MKP25
Metallized polypropylene film capacitor (Box-type)
■ Outline Drawing
W±0.4, H±0.4, T±0.4
■ Features
● Metallized polypropylene structure.
● Excellent electric property.
● Plastic case (UL94 V-0), Epoxy resin sealing.
■ Typical Applications
● As intermediate circuit capacitors for SMPS、Electronic Ballast、inverter(i.e. DC-link, DC-filter and P.F.C)
■ Specifications
Reference Standard
GB/T 10190(IEC 60384-16)
Climatic Category
40/105/56
Rated Temperature
85℃
Operating Temperature Range
-40℃~105℃
(+85℃ to +105℃: decreasing factor 1.25% per ℃ for UR)
Rated Voltage
450Vdc, 520Vdc, 630Vdc
Capacitance Range
0.022μF~22μF
Capacitance Tolerance
5(J), 10 (K), 20 (M)
Voltage Proof
1.6UR (5s)
Dissipation Factor
≤15×10 -4 (20℃, 1kHz)
Insulation Resistance
R ≥ 100 000M,
RCN ≥ 30 000s,
Maximum Pulse Rise Time(dV/dt)
If the working voltage(U) is lower th
an the rated voltage(UR),the capacitor c
an be worked at a higher dV/dt. In this
case, the maximum allowed dV/dt is o
btain by multiplying the right value wit
h UR/U.
P
P
CN≤0.33F
CN0.33F
(20℃,100V,1min)
Max dV/dt(V/us)
——Miniature version
UR(V)
Max dV/dt(V/us)
P=10.0
P=15.0
P=22.5
P=27.5
P=10.0
P=15.0
P=22.5
P=27.5
450
100
65
35
200
100
80
520
120
80
60
40
350
220
150
100
630
200
160
70
50
400
300
180
120
MKP25
■ Part number system
The 18 digits part number is formed as follow:
1
2
C
3
3
4
5
6
7
8
9 10 11
12 13 14 15 16 17 18
5
Digit 1 to 3
Series code
C35=MKP25
Digit 4 to 5
D.C. rated voltage:
2S=450V
Digit 6 to 8
2T=520V
2J=630V
Rated capacitance value
For example: 103=10×103pf=0.01uF
Digit 9
Capacitance tolerance
J=±5%, K=±10%, M=±20%
Digit 10
Pitch
4=10.0mm 6=15.0mm
9=22.5mm B=27.5mm
Digit 11
Internal use
Digit 12 to 15 Lead form and packaging code
Digit 16 to 18 Internal use
Table1 Lead form and packaging code
Digit 12
Digit 13
Digit 14
code
explanation
code
explanation
code
A
ammo-pack
4
6
F=10.0mm
F=15.0mm
code
explanation
C S straight lead
“C” in the
figure above
00
45
35
32
standard lead length
(18mm~26mm)
lead length 4.5mm
lead length 3.5mm
lead length 3.2mm
explanation
straight
Digit 15
code
explanation
5
P3=25.4mm;H=18.5mm (For pitch=10/15mm)
Length tolerance ±0.5mm
Or standard length
2
Length tolerance ±0.3mm
MKP25
■ Dimensions (mm) ---Miniature version (Small sizes+ Segmented metallized-film design)
450Vdc
CN
(F)
W H
T
P
±0.4 ±0.4 ±0.4 ±0.4
d
520Vdc
Part number
W H
T
P
CN
d
(F) ±0.4 ±0.4 ±0.4 ±0.4
630Vdc
Part number
CN
(F)
W H
T
P
±0.4 ±0.4 ±0.4 ±0.4
d
Part number
0.12 13.0
9.0
4.0
10
0.6 C352S124-4S****+++
0.082
13.0
9.0
4.0
10
0.6 C352T823-4S****+++
0.056
13.0 9.0
4.0
10
0.15 13.0
9.0
4.0
10
0.6 C352S154-4S****+++
0.10
13.0
9.0
4.0
10
0.6 C352T104-4S****+++
0.068
13.0 9.0
4.0
10
0.6 C352J563-4S****+++
0.6 C352J683-4S****+++
0.18 13.0 11.0
5.0
10
0.6 C352S184-4S****+++
0.12
13.0 11.0
5.0
10
0.6 C352T124-4S****+++
0.082
13.0 11.0
5.0
10
0.6 C352J823-4S****+++
0.22 13.0 11.0
5.0
10
0.6 C352S224-4S****+++
0.15
13.0 11.0
5.0
10
0.6 C352T154-4S****+++
0.10
13.0 11.0
5.0
10
0.6 C352J104-4S****+++
0.27 13.0 12.0
6.0
10
0.6 C352S274-4S****+++
0.18
13.0 12.0
6.0
10
0.6 C352T184-4S****+++
0.12
13.0 12.0
6.0
10
0.6 C352J124-4S****+++
0.33 13.0 12.0
6.0
10
0.6 C352S334-4S****+++
0.22
13.0 12.0
6.0
10
0.6 C352T224-4S****+++
0.15
13.0 12.0
6.0
10
0.6 C352J154-4S****+++
0.39 13.0 13.0
7.0
10
0.6 C352S394-4S****+++
0.27
13.0 13.0
7.0
10
0.6 C352T274-4S****+++
0.18
13.0 13.0
7.0
10
0.6 C352J184-4S****+++
0.47 13.0 13.0
7.0
10
0.6 C352S474-4S****+++
0.33
13.0 13.0
7.0
10
0.6 C352T334-4S****+++
0.22
13.0 13.0
7.0
10
0.6 C352J224-4S****+++
0.56 13.0 14.0
8.0
10
0.6 C352S564-4S****+++
0.39
13.0 14.0
8.0
10
0.6 C352T394-4S****+++
0.27
13.0 14.0
8.0
10
0.6 C352J274-4S****+++
0.68 13.0 14.0
8.0
10
0.6 C352S684-4S****+++
0.47
13.0 14.0
8.0
10
0.6 C352T474-4S****+++
0.33
13.0 14.0
8.0
10
0.6 C352J334-4S****+++
0.22 17.5 11.0
5.0
15
0.6 C352S224-6S****+++
0.27
17.5 11.0
5.0
15
0.6 C352T274-6S****+++
0.18
17.5 11.0
5.0
15
0.6 C352J184-6S****+++
0.33 17.5 11.0
5.0
15
0.6 C352S334-6S****+++
0.33
17.5 11.0
5.0
15
0.6 C352T334-6S****+++
0.22
17.5 11.0
5.0
15
0.6 C352J224-6S****+++
0.39 17.5 11.0
5.0
15
0.6 C352S394-6S****+++
0.39
17.5 12.0
6.0
15
0.6 C352T394-6S****+++
0.27
17.5 12.0
6.0
15
0.6 C352J274-6S****+++
0.47 17.5 11.0
5.0
15
0.6 C352S474-6S****+++
0.47
17.5 12.0
6.0
15
0.6 C352T474-6S****+++
0.33
17.5 12.0
6.0
15
0.6 C352J334-6S****+++
0.56 17.5 12.0
6.0
15
0.6 C352S564-6S****+++
0.56
17.5 12.0
7.0
15
0.6 C352T564-6S****+++
0.39
17.5 12.0
7.0
15
0.6 C352J394-6S****+++
0.68 17.5 12.0
7.0
15
0.6 C352S684-6S****+++
0.68
17.5 13.5
7.5
15
0.6 C352T684-6S****+++
0.47
17.5 13.5
7.5
15
0.6 C352J474-6S****+++
0.82 17.5 12.0
7.0
15
0.6 C352S824-6S****+++
0.82
17.5 14.0
8.0
15
0.6 C352T824-6S****+++
0.56
17.5 14.0
8.0
15
0.6 C352J564-6S****+++
1.0
17.5 13.5
7.5
15
0.6 C352S105-6S****+++
1.0
17.5 14.5
8.5
15
0.6 C352T105-6S****+++
0.68
17.5 14.5
8.5
15
0.6 C352J684-6S****+++
1.2
17.5 14.0
8.0
15
0.6 C352S125-6S****+++
1.2
17.5 16.0 10.0
15
0.8 C352T125-6S****+++
0.82
17.5 16.0 10.0
15
08 C352J824-6S****+++
1.5
17.5 16.0 10.0
15
0.8 C352S155-6S****+++
1.5
17.5 19.0 11.0
15 0.8 C352T155-6S****+++
1.0
17.5 16.0 10.0
15
0.8 C352J105-6S****+++
1.8
17.5 16.0 10.0
15
0.8 C352S185-6S****+++
0.68
26.5 15.0
22.5 0.8 C352T684-9S****+++
1.2
17.5 19.0
15
0.8 C352J125-6S****+++
6.0
11.0
2.2
17.5 19.0 11.0
15
0.8 C352S225-6S****+++
0.82
26.5 15.0
6.0
22.5 0.8 C352T824-9S****+++
0.47
26.5 15.0
6.0 22.5
0.8 C352J474-9S****+++
1.0
26.5 15.0
6.0
22.5
0.8 C352S105-9S****+++
1.0
26.5 16.0
7.0
22.5 0.8 C352T105-9S****+++
0.56
26.5 15.0
6.0 22.5
0.8 C352J564-9S****+++
1.2
26.5 15.0
6.0
22.5
0.8 C352S125-9S****+++
1.2
26.5 16.0
7.0
22.5 0.8 C352T125-9S****+++
0.68
26.5 16.0
7.0 22.5
0.8 C352J684-9S****+++
1.5
26.5 16.0
7.0
22.5
0.8 C352S155-9S****+++
1.5
26.5 17.0
8.5
22.5 0.8 C352T155-9S****+++
0.82
26.5 16.0
7.0 22.5
0.8 C352J824-9S****+++
1.8
26.5 16.0
7.0
22.5
0.8 C352S185-9S****+++
1.8
26.5 17.0
8.5
22.5 0.8 C352T185-9S****+++
1.0
26.5 17.0
8.5 22.5
0.8 C352J105-9S****+++
2.2
26.5 17.0
8.5
22.5
0.8 C352S225-9S****+++
2.2
26.5 18.5 10.0 22.5 0.8 C352T225-9S****+++
1.2
26.5 17.0
8.5 22.5
0.8 C352J125-9S****+++
2.7
26.5 17.0
8.5
22.5
0.8 C352S275-9S****+++
2.7
26.5 18.5 10.0 22.5 0.8 C352T275-9S****+++
1.5
26.5 18.5 10.0 22.5
0.8 C352J155-9S****+++
3.3
26.5 18.5 10.0 22.5
0.8 C352S335-9S****+++
3.3
26.5 20.0 11.0 22.5 0.8 C352T335-9S****+++
1.8
26.5 18.5 10.0 22.5
0.8 C352J185-9S****+++
3.9
26.5 18.5 10.0 22.5
0.8 C352S395-9S****+++
3.9
26.5 22.0 12.0 22.5 0.8 C352T395-9S****+++
2.2
26.5 20.0
11.0 22.5
0.8 C352J225-9S****+++
4.7
26.5 20.0 11.0 22.5
0.8 C352S475-9S****+++
4.7
26.5 24.5 15.5 22.5 0.8 C352T475-9S****+++
2.7
26.5 22.0 12.0 22.5
0.8 C352J275-9S****+++
5.6
26.5 22.0 12.0 22.5
0.8 C352S565-9S****+++
5.6
26.5 24.5 15.5 22.5 0.8 C352T565-9S****+++
3.3
26.5 24.5 15.5 22.5
0.8 C352J335-9S****+++
6.8
26.5 24.5 15.5 22.5
0.8 C352S685-9S****+++
2.2
32.0 18.0
9.0
27.5 0.8 C352T225-BS****+++
3.9
26.5 24.5 15.5 22.5
0.8 C352J395-9S****+++
8.2
26.5 24.5 15.5 22.5
0.8 C352S825-9S****+++
2.7
32.0 18.0
9.0
27.5 0.8 C352T275-BS****+++
1.8
32.0 18.0
3.3
32.0 18.0
9.0
27.5
0.8 C352S335-BS****+++
3.3
32.0 20.0 11.0 27.5 0.8 C352T335-BS****+++
2.2
32.0 20.0 11.0 27.5
0.8 C352J225-BS****+++
3.9
32.0 18.0
9.0
27.5
0.8 C352S395-BS****+++
3.9
32.0 20.0 11.0 27.5 0.8 C352T395-BS****+++
2.7
32.0 20.0 11.0 27.5
0.8 C352J275-BS****+++
4.7
32.0 20.0 11.0 27.5
0.8 C352S475-BS****+++
4.7
32.0 22.0 13.0 27.5 0.8 C352T475-BS****+++
3.3
32.0 22.0 13.0 27.5
0.8 C352J335-BS****+++
5.6
32.0 20.0 11.0 27.5
0.8 C352S565-BS****+++
5.6
32.0 22.0 13.0 27.5 0.8 C352T565-BS****+++
3.9
32.0 22.0 13.0 27.5
0.8 C352J395-BS****+++
6.8
32.0 22.0 13.0 27.5
0.8 C352S685-BS****+++
6.8
32.0 24.5 15.0 27.5 0.8 C352T685-BS****+++
4.7
32.0 24.5 15.0 27.5
0.8 C352J475-BS****+++
8.2
32.0 24.5 15.0 27.5
0.8 C352S825-BS****+++
8.2
32.0 24.5 15.0 27.5 0.8 C352T825-BS****+++
5.6
32.0 28.0 17.0 27.5
0.8 C352J565-BS****+++
10.0 32.0 24.5 15.0 27.5
0.8 C352S106-BS****+++
10.0
32.0 28.0 17.0 27.5 0.8 C352T106-BS****+++
6.8
32.0 29.0 19.0 27.5
0.8 C352J685-BS****+++
12.0 32.0 28.0 17.0 27.5
0.8 C352S126-BS****+++
12.0
32.0 33.0 18.0 27.5 0.8 C352T126-BS****+++
8.2
32.0 29.0 19.0 27.5
0.8 C352J825-BS****+++
9.0
27.5
0.8 C352J185-BS****+++
15.0 32.0 33.0 18.0 27.5
0.8 C352S156-BS****+++
15.0
32.0 37.0 22.0 27.5 0.8 C352T156-BS****+++
10.0
32.0 37.0 22.0 27.5
0.8 C352J106-BS****+++
18.0 32.0 37.0 22.0 27.5
0.8 C352S186-BS****+++
18.0
32.0 37.0 22.0 27.5 0.8 C352T186-BS****+++
12.0
32.0 37.0 22.0 27.5
0.8 C352J126-BS****+++
22.0 32.0 37.0 22.0 27.5
0.8 C352S226-BS****+++
Note:
1. “-”=capacitance tolerance code, M=±20%,K=±10%,J=±5%
2. “****”=lead form and packaging code (refer to table 1)
MKP25
■ Dimensions (mm)
450Vdc
W H
T
P
CN
d
520Vdc
Part number
W H
T
P
CN
d
630Vdc
Part number
W H
T
P
CN
d
Part number
0.068
13.0
9.0
4.0
10.0
0.6 C352S683-40****+++
0.047
13.0
9.0
4.0 10.0 0.6 C352T473-40****+++
0.022
13.0
9.0
4.0
10.0
0.082
13.0
9.0
4.0
10.0
0.6 C352S823-40****+++
0.056
13.0
9.0
4.0 10.0 0.6 C352T563-40****+++
0.027
13.0
9.0
4.0
10.0
0.6 C352J223-40****+++
0.6 C352J273-40****+++
0.10
13.0 11.0
5.0
10.0
0.6 C352S104-40****+++
0.068
13.0
9.0
4.0 10.0 0.6 C352T683-40****+++
0.033
13.0
9.0
4.0
10.0
0.6 C352J333-40****+++
0.12
13.0 11.0
5.0
10.0
0.6 C352S124-40****+++
0.082
13.0 11.0
5.0 10.0 0.6 C352T823-40****+++
0.039
13.0
9.0
4.0
10.0
0.6 C352J393-40****+++
0.15
13.0 12.0
6.0
10.0
0.6 C352S154-40****+++
0.1
13.0 11.0
5.0 10.0 0.6 C352T104-40****+++
0.047
13.0 11.0
5.0
10.0
0.6 C352J473-40****+++
0.18
13.0 12.0
6.0
10.0
0.6 C352S184-40****+++
0.12
13.0 12.0
6.0 10.0 0.6 C352T124-40****+++
0.056
13.0 11.0
5.0
10.0
0.6 C352J563-40****+++
0.22
13.0 13.0
7.0
10.0
0.6 C352S224-40****+++
0.15
13.0 12.0
6.0 10.0 0.6 C352T154-40****+++
0.068
13.0 11.0
5.0
10.0
0.6 C352J683-40****+++
0.27
13.0 13.0
7.0
10.0
0.6 C352S274-40****+++
0.18
13.0 13.0
7.0 10.0 0.6 C352T184-40****+++
0.082
13.0 12.0
6.0
10.0
0.6 C352J823-40****+++
0.33
13.0 14.0
8.0
10.0
0.6 C352S334-40****+++
0.22
13.0 13.0
7.0 10.0 0.6 C352T224-40****+++
0.10
13.0 12.0
6.0
10.0
0.6 C352J104-40****+++
0.10
17.5
9.5
5.0
15.0
0.6 C352S104-6A****+++
0.27
13.0 14.0
8.0 10.0 0.6 C352T274-40****+++
0.12
13.0 13.0
7.0
10.0
0.6 C352J124-40****+++
0.12
17.5 11.0
5.0
15.0
0.6 C352S124-6A****+++ 0.033
17.5 11.0
5.0 15.0 0.6 C352T333-6A****+++
0.15
13.0 13.0
7.0
10.0
0.6 C352J154-40****+++
0.15
17.5 11.0
5.0
15.0
0.6 C352S154-6A****+++ 0.039
17.5 11.0
5.0 15.0 0.6 C352T393-6A****+++
0.18
13.0 14.0
8.0
10.0
0.6 C352J184-40****+++
0.18
17.5 11.0
5.0
15.0
0.6 C352S184-6A****+++ 0.047
17.5 11.0
5.0 15.0 0.6 C352T473-6A****+++
0.068
17.5 11.0
5.0
15.0
0.6 C352J683-6A****+++
0.22
17.5 11.0
5.0
15.0
0.6 C352S224-6A****+++ 0.056
17.5 11.0
5.0 15.0 0.6 C352T563-6A****+++
0.082
17.5 11.0
5.0
15.0
0.6 C352J823-6A****+++
0.27
17.5 12.0
6.0
15.0
0.6 C352S274-6A****+++ 0.068
17.5 11.0
5.0 15.0 0.6 C352T683-6A****+++
0.10
17.5 11.0
5.0
15.0
0.6 C352J104-6A****+++
0.33
17.5 12.0
6.0
15.0
0.6 C352S334-6A****+++ 0.082
17.5 11.0
5.0 15.0 0.6 C352T823-6A****+++
0.12
17.5 11.0
5.0
15.0
0.6 C352J124-6A****+++
0.39
17.5 13.5
7.5
15.0
0.6 C352S394-6A****+++
0.1
17.5 11.0
5.0 15.0 0.6 C352T104-6A****+++
0.15
17.5 12.0
6.0
15.0
0.6 C352J154-6A****+++
0.47
17.5 13.5
7.5
15.0
0.6 C352S474-6A****+++
0.12
17.5 11.0
5.0 15.0 0.6 C352T124-6A****+++
0.18
17.5 12.0
6.0
15.0
0.6 C352J184-6A****+++
0.56
17.5 13.5
7.5
15.0
0.6 C352S564-6A****+++
0.15
17.5 11.0
5.0 15.0 0.6 C352T154-6A****+++
0.22
17.5 13.5
7.5
15.0
0.6 C352J224-6A****+++
0.68
17.5 16.0 10.0 15.0
0.8 C352S684-60****+++
0.18
17.5 11.0
5.0 15.0 0.6 C352T184-6A****+++
0.27
17.5 13.5
7.5
15.0
0.6 C352J274-6A****+++
0.82
17.5 16.0 10.0 15.0
0.8 C352S824-60****+++
0.22
17.5 12.0
6.0 15.0 0.6 C352T224-6A****+++
0.33
17.5 14.5
8.5
15.0
0.8 C352J334-60****+++
1.0
17.5 19.0 11.0 15.0
0.8 C352S105-60****+++
0.27
17.5 12.0
6.0 15.0 0.6 C352T274-6A****+++
0.39
17.5 16.0
10.0 15.0
0.8 C352J394-60****+++
0.27
26.5 15.0
6.0
22.5
0.6 C352S274-9A****+++
0.33
17.5 13.5
7.5 15.0 0.6 C352T334-6A****+++
0.47
17.5 16.0
10.0 15.0
0.8 C352J474-60****+++
0.33
26.5 15.0
6.0
22.5
0.6 C352S334-9A****+++
0.39
17.5 13.5
7.5 15.0 0.6 C352T394-6A****+++
0.56
17.5 19.0
11.0 15.0
0.8 C352J564-60****+++
0.39
26.5 15.0
6.0
22.5
0.6 C352S394-9A****+++
0.47
17.5 14.5
8.5 15.0 0.8 C352T474-60****+++
0.68
17.5 19.0
11.0 15.0
0.8 C352J684-60****+++
0.47
26.5 15.0
6.0
22.5
0.6 C352S474-9A****+++
0.56
17.5 16.0 10.0 15.0 0.8 C352T564-60****+++
0.15
26.5 15.0
6.0
22.5
0.6 C352J154-9A****+++
0.56
26.5 16.0
7.0
22.5
0.6 C352S564-9A****+++
0.68
17.5 16.0 10.0 15.0 0.8 C352T684-60****+++
0.18
26.5 15.0
6.0
22.5
0.6 C352J184-9A****+++
0.68
26.5 16.0
7.0
22.5
0.6 C352S684-9A****+++
0.82
17.5 19.0 11.0 15.0 0.8 C352T824-60****+++
0.22
26.5 15.0
6.0
22.5
0.6 C352J224-9A****+++
0.82
26.5 16.0
7.0
22.5
0.6 C352S824-9A****+++
1.0
17.5 19.0 11.0 15.0 0.8 C352T105-60****+++
0.27
26.5 15.0
6.0
22.5
0.6 C352J274-9A****+++
1.0
26.5 17.0
8.5
22.5
0.8 C352S105-90****+++
0.18
26.5 15.0
6.0 22.5 0.6 C352T184-9A****+++
0.33
26.5 15.0
6.0
22.5
0.6 C352J334-9A****+++
1.2
26.5 18.5 10.0 22.5
0.8 C352S125-90****+++
0.22
26.5 15.0
6.0 22.5 0.6 C352T224-9A****+++
0.39
26.5 16.0
7.0
22.5
0.6 C352J394-9A****+++
1.5
26.5 18.5 10.0 22.5
0.8 C352S155-90****+++
0.27
26.5 15.0
6.0 22.5 0.6 C352T274-9A****+++
0.47
26.5 16.0
7.0
22.5
0.6 C352J474-9A****+++
1.8
26.5 22.0 12.0 22.5
0.8 C352S185-90****+++
0.33
26.5 15.0
6.0 22.5 0.6 C352T334-9A****+++
0.56
26.5 17.0
8.5
22.5
0.8 C352J564-90****+++
0.68
32.0 18.0
9.0
27.5
0.8 C352S684-B0****+++
0.39
26.5 15.0
6.0 22.5 0.6 C352T394-9A****+++
0.68
26.5 17.0
8.5
22.5
0.8 C352J684-90****+++
0.82
32.0 18.0
9.0
27.5
0.8 C352S824-B0****+++
0.47
26.5 15.0
6.0 22.5 0.6 C352T474-9A****+++
0.82
26.5 18.5
10.0 22.5
0.8 C352J824-90****+++
1.0
32.0 18.0
9.0
27.5
0.8 C352S105-B0****+++
0.56
26.5 16.0
7.0 22.5 0.6 C352T564-9A****+++
1.0
26.5 18.5
10.0 22.5
0.8 C352J105-90****+++
1.2
32.0 18.0
9.0
27.5
0.8 C352S125-B0****+++
0.68
26.5 16.0
7.0 22.5 0.6 C352T684-9A****+++
1.2
26.5 22.0
12.0 22.5
0.8 C352J125-90****+++
1.5
32.0 18.0
9.0
27.5
0.8 C352S155-B0****+++
0.82
26.5 17.0
8.5 22.5 0.8 C352T824-90****+++
0.27
32.0 18.0
9.0
27.5
0.8 C352J274-B0****+++
1.8
32.0 20.0 11.0 27.5
0.8 C352S185-B0****+++
1.0
26.5 18.5 10.0 22.5 0.8 C352T105-90****+++
0.33
32.0 18.0
9.0
27.5
0.8 C352J334-B0****+++
2.2
32.0 20.0 11.0 27.5
0.8 C352S225-B0****+++
1.2
26.5 18.5 10.0 22.5 0.8 C352T125-90****+++
0.39
32.0 18.0
9.0
27.5
0.8 C352J394-B0****+++
2.7
32.0 22.0 13.0 27.5
0.8 C352S275-B0****+++
1.5
26.5 22.0 12.0 22.5 0.8 C352T155-90****+++
0.47
32.0 18.0
9.0
27.5
0.8 C352J474-B0****+++
3.3
32.0 22.0 13.0 27.5
0.8 C352S335-B0****+++
1.8
26.5 22.0 12.0 22.5 0.8 C352T185-90****+++
0.56
32.0 18.0
9.0
27.5
0.8 C352J564-B0****+++
3.9
32.0 24.5 15.0 27.5
0.8 C352S395-B0****+++
0.27
32.0 18.0
9.0 27.5 0.8 C352T274-B0****+++
0.68
32.0 18.0
9.0
27.5
0.8 C352J684-B0****+++
4.7
32.0 33.0 18.0 27.5
0.8 C352S475-B0****+++
0.33
32.0 18.0
9.0 27.5 0.8 C352T334-B0****+++
0.82
32.0 18.0
9.0
27.5
0.8 C352J824-B0****+++
5.6
32.0 33.0 18.0 27.5
0.8 C352S565-B0****+++
0.39
32.0 18.0
9.0 27.5 0.8 C352T394-B0****+++
1.0
32.0 20.0
11.0 27.5
0.8 C352J105-B0****+++
6.8
32.0 33.0 18.0 27.5
0.8 C352S685-B0****+++
0.47
32.0 18.0
9.0 27.5 0.8 C352T474-B0****+++
1.2
32.0 20.0
11.0 27.5
0.8 C352J125-B0****+++
8.2
32.0 33.0 18.0 27.5
0.8 C352S825-B0****+++
0.56
32.0 18.0
9.0 27.5 0.8 C352T564-B0****+++
1.5
32.0 22.0
13.0 27.5
0.8 C352J155-B0****+++
0.68
32.0 18.0
9.0 27.5 0.8 C352T684-B0****+++
1.8
32.0 22.0
13.0 27.5
0.8 C352J185-B0****+++
0.82
32.0 18.0
9.0 27.5 0.8 C352T824-B0****+++
2.2
32.0 24.5
15.0 27.5
0.8 C352J225-B0****+++
1.0
32.0 18.0
9.0 27.5 0.8 C352T105-B0****+++
2.7
32.0 28.0
14.0 27.5
0.8 C352J275-B0****+++
1.2
32.0 18.0
9.0 27.5 0.8 C352T125-B0****+++
3.3
32.0 33.0
18.0 27.5
0.8 C352J335-B0****+++
1.5
32.0 20.0 11.0 27.5 0.8 C352T155-B0****+++
3.9
32.0 33.0
18.0 27.5
0.8 C352J395-B0****+++
1.8
32.0 20.0 11.0 27.5 0.8 C352T185-B0****+++
Note:
M=±20%,K=±10%,J=±5%
to table 1)
2.2
32.0 22.0 13.0 27.5 0.8 C352T225-B0****+++
2.7
32.0 24.5 15.0 27.5 0.8 C352T275-B0****+++
3.3
32.0 28.0 14.0 27.5 0.8 C352T335-B0****+++
3.9
32.0 28.0 14.0 27.5 0.8 C352T395-B0****+++
4.7
32.0 33.0 18.0 27.5 0.8 C352T475-B0****+++
5.6
32.0 33.0 18.0 27.5 0.8 C352T565-B0****+++
6.8
32.0 33.0 18.0 27.5 0.8 C352T685-B0****+++
MKP25
■ Max. Current (Ir.m.s.) versus Frequency – Miniature version
NOTE: 1.sinusoidal wave-form, environment temperature≤85℃,internal temperature rise △ T=10℃, p (pitch) in mm.
2. The series product is only recommended to use in DC-filter or DC-blocking circuits. It means the voltage
applied to the capacitors must be unidirectional ripple voltage. The typical voltage curve is as follows reference.
If you have any questions for this note, please feel free to contact with our technical engineer.
Here: V1≥0, V2≤UR, Irms=2 π f×C×(V2 -V1)/ 2
UR is the rated voltage of the capacitor
MKP25
reference. If you have any questions for this note, please feel free to contact with our technical engineer.
Here: V1≥0, V2≤UR, Irms 2πfC(V2 V1 )/ 2
MKP25
■ Test Method And Performance
No.
Item
1
Solderability
Initial measurement
Performance
Good quality of tinning
Test method(IEC 60384-16)
Solder temperature: 245˚C 5˚C
Immersion time: 2.0s0.5s
Capacitance
Tg: 1kHz,C1.0F
10kHz,C1.0F
Tension: 10N(0.6φd0.8)
20N(φd=1.0)
Bend:
5N(0.6φd0.8)
10N(φd=1.0)
The terminals shall be bent 2 times in
each direction.
Solder temperature:260˚C5˚C
Immersion time: 10s1s
There shall be no visible damage
Terminal strength
2
Resistance to solder heat
Final measurement
Initial measurement
Rapid change of
temperature
Vibration
C/C 3(relative to the initial
value)
Increase of tg:
0.004 (10kHz,C1.0μF)
0.004 (1kHz, C>1.0μF)
Capacitance
Tg: 1kHz,C1.0F
10kHz,C1.0F
There shall be no evidence of
deterioration.
There shall be
deterioration.
no
evidence
of
3
Bump
Final measurement
Initial
measurement
4
Climate
sequence
Dry heat
Damp
heat, Cyclic
Cold
Low
air
pressure
Damp heat,
Cyclic other
Final
measurement
deterioration.
value)
Increase of tg:
IR: 50 of the rated value
Capacitance
Tg: 1kHz,C1.0F
10kHz,C1.0F
A=-40˚C, B =+105˚C 5 cycles
Duration: t=30min
Amplitude 0.75mm or acceleration
98m/s2 (whichever is the smaller
severity), f: 10Hz to 500Hz.Three
directions, 2h for each direction, total 6h.
4
000
times,
Acceleration:
390m/s2,Pulse duration, 6ms
+105℃, 16h
Test Db, Severity: b, the first cycle
There shall be no permanent breakdown,
flashover or other harmful deformation
when applying UR at the last 1 minute.
Applying UR for 1 minute after 15
minutes the test finished.
There shall be no visible damage,
legible marking
C/C 5(relative to the initial
value)
Increase of tg:
0.005 (C1.0μF,10kHz)
0.005(C>1.0μF,1kHz)
I.R.: 50 of the rated value
-40℃, 2h
15℃~35℃, 8.5kPa, 1h
Test Db, Severity b, the other cycles,
MKP25
No.
Item
5
Damp heat steady state
6
Endurance
7
Charging and discharging
Performance
There shall be no visible damage, Temperature:40˚C 2˚C
legible marking
2
Humidity: 93 3 %RH
Duration: 56 days
value)
Increase of tg:0.002 (1kHz)
There shall be no visible damage, Temperature: +85℃
legible marking
Voltage: 1.25×UR
C/C 5(relative to the initial Duration: 1 000h
value)
Increase of tg:
C/C 5(relative to the initial Times: 10 000
Duration of charging: 0.5s
value)
Duration
of discharging: 0.5s
ncrease of tg:
Charging
voltage: rated voltage UR
Charging
resistance:
220/CN()
0.005(C>1.0μF,1kHz)
Discharging
resistance:
UR÷CN÷dv/dt()
CN: rated capacitance (μF)
dv/dt value: see P2
■ Quality ensuring test (before shipment):
Inspection item(each batch)
Inspection level (GB 2828)
IL
AQL
II
1.5
II
0.65
S-3
2.5
Appearance inspection
Dimensions
Capacitance
Tangent of the loss angle
Dielectric strength
Insulation resistance
Solderability
■ Marking
MKP25
Taping specification for box-type capacitors
▲ Outline Drawing
Fig.1 P=5.0、7.5mm
Fig.2 P=10.0、15.0mm
▲ Taping Dimensions(mm)
Technology index
Code
title
Taping type
Part number AmmoDigit12-15
pack
Taping pitch
P3
Feed hole pitch
P0
▲ Packing Quantity
Dimensions
P=5.0
P=7.5
P=10.0
P=15.0 Tolerance
Fig 1
Fig 1
Fig2
Fig 2
A201
A301
A405
A605
12.7
12.7
12.7
12.7
25.4
12.7
25.4
12.7
±1.0
±0.3
Center of wire
P1
3.85
2.6
7.7
5.2
±0.7
Center of body
Pitch of taping
wire
Component
alignment
Height of
component from
tape center
P2
6.35
6.35
12.7
12.7
F**
5.0
7.5
10.0
15.0
±1.3
+0.6
-0.1
△S
±2.0
H***
18.5
18.5
18.5
18.5
±0.5
W
18.0
18.0
18.0
18.0
+1.0
-0.5
W0
6min
10min
10min
10min
W1
9.0
9.0
9.0
9.0
±0.5
W2
3max
3max
3max
3max
D0
t
4.0
0.7
4.0
0.7
4.0
0.7
4.0
0.7
±0.2
±0.2
Carrier tape width
Hold down tape
width
Hole position
Hold down tape
sition
Feed hole dia.
Tape thickness
■ Packing box sizes(mm)
1. Out packing box for bulk
3. Box sizes for Ammo-pack
Pitch
(mm)
5.0
7.5
10.0/
15.0
15.0
Box
thickness
T(mm)
2.5
3.5
4.5
5.0
6.0
3.5
4.0
5.0
6.0
4.0
5.0
6.0
7.5
8.5
10.0
11.0
Ammo-pack
(pcs/box)
Domestic
Export
2500
1 700
1 400
1 200
1 000
2 000
1 500
1 300
1 000
800
1 700
1 500
1 200
1 000
750
600
500
400
350
300
250
1 500
1 350
1 050
850
650
500
450
350
300
250
220
Note: * P0=15mm is also available;
**F can be other lead spacing;
***H=16.5mm is available;
2. Inner packing box for bulk
