SPECIFICATIONS FOR APPROVAL
GP
Customer Part No.
HELE. Part No:
Application For:
Products:
Accepted Model:
Type & Freq.:
Sample Order No:
EOS-EB0074-1
X3S032000BC1HZ-NU
CRYSTAL
HSX321S / 32.000MHz
Date:
2014/11/06
Approved By :
HARMONY ELECTRONICS CORP.
HARMONY ELECTRONICS (THAILAND) CO., LTD.
HARMONY ELECTRONICS (SHENZHEN) CORP., LTD.
TAIPEI OFFICE:
公司:(114)
台北市內湖區堤頂大道 2 段 409 號 2 樓
2F., NO.409, SEC.2, TIDING BLVD.,
NEIHU DISTRICT, TAIPEI CITY 114,
TAIWAN
TEL:886-2-26588883
FAX:886-2-26588683
TAIWAN FACTORY:
工廠:(831)
高雄市大寮區大發工業區華東路 39 號
No.39, HWA DONG RD., DALLIAO
DIST.,DAFA INDUSTRIAL PARK.,
KAOHSIUNG CITY 831, TAIWAN
TEL: (07)787-1555-6
FAX: (07)787-1557
THAILAND FACTORY:
66MOO 5, KAONGU-BEOKPRAI RD.,
T.BEOKPRAI, A. BANPONG,
RAJCHABUREE PROVINCE 70110,
THAILAND
TEL: (032)221994-6,
200740-1
FAX: (032)200742
Country of origin
Tittle HSX321S
QUARTZ CRYSTAL SPECIFICATION
Date
Confirm
2014/11/06 F. S. TSAI
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
SHENZHEN FACTORY:
深圳市福永鎮塘尾村塘橋路聚源工業區
QIAO TANG RD., TANGWEI VILLAGE
FU YONG TOWN SHENZHEN CITY
CHINA
TEL: 0755-27309272 /
27309262
FAX: 0755-27309755
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
HSX321S SPECIFICATION
INDEX
ITEM
PAGE
1. QUARTZ CRYSTAL UNIT SPECIFICATION...........
3
2. MARKING & DIMENSIONS...................
4
3. INSIDE STRUCTURE......................
5
4. EMBOSS CARRIER TAPE&REEL................
a. DIMENSIONS OF CARRIER TAPE...............
6
b. DIMENSIONS OF REEL...................
6-7
c. STORAGE CONDITION...................
7
d. STANDARD PACKING QUANTITY...................
7
e. MATERIAL OF TAPE.....................
7
f. LABEL CONTENTS......................
7
g. TAPING DIMENSION.....................
8
h. JOINT OF TAPE.......................
8
i. RELEASE STRENGHT OF COVER TAPE............
8
j. PACKAGE..........................
9
5. MECHANICAL PERFORMANCE.................
10
6. ENVIRONMENTAL PERFORMANCE...............
11
7. SUPPLEMENT ........................
12-13
8. FLOW CHART.........................
14
9. Environmental Workload Chemical Substance Components List.
15
10. TEST DATA..........................
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
1. Frequency:
32.000000MHz
2. Holder type :
HSX321S
3. Frequency tolerance:
+/-10 ppm at 25deg.C +/-3deg.C
4. Equivalent resistance:
50 ohms Max. / SERIES
5. Storage temperature range:
-40 deg.C To +85 deg.C
6. Operable temperature range:
-20 deg.C To +70 deg.C
7. Temperature drift:
+/-10 ppm
8. Loading capacitance (CL) :
12.0 pF
9. Drive level:
10 μW
10. Shunt Capacitance:
2.0 pF Max.
11. Insulation resistance :
More than 500M ohms at DC 100V
12. Mode of oscillation:
Fundamental
13. Circuit:
Measured in HP/E5100A,S&A 250B
14. Shocking :
Dropping from 120 cm height 3 times on Concrete
(100uW Max.)
floor
Variation :
Frequency less than +/-5 ppm
Resistance less than +/- 15 ﹪or 2ohms max.
15. Aging:
Less than +3 ppm/Year
16. Holder
HSX321S Seam type
17. Dimensions and marking
Refer to page.4
18. Emboss carrier tape & reel
Refer to page.6 and page.7
19. Moisture Sensitivity Level
Level 1
20. Note:
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
2. HSX321S MARKING & DIMENSIONS
Chamfer index mark depends on the ceramic base supplier.
*Marking should be printed as following:
Logo, Nominal Frequency, Manufactured year & month
*Nominal frequency = integer only
( ex. 14.31818 MHz 14 )
*Manufacturing Lot No.
(Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1)
(M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2).
Marking : Laser marking.
(Table-1)
Year
2000 2001 2002 2003 2004 2005 2006 2007 2008
2010 2011 2012 2013 2014 2015 2016 2017 2018
Code
2
3
4
5
6
7
8
(Table-2)
Jan. Feb. Mar. Apr. May. Jun. Jul. Aug. Sep. Oct. Nov.
A
B
C
D
E
F
G
H
J
K
L
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
2009
2019
9
Dec.
M
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
3. INSIDE STRUCTURE
Cover Ring(8)
ELECTRODE(7)
PAD(6)
CRYSTAL BLANK(4)
PAD(6)
LID(2)
Base(1)
ADHESIVE(5)
※Reference drawing
(1) Base:
Alumina Ceramic (Al2O3)
(6) Metallized Pad: W
Ni Plating
Au Plating
(2) Lid :
Fe- Ni -Co
(3) Crystal Enclosure Seal:
Seal Seam
(4) Crystal Blank
Rectangular At-Cut Quartz Crystal Blank
(5) Adhesive
Silver Conductive Silicon Resin
Adhesive bonding:
upper & lower bonding/lower bonding only
(7) Electrode
(8) Cover Ring:
Fe-Ni-Co Alloy
The use prohibition chemistry
substance of Table 1 of DHE-0204-1
(HE-QA-24) is not included in this
item.
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
4. HSX321S EMBOSS CARRIER TAPE & REEL
a.) Dimensions of Carrier Tape
b.) Dimensions of Reel
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
(Table-2)
(UNIT: mm)
MARK
DIMENSIONS‧ANGLE
Diameter
A
ψ180+0/-3
Inner Width
W1
9.3+/-0.3
Outer Width
W2
11.3+/-1.0
Out Line diameter
B
ψ60.5+/-0.5
F1
3.0+0.5/-0
F2
4.0+0.5/-0
F3
5.0+0.5/-0
Q
120deg
C
ψ13.2+/-0.5
E
3.0+/-0.2
ITEM
FLANCE
HUB
Width
Center
Core slit
Position
Spindle diameter
Key Ditch
Width
c.) Storage condition
Temperature: +40deg.C Max.
Relative Humidity: 80% Max.
d.) Standard packing quantity
3,000PCS / REEL
e.) Material of the tape
Tape
Carrier tape
Top tape
Material
PS Conductive
Polyester
f.) Label contents
Sticks label for every reel.
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
g.) Taping dimension
Cover-tape
Leader
Carrier-tape
Cover-tape
Terminal
Carrier-tape
Terminal
The length of cover-tape in the leader is more than 400 mm including
empty embossed area.
After all products were packaged, must remain more than twenty
pieces or 400 mm empty area, which should be sealed by cover-tape.
The tip of cover-tape shall be fixed temporary by paper tape and roll
around the core of reel one round.
The empty embossed area which are sealed by top cover-tape must
remain more the 40 mm.
Components
Leader
Emptv compartments
Emptv compartments
Top cover-tape
Embossed Carrier-tape
h.) Joint of tape
The carrier-tape and top cover-tape should not be jointed.
i.) Release strength of cover tape
It has to between 0.1N to 0.7N under following condition.
Pulling direction 165° to 180°
Speed
300mm/min.
Otherwise unless specified.
165°~ 180°
Pulling direction
Other standards shall be based on JIS C 0806-1990.
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
j.) Package
TYPE:
SPEC. No.:
Parts No.:
Lot No.:
Label
Up side(Produce)
Q.C
PASS
H10
FREQ.:
Q'TY:
MHz
PCS
HSF
Under side(Fixing Hole)
One reel quantity: [1000pcs]&[3000pcs]
1 Top and bottom with 2.3cm thickness
foam-rubber cushion for protection
2 Carton's Q'TY:1~15 pcs.
3 Carton Type=A,B ,C use 4 trigon pillar to fasten the Reel.
4 Need to add 3 pages dry agent in each outer box.
use 4 trigon pilla
OR
Green Product
ROHS Compliant
A
Carton Type
B
630/531/ 321/221
211/111
Produce Type 840/751 421
Reel
D
C
OTHER
15
15
15
1~7
200
200
200
195
200
200
200
195
230/260
230
230
150
Gree
n Pr
oduc
ROHS
t
Co mp
liant
1.Every Carton with 3 desiccant.
2.Top and bottom with 2.3cm thickness
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
5. Mechanical Performance
Test Methods
1
Natural Drop
2
Vibration
Dropping from 120 cm height 3 times on Concrete floor
Refer to: JIS C 60068-2-6
Frequency 10-55Hz, Sine Wave full amplitude of 0.8mm to X, Y and Z
3 axes, Duration of 2 hours to each axis.
Refer to: MIL-HDBK-781A 6.5.2/ JIS C 60068-2-6
Leak Rate 1.0x10-8 Pa-m3/sec. Max. Measured by Helium leak
detector.
After applying ROSIN Flux, dipping in solder bath at
245deg.C+/-5deg.C for 3+/-0.5 sec.
Refer to: JIS C 60068-2-20
Mount a sample on board.
Apply Pressure to the
center of board until it is
bent to 3 mm and hold
for 5 ±1 sec
Pressure speed :0.5 mm / sec
Refer to: EIAJ ET-7403
Mount a sample on
the circuit board.
Apply pressure
vertically to the side
of specimen attached
to the circuit board
with the pressure jig.
Pressure : 5N for 10±1 sec
Apply pressure to the
center of body with the
R0.5 pressure jig.
pressure :10N for 10±1sec
3
Sealing Tightness
4
Solder ability
5
6
7
Substrate Bending
Adhesion
Body strength
Country of origin
Tittle HSX321S
Date
Specifications
Code
Item
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
A
--B
A
A
A
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
A
CORP.
6.
Environment Performance
Item
1
2
3
4
Specifications
Code
Test Methods
Humidity
Temperature 60℃+/-2℃, RH 90~95%, Duration of 240 hours.
Back to room temperature first, then in 1~2 hours, the component shall
be checked.
Refer to: JIS C 60068-2-3
-40deg.C +/-2deg.C, Duration of 240 hours.
Back to the room temperature first, then in 1~2 hours, the component
shall be checked.
Refer to: JIS C 60068-2-1
+85deg.C +/-2deg.C, Duration of 240 hours.
shall be checked.
-40deg.C +/-2deg.C (30min) +85deg.C +/-2deg.C (30min) 25
cycles. Back to the room temperature first, then in 1~2 hours, the
component shall be checked.
Refer to: JIS C 0025
Storage in Low
Temperature
Storage in High
Temperature
Temperature cycles
A
A
A
A
Specifications code
Specifications
A
Frequency variation shall be within +/-5ppm and equivalent resistance shall be within
+/-15% or 2Ω
More than 90% of lead shall be covered by new solder.
B
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
7. Supplement
7.1. Soldering
7.2. Please stay with our proposed reflow condition and do then soldering 2 times max.
Available for Lead Free Soldering
260 deg.C
Temperature
220 deg.C
(3)
160~180deg.C
(2)
(1)
Time
(1) Preheat
160~180 deg.C 120sec.
(2) Primary heat 220
deg.C 60sec.
(3) Peak
260
deg.C 10sec. Max.
7.3. Land pattern layout (Example)
7.4. Solder iron (Example)
Bit temp.: 350℃ max., Time: 3sec max. , Each terminal solder a 1 time max.
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
7.5. Mounting
This component is designed for automatic insertion.
However, you are requested to do the trial with your insertion machine in order to be
Sure of proper operation and no damage of component.
Please pay attention to board warp which may damage the component and cause
Soldering Process.
Avoid mounting and processing by Ultrasonic welding because this method has a
Possibility of an excessive vibration spreading inside the crystal products and
Becoming the cause of characteristic deterioration and not oscillating.
7.6. Cleaning
Cleaning liquid which corrodes Nickel shall not be used
It may cause the problem on the surface, color, marking etc.
Ultra-sonic cleaning is possible, however, you are requested to check on your board.
Because we only checked as single unit.
7.7. Storage
Please keep away from high temperature and high humidity, which may cause put solderbility.
No direct Sunlight, No dew as well.
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
8. Flow Chart
LID(外 殼 蓋 )
BLANK(晶 片 )
LID進 料 檢 查
BASE(基 座 )進 料 檢 查
BLANK進 料 檢 查
1
Incoming Inspection
of Lid
5
2
LID洗 淨
6
Lid Cleaning and Dry
BASE(基 座 )
7
8
9
10
11
12
13
14
15
16
17
Incoming Inspection
of Crystal blank
Etching
4
Base Cleaning
BASE(基 座 )洗 淨
頻率選別
Frequency Sorting
晶片排盤
Blank Filling
洗 淨 +微 蝕 刻
Blank Cleaning (Individule
cleaning+flash etching)
基礎蒸著
Base Plating
押入接著
Blank Mounting and
Bonding
接著硬化
Bonding Curing
接著外觀檢查
24
Bonding Inspection
氣 密 檢 查 I (Air)
Sealing Inspection I (Air Leak)
調整蒸著
Partial Adjustment (Ion Partial)
25
氣 密 檢 查 II (氦 氣 加 壓 )
Sealing Inspection II
(He Pressurization)
中 間 檢 查 ($)
Middle Check
26
氣 密 檢 查 II (He )
Sealing Inspection II (He Leak)
高真空烘烤
High Vacuum Anneal
27
LID點 焊
Temporary Positioning
熔 接 (seam)
19
強 勵 振 Overdrive
Re low
21
老 化 Aging
23
Incoming Inspection
of Base
化學蝕刻
18
22
3
28
Sealing (seam)
29
30
31
印字排盤
溫度特性抽檢
Temperature characteristics
adjustment inspection
最 終 檢 查 ($)
Final Inspection
TAPPING外 觀 檢 查
Appearance inspection after Taping
出 貨 檢 查 ($)
Outgoing Inspection
出貨捆包
Packing
Mark Loading
印 字 +外 觀 檢 查
出 貨 Shipment
Laser Marking and
Appearance Inspection
($): 特 殊 特 性
(For Critical prcoess had been monitored)
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
TYPE
H(D)SX321S
PERCENTAGE
20.5(mg)
ppm
Si
0.04715
9.6658
Au
0.15785
32.3593
Co & Co Compound
1.21770
249.6285
Mo & Mo Compound
0.04100
8.4050
Ag
0.42640
87.4120
Cu
0.11890
24.3745
Cr & Cr Compound
0.04100
8.4050
Al
5.09630
1044.7415
Mn & Mn Compound
0.02460
5.0430
W & W Compound
0.19885
40.7643
Ni & Ni Compound
3.06680
628.6940
Fe
4.14715
850.1658
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
REV.
No.
DATE
REASON
New
CONTENTS
Country of origin
Tittle HSX321S
Date
Confirm
Check
Prepare
Y. W. LEE
U. F. CHEN
HARMONY
Spec. No.
TAIWAN FACTORY
THAILAND FACTORY
CHINA FACTORY
Rev.
Page
X3S032000BC1HZ-NU
ELECTRONICS
CORP.
