RoHS
Compliant
SPECIFICATION FOR APPROVAL
File No.: Q/FRK 0.GS.E.C43-C15
Product Name
Metallized Polypropylene Film Interference Suppression Capacitor
(Class Y2,300Vac)
Product Type
MKP63
Product Code
C43
Customer
Customer Code
Issue Date
Approved by Customer
Xiamen Faratronic Co. Ltd.
Drafted
Checked
Approved
厦门法拉电子股份有限公司
地址: 中国厦门市海沧区新园路 99 号
Add: No.99 Xinyuan Road, Haicang District, Xiamen, China
TEL:
FAX:
Mail:
Http:
Export business
0086-592-6208609 6208608
0086-592-6208557
Vivian@faratronic.com.cn
Donny@faratronic.com.cn
james@faratronic.com.cn
www.faratronic.com.cn
HK office : Faratronic (HK) Co. Ltd.
0852-2898 9168
0852-2898 9683
hkoffice@faratronic.com.hk
kolin@faratronic.com.hk
www.faratronic.com
*.The specification are the property of Xiamen Faratronic Co.Ltd and shall not be copied or used as commercial
purposes without permission.
Page 1 of 10
MKP63
Version history
Current version
Date
Author
Change description
Page 2 of 10
MKP63
Metallized polypropylene film interference suppression capacitor(Class Y2, 300Vac)
■Outline Drawing
W±0.4, H±0.4, T±0.4
W±0.4, H±0.4, T±0.4
Arc-bottom
Square-bottom
■ Features
● Withstanding overvoltage stressing
● Excellent active and passive flame resistant abilities
● Widely used in across-the-line, line-by-pass, antenna Coupling interference suppression circuit, etc.
■ Safety Approvals
CQC
ENEC-SEMKO
UL/CUL
KC
IEC 60384-14:2005, Y2, 300Vac, 0.001F~1.0F , 40/110/56/B
Certificate No.: CQC04001009958
EN 60384-14:2013, Y2, 300Vac, 0.001F~1.0F, 40/110/56/B
Certificate No.: SE/0366-2C
UL60384-14:2014, CSA E60384-14:09, Y2, 300Vac, 0.001F1.0F, 40/110/56/B
File No.: E186600, CN: FOWX2/8
K60384-14(2006-12) , Y2, 300Vac, 0.001F~0.10F, 40/110/56/B
Certificate No.: SU03060-12005
■ Specifications
Class
Climatic Category /
Passive Flammability Category
Operating Temperature Range
Class Y2
Rated Voltage (UR)
300Vac, 50/60Hz
Maximum continuous DC voltage
Capacitance Range
1 500Vdc
Capacitance Tolerance
10(K), 20(M)
Voltage Proof
Insulation Resistance
Dissipation Factor
40/110/56/B
-40℃ ~ +110℃
0.0010F~1.0F
Between Terminals:
2 000Vac(2s) or
4 000Vdc(2s) CN≤0.33F
3 700Vdc(2s) CN0.33F
Between Termianls To Case: 2 500Vac(1min)
R≥15 000M , CN≤0.33F
(20℃, 100V ,1min)
RCN≥5 000s,
CN0.33F
≤3010-4(1kHz,20℃)
≤4010-4(10kHz,20℃)
Page 3 of 10
MKP63
■ Part number system
The 18 digits part number is formed as follow:
1
2
3
C
4
3
4
5
Digit 1 to 3
6
7
8
9
10 11 1 2 1 3 14 1 5 1 6 1 7 1 8
Series code
C43=MKP63
Digit 4 to 5
A.C. rated voltage
Q1=300V
Digit 6 to 8
Rated capacitance value
For example : 103=10×103 pF= 0.01μF
Digit 9
Capacitance tolerance
K=±10%, M=±20%
Digit 10
Pitch
3=7.5mm
4=10mm
6=15mm
9=22.5mm B=27.5mm F=37.5mm
Digit 11
Internal use
Digit 12 to 15 Lead form and packaging code
Digit 16 to 18 Internal use
Table 1
Digit 12
code
A
explanation
ammo-pack
C
straight lead
“C” in the
figure above
D
Insulated
stranded leads
E
M
Insulated
solid leads
Digit 13
code
3
4
6
mounting foot
F=7.5mm
F=10.0mm
F=15.0mm
explanation
code
Straight
1
5
explanation
00
45
35
32
standard lead length (18mm~26mm)
lead length 4.5mm
lead length 3.5mm
lead length 3.2mm
35mm
100mm
120mm
200mm
Digit 15
code
code
C5
K0
K2
Insulated leads L0
and box with
explanation
Digit 14
explanation
each cap. among two consecutive holes
P3=12.7mm,H=18.5mm (For P=7.5mm)
P3=25.4mm;H=18.5mm (For pitch=10/15mm)
(Detail parameter refer to page 11)
Length tolerance ±0.5mm or standard length
Length tolerance ±0.3mm
Note 1:This length
includes the stripping
parts.
1
Length tolerance -5 mm~0 mm
2
Length tolerance 0 mm~+5 mm
Note 2:Normally, for
P ≥ 27.5 Caps can
choice
Insulated
leads.
3
Length tolerance 0 mm~+10mm
4
Length tolerance ±5 mm
Page 4 of 10
MKP63
■ Dimensions(mm)
300Vac
300Vac
CN
W
H
T
P
d
Part number
(F)
±0.4 ±0.4 ±0.4 ±0.4
0.0010
10.5
9.0
4.0
7.5
0.6
C43Q1102-30****+++
0.0012
10.5
9.0
4.0
7.5
0.6
C43Q1122-30****+++
0.0015
10.5
9.0
4.0
7.5
0.6
C43Q1152-30****+++
0.0018
10.5
9.0
4.0
7.5
0.6
C43Q1182-30****+++
0.0022
10.5
9.0
4.0
7.5
0.6
C43Q1222-30****+++
0.0027
10.5
9.0
4.0
7.5
0.6
C43Q1272-30****+++
0.0033
10.5 11.0
5.0
7.5
0.6
C43Q1332-30****+++
0.0039
10.5 11.0
5.0
7.5
0.6
C43Q1392-30****+++
0.0047
10.5 12.0
6.0
7.5
0.6
C43Q1472-30****+++
0.0056
10.5 12.0
6.0
7.5
0.6
C43Q1562-30****+++
0.0010
13.0
9.0
4.0
10.0 0.6
C43Q1102-40****+++
0.0012
13.0
9.0
4.0
10.0 0.6
C43Q1122-40****+++
0.0015
13.0
9.0
4.0
10.0 0.6
C43Q1152-40****+++
0.0018
13.0
9.0
4.0
10.0 0.6
C43Q1182-40****+++
0.0022
13.0
9.0
4.0
10.0 0.6
C43Q1222-40****+++
0.0027
13.0
9.0
4.0
10.0 0.6
C43Q1272-40****+++
0.0033
13.0
9.0
4.0
10.0 0.6
C43Q1332-40****+++
0.0039
13.0
9.0
4.0
10.0 0.6
C43Q1392-40****+++
0.0047
13.0 11.0
5.0
10.0 0.6
C43Q1472-40****+++
0.0056
13.0 11.0
5.0
10.0 0.6
C43Q1562-41****+++
0.0068
13.0 11.0
5.0
10.0 0.6
C43Q1682-41****+++
0.0068
13.0
7.5
9.5
10.0 0.6
C43Q1682-4C****+++
0.0082
13.0 12.0
6.0
10.0 0.6
C43Q1822-40****+++
0.010
13.0 12.0
6.0
10.0 0.6
C43Q1103-40****+++
0.015
13.0 12.0
6.0
10.0 0.6
C43Q1153-4S****+++
0.0022
17.5
9.5
5.0
15.0 0.6
C43Q1222-60****+++
0.0027
17.5
9.5
5.0
15.0 0.6
C43Q1272-61****+++
0.0033
17.5
9.5
5.0
15.0 0.6
C43Q1332-61****+++
0.0039
17.5
9.5
5.0
15.0 0.6
C43Q1392-61****+++
0.0047
17.5
9.5
5.0
15.0 0.6
C43Q1472-61****+++
0.0056
17.5
9.5
5.0
15.0 0.6
C43Q1562-61****+++
0.0068
17.5
9.5
5.0
15.0 0.6
C43Q1682-61****+++
0.0082
17.5
9.5
5.0
15.0 0.6
C43Q1822-61****+++
0.010
17.5
9.5
5.0
15.0 0.6
C43Q1103-6S****+++
0.012
17.5 11.0
5.0
15.0 0.6
C43Q1123-6S****+++
0.015
17.5 11.0
5.0
15.0 0.6
C43Q1153-6S****+++
0.018M 17.5 11.0
5.0
15.0 0.6
C43Q1183M6S****+++
0.018K 17.5 12.0
6.0
15.0 0.6
C43Q1183K6S****+++
0.022
17.5 12.0
6.0
15.0 0.6
C43Q1223-6S****+++
0.027M 17.5 12.0
6.0
15.0 0.6
C43Q1273M6S****+++
0.027K 17.5 12.0
7.0
15.0 0.6
C43Q1273K6S****+++
0.033
17.5 13.5
7.5
15.0 0.6
C43Q1333-6S****+++
0.033
17.5 12.5
9.0
15.0 0.6
C43Q1333-6A****+++
0.039
17.5 13.5
7.5
15.0 0.6
C43Q1393-6S****+++
0.039
17.5 12.5
9.0
15.0 0.6
C43Q1393-6A****+++
0.047
17.5 14.5
8.5
15.0 0.6
C43Q1473-6S****+++
0.047
17.5 12.0 13.0 15.0 0.8
C43Q1473-6C****+++
0.056
17.5 16.0 10.0 15.0 0.8
C43Q1563-6S****+++
0.068
C43Q1683-6S****+++
0.082
17.5 19.0 11.0 15.0 0.8
C43Q1823-6S****+++
0.033
26.5 15.0
6.0
22.5 0.8
C43Q1333-90****+++
0.039
26.5 15.0
6.0
22.5 0.8
C43Q1393-90****+++
0.047
26.5 15.0
6.0
22.5 0.8
C43Q1473-9S****+++
0.056
26.5 15.0
6.0
22.5 0.8
C43Q1563-9S****+++
0.068M 26.5 15.0
6.0
22.5 0.8
C43Q1683M9S****+++
0.068K 26.5 16.0
7.0
22.5 0.8
C43Q1683K9S****+++
0.082
26.5 16.0
7.0
22.5 0.8
C43Q1823-9S****+++
Note: 1. “-”=capacitance tolerance code, M=±20%,K=±10%
2. “****”=lead form and packaging mode code (refer to table 1)
3. “★” = Arc bottom of the outer shell.
CN
(F)
0.10
0.12
0.15
0.18
0.22
0.27
0.33
0.33
0.39M
0.10
0.12
0.15
0.15
0.18
0.22
0.22M
★0.22K
0.27M
0.27K
0.33M
0.33K
0.33K
★0.33M
0.39
0.39
0.47M
0.47M
0.47K
0.47K
★0.47
0.56
0.56
0.68M
0.68K
0.68
★0.68
★0.82M
0.82M
0.82K
1.0
0.33
0.39M
0.39K
0.47
0.47
0.56
0.56
0.68M
0.68M
0.68K
0.68M
0.82
0.82
1.0M
1.0K
Page 5 of 10
W
±0.4
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
41.0
41.0
41.0
41.0
42.0
41.0
42.0
41.0
42.0
41.0
42.0
41.0
42.0
41.0
41.0
H
±0.4
17.0
17.0
18.5
20.0
22.0
23.0
24.5
29.5
29.5
18.0
18.0
18.0
12.0
20.0
20.0
12.0
12.0
20.0
22.0
22.0
25.0
24.5
12.0
24.5
28.0
24.5
28.0
30.0
28.0
16.0
30.0
28.0
29.0
30.0
33.0
18.5
18.5
33.0
37.0
37.0
22.0
22.0
24.0
24.0
15.0
26.0
28.0
26.0
28.0
30.0
15.0
30.0
19.0
32.0
33.5
T
±0.4
8.5
8.5
10.0
11.0
12.0
13.5
15.5
14.5
14.5
9.0
9.0
9.0
18.0
11.0
11.0
18.0
22.0
11.0
13.0
13.0
13.0
15.0
22.0
15.0
14.0
15.0
14.0
16.0
17.0
27.5
16.0
17.0
19.0
21.0
18.0
31.0
31.0
18.0
22.0
22.0
11.0
11.0
13.0
13.0
24.0
15.0
14.0
15.0
14.0
16.0
24.0
16.0
24.0
17.0
18.5
P
±0.4
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
d
Part number
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
C43Q1104-9S****+++
C43Q1124-9S****+++
C43Q1154-9S****+++
C43Q1184-9S****+++
C43Q1224-9S****+++
C43Q1274-9S****+++
C43Q1334-9S****+++
C43Q1334-9A****+++
C43Q1394M9S****+++
C43Q1104-B0****+++
C43Q1124-B0****+++
C43Q1154-BS****+++
C43Q1154-BC****+++
C43Q1184-BS****+++
C43Q1224-BS****+++
C43Q1224MBC****+++
C43Q1224KBC****+++
C43Q1274MBS****+++
C43Q1274KBS****+++
C43Q1334MBS****+++
C43Q1334KBS****+++
C43Q1334KBA****+++
C43Q1334MBC****+++
C43Q1394-BA****+++
C43Q1394-BS****+++
C43Q1474MBA****+++
C43Q1474MBS****+++
C43Q1474KBS****+++
C43Q1474KBA****+++
C43Q1474-BC****+++
C43Q1564-BS****+++
C43Q1564-BA****+++
C43Q1684MBA****+++
C43Q1684KBA****+++
C43Q1684-BS****+++
C43Q1684-BC****+++
C43Q1824MBC****+++
C43Q1824MBS****+++
C43Q1824KBS****+++
C43Q1105-BS****+++
C43Q1334-FS****+++
C43Q1394MFS****+++
C43Q1394KFS****+++
C43Q1474-FS****+++
C43Q1474-FC****+++
C43Q1564-FS****+++
C43Q1564-FA****+++
C43Q1684MFA****+++
C43Q1684MFS****+++
C43Q1684KFS****+++
C43Q1684MFC****+++
C43Q1824-FS****+++
C43Q1824-FC****+++
C43Q1105MFS****+++
C43Q1105KFS****+++
MKP63
■ Maximum permissible voltage change per unit of time
Rated
Voltage
(Vac)
P=7.5mm
P=10mm
P=15mm
P=22.5mm
P=27.5mm
P=37.5mm
300
800
800
600
500
400
300
Max dV/dt(V/us) at 425Vdc
Note:
1. Rated voltage pulse slope (dV/dt)R at rated voltage.
2. If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In
this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U.
■ Impedance Vs. Frequency
TYPICAL GRAPHS
Z=f(f) Typical values
■ Quality ensuring test (before shipment):
Inspection item(each batch)
Inspection level (GB/T 2828.1,ISO2859-1)
IL
AQL
II
1.5
II
0.25
S-3
2.5
Appearance inspection
Dimensions
Capacitance
Tangent of the loss angle
Dielectric strength
Insulation resistance
Solderability
Page 6 of 10
MKP63
■ Test Method And Performance
No.
Item
1
4.5 Solderability
2
4.3
Terminal strength
3
4.4
Resistance to solder heat
4
4.20
Solvent resistance
of the marking
4.2 Initial measurement
Good quality of tinning
Solder temperature: 245˚C 5˚C
Immersion time: 2.0s0.5s
There shall be no visible damage
Tense: 0.50d≤0.80, 10N
0.80d≤1.25, 20N
Bend: 0.50d≤0.80, 5N
0.80d≤1.25, 10N
The terminals shall be bent 2 times in
each direction
C/C 5(relative to the initial value)
Solder temperature:260˚C5˚C
Immersion time: 10s1s
The marking shall be legible
Solvent: Industrial isopropanol.
Solvent temperature:23˚C±5˚C
Dipping time: 5min0.5min
Condition: scrub
Scrub material: absorbent cotton
Reverting time: No
Capacitance, Tg
5 cycles
There shall be no evidence of
deterioration.
TA=-40˚C, TB =+110˚C
Duration: t=30min
4.7 Vibration
deterioration.
Amplitude 0.75mm or acceleration
100m/s2 (whichever is the smaller
severity), f: 10Hz to 500Hz.Three
directions, 2h foreach direction,
total 6h.
4.8 Bump
deterioration.
4 000 times,
Acceleration: 400m/s2,
Pulse duration, 6ms
4.6 Rapid change
of temperature
5
Test Method
(IEC 60384-14)
Performance
Final measurement
Initial
measurement
+110℃, 16h
Dry heat
Damp
heat, Cyclic
Test Db, Severity: b, the first cycle
-40℃, 2h
Cold
6
4.11
Climate
sequence
Damp heat,
cyclic other
Final
measurement
Test Db, Severity b, the other cycles,
There shall be no visible damage, legible
marking
Increase of tg: 0.008 (10kHz)
Dielectric strength : there shall be no
permanent breakdown or flashover
I.R.: 50 of the rated value
Page 7 of 10
MKP63
No.
7
8
9
Test Method
(IEC 60384-14)
Item
Performance
4.12
Damp heat
steady state
legible marking
Temperature:40˚C 2˚C
Humidity: 933RH
Duration: 56 days
4.13
Impulse voltage
There are three or more waveforms
which indicate that no self-heating
breakdown have occurred when it is
monitored by the monitor
Each individual capacitor shall be
subjected to 24 impulses of the same
polarity (when any three successive
impulses are shown by the monitor to
have a wave form indicating that no
self-healing breakdown have taken
place the impulses can be stopped), the
time between impulses shall not be less
than 10s, and the peak value of the
voltage impulse: 5.0kV
4.14 Endurance
marking
C/C10(relative to the initial value)
Dielectric strength : There shall be no
I.R. : 50 of the rated value
+110˚C,
1.7URVa.c.
1 000h
The voltage shall be subjected to
1 000Vrms for 0.1s every one hour
during test.
Times: 10 000
Duration of charging: 0.5s
Duration of discharging: 0.5s
10
11
4.15
Charging and
discharging
4.17
Passive
flammability
C/C 10(relative to the initial
value)
Increase of tg:
CN1F: 0.008 (10kHz)
The flaming time of each capacitor shall
not go beyond 10s after it is taken apart
from the flame.
Drop of each capacitor caused by flame
shall not fire the tissue below.
Page 8 of 10
Charging voltage: 2 UR Vd.c.
Charging resistance: 220/CN() or the
current ≤1.0A (whichever
is the
minor)
Discharging resistance:
2UR
R
dU
CN
dt
CN: Capacitance (F)
dU/dt(V/us) : 100V/s
Needle flame test
The category of flammability: B
Expose time: 1 time
Capacitor Volume Exposing time
250
