470 nF 1.0 uF 100 nF 220 nF 470 nF 1.0 uF 1.0 uF 2.2 uF 100 nF 220 nF 470 nF 1.0 uF 2.2 uF 4.7 uF 10.0 uF 4.7 uF 10 uF Available Tolerance +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% Standard Packing Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Paper, 4Kpcs Embossed, 3Kpcs Embossed, 3Kpcs Test Spec. (I) (I) (I) (I) (I) (I) (I) (I) (II) (I) (I) (I) (I) (I) (I) (I) (II) (II)* (II)* (II)* C3216Y5V Series (EIA1206) DARFON P/N DARFON P/N 2 C3216Y5V105ZGPS C3216Y5V475ZGPS C3216Y5V475ZNPS C3216Y5V225ZFPS C3216Y5V475ZFPS C3216Y5V106ZFPS C3216Y5V475ZETS C3216Y5V475ZEPS C3216Y5V106ZEPS C3216Y5V226ZEPS C3216Y5V475ZDPS C3216Y5V226ZDPS C3216Y5V105ZGP C3216Y5V475ZGP C3216Y5V475ZNP C3216Y5V225ZFP C3216Y5V475ZFP C3216Y5V106ZFP C3216Y5V475ZET C3216Y5V475ZEP C3216Y5V106ZEP C3216Y5V226ZEP C3216Y5V475ZDP C3216Y5V226ZDP Measuring Condition 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 1V , 1kHz 0.5V , 120Hz 1V , 1kHz 0.5V , 120Hz Capacitance Value Unit 1.0 uF 4.7 uF 4.7 uF 2.2 uF 4.7 uF 10 uF 4.7 uF 4.7 uF 10 uF 22 uF 4.7 uF 22 uF Available Tolerance +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% +80%/-20% Embossed, 3Kpcs Embossed, 2Kpcs Paper, 4Kpcs Embossed, 3Kpcs C3225Y5V Series (EIA1210) RV DARFON P/N DARFON P/N 2 35V 6.3V C3225Y5V106ZNPS C3225Y5V476ZCWS C3225Y5V106ZNP C3225Y5V476ZCW Measuring Condition 1V , 1kHz 0.5V , 120Hz Capacitance Value Unit 10 uF 47 uF Available Tolerance +80%/-20% +80%/-20% (II)* High temperature load life test are applicable in rated voltage *100% 32   Test Spec. General Purpose (I) Specification Item Temp. compensation type Test Method High dielectric constant type NP0: -55 to 125 ℃ X5R: -55 to 85 ℃ --- X6S: -55 to 105 ℃ X7R/X7S/X7T/X7U : -55 to 125 ℃ Y5V: -30 to 85 ℃ Shown in the table of “Part Number & Characteristic” The rated voltage is defined as the maximum voltage, which may be applied continuously to the capacitor. 2 Rated Voltage 3 Appearance No defects or abnormalities. Visual inspection 4 Dimensions Within the specified dimension. Using calipers No defects or abnormalities. No failure shall be observed when 250% of the rated voltage is applied between the terminations for 1 to 5 seconds. The charge and discharge current is less than 50mA. To apply rated voltage. I.R. ≧10GΩor RiCR≧500Ω-F (whichever is smaller) The insulation resistance shall be measured with a DC voltage not exceeding the rated voltage at 25℃ and 75%RH max, and within 1 minute of charging. 5 Dielectric Strength 6 Insulation Resistance ( I.R.) 7 Capacitance 8 Q/Dissipation Factor ( D.F.) The capacitance / D.F. shall be measured at 25 ℃ at the frequency and voltage shown in the table of “Part Number & * X5R, X6S, X7RS, X7S, X7T, X7U and Y5V at 1000 hours Characteristic”. Shown in the table of “Part NP0: Number & Characteristic” If C≦30pF, DF≦1/(400+20C), Within the specified tolerance C in pF If C >30pF, DF≦0.1%. Capacitance change Capacitance change 1. Temperature compensation type: NP0 within 0±30ppm/℃ under X5R/X7R within ±15% operating temperature range. X6S/X7S within ±22% 9 Capacitance Temperature Characteristics The capacitance value at 25℃ and 85℃ shall be measured and calculated from the formula given below. T.C.=(C85-C25)/C25*ΔT*106(PPM/℃) X7T: -33% to + 22% X7U:-56% to + 22% 2. High dielectric constant type: Y5V: -82 to + 22% The ranges of capacitance change compared with the 25℃ value over the temperature ranges shall be within the specified ranges. Apply a parallel force of 5N to a PCB mounted sample for 10±1sec. *2N for 0603 (EIA 0201). No removal of the terminations or marking defect. 10 Termination Strength No cracking or marking defects shall occur at 1mm deflection. Capacitance change: NP0: within ±5% or ± 0.5pF. (whichever is larger) Solder the capacitor to the test jig (glass epoxy boards) shown in Fig.a using a SAC305(Sn96.5Ag3.0Cu0.5) solder (then let sit for 24±2 hours for X5R, X6S, X7R, X7S, X7T, X7U and Y5V). Then apply a force in the direction shown in Fig.b. The soldering shall be done with the reflow method and shall be conducted with care so that the soldering is uniform and free of defects such as heat shock. X5R, X6S, X7R, X7S, X7T, X7U: within ±12.5% Y5V: within±20% (Unit in mm) 11 Deflection (Bending Strength) b c 20 50Pressurizing speed:1.0m/sec. 4.5 40 a 100 T:1.6mm(0.8 mm for 0603 & 1005 size) Fig. a. 12 Solderability of Termination Size 0603 1005 1608 2012 3216 4520 4532 a 0.3 0.4 1.0 1.2 2.2 3.5 3.5 Resistance to Soldering Heat Appearance No marking defects Cap. Change NP0 within ±2.5% or 0.25pF X5R/X6S/X7R/X7S/X7T/X7U ( whichever is larger ) within ±7.5% Q/D.F. I.R. C 0.3 0.5 1.2 1.65 2.0 2.5 3.7 Pressurize R230 Flexure: 1mm Capacitance Meter 45 45 Fig.b. 90% of the terminations are to be soldered evenly and Immerse the test capacitor into a methanol solution containing continuously. rosin for 3 to 5 seconds, preheat it 150 to 180℃ for 2 to 3 minutes and immerse it into SAC305(Sn96.5Ag3.0Cu0.5) solder of 245 ± 5℃ for 3±1seconds. Y5V within ±20% 13 b 0.9 1.5 3.0 4.0 5.0 7.0 7.0 *Preheat the capacitor at 120 to 150℃ for 1 minute. Immerse the capacitor in a SAC305(Sn96.5Ag3.0Cu0.5) solder solution at 270±5℃ for 10±1 seconds. Let sit at room temperature for 24±2 hours, then measure. If C≦30pF, DF≦1/(400+20C) To satisfy the specified initial * Preheat 150 to 200℃ for size≧3216. spec. If C >30pF, DF≦0.1% I.R.≧10,000MΩ or RiCR≧ 500Ω-F. I.R.≧10,000MΩor RiCR≧ 500Ω-F. (whichever is smaller) (whichever is smaller) 33 *High dielectric constant type: Initial measurement : perform a heat treatment at 150+0/-10℃ for one hour and then let sit for 24±2 hours at room temperature. Perform the initial measurement. Rev. 201710 MLCC Operation Temperature Range General Purpose 1 Specification Item Temp. compensation type Appearance Test Method High dielectric constant type No marking defects Solder the capacitor to supporting jig (Glass epoxy board) and NP0 within ±2.5% or 0.25pF X5R/X6S/X7R/X7S/X7T ( whichever is larger ) within ±7.5% perform the five cycles according to the four heat treatments Cap. Change X7U within ±30% listed in the following table. Let sit for 24±2hrs at room temperature, then measure. Y5V within ±20% 14 Temperature cycle (Thermal shock) If C≦30pF, DF≦1/(400+20C) Q/D.F. If C >30pF, DF≦0.1% I.R.≧10GΩor RiCR≧500Ω-F. (whichever is smaller) I.R. Appearance Cap. Change Step 1: Minimum operating temperature To satisfy the specified initial Step 2: Room temperature spec. Step 3: Maximum operating temperature I.R. ≧ 10GΩ or 500Ω-F. RiCR ≧ Step 4: Room temperature (whichever is smaller) 30±3min 2~3 min 30±3min 2~3min *High dielectric constant type: Initial measurement: perform a heat treatment at 150±10℃ for one hour and then let sit for 24±2 hours at room temp. Perform the initial measurement. No marking defects Apply the rated voltage at 40±2℃ and 90 to 95% humidity for NP0 within ±7.5% or 0.75pF X5R/X6S/X7R/X7S/X7T/X7U 500±12 hours. The charge / discharge current is less than 50mA. ( whichever is larger ) within ±12.5% Y5V within ±30% If C>30pF, DF≦0.5% Q/D.F. If C≦30pF,DF≦1/(100+10xC/3) C in pF 15 Humidity load [Temperature compensation type] X5R/X6S/X7R/X7S/X7T/X7U Remove and let sit for 24±2 hours at room temperature, then 200% max of initial spec. measure. Y5V150% max of initial spec. I.R.≧500MΩ or I.R.≧500MΩ or [High dielectric constant type] RiCR≧25Ω-F. RiCR≧25Ω-F. *Initial measurement (whichever is smaller) (whichever is smaller) Perform a heat treatment at 150+0/-10°C for one hour and then let sit for 24±2 hours at room temperature. I.R. Perform the initial measurement. *Measurement after test Perform a heat treatment and then let sit for 24±2 hours at room temperature, then measure. Appearance Cap. Change No marking defects Apply 200%of the rated voltage for 1000±12 hours at the maximum operating temperature ± 3℃. The charge / discharge NP0 within ±7.5% or 0.75pF X5R/X6S/X7R/X7S/X7T/X7U current is less than 50mA. ( whichever is larger ) within ±12.5% [Temperature compensation type] Y5V within ±30% If C>30pF, DF≦0.3% If 10pF B = C > D > E 47 Rev. 201710 【Temperature Coefficient】  Class 1 (Temperature Compensation series)  Class 2 (High Dielectric Constant Series) 48 MLCC 【DC Voltage Coefficient】 【Aging Rate】 The capacitance and dissipation factor of class 2 capacitors decreases with time. It is known as ‘aging’ that follows a logarithmic low and expressed in terms of an aging constant. Aging is caused by a gradual re-alignment of the crystalline structure of the ceramic. The aging constant is defined as the percentage loss of capacitance at a ‘time decade’. The law of capacitance aging is expressed as following equation: Ct2 = Ct1 x (1 – k x log10(t2/t1)) Ct1: Capacitance after t1 hours of start aging. Ct2: Capacitance after t2 hours of start aging. k: aging constant (capacitance decrease per decade) t1, t2: time in hours from start of aging. A typical curve of aging rate is shown in following figure. When heating the capacitors above Curie temperature (130℃~150℃) the capacitance can be re-new. So capacitance of class 2 capacitors will be complete de-aged by soldering process; subsequently a new aging process begins. Because of aging, it is specified an age for measurement to meet the prescribed tolerance for class 2 capacitors. Normally, 1000 hours (t2=1000 hrs) is defined. 49 Rev. 201710 【Peeling Off Force】 Peeling off force: 0.1N to 1.0 N* in the direction shown as below. The peeling speed: 300±10 mm/min 165 ° to 180° Peeling force Top tape Base tape 1. The taped tape on reel is wound clockwise. The sprocket holes are to the right as the tape is pulled toward the user. 2. There are minimum 150 mm as the leader and minimum 40 mm empty tape as the tail is attached to the end of the tape. 50
C1005X5R334KDTS 价格&库存
很抱歉,暂时无法提供与“C1005X5R334KDTS”相匹配的价格&库存,您可以联系我们找货
