环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列
Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series
■ 引用标准 Reference standards
GB10190(IEC384-16)
■ 结构 Structure
介质:聚丙烯膜
电极:金属真空蒸发层
封装:阻燃粉末环氧树脂,符合 UL94 V-0
Dielectric: Polypropylene film
Electrode: metal vacuum evaporation layer
Encapsulation: Flame retardant power epoxy resin, conforming to UL94 V-0
典型应用 Typical
Application
用于开关电源,电子镇流器和变频器等中间电路直流滤波(如 DC filter,DC-link,PFC 等)
As intermediate circuit capacitor for SMPS, LED driver, inverter (i.e. DC filter,DC-link, DC filter and P.F.C)
特点 Features
有良好自愈性能 ,缩小产品尺寸,高频损耗小,温升低
Reduced size depended on good self-healing property, low dissipation at high frequency, low temperature rise
符合 RoHS 及 REACH 环保标准 Compliance with RoHs &
电性能规范 Performance Specifications
REACH requirements.
气候类别 Climate category
40/105/56
额定温度 Rated Temperature
85℃
工作温度范围
-40℃--+105℃.
Operating Temperature range
(+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC)
(+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC)
额定电压 Rated Voltage
400(450)VDC, 630VDC
容量误差 Capacitance Tolerance
J: ±5%
容量范围
0.001μF~22μF
Capacitance Range
测试条件 Test Condition:
耐电压
Withstand Voltage
无击穿或飞弧
1.6UR,5S
No breakdown or electric arcing
损耗角 Dissipation factor
≤0.001
绝缘电阻或时间常数
CR≤0.33μF IR≥30000MΩ
Insulation Resistance
CR>0.33μF IR≥10000S
最大脉冲爬升速率
Max. Pulse Rise Time
(dV / dt)
20℃, 1KHz, 1Vrms
测试条件 Test Condition :
(1KHZ )
20℃
1Vrms
20℃
100V
1 min
UR(V)
P7.5
P10
P15
P20
P25
P31
400(450)V
120
80
65
35
630V
150
120
80
60
40
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change ( relative to the initial
value):△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0020(1KHZ),CR>1uF
耐久性试验
温度 Temp.: +85℃,
绝缘电阻 Insulation Resistance
Endurance Test
电压 Voltage:
IR:≥ 额定值的 50%
IR:≥ 50% of rated value
1.25 Times Rated Voltage
持续时间 Duration Time: 1000H
损耗角增加:≤0.0040
dissipation factor rise:≤0.0040
容量变化(相对初始值):△C/C≤±10%
Capacitance change
(relative to the initial value):△C/C≤±10%
产品编码说明 Part No. Description:
18 位产品编码如下:
The Part No. Is total 18 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
M
P
P
1
J
2
G
1
11
12
13
14
15
16
17
18
9
1
4
8
Digit 1-3
型号代码 Product series Code
MPP= CBB21 series
Digit 4-6
Digit 7
Digit 8-9
Digit 10-15
Digit 16
Digit 17-18
标称容量 Rated Capacitance Value
For example : 105 = 10×105pF = 1.0F
J=±5%
2G=400VDC 2W=450VDC 2J=630VDC
容量偏差 Capacitance Tolerance
额定电压 Rated Voltage Code
外形尺寸 Dimensions Code
线径代码 Line diameter code
6=0.6 8=0.8
成型或内部识别码 Forming Type or Internal Use
1=1.0
料号明细及尺寸 Part No. List and Dimensions
UR :250Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP104J2E1303075LC
CBB21
0.1
13
4.5
8
10
0.5
MPP104J2E1304095LC
CBB21
0.1
13
5
9.5
10
0.5
MPP104J2E1305085LC
CBB21
0.1
13
5
9
10
0.5
MPP104J2E1305105LC
CBB21
0.1
13
5.5
10.5
10
0.5
MPP104J2E1005105LC
CBB21
0.1
10
5.5
10.5
7.5
0.5
MPP105J2E1310186LC
CBB21
1.0
13
9.5
18
10
0.6
MPP105J2E1907138LC
CBB21
1.0
13
7.5
13.5
10
0.8
MPP105J2E1907148LC
CBB21
1.0
18
7.5
14.5
15
0.8
MPP105J2E1909168LC
CBB21
1.0
18
9
16
15
0.8
MPP105J2E1910178LC
CBB21
1.0
18
9.5
16
15
0.8
MPP105J2E2408158LC
CBB21
1.0
23
7.5
14
MPP105J2E2410178LC
CBB21
1.0
23
9.5
16.5
MPP124J2E1004095LC
CBB21
0.12
10
5
10
7.5
0.5
MPP124J2E1303075LC
CBB21
0.12
13
4.5
8.5
10
0.5
MPP125J2E1907158LC
CBB21
1.2
18
8
16
15
0.5
MPP153J2E1305105LC
CBB21
0.015
13
6.5
11
10
0.5
MPP154J2E1304085LC
CBB21
0.15
13
4.5
9.5
10
0.5
MPP154J2E1305105LC
CBB21
0.15
13
5.5
10.5
10
0.5
MPP154J2E1307126LC
CBB21
0.15
13
7
12
10
0.6
MPP155J2E1908168LC
CBB21
1.5
18
8.5
17
15
0.8
MPP155J2E2410168LC
CBB21
1.5
23
9.5
16
MPP184J2E1304095LC
CBB21
0.18
13
5
10
10
0.5
MPP184J2E1306116LC
CBB21
0.18
13
6
10.5
10
0.6
MPP185J2E1909178LC
CBB21
1.8
18
9.5
18
15
0.8
MPP205J2E3109168LC
CBB21
2.0
30
9
16.5
27.5
0.8
MPP224J2E1304095LC
CBB21
0.22
13
5.5
10.5
10
0.5
MPP224J2E1305105LC
CBB21
0.22
13
5
10
10
0.5
MPP224J2E1305125LC
CBB21
0.22
13
5.5
11.5
10
0.5
MPP224J2E1306116LC
CBB21
0.22
13
6
11
10
0.6
MPP224J2E1906116LC
CBB21
0.22
18
6.5
11.5
15
0.6
MPP224J2E1907138LC
CBB21
0.22
18
7
12.5
15
0.8
MPP225J2E2411208LC
CBB21
2.2
23
10.5
18.5
MPP255J2E2412208LC
CBB21
2.5
23
12
UR :250Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP274J2E1005125LC
CBB21
0.27
10
6.5
13
7.5
0.5
MPP275J2E3110188LC
CBB21
2.7
30
9.8
17.5
27.5
0.8
MPP333J2E1305105LC
CBB21
0.033
13
5
10
10
0.5
MPP334J2E1006135LC
CBB21
0.33
10
7
14
7.5
0.5
MPP334J2E1305125LC
CBB21
0.33
13
6
12.5
10
0.5
MPP334J2E1308136LC
CBB21
0.33
13
7
12
10
0.6
MPP334J2E1904096LC
CBB21
0.33
18
5
10
15
0.6
MPP334J2E1906116LC
CBB21
0.33
18
5.5
11
15
0.6
MPP335J2E1912228LC
CBB21
3.3
18
13
23
15
0.8
MPP335J2E2414228LC
CBB21
3.3
23
13
21
MPP393J2E1305105LC
CBB21
0.39
13
5.5
10
10
0.5
MPP394J2E1305125LC
CBB21
0.39
13
6.5
13
10
0.5
MPP394J2E1904096LC
CBB21
0.39
18
5.5
10.5
15
0.6
MPP473J2E1304075LC
CBB21
0.047
13
5
8
10
0.5
MPP473J2E1304095LC
CBB21
0.047
13
5
10
10
0.5
MPP474J2E1308156LC
CBB21
0.47
13
8
15
10
0.6
MPP474J2E1906116LC
CBB21
0.47
18
6.5
11.5
15
0.6
MPP475J2E2915238LC
CBB21
4.7
28
14
22.5
25
0.8
MPP563J2E1304085LC
CBB21
0.056
13
5
8.5
10
0.5
MPP564J2E1306146LC
CBB21
0.56
13
7
15.5
10
0.6
MPP683J2E1305095LC
CBB21
0.068
13
5.5
9.5
10
0.5
MPP684J2E1308166LC
CBB21
0.68
13
8
16
10
0.6
MPP684J2E1905125LC
CBB21
0.68
13
6
13.5
10
0.5
MPP823J2E1304075LC
CBB21
0.082
13
5
8
10
0.5
MPP823J2E1306116LC
CBB21
0.082
13
5.6
10.7
10
0.6
MPP824J2E1309176LC
CBB21
0.82
13
8.5
17
10
0.6
MPP824J2E1906136LC
CBB21
0.82
18
7
14
15
0.6
UR :400Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP104J2E1303075LC
CBB21
0.1
13
4.5
8
10
0.5
MPP104J2E1304095LC
CBB21
0.1
13
5
9.5
10
0.5
MPP104J2E1305085LC
CBB21
0.1
13
5
9
10
0.5
MPP104J2E1305105LC
CBB21
0.1
13
5.5
10.5
10
0.5
MPP104J2E1005105LC
CBB21
0.1
10
5.5
10.5
7.5
0.5
MPP105J2E1310186LC
CBB21
1.0
13
9.5
18
10
0.6
MPP105J2E1907138LC
CBB21
1.0
18
7.5
13.5
15
0.8
MPP105J2E1907148LC
CBB21
1.0
18
7.5
14.5
15
0.8
MPP105J2E1909168LC
CBB21
1.0
18
9
16
15
0.8
MPP105J2E1910178LC
CBB21
1.0
18
9.5
16
15
0.8
MPP105J2E2408158LC
CBB21
1.0
23
7.5
14
MPP105J2E2410178LC
CBB21
1.0
23
9.5
16.5
MPP124J2E1004095LC
CBB21
0.12
10
5
10
7.5
0.5
MPP124J2E1303075LC
CBB21
0.12
13
4.5
8.5
10
0.5
MPP125J2E1907158LC
CBB21
1.2
18
8
16
15
0.5
MPP103K2E1004075LC CBB21
0.01
10
5.5
8.5
7.5
0.5
MPP104K2E1304085LC CBB21
0.1
13
5.5
8.5
10
0.5
MPP104K2E1305105LC CBB21
0.1
13
5.5
10.5
10
0.5
MPP104K2E1005105LC CBB21
0.1
10
5.5
10.5
7.5
0.5
MPP105K2E1910178LC CBB21
1.0
18
9
16
15
0.8
MPP105K2E2408158LC CBB21
1.0
23
7.5
14
MPP125K2E1911188LC CBB21
1.2
23
10.5
17
MPP154K2E1307126LC CBB21
0.15
13
7
12
10
0.6
MPP154K2E1006115LC CBB21
0.15
10
6
11
7.5
0.5
MPP205K2E2411198LC CBB21
2.0
23
10.5
18.5
MPP223K2E1006095LC CBB21
0.022
10
6
10
7.5
0.5
MPP224K2E1305125LC CBB21
0.22
13
5
11.5
10
0.5
MPP224K2E1306116LC CBB21
0.22
13
6
11
10
0.6
MPP224K2E1907128LC CBB21
0.22
18
7
12.5
15
0.8
MPP225K2E2411208LC CBB21
2.2
23
10.5
18.5
MPP225K2E2613228LC CBB21
2.2
25
12
22
22.5
0.8
MPP225K2E2909188LC CBB21
2.2
28
9
18
25
0.8
MPP473K2E1304095LC CBB21
0.047
13
5
9.5
10
0.8
UR :400Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP103J2G1305085LC
CBB21
0.01
13
5.5
8.5
10.0
0.5
MPP103J2G1304075LC
CBB21
0.01
13
4.5
8.0
10.0
0.5
MPP104J2G1004075LC
CBB21
0.1
10
4.5
8.0
7.5
0.5
MPP104J2G1006095LC
CBB21
0.1
10
5.5
9.0
7.5
0.5
MPP104J2G1305085LC
CBB21
0.1
13
5.0
9.0
10.0
0.5
MPP104J2G1305105LC
CBB21
0.1
13
5.5
10.5
10.0
0.5
MPP123J2G1305085LC
CBB21
0.012
13
5.5
9.0
10.0
0.5
MPP124J2G1304075LC
CBB21
0.12
13
5.0
8.5
10.0
0.5
MPP124J2G1305105LC
CBB21
0.12
13
5.5
10.5
10.0
0.5
MPP153J2G1303075LC
CBB21
0.015
13
5.0
7.5
10.0
0.5
MPP154J2G1005085LC
CBB21
0.15
10
6.0
9.5
7.5
0.5
MPP154J2G1305105LC
CBB21
0.15
13
5.0
10
10.0
0.5
MPP183J2G1005095LC
CBB21
0.018
10
6.0
9.5
7.5
0.5
MPP184J2G1305125LC
CBB21
0.18
13
5.0
12.0
10.0
0.5
MPP222J2G1305085LC
CBB21
0.0022
13
5.5
9.0
10.0
0.5
MPP223J2G1304095LC
CBB21
0.022
13
4.5
8.5
10.0
0.5
MPP224J2G1305095LC
CBB21
0.22
13
6.0
10.5
10.0
0.5
MPP224J2G1305145LC
CBB21
0.22
13
5.5
13.0
10.0
0.5
MPP273J2G1305095LC
CBB21
0.027
13
5.5
9.0
10.0
0.5
MPP274J2G1305105LC
CBB21
0.27
13
6.0
11.5
10.0
0.5
MPP332J2G1304075LC
CBB21
0.0033
13
5.0
8.0
10.0
0.5
MPP333J2G1305095LC
CBB21
0.033
13
5.0
10.0
10.0
0.5
MPP334J2G1305115LC
CBB21
0.33
13
6.5
11.5
10.0
0.5
MPP472J2G1304085LC
CBB21
0.0047
13
5.0
8.0
10.0
0.5
MPP472J2G1305085LC
CBB21
0.0047
13
5.0
8.0
10.0
0.5
MPP473J2G1304095LC
CBB21
0.047
13
4.5
9.5
10.0
0.5
MPP473J2G1305105LC
CBB21
0.047
13
5.5
10.5
10.0
0.5
MPP563J2G1304085LC
CBB21
0.056
13
5
8.5
10.0
0.5
MPP682J2G1304075LC
CBB21
0.0068
13
4.5
7.0
10.0
0.5
MPP683J2G1305095LC
CBB21
0.068
13
5.5
9.5
10.0
0.5
MPP683J2G1305105LC
CBB21
0.068
13
5.5
10.5
10.0
0.5
MPP823J2G1305105LC
CBB21
0.082
13
5.5
10.5
10.0
0.5
MPP102K2G1304075LC CBB21
0.001
13
5.0
7.5
10.0
0.5
UR :400Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP103K2G1305085LC
CBB21
0.01
13
5.5
8.5
10.0
0.5
MPP104K2G1305085LC
CBB21
0.1
13
5.5
10.5
10.0
0.5
MPP104K2G1305105LC
CBB21
0.1
13
5.2
10.5
10.0
0.5
MPP104K2G1306126LC
CBB21
0.1
13
5.5
10.5
10.0
0.6
MPP104K2G1907128LC
CBB21
0.1
18
7.0
12.0
15.0
0.8
MPP104K2G1006095LC
CBB21
0.1
10
5.5
9.0
7.5
0.5
MPP105K2G1909178LC
CBB21
1.0
18
9.0
15.5
15.0
0.8
MPP105K2G1910178LC
CBB21
1.0
18
9.5
16.0
15.0
0.8
MPP105K2G2409178LC
CBB21
1.0
23
8.5
16.5
20.0
0.8
MPP154K2G1305105LC
CBB21
0.15
13
5.5
10.5
10.0
0.5
MPP154K2G1307126LC
CBB21
0.15
13
6.5
11.5
10.0
0.6
MPP155K2G2412208LC
CBB21
1.5
23
12.0
20.0
20.0
0.8
MPP205K2G2414228LC
CBB21
2.0
23
13.0
22.0
20.0
0.8
MPP222K2G1305085LC
CBB21
0.0022
13
5.5
9.0
10.0
0.5
MPP224K2G1305125LC
CBB21
0.22
13
5
11.5
10.0
0.5
MPP224K2G1306116LC
CBB21
0.22
13
5.5
11.0
10.0
0.6
MPP224K2G1907138LC
CBB21
0.22
18
7.0
12.5
15.0
0.8
MPP225K2G2414238LC
CBB21
2.2
23
14.0
23.0
20.0
0.8
MPP225K2G3112208LC
CBB21
2.2
30
11.5
19.5
27.5
0.8
MPP305K2G3114238LC
CBB21
3.0
30
13.5
23.2
27.5
0.8
MPP333K2G1305105LC
CBB21
0.033
13
5.0
10.0
10.0
0.5
MPP334K2G1906136LC
CBB21
0.33
18
6.0
12.5
15.0
0.6
MPP334K2G1908158LC
CBB21
0.33
18
8.0
15.0
15.0
0.8
MPP335K2G2912208LC
CBB21
3.3
28
12.5
20.0
25.0
0.8
MPP335K2G3115238LC
CBB21
3.3
30
15.0
23.0
27.5
0.8
MPP472K2G1304085LC
CBB21
0.0047
13
5.0
8.0
10.0
0.5
MPP473K2G1304095LC
CBB21
0.047
13
5.0
9.5
10.0
0.5
MPP473K2G1305105LC
CBB21
0.047
13
5.5
10.5
10.0
0.5
MPP473K2G1005105LC
CBB21
0.047
10
5.5
10.5
7.5
0.5
MPP474K2G1311146LC
CBB21
0.47
13
9.5
13.5
10.0
0.6
MPP474K2G1906136LC
CBB21
0.47
18
6.0
12.5
15.0
0.6
MPP474K2G1908158LC
CBB21
0.47
18
8.0
14.5
15.0
0.8
MPP474K2G1909148LC
CBB21
0.47
18
8.5
13.5
15.0
0.8
UR :400Vdc
尺寸 Dimension (mm)
容量
成品编码
系列
Part No.
Series
MPP475K2G3516248LC
CBB21
4.7
MPP564K2G1910168LC
CBB21
MPP683K2G1305095LC
Capacitance
Wmax
(μF)
Tmax
Hmax
P±0.5
d±0.05
34
15.5
24.0
31.5
0.8
0.56
18
9.0
15.5
15.0
0.8
CBB21
0.068
13
5.5
9.0
10.0
0.5
MPP683K2G1305105LC
CBB21
0.068
13
5.5
10.5
10.0
0.5
MPP684K2G1908158LC
CBB21
0.68
18
7.5
14.0
15.0
0.8
MPP684K2G1910178LC
CBB21
0.68
18
9.0
16.0
15.0
0.8
MPP684K2G2408158LC
CBB21
0.68
23
7.5
15.0
20.0
0.8
MPP684K2G2412198LC
CBB21
0.68
23
12.0
19.0
20.0
0.8
MPP824K2G2409168LC
CBB21
0.82
23
9.0
16.0
20.0
0.8
UR :450Vdc
尺寸 Dimension (mm)
容量
成品编码
系列
Part No.
Series
MPP223J2W1006095LC
CBB21
0.022
MPP224J2W1005105LC
CBB21
MPP224J2W1305125LC
Capacitance
Wmax
(μF)
Tmax
Hmax
P±0.5
d±0.05
10
6.0
9.5
7.5
0.5
0.22
10
6.0
11.5
7.5
0.5
CBB21
0.22
13
6.0
12.0
10.0
0.5
MPP333J2W1305095LC
CBB21
0.033
13
5.5
9.0
10.0
0.5
MPP333J2W1005085LC
CBB21
0.033
10
6.0
9.0
7.5
0.5
MPP473J2W1304095LC
CBB21
0.047
13
5.5
10.0
10.0
0.5
MPP473J2W1305085LC
CBB21
0.047
13
5.5
9.0
10.0
0.5
MPP473J2W1005085LC
CBB21
0.047
10
5.0
8.0
7.5
0.5
MPP473J2W1005105LC
CBB21
0.047
10
6.0
10.0
7.5
0.5
MPP474J2W1305125LC
CBB21
0.47
13
6.0
13.0
10.0
0.5
MPP683J2W1305105LC
CBB21
0.068
13
5.0
10.0
10.0
0.5
MPP683J2W1006095LC
CBB21
0.068
10
6.0
9.5
7.5
0.5
MPP823J2W1304085LC
CBB21
0.082
13
5.5
9.5
10.0
0.5
MPP104K2W1305085LC CBB21
0.1
13
5.5
10.5
10.0
0.5
MPP104K2W1305105LC CBB21
0.1
13
5.5
10.5
10.0
0.5
MPP104K2W1306126LC CBB21
0.1
13
7.0
12.5
10.0
0.6
MPP105K2W1906116LC CBB21
1.0
18
8.0
13.0
15.0
0.6
MPP105K2W1908128LC CBB21
1.0
18
9.0
13.5
15.0
0.8
■料号明细及尺寸 Part No. List and Dimensions
UR :450Vdc
成品编码
Part No.
尺寸 Dimension (mm)
容量
系列 Series Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP105K2W1912208LC
CBB21
1.0
18
11.0
19.5
15.0
0.8
MPP105K2W2608178LC
CBB21
1.0
25
9
17.5
22.5
0.8
MPP154K2W1305105LC
CBB21
0.15
13
5
10
10
0.5
MPP154K2W1307126LC
CBB21
0.15
13
6.5
11.5
10
0.6
MPP155K2W1909168LC
CBB21
1.5
18
10.5
17
15
0.8
MPP155K2W1910148LC
CBB21
1.5
18
11.5
15
15
0.8
MPP224K2W1306106LC
CBB21
0.22
13
6
10
10
0.6
MPP333K2W1305105LC
CBB21
0.033
13
5
10
10
0.5
MPP473K2W1304095LC
CBB21
0.047
13
5
9
10
0.5
MPP473K2W1005105LC
CBB21
0.047
10
5
9
7.5
0.5
MPP474K2W1308156LC
CBB21
0.47
13
7.2
15
10
0.6
UR :630Vdc
成品编码
Part No.
尺寸 Dimension (mm)
容量
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP102J2J1304075LC
CBB21
0.001
13
4.5
7
10
0.5
MPP103J2J1304075LC
CBB21
0.01
13
4.5
8
10
0.5
MPP103J2J1304085LC
CBB21
0.01
13
4.5
8
10
0.5
MPP103J2J1304095LC
CBB21
0.01
13
4.5
9
10
0.5
MPP103J2J1305085LC
CBB21
0.01
13
5.5
8.5
10
0.5
MPP104J2J1006115LC
CBB21
0.1
10
6.5
11.5
7.5
0.5
MPP104J2J1304095LC
CBB21
0.1
13
5.5
10
10
0.5
MPP104J2J1305105LC
CBB21
0.1
13
5.5
10.5
10
0.5
MPP104J2J1006115LC
CBB21
0.1
10
6
11.5
7.5
0.5
MPP123J2J1304095LC
CBB21
0.012
13
5.5
10.5
10
0.5
MPP123J2J1305085LC
CBB21
0.012
13
5.5
9
10
0.5
MPP124J2J1304115LC
CBB21
0.12
13
5
11.5
10
0.5
MPP154J2J1006125LC
CBB21
0.15
10
6.5
13.5
7.5
0.5
MPP184J2J1305125LC
CBB21
0.18
13
6
12.5
10
0.5
MPP222J2J1305085LC
CBB21
0.0022
13
5.5
9
10
0.5
MPP223J2J1304095LC
CBB21
0.022
13
4.5
8.5
10
0.5
MPP223J2J1305085LC
CBB21
0.022
13
5
8
10
0.5
UR :630Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP224J2J1305135LC
CBB21
0.22
13
6
14.5
10
0.5
MPP333J2J1304085LC
CBB21
0.033
13
5
8.5
10
0.5
MPP333J2J1305105LC
CBB21
0.033
13
5
10
10
0.5
MPP333J2J1004075LC
CBB21
0.033
10
6
9
7.5
0.5
MPP472J2J1305085LC
CBB21
0.0047
13
5
8
10
0.5
MPP472J2J1004075LC
CBB21
0.0047
10
5.5
8.5
7.5
0.5
MPP473J2J1304095LC
CBB21
0.047
13
4
8
10
0.5
MPP473J2J1305105LC
CBB21
0.047
13
5
10
10
0.5
MPP473J2J1004085LC
CBB21
0.047
10
4.5
10
7.5
0.5
MPP562J2J1304075LC
CBB21
0.0056
13
4.5
9
10
0.5
MPP563J2J1303075LC
CBB21
0.056
13
4.5
8
10
0.5
MPP682J2J1304075LC
CBB21
0.0068
13
4.5
7
10
0.5
MPP683J2J1304075LC
CBB21
0.068
13
5
8.5
10
0.5
MPP683J2J1305105LC
CBB21
0.068
13
5.5
10.5
10
0.5
MPP822J2J1304075LC
CBB21
0.0082
13
5
8
10
0.5
MPP823J2J1304075LC
CBB21
0.082
13
5
8.5
10
0.5
MPP103K2J1304075LC
CBB21
0.01
13
4.5
8
10
0.5
MPP103K2J1305085LC
CBB21
0.01
13
5.5
8.5
10
0.5
MPP103K2J1306106LC
CBB21
0.01
13
6.5
10.5
10
0.6
MPP104K2J1306126LC
CBB21
0.1
13
6.5
11.5
10
0.6
MPP104K2J1307146LC
CBB21
0.1
13
6.5
14
10
0.6
MPP104K2J1308136LC
CBB21
0.1
13
7.5
12.5
10
0.6
MPP104K2J1906136LC
CBB21
0.1
18
7
12
15
0.6
MPP104K2J1907128LC
CBB21
0.1
18
7
12
15
0.8
MPP105K2J2411208LC
CBB21
1.0
23
11
MPP105K2J3111208LC
CBB21
1.0
30
11
0.8
MPP154K2J1307136LC
CBB21
0.15
13
7
12
10
0.6
MPP154K2J1308146LC
CBB21
0.15
13
7
13.5
10
0.6
MPP205K2J3116248LC
CBB21
2.0
30
16.5
25
27.5
0.8
MPP222K2J1305085LC
CBB21
0.0022
13
5.5
9
10
0.5
MPP223K2J1304095LC
CBB21
0.022
13
4.5
8.5
10
0.5
MPP224K2J1307136LC
CBB21
0.22
13
7.5
14
10
0.6
MPP224K2J1908158LC
CBB21
0.22
18
8
14.5
15
0.8
UR :630Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP224K2J1909148LC
CBB21
0.22
18
8.5
13.5
15
0.8
MPP225K2J3115238LC
CBB21
2.2
30
13.5
22.5
27.5
0.8
MPP225K2J3518268LC
CBB21
2.2
34
18
26
31.5
0.8
MPP333K2J1305105LC
CBB21
0.033
13
5
10
10
0.5
MPP334K2J1908158LC
CBB21
0.33
18
8
15
15
0.8
MPP334K2J1910158LC
CBB21
0.33
18
10.5
16
15
0.8
MPP334K2J1911178LC
CBB21
0.33
18
10
16.5
15
0.8
MPP334K2J2409168LC
CBB21
0.33
23
9.5
16
MPP473K2J1005105LC
CBB21
0.047
10
6
10
7.5
0.5
MPP473K2J1305085LC
CBB21
0.047
13
5
8.5
10
0.5
MPP473K2J1005105LC
CBB21
0.047
10
6
10
7.5
0.5
MPP474K2J1908158LC
CBB21
0.47
18
8
15
15
0.8
UR :1000Vdc
成品编码
系列
Part No.
尺寸 Dimension (mm)
容量
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP104J3A1907138LC
CBB21
0.1
18
8
12.5
15
0.8
MPP104J3A1908138LC
CBB21
0.1
18
7.5
13
15
0.8
MPP154J3A1908138LC
CBB21
0.15
18
8
13
15
0.8
MPP224J3A1909168LC
CBB21
0.22
18
8.5
16
15
0.8
MPP332J3A1306096LC
CBB21
0.0033
13
6.5
10.5
10
0.6
很抱歉,暂时无法提供与“MPP683J2W1305105LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23793
- 200+0.19473
- 500+0.15984
