M8-32.768KHZ-12.5PF-20PPM 数据手册
HuBei TKD Electronic Technology Co.,LTD
湖北泰晶电子科技股份有限公司
Page 1 of 9
CRYSTAL SPECIFICATION
Customer
天河星
Part Name
Tuning Fork Quartz Crystal
Product Description
M8-32.768-12.5-20
Issue Date
Customer P/N
2016.12.9
CUSTOMER’S APPROVAL
(PLEASE
RETURN A COPY WITH APPOVAL
Hubei TKD Electronic Technology Co.,LTD
湖北泰晶电子科技股份有限公司
DESIGNER
APPROVED
代 伟
罗 兵
SALE Department :TEL :0722-3309660
FAX :0722-3309768
QCD Department :TEL :0722-3308231
FAX :0722-3309768
FAE Department :TEL :0755-27328651
FAX :0755-27328001
湖北泰晶电子科技股份有限公司
Page 2 of 9
REV.
Description of Revision History
Date
Designer
Checked By
A
New revision
2016 年 12 月 9 日
Dai Wei
LUO BIN
湖北泰晶电子科技股份有限公司
Page 3 of 9
1.
2.
3.
4.
5.
6.
Description:
Nominal Frequency:
32.768KHz
Oscillation Mode:
Fundamental
Cutting Mode:
X-2° cut
Measurement Instrument: S&A 250B(Calculated FL)
Electrical Characteristics:
[1]Operation Conditions:
Item
Symbol
MIN.
Operating Temperature Range
Topt
Storage Temperature Range
Tstg
TYP.
MAX.
Unit
-40
85
-55
125
Load Capacitance
CL
12.5
pF
Drive Level
DL
0.1
uW
Condition
[2]Frequency Stability:
Item
Symbol
MIN.
Tolerance
dF/Fo
-20
Stability Over Temperature
dF/F25
Aging
dF/F25
TYP.
MAX.
Unit
Condition
ppm
Refer to Center Frequency@25±3℃
ppm/℃2
-0.036
-5
5
ppm
Refer to Operating Temperature
Per Year
dF/Fo:Frequency Deviation Refer to Center Frequency
dF/F25:Frequency Deviation Refer to 25℃ Frequency
[3]Electrical Performance:
Item
MAX.
Unit
ESR
50
KΩ
Shunt Capacitance
C0
5
pF
Insulation Resistance
IR
Equivalent Series Resistance
Symbol
MIN.
TYP.
500
MΩ
Condition
@Series
@DC 100 Volt
7.
Marking:Laser
Marking Generally:32.768. Refer to with Customer’s requirement.
32.768
湖北泰晶电子科技股份有限公司
Page 4 of 9
8.
Outline drawing (unit:mm)
Recommended soldering pattern
湖北泰晶电子科技股份有限公司
Page 5 of 9
9. Reliability Specification
Test Items
Test Method and Condition
Vibration
(1)Vibration Frequency
10 to 55Hz
(2)Vibration Amplitude
1.5mm
(3)
Cycle Time
1-2min(10-55-10Hz)
(4)Direction
(5)Duration
Shock
Hermetic seal
Solder ability
High temperature
X.Y.Z
3 Times free drop from 75cm height to hard wooden
board of thickness more than 30mm
Helium leak detector
Checked:before the molded crystal uints
Temperature cycle
Resistance Change:±15% or 5kohm Max.
Frequency Change:±10ppm Max.
less than 1 × 10 EXP(–7) mbar.l/sec.
Dip the leads of crystal units into the solution (7-10%) of
The dipped surface of the leads should be at
rosin 3±0.5s,then dip it into the tank 5-10s.
least 95% covered with continuous new solder
Temperature of solder melted tank is
coating
245℃±5℃
240 hours at +85℃±2℃
After 1-2hours past at room temperature from following
test.
Humidity
2h/each direction
240 hours at -40℃±2℃
Low temperature
Requirements
240 hours at +40℃±2℃,relative humidity 90-95%
Resistance Change:±25% or 10kohm Max.
After supplying the following temperature cycle
(50cycles)
湖北泰晶电子科技股份有限公司
Page 6 of 9
After 24h past from frequency test,
F
Reflow soldering
Notice:
1、Using the infrared lamp at soldering
process may cause uneven temperature
rise on plastic surface of the parts,so
that
please keep the package temperature
within left conditions.
2、DO NOT dip the plastic part into
solder
湖北泰晶电子科技股份有限公司
Page 7 of 9
10. Handling Notice for Standard Tuning Fork Crystal (Cylindrical Type)
10.1. Shock resistance
It may deteriorate the characteristics or cause of no oscillation if excess physical shock given. Please be
careful not to drop. Please use under condition to minimize the shocks as much as possible.
Please review the conditions if it is used by auto mounting or after the conditions are changed.
10.2. Heat and humidity resistance in storage
Storing the crystal products under higher or lower temperature or high humidity for a long period may
deteriorate the characteristics of crystal units. Please store and use the crystal products at the normal
temperature and humidity.
10.3 Solder heat resistance
Please review the condition or consult us about flow solder process.
Our soldering condition is under 260ºC within 10sec .
10.4. Mounting metho
When the crystal products need to be lay down please fix to PCB securely.
If the crystal is used with mechanical vibration location, please put cushion in between PCB or fix with
湖北泰晶电子科技股份有限公司
Page 8 of 9
elasticity glue (Silicon etc) as shown in below figure. Please don’t gluing hermetic seal grass.
10.5.Ultrasonic cleaning and ultrasonic soldering
Soldered by ultrasonic cannot be guaranteed, because crystal may be sympathetic vibrated and may damage.
Please study at your side about ultrasonic cleaning.
10.6. Drive level
Applying excessive drive level to the crystal units may cause deterioration of characteristics or damage. Less
then 1.0μW is recommended to this products. More than 2.0μW cannot be guaranteed.
10.7.Solder paste should be more than 150μm thickness.
10.8.Storage environment
10.8.1 To storage the reel at +15℃ to +35℃,25%RH to 65%RH of Humidity.
10.8.2 To open the packing just before using.
10.8.3 Not to expose the sun.
10.8.4 Not to storage with some erosive chemicals.
10.8.5 Nothing is allowed to put on the reel or carton to prevent mechanical damage.
湖北泰晶电子科技股份有限公司
Page 9 of 9
11.PACKING
M8-32.768KHZ-12.5PF-20PPM 价格&库存
很抱歉,暂时无法提供与“M8-32.768KHZ-12.5PF-20PPM”相匹配的价格&库存,您可以联系我们找货
