CMLE061E-2R2MS
CMLE061E-2R2MS
    CYNTEC(乾坤)
    SMD
    功率电感 SMD
CMLE061E-2R2MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLE061E-000 REVISION : A8 PAGE : 1 OF 4 Power Choke Coil CMLE061E type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 1.5mm Low loss realized with low DCR Capable of corresponding high frequency (3MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A B W B' H  T Code Dimensions (mm) L 6.86 ± 0.381 W 6.47 ± 0.254 T 1.3 ± 0.2 A 1.6 ± 0.3 A’ 2.0 ± 0.1 B 3.0 ± 0.3 B’ 3.6 ± 0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.5 B 3.7 C 8.4 Unit : mm Mar., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLE061E-000 REVISION : A8 PAGE : 2 OF 4 Specifications L0 Inductance ( µH ) @ (0A) Typical CMLE061E-R12MS 0.12 CMLE061E-R33MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 3.0 3.65 19.0 17.0 29.0 25.0 0.33 5.6 6.50 13.5 12.0 21.0 19.0 CMLE061E-R47MS 0.47 7.2 8.50 13.0 11.0 18.0 15.5 CMLE061E-R56MS 0.56 9.5 11.0 10.0 9.0 15.0 14.0 CMLE061E-R82MS 0.82 15.0 17.0 9.0 8.5 13.0 11.0 CMLE061E-1R0MS 1.0 18.5 21.0 8.2 7.6 12.0 10.0 CMLE061E-1R2MS 1.2 21.0 25.0 7.5 7.0 10.5 8.5 CMLE061E-1R5MS 1.5 25.0 28.0 7.2 6.7 8.5 7.7 CMLE061E-2R2MS 2.2 35.0 42.0 6.0 5.1 7.2 6.1 CMLE061E-3R3MS 3.3 54.0 63.0 3.8 3.3 6.0 5.2 CMLE061E-4R7MS 4.7 75.0 84.0 3.5 3.0 5.0 4.5 CMLE061E-6R8MS 6.8 125.0 135.0 3.0 2.5 4.5 4.0 CMLE061E-100MS 10.0 165.0 175.0 2.2 2.0 3.5 3.0 Part Number Rdc ( mΩ) *: If you require another part number please contact with us. **: Inductance Tolerance ± 20% : Note 2.: Note 3.: Note 4.: Note 5.: Note 6.: Note 1. All test data is referenced to 25 ℃ ambient. Test Condition:100KHz, 1.0Vrms Idc : DC current (A) that will cause an approximate △T of 40 ℃ Isat : DC current (A) that will cause L0 to drop approximately 30% Operating Temperature Range -55 ℃ to + 125℃ The part temperature (ambient + temp rise) should not exceed 125 ℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling Note 7. : provision all affect the part temperature. Part temperature should be verified in the end application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. Mar., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  : A8 PAGE : 3 OF 4 0.06 ℃) 40 0.03 20 0.21 0.60 16 20 24 DC BIAS(Amps) 28 32 0.00 0.50 60 0.20 TEMP. RISE( ℃) 40 20 0.10 0 2 4 6 8 10 12 14 DC BIAS(Amps) 1.02 16 18 0.85 INDUCTANCE(µH) 0.17 TEMP. RISE( 20 ℃) 0.00 0 2 4 1.50 6 8 DC BIAS(Amps) 10 12 1.20 80 0.90 60 INDUCTANCE(µH) 0.60 TEMP. RISE( ℃) 40 0.30 20 0.00 0 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) 9 10 11 12 INDUCTANCE(µH) TEMP. RISE( 2 4 6 20 ℃) 8 10 12 DC BIAS(Amps) 14 16 18 20 100 CMLE061E-1R0MS 80 0.80 60 0.60 INDUCTANCE(µH) TEMP. RISE( 0.40 ℃) 40 ℃ 20 0.20 0 1 2 3 4 5 6 7 8 9 10 DC BIAS(Amps) 11 12 13 CMLE061E-1R5MS 1.80 100 1.50 ℃ ℃ 0 0 100 CMLE061E-1R2MS 100 0.00 14 INDUCTANCE(µH) 0 24 80 0.12 1.00 40 22 40 80 0.34 20 CMLE061E-R56MS 0 ℃ 18 0.24 1.20 60 10 12 14 16 DC BIAS(Amps) 0.36 100 0.51 8 60 0.00 0.68 6 0.48 20 CMLE061E-R82MS 4 0.60 0 0.00 TEMP. RISE( ) INDUCTANCE(µH) ℃ TEMP. RISE( ) 0.40 2 0.72 80 0.30 0 0 100 CMLE061E-R47MS 40 20 36 INDUCTANCE(µH) 12 ℃) 0.07 INDUCTANCE(µH) 8 TEMP. RISE( 0.14 0 4 TEMP. RISE( ) TEMP. RISE( ℃ 60 INDUCTANCE(µH) TEMP. RISE( ) INDUCTANCE(µH) ℃ 80 0.28 TEMP. RISE( ) 60 TEMP. RISE( ) 0.09 100 CMLE061E-R33MS 0.35 INDUCTANCE(µH) 80 TEMP. RISE( ) INDUCTANCE(µH) 0.42 100 0.12 0 INDUCTANCE(µH) REVISION 80 1.20 60 INDUCTANCE(µH) 0.90 TEMP. RISE( ℃) 40 0.60 20 0.30 0.00 0 0 1 2 3 4 5 6 7 8 9 10 11 12 DC BIAS(Amps) Mar., 2018 ℃ TEMP. RISE( ) CMLE061E-R12MS 0.00 INDUCTANCE(µH) : CMLE061E-000 Current Characteristic 0.15 INDUCTANCE(µH) DOCUMENT CYNTEC CO., LTD. 乾坤科技股份有限公司 40 0.90 20 0.45 0.00 3 6.00 4 5 6 DC BIAS(Amps) 7 8 9 INDUCTANCE(µH) 5.00 TEMP. RISE( ℃) 0.00 ℃ 0 ℃) 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 100 CMLE061E-6R8MS 80 5.60 60 INDUCTANCE(µH) 4.20 TEMP. RISE( ℃) 40 2.80 20 1.40 0.00 0 0.0 0.4 0.8 1.2 1.6 2.0 2.4 2.8 3.2 3.6 4.0 4.4 DC BIAS(Amps) 8.0 60 INDUCTANCE(µH) ℃) 40 4.0 20 2.0 0.0 ℃ TEMP. RISE( ) 80 0 0.0 0.5 1.0 1.5 2.0 2.5 DC BIAS(Amps) 3.0 3.5 ℃ 20 100 10.0 INDUCTANCE(µH) TEMP. RISE( 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 DC BIAS(Amps) CMLE061E-100MS INDUCTANCE(µH) 0.00 20 TEMP. RISE( 40 1.40 7.00 40 1.00 6.0 2.10 80 2.00 12.0 60 8.40 60 INDUCTANCE(µH) 80 2.80 100 4.00 100 CMLE061E-3R3MS 3.50 10 CMLE061E-4R7MS 3.00 : 4 OF 4 ℃ ) 2 INDUCTANCE(µH) 1 PAGE 0.70 0 0 : A8 TEMP. RISE( ) ℃) TEMP. RISE( ) 60 INDUCTANCE(µH) ℃ TEMP. RISE( ) INDUCTANCE(µH) 80 1.80 INDUCTANCE(µH) 4.20 2.25 TEMP. RISE( REVISION 100 CMLE061E-2R2MS 1.35 : CMLE061E-000 4.0 Mar., 2018 TEMP . RISE( 2.70 DOCUMENT
CMLE061E-2R2MS 价格&库存
很抱歉,暂时无法提供与“CMLE061E-2R2MS”相匹配的价格&库存,您可以联系我们找货
