PRODUCT SPECIFICATION
SPEC. NO: T-0653-010M
新弘智
DATE: Aug.7,2018
CUSTOMER'S PRODUCT NAME:
EMTEK PRODUCT NAME:
PHC0412-Series
THIS SPECIFICATION IS:
□ FULLY ACCEPTED
□ DENIED
□ ACCEPTED UNDER THE FOLLOWING CONDITIONS
SIGNATURE:
NAME(PRINT):
TITLE:
本文件內容全部或部份,未經兆欣科技股份有限公
司同意不得以任何形式複製或其他用途
All rights reserved.This document or parts thereof,may
not be reproduced by any means or used in any manner
witout written permission of EMTEK CO.,LTD.
DATE:
FACTORY:
39,Chingao Rd.,(305)Hsinpu,
Hsinchu Hsien,Taiwan,R.O.C
TEL: 03-5894-433
FAX: 03-5894-523
1/8
SPEC. No.
T-0653-010M
1. Scope
This specification applies High Current Power Inductors PHC0412-Series to be delivered to user.
2. Product Identification
PHC 0412 - 1R5 □ - T
(1) (2) (3) (4) (5)
(1) Product name
(2) Shapes and dimensions
(3) Inductance
1R5: 1.5μH
(4) Tolerance(%)
M: ±20%
(5) Taping Type
T: Taping, None:Bulk
3. Shapes and Dimensions
A:
B:
C:
D:
E:
Drawn by
4.45±0.25 mm
4.06±0.25 mm
1.2 Max. mm
2.0±0.3 mm
0.76±0.3 mm
Checked by
Approved by
2/8
SPEC. No.
T-0653-010M
4. Schematics and Land Patterns
A
B
C
4.95 mm
2.35 mm
1.65 mm
Saturation
Current DC
Amps. Isat(A)
Typ.
5. Electrical Characterisitics
5-1 Electrical Spec.
Customer
Part Number
EMTEK
Part No.
Inductance
uH
Tol.
(100KHz/0.5V)
Typ.
Max.
Heat Rating
Current DC
Amps.Idc(A)
Typ.
Rdc (mΩ)
PHC0412-R10□-T
0.10
M
9.0
11.0
10.0
15.0
PHC0412-R22□-T
0.22
M
15.0
18.0
7.0
10.0
PHC0412-R24□-T
0.24
M
11.0
15.0
7.50
11.5
PHC0412-R33□-T
0.33
M
17.0
19.0
6.50
8.4
PHC0412-R36□-T
0.36
M
18.0
20.0
6.40
7.8
PHC0412-R47□-T
0.47
M
19.0
21.0
6.00
6.8
PHC0412-R68□-T
0.68
M
32.0
36.0
4.50
6.0
PHC0412-1R0□-T
1.0
M
43.0
47.0
4.20
5.2
PHC0412-1R2□-T
1.2
M
43.0
55.0
4.00
5.1
PHC0412-1R5□-T
1.5
M
68.0
75.0
3.25
4.0
PHC0412-2R2□-T
2.2
M
79.4
83.5
2.75
3.5
Inductance Tolerance:M=±20% , N=±30%
1.All test data is referenced to 25℃ ambient.
2. Idc : DC current (A) that will cause an approximate △T of 40℃
3. Isat : DC current (A) that will cause Lo to drop approximately 30%
4.Operating Temperature Range -40℃ to + 125℃
5. The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case
operating conditions. Circuit design , component placement, PWB trace size and thickness,
airflow and other cooling provision all affect the part temperature. Part temperature should be
verified in the end application.
6.The rated current as listed is either the saturation current or the heating current depending on
which value is lower.
7. TEST FREQUENCY:100KHz,0.5V
TESTING INSTRUMENT L:Agilent/HP4284A Precision LCR Meter.
Rdc:Chroma Millohmmeter16502 or equivalent.
3/8
SPEC. No.
5-2 Typical Electrical Curve:Inductance VS Isat , Irms VS TEMP.
PHC0412-R24M-T
100
0.30
0.25
0.20
L(uH)
60
0.15
40
0.10
L(uH)
0.05
ΔT(℃)
0.00
2
3
4
5
6
7
8
9
10
11
12
13
14
DC CURRENT(A)
PHC0412-R36M-T
0.40
100
L(uH)
60
0.20
40
0.10
L(uH)
ΔT(℃)
2
3
4
5
6
7
8
9
DC CURRENT(A)
10
11
12
13
14
TEMPERATURE(℃)
80
0.30
TEMPERATURE(℃)
80
T-0653-010M
4/8
SPEC. No.
T-0653-010M
5/8
SPEC. NO.
T-0653-010M
6. Reliability Test
Item
Solderability
Specifications
The metalized area must have 90%
minimum solder coverage.
Test conditions
Dip pads in flux and dip in solder pot( 96.5 Sn/3.5
Ag solder) at 255°C ±5°C.
Resistance to There must be no case deformation or Inductors shall be reflowed onto a PC board using
soldering heat change in dimensions.
96.5 Sn/3.5 Ag solder paste.
Inductance must not change more
Solder process shall be at a maximum temperature
than the stated tolerance.
of 260°C.
For 96.5 Sn/3.5 Ag solder paste:>217°C for 90
seconds
High
temperature
There must be no case deformation or Inductors shall be subjected to temperature 125±2℃
for 100 hours.
resistance
Measure the test items after leaving the inductors at
room temperature and humidity for 2 hours.
Static
Humidity
Inductors must not have a shorted or Inductors shall be subjected to temperature 85±2℃
openwinding.
and 90 to 95%RH. for 100 hours.
at room temperature and humidity for 2 hours.
Low
temperature
resistance
-40±2℃ for 100 hours.
at room temperature and humidity for 1 to 2
hours.
Temperaure
cycle
Change from an initial value
Inductance: within ±10%
The specimen shalll be subjected to 10 continuous
cycles of temperature change of -40℃ for 30 min
and 125℃ for 30 min with the transit period of 3 min
or less.
Then it shall be stabilized under standard
atmospheric conditions for 1 hr before measurement.
Measurement shall be made within 2 hr.
6/8
SPEC. NO.
T-0653-010M
7. Packaging
The packaging must be done not to receive any damage during transporting and storing.
7-1 Tape dimensions
Ko
P1
P0
P
Bo
W
Ao
t
( Dimensions in mm; Tolerance:±0.1)
Symbol
W
P
P0
P1
Ao
Bo
Ko
t
Dimension
12
8
4
2
4.55
4.75
1.5
0.25±0.05
7-2 Reel dimensions
D
Symbol
C B
A
( Dimensions in mm )
T
A
B
180
C
13
D
16
E
13.2
E
7-3 Tapping figure
Top cover tape
Carrier tape
Sprocket hole
Cavity (chip insert)
60
7/8
SPEC. NO.
T-0653-010M
7-4 Packaging Form
There shall not continuation more than two vacancies of the product.
(360 mm)
Leader.
Blank
(25 pitches)
Chip
Blank
(25 pitches)
7-5 Cover Tape Peel Strength
The force for tearing off cover tape is 0.1~0.6(N) in the arrow direction at the following
conditions:
Temperature : 5 ~ 35℃
Humidity : 45 ~ 85%
Atmospheric pressure : 860 ~ 1060 hpa
160 ~ 180。
Top cover tape
Base tape
7-6 Packing Quantity
φ180 mm reel type : 1,000 pcs./reel
8/8
SPEC. NO.
T-0653-010M
8. Recommended Reflow Pattern
8-1 Recommended Reflow Pattern
Reflow : until two times
10sec. Min.
255℃
217℃
Natural cooling
150sec. Max.
150℃
60sec. Min.
8-2 Iron Soldering
Use a solder iron of less than 30W when soldering ,do not allow the soldering iron tip
directly touch the Ceramic body outside of terminal electrode.
5 seconds max. at 260℃.
9. Attention in Case of Using
In case of using product ,please avoid following matters:
Splashing water or salt water
Dew condenses
Toxic gas (Hydrogen sulfide, Sulfurous acid ,Chlorine, Ammonia)
Vibrations or shocks which exceed the specified condition
Please be careful for the stress to this product by board flexure or something after the mounting.
10. Others
10-1 Operating temperature range
: Ferrite Series :-40~+125℃
10-2 Storage condition
: Temperature 20°~25℃﹐Relative Humidity 40%~60%
10-3 Recommended wire wound inductors should be used within 6 months from the time of delivery.
很抱歉,暂时无法提供与“PHC0412-R22M-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.81000
- 10+0.43848
- 30+0.19764
- 100+0.17064
- 500+0.15876
- 1000+0.15228
