PROGRAMMABLE
CRYSTAL OSCILLATOR
YSO680PR
Low Power
Applications
Features
‧Any frequency
‧One time programmable
‧Low power consumption design
‧PLL circuit provides wide frequency
‧Package Size: 2.5*2.0 3.2*2.5 5.0*3.2 7.0*5.0mm.
range application (1-108MHz)
Specifications
Parameter
Frequency Range
Supply Voltage Variation (Vdd)10%
1.8V
2.5V
3.3V
1MHz to108MHz
1MHz to 108MHz
1MHz to 108MHz
1.62V~1.98V
2.25V~2.75V
2.97V~3.63V
Standby Current
15uA
Frequency Tolerance
±20ppm,±25ppm,±50ppm,or specify
Output Load
15pF
Operating Temperature Range
-40~+85℃,or specify
Storage Temperature Range
-55~+125℃
Voltage Vol ( Max. ) / Vol ( Min. )
VOH = 90%Vdd/VOL = 10%Vdd
Duty Cycle
45~55%
Period Jitter (@12K-20Mhz)
1.8V=1.5ps 2.5V=1.1ps 3.3V=1ps
Start-up Time
10ms Max.
Supply Current
See Below
Frequency Aging (at 25℃)
±3 ppm / year Max.
Pin Dimension
Pin
Symbol
Output Enable
1
OE/ST/NC
Pin Assignments
Functionality
Standby
No Connect
H:specified frequency output
L:output is low. Specified frequency output stop.
L:output is low. Device goes to sleep mode. Supply current
reduces to 400uA(Standby Current).
Pin 1 = VDD or Pin 1 is Open : Specified frequency output.Pin 1
has no function
2
GNG
Power
Electrical ground
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage
Current Consumption
Supply
Voltage
Power Dissipation
1.000~30.000MHZ
31.000~75.000MHZ
76.000~108.000MHZ
1.8V
6mA max
8mA max
12mA max
2.5V
8mA max
10mA max
15mA max
3.3V
10mA max
15mA max
20mA max
www.yxc.hk
第1页共3页
PROGRAMMABLE
CRYSTAL OSCILLATOR
YSO680PR
Low Power
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
2.5*2.0mm
Recommended Land Pattern (Unit: mm)
0.9 0.95 0.9
#4
#3
0.95
0.8±0.1
0.8 0.65 0.8
0.65
MARKING
#2
2.0±0.1
#1
0.68
2.5±0.1
0.78
0.4
3.2*2.5mm
3.2±0.15
1.3 1.0
1.3
#2
1.1 0.8 1.1
1.0
MARKING
2.5±0.1
0.65
#1
#4
#3
0.9
0.9±0.1
1.2
5.0*3.2mm
1.4
2.54±0.1
5.0±0.2
#1
2.2
1.0
MARKING
3.2±0.1
1.2
#2
#4
#3
1.2±0.1
1.2
2.54
7.0*5.0mm
7.00±0.15
5.08±0.15
2.0
#3
1.4±0.1
#4
2.2
2.6±0.1
MAR KING
#2
5.0±0.1
#1
1.4±0.15
0.6±0.15
3.28
1.8
Notes:
A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required.
www.yxc.hk
第2页共3页
PROGRAMMABLE
CRYSTAL OSCILLATOR
YSO680PR
Low Power
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability Terminal.
In case of Resistance to soldering heat Surface.
Tp2
Tp1
35s
100s
t(time)
Test Circuit
Taping Specification(Unit: mm)
Size(OSC)
A
B
C
D
E
F
G
H
SMD-7050
180±2.0
16.0±0.3
7.50±0.1
5.50±0.1
8.0±0.1
2.00±0.1
61.0±1.0
16.0±1.0
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.0±0.1
1.70±0.1
61.0±1.0
12.0±1.0
SMD-3225
180±2.0
8.0±0.3
3.40±0.1
2.70±0.1
4.0±0.1
1.50±0.1
61.0±1.0
8.0±1.0
SMD-2520
180±2.0
8.0±0.3
2.90±0.1
2.40±0.1
4.0±0.1
1.20±0.1
61.0±1.0
8.0±1.0
www.yxc.hk
第3页共3页
很抱歉,暂时无法提供与“OP252030MEDA4SI-u”相匹配的价格&库存,您可以联系我们找货
