P1
TAI-TECH
Power Inductor
UHP252010NF-SERIES
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
12/12/19
新 發 行
楊祥忠
詹偉特
林宜蕰
1.1
13/03/09
加入 R68 感值
楊祥忠
詹偉特
林宜蕰
備
註
www.tai-tech.com.tw
P2
TAI-TECH
Power Inductor
UHP252010NF-SERIES
1. Features
1. This specification applies Low Profile Power Inductors.
2. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
Halogen
Pb
Halogen-free
Pb-free
B
A
D
E
D
C
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
UHP252010NF
2.5 -0.1/+0.3
2.0 -0.05/+0.35
1.02max.
0.85 ref.
0.80 ref.
Units: mm
3. Part Numbering
UHP
252010 NF
A
B
4R7
M
D
E
C
A: Series
B: Dimension
C: Lead Free
Material
D: Inductance
E: Inductance Tolerance
4R7=4.7uH
M=±20%
4. Specification
TAI-TECH
Part Number
Inductance
(uH)
Tolerance
Test
Frequency
(Hz)
UHP252010NF-R47M
0.47
±20%
0.1V/1M
0.030
2.85
UHP252010NF-R68M
0.68
±20%
0.1V/1M
0.039
UHP252010NF-1R0M
1.0
±20%
0.1V/1M
0.055
UHP252010NF-1R5M
1.5
±20%
0.1V/1M
UHP252010NF-2R2M
2.2
±20%
UHP252010NF-3R3M
3.3
UHP252010NF-4R7M
DCR
I sat
I sat
(Ω) ±20% (A) typ. (A) Max.
I rms
(A) typ
I rms
(A) Max.
2.57
2.80
2.50
2.70
2.45
2.40
2.20
2.20
1.89
2.20
1.80
0.075
1.90
1.58
1.80
1.50
0.1V/1M
0.100
1.62
1.39
1.68
1.30
±20%
0.1V/1M
0.145
1.30
1.17
1.34
1.10
4.7
±20%
0.1V/1M
0.215
1.20
1.08
1.10
1.00
UHP252010NF-6R8M
6.8
±20%
0.1V/1M
0.315
0.90
0.77
0.90
0.80
UHP252010NF-100M
10
±20%
0.1V/1M
0.420
0.73
0.65
0.82
0.65
UHP252010NF-150M
15
±20%
0.1V/1M
0.600
0.55
0.50
0.55
0.50
UHP252010NF-220M
22
±20%
0.1V/1M
0.830
0.50
0.40
0.40
0.35
Note:
Isat:Based on inductance change (△L/L0:≦-30%)@ ambient temp. 25℃
Irms:Based on temperature rise (△T:40℃.)
www.tai-tech.com.tw
P3
TAI-TECH
UHP252010NF-R47
1
UHP252010NF-R68
1.2
0.8
Inductance(uH)
Inductance(uH)
0.9
0.6
0.4
0.6
0.3
0.2
2
3
DCcurrent(A)
UHP252010NF-1R0
2
1.8
DCcurrent(A)
2.4
3
2
Inductance(uH)
Inductance(uH)
1.2
UHP252010NF-1R5
2.5
1.5
1
1.5
1
0.5
0.5
1
1.5
2
DCcurrent(A)
2.5
UHP252010NF-2R2
4
0.8
1.2
DCcurrent(A)
1.6
2
UHP252010NF-3R3
6
5
Inductance(uH)
3
Inductance(uH)
0.6
2
1
4
3
2
1
0.6
0.9
DCcurrent(A)
1.2
1.5
UHP252010NF-4R7
8
0.6
0.9
DCcurrent(A)
1.2
1.5
UHP252010NF-6R8
10
8
Inductance(uH)
6
Inductance(uH)
0.3
4
2
6
4
2
0.6
0.9
DCcurrent(A)
1.2
1.5
www.tai-tech.com.tw
0.2
0.4
0.6
DCcurrent(A)
0.8
1
P4
TAI-TECH
UHP252010NF-100
15
12
Inductance(uH)
Inductance(uH)
UHP252010NF-150
25
9
6
3
15
10
5
0.4
0.6
0.8
DCcurrent(A)
1
0.4
DCcurrent(A)
0.6
0.8
UHP252010NF-220
35
Inductance(uH)
28
21
14
7
0.2
0.3
DCcurrent(A)
0.4
0.5
0.6
5. Material
No.
Description
Specification
a.
Core
Ferrite N4 Core
b.
Coating
Epoxy
c
Termination
Tin Pb Free
d
Wire
Enameled Copper Wire
6. Reliability and Test Condition
Item
Operating Temperature
Performance
Test Condition
-40~+85℃(For products in unopened tape package, less than 40℃)
Electrical Performance Test
Inductance L
Agilent-4291, Agilent-4287
Agilent-4192, Agilent-4285
Q
Refer to standard electrical characteristic list
SRF
Agilent-4291
DC Resistance
Agilent-4338
Rated Current
Temperature Rise Test
Base on temp. rise & △L/L0A≦30%.
Saturation DC Current (Isat) will cause L0
to drop approximately △L(%).
ΔT 40℃Max
Heat Rated Current (Irms) will cause the coil
temperature rise approximately △T(℃) without
core loss.
1.Applied the allowed DC current.
2.Temperature measured by digital surface
thermometer
www.tai-tech.com.tw
P5
TAI-TECH
Item
Performance
Test Condition
Mechanical Performance Test
Resistance to Soldering Heat
1. Inductors shall be no evidence of electrical and mechanical damage.
MIL-STD-202
2. Inductance : within ±10% of initial value
METHOD 210
Temp.: 260±5℃
Time: 10±1.0 Sec
Preheating Dipping Natural cooling
235° C
Solderability Test
More than 95% of terminal electrode should be covered with solder.
150° C
4±1
second
60
second
ANSI/J-STD-002
After fluxing,component shall
be dipped in a melted solder
bath at 235±5℃ for 4±1seconds.
Reliability Test
Humidity Test
1.Temperature:40±2℃
MIL-STD-202
2.Humidity:90 ~ 95%
METHOD 103
3.Time:504 ±8hrs
4.Measured at room temperature after placing
for 2 to 3 hrs
Conditions for 1 cycle
Step
Temperature(℃)
MIL-STD-202
1
-55±2
30±3
METHOD 107
2
Room Temperature
Within5
2
85±5
30±3
Thermal Shock Test
Times(min.)
1.Visual examination:No mechanical damage
Total:100 cycles
2.Inductance:within±10% of initial value
placing for 2 to 3 hrs
1.Temperature:85±2℃
High Temperature Life Test
2.Time:500±8hrs
MIL-STD-202
3.Measured at room temperature after placing
METHOD 108
for 2to3 hrs
1.Temperature:40±2℃
2.Humidity:90~ 95%
3.Time:500±8hr.
4.Recovery:2 to 3hrs of recovery under the
standard condition after the removal from test
chamber.
Humidity Resistance Test
MIL-STD-202
METHOD 103
1.Temperature:-40±2℃
Low temperature
2.Time:500±8hrs
Storage Test
JESD22-A119
for 2to3 hrs
Frequency: 10-55-10Hz for 15 min.
Amplitude: 1.52mm
Random Vibration Test
Appearance: Cracking, shipping and any other defects harmful to the
Directions and times:
MIL-STD-202
characteristics should not be allowed.
X, Y, Z directions for 15 min.
Method 204
Impedance: within±30%
This cycle shall be performed 12 times in each
of three mutually perpendicular directions
(Total 9hours).
www.tai-tech.com.tw
P6
TAI-TECH
7. Soldering and Mounting
7-1. Soldering
Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for all wave and re-flow soldering systems.
If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
7-1.1 Solder re-flow:
Recommended temperature profiles for re-flow soldering in Figure 1.
7-1.2 Soldering Iron(Figure 2):
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that
a soldering iron must be employed the following precautions are recommended.
‧Preheat circuit and products to 150℃
‧355℃ tip temperature (max)
‧Never contact the ceramic with the iron tip
‧1.0mm tip diameter (max)
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
20~40s
PRE-HEATING
NATURAL
COOLING
TEMPERATURE(°C)
217
60~150s
200
150
SOLDERING
within 4~5s
TP(260° C / 40s max.)
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧Limit soldering time to 4~5 sec.
60~180s
NATURAL
COOLING
350
150
Gradual cooling
Over 60s
480s max.
25
TIME(sec.)
TIME( sec.)
Reflow times: 3 times max.
Iron Soldering times: 1 times max.
Fig.1
Fig.2
7-2. Recommended PC Board Pattern
H
L
L(mm)
G(mm)
H(mm)
2.9
0.8
2.4
G
www.tai-tech.com.tw
P7
TAI-TECH
8. Packaging Information
8-1. Reel Dimension
C
B
D
A
Type
A(mm)
B(mm)
C(mm)
D(mm)
7”x8mm
8.4±1.0
50 min.
13±0.8
178±2
8-2. Tape Dimension / 8mm
7"x8mm
t
P
Ao
Bo
Po:4±0.1
W:8.0±0.1
P2:2±0.05
Series
Size
UHP
252010
Bo(mm) Ao(mm) Ko(mm) P(mm)
3.10±0.1
2.45±0.1
1.40±0.1
4.0±0.1
t(mm)
0.23±0.05
Ko
8-3. Packaging Quantity
Chip size
252010
Chip / Reel
2000
8-4. Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 15 to 80 grams
in the arrow direction under the following conditions.
165° to180°
Base tape
Room Temp.
Room Humidity
Room atm
Tearing Speed
(hPa)
mm/min
5~35
45~85
860~1060
300
Application Notice
‧Storage Conditions
To maintain the solderability of terminal electrodes:
1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months form the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
‧Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.tai-tech.com.tw
很抱歉,暂时无法提供与“UHP252010NF-R68M”相匹配的价格&库存,您可以联系我们找货
