MKP62
Metallized polypropylene film interference suppression capacitor(Class X2, 305Vac/275Vac)
■ Outline Drawing
4pins
W±0.4, H±0.4, T±0.4
Square-bottom
4pins
W±0.4, H±0.4, T±0.4
4pins
Arc-bottom
■ Features
●Metallized polypropylene structure
●Withstanding overvoltage stressing
● Excellent active and passive flame resistant abilities
● Used in across-the-line, interference suppression circuit.
■ Safety Approvals
CQC
IEC 60384-14:2013, X2, 305Vac/275Vac, 0.0010F50.0F, 40/110/56/B
Certificate No.: CQC03001002875
ENEC-VDE
EN 60384-14:2013,X2, 305Vac/275Vac, 0.0010F50.0F, 40/110/56/B
Certificate No.: 40000358
UL-CUL
KC
UL 60384-14:2009 , CSA E60384-14:09 , X2, 305Vac/275Vac, 0.0010F50.0F,
40/110/56/B
File No.: E186600, CCN: FOWX2/8
K60384-14(2006-12) , X2, 305Vac/275Vac, 0.0010F3.0F, 40/110/56/B
Certificate No.: SU03060-12001A/12002/12003/12004
MKP62
■ Specifications
Class
Climatic Category / Passive Flammability
Category Temperature Range
Operating
Rated Voltage (UR)
Maximum continuous DC voltage
Capacitance Range
Capacitance Tolerance
Voltage Proof
Insulation Resistance
Dissipation Factor
Class X2
40/110/56/B
-40℃ ~ +110℃
305Vac/275Vac,50/60Hz
630Vdc
0.0010F~25.0F
10(K), 20(M)
Between Terminals
4.3UR(dc), 2s
Between Terminals To Case
R≥15 000M , CN≤0.33F
RCN≥5 000s, CN0.33F
0.0010F≤CN0.010F
0.010F≤CN0.47F
0.47F≤CN≤1.0F
1.0FCN≤10.0F
10.0FCN≤50.0F
2 120Vac, 1min
(20℃, 100V ,1min)
≤2010-4(1kHz,20℃)
≤1010-4(1kHz,20℃)
≤2010-4(1kHz,20℃)
≤3010-4(1kHz,20℃)
≤4010-4(1kHz,20℃)
≤2010-4(10kHz,20℃)
≤2010-4(10kHz,20℃)
≤4010-4(10kHz,20℃)
MKP62
■ Part number system
The 18 digits part number is formed as follow:
1
2
3
C
4
2
4
Digit 1 to 3
5
6
7
8
9
10 11 1 2 1 3 14 1 5 1 6 1 7 1 8
Series code
C42=MKP62
Digit 4 to 5
A.C. rated voltage
Q2=305V P2=275V
Digit 6 to 8
Rated capacitance value
For example : 103=10×103 pF= 0.01μF
Digit 9
Capacitance tolerance
K=±10%, M=±20%
Digit 10
Pitch
3=7.5mm
B=27.5mm
Digit 11
4=10.0mm
6=15.0mm
F=37.5mm
9=22.5mm
M=52.5mm
Internal use
Digit 12 to 15 Lead form and packaging code
Digit 16 to 18 Internal use
Table1 Lead form and packaging code
Digit 12
code
A
C
explanation
ammo-pack
straight lead
“C” in the
figure above
D
Insulated stranded leads
E
Insulated solid leads
M
Box with mounting foot
T
P1=20.3mm±0.5mm
Digit 13
code
3
4
6
explanation
F=7.5mm
F=10.0mm
F=15.0mm
Digit 14
code
explanation
Straight
code
1
5
code
explanation
00
45
35
32
C5
K0
K2
L0
standard lead length (18mm~26mm)
lead length 4.5mm
lead length 3.5mm
lead length 3.2mm
35mm
100mm
120mm
200mm
Note 1:This length includes the stripping parts.
Note 2:Normally, for P≥27.5 Caps can choice
Insulated leads.
45
Digit 15
Length tolerance ±0.5mm or standard
length
Length tolerance ±0.3mm
1
Length tolerance -5 mm~0 mm
2
Length tolerance 0 mm~+5 mm
3
Length tolerance 0 mm~+10mm
4
Length tolerance ±5 mm
lead length 4.5mm
P1=20mm±0.5mm
55
lead length 5.5mm
explanation
each cap. among two consecutive
holes
P3=12.7mm,H=18.5mm
(For
P=7.5mm)
P3=25.4mm;H=18.5mm
(For
pitch=10/15mm)
(Detail parameter refer to page 11)
Length tolerance
standard length
±0.5mm
or
MKP62
■ Dimensions(mm)
305Vac/275Vac#
305Vac/275Vac#
305Vac/275Vac#
CN
(F)
0.0010
0.0012
0.0015
0.0018
0.0022
0.0027
0.0033
0.0039
0.0047
0.0056
0.0068
0.0082
0.010
0.012
0.015
0.018
0.022
0.027
0.033
0.039
0.047
0.056
0.068
0.0047
0.0056
0.0068
0.0082
0.010
0.012
0.015
0.018
0.022
0.027
0.033
0.039
0.047
0.056
0.068
0.082
0.10M
0.10K
0.12
0.15
0.18
0.22M
W
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
10.5
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
H
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
11.0
11.0
11.0
12.0
12.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
9.0
11.0
11.0
11.0
11.0
12.0
13.0
13.0
14.0
14.0
T
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
5.0
5.0
5.0
6.0
6.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
5.0
5.0
5.0
5.0
6.0
7.0
7.0
8.0
8.0
P
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
d
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
Part number
C42Q2102-30****+++
C42Q2122-30****+++
C42Q2152-30****+++
C42Q2182-30****+++
C42Q2222-30****+++
C42Q2272-30****+++
C42Q2332-30****+++
C42Q2392-30****+++
C42Q2472-30****+++
C42Q2562-30****+++
C42Q2682-30****+++
C42Q2822-30****+++
C42Q2103-30****+++
C42Q2123-30****+++
C42Q2153-30****+++
C42Q2183-30****+++
C42Q2223-3S****+++
C42Q2273-3S****+++
C42Q2333-3S****+++
C42Q2393-3S****+++
C42Q2473-3S****+++
C42Q2563-3S****+++
C42Q2683-3S****+++
C42Q2472-40****+++
C42Q2562-40****+++
C42Q2682-40****+++
C42Q2822-40****+++
C42Q2103-40****+++
C42Q2123-40****+++
C42Q2153-40****+++
C42Q2183-40****+++
C42Q2223-40****+++
C42Q2273-40****+++
C42Q2333-4S****+++
C42Q2393-4S****+++
C42Q2473-4S****+++
C42Q2563-4S****+++
C42Q2683-4S****+++
C42Q2823-4S****+++
C42Q2104M4S****+++
C42Q2104K4S****+++
C42Q2124-4S****+++
C42Q2154-4S****+++
C42Q2184-4S****+++
C42Q2224M4S****+++
CN
(F)
0.022
0.027
0.033
0.039
0.047
0.056
0.068
0.082
0.10M
0.10
0.12
0.15M
0.15K
0.18
0.22M
0.22K
0.22K
0.22K
0.27
0.33M
0.33K
0.33M
0.33M
0.33K
0.33
0.39
0.47M
0.47M
0.47K
0.56
0.60
0.68
0.82M
0.15
0.18
0.22
0.27
0.33
0.39
0.47M
0.47K
0.56
0.60
0.68
0.82
W
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
26.5
H
9.5
9.5
9.5
9.5
9.5
9.5
9.5
9.5
9.5
11.0
11.0
11.0
12.0
12.0
12.0
13.5
12.0
13.5
13.5
13.5
14.0
12.5
17.5
18.5
12.0
14.5
14.5
18.5
16.0
16.0
19.0
19.0
19.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
16.0
16.0
17.0
17.0
18.5
T
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
6.0
6.0
6.0
6.0
7.0
7.5
7.5
7.5
8.0
9.0
6.0
7.5
13.0
8.5
8.5
7.5
10.0
10.0
11.0
11.0
11.0
6.0
6.0
6.0
6.0
6.0
6.0
6.0
7.0
7.0
8.5
8.5
10.0
P
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
d
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.8
0.8
0.6
0.6
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
Part number
C42Q2223-6A****+++
C42Q2273-6A****+++
C42Q2333-6A****+++
C42Q2393-6A****+++
C42Q2473-6A****+++
C42Q2563-6A****+++
C42Q2683-6A****+++
C42Q2823-6A****+++
C42Q2104M6A****+++
C42Q2104-6S****+++
C42Q2124-6S****+++
C42Q2154M6S****+++
C42Q2154K6S****+++
C42Q2184-6S****+++
C42Q2224M6S****+++
C42Q2224K6B****+++
C42Q2224K6C****+++
C42Q2224K6S****+++
C42Q2274-6S****+++
C42Q2334M6S****+++
C42Q2334K6S****+++
C42Q2334M6A****+++
C42Q2334M6B****+++
C42Q2334K6A****+++
C42Q2334-6C****+++
C42Q2394-6S****+++
C42Q2474M6S****+++
C42Q2474M6A****+++
C42Q2474K6S****+++
C42Q2564-6A****+++
C42Q2604-6S****+++
C42Q2684-6S****+++
C42Q2824M6S****+++
C42Q2154-90****+++
C42Q2184-90****+++
C42Q2224-9S****+++
C42Q2274-9S****+++
C42Q2334-9S****+++
C42Q2394-9S****+++
C42Q2474M9S****+++
C42Q2474K9S****+++
C42Q2564-9S****+++
C42Q2604-9S****+++
C42Q2684-9S****+++
C42Q2824-9S****+++
CN
(F)
0.39
0.47
0.56
0.68
0.82
1.0
1.0
1.2
1.5
1.8
2.2M
2.2K
★2.2
2.7
3.3
3.3M
3.3K
★3.3M
★3.3K
3.9
3.9
4.7M
★4.7M
4.7K
4.7
5.6
6.8M
1.5
1.8
2.2
2.2
2.7
3.3
3.3
3.3
3.9
4.7M
4.7K
4.7
5.6
6.8
6.8
8.2
10.0M
10.0K
W
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
32.0
41.0
41.0
41.0
42.0
41.0
41.0
42.0
42.0
41.0
42.0
41.0
41.0
41.0
41.0
42.0
41.0
41.0
41.0
H
18.0
18.0
18.0
18.0
18.0
18.0
12.0
20.0
20.0
22.0
22.0
25.0
16.0
28.0
30.0
24.5
28.0
16.0
18.5
29.0
33.0
33.0
18.5
33.0
30.0
37.0
37.0
22.0
22.0
24.0
15.0
24.0
26.0
28.0
15.0
30.0
19.0
20.0
30.0
33.5
33.5
24.0
37.0
37.0
41.0
T
9.0
9.0
9.0
9.0
9.0
9.0
18.0
11.0
11.0
13.0
13.0
13.0
22.0
14.0
16.0
15.0
17.0
27.5
31.0
19.0
18.0
18.0
31.0
18.0
21.0
22.0
22.0
11.0
11.0
13.0
24.0
13.0
15.0
14.0
24.0
16.0
24.0
26.0
16.0
18.5
18.5
32.0
22.0
22.0
26.0
P
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
27.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
37.5
d
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Part number
C42Q2394-B0****+++
C42Q2474-B0****+++
C42Q2564-B0****+++
C42Q2684-B0****+++
C42Q2824-BS****+++
C42Q2105-BS****+++
C42Q2105-BC****+++
C42Q2125-BS****+++
C42Q2155-BS****+++
C42Q2185-BS****+++
C42Q2225MBS****+++
C42Q2225KBS****+++
C42Q2225-BC****+++
C42Q2275-BS****+++
C42Q2335-BA****+++
C42Q2335MBB****+++
C42Q2335KBB****+++
C42Q2335MBC****+++
C42Q2335KBC****+++
C42Q2395-BA****+++
C42Q2395-BS****+++
C42Q2475MBS****+++
C42Q2475MBC****+++
C42Q2475KBA****+++
C42Q2475-BB****+++
C42Q2565-BS****+++
C42Q2685MBS****+++
C42Q2155-FS****+++
C42Q2185-FS****+++
C42Q2225-FS****+++
C42Q2225-FC****+++
C42Q2275-FS****+++
C42Q2335-FA****+++
C42Q2335-FS****+++
C42Q2335-FC****+++
C42Q2395-FS****+++
C42Q2475MFC****+++
C42Q2475KFC****+++
C42Q2475-FS****+++
C42Q2565-FS****+++
C42Q2685-FS****+++
C42Q2685-FC****+++
C42Q2825-FS****+++
C42Q2106MFS****+++
C42Q2106KFS****+++
0.010
0.012
0.015
0.018
17.5
17.5
17.5
17.5
9.5
9.5
9.5
9.5
5.0
5.0
5.0
5.0
15.0
15.0
15.0
15.0
0.6
0.6
0.6
0.6
C42Q2103-6A****+++
C42Q2123-6A****+++
C42Q2153-6A****+++
C42Q2183-6A****+++
1.0
1.2
1.5M
1.5K
1.8
2.2
2.2
26.5
26.5
26.5
26.5
26.5
26.5
26.5
18.5
20.0
20.0
22.0
24.5
24.5
29.5
10.0
11.0
11.0
12.0
15.5
15.5
14.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
0.8
0.8
0.8
0.8
0.8
0.8
0.8
C42Q2105-9S****+++ 10.0K
C42Q2125-9S****+++
12.0
C42Q2155M9S****+++ 15.0
C42Q2155K9S****+++ 20.0
C42Q2185-9S****+++
20.0
C42Q2225-9S****+++
20.0
C42Q2225-9A****+++ 25.0
41.5
41.0
42.0
42.0
57.0
57.0
57.0
37.5
43.0
45.0
57.5
45.0
30.0
50.0
27.5
28.0
30.0
30.0
30.0
44.0
35.0
37.5
37.5
37.5
37.5
52.5
52.5
52.5
1.0
1.0
1.0
1.0
1.2
1.2
1.2
C42Q2106KFA****+++
C42Q2126-FS****+++
C42Q2156-FS****+++
C42Q2206-FS****+++
C42Q2206-MST***+++
C42Q2206-MCT***+++
C42Q2256-MST***+++
Note: 1. “-”=capacitance tolerance code, M=±20%, K=±10%
2. “****”=lead form and packaging mode code (refer to table 1)
3. “#”when the rated voltage is 275Vac, the digit 4~5 is P2.
4. Not for use in series with the mains, the capacitors for series with the mains please refer to A.C. Capacitors for Capacitive Divider.
5. “★” = Arc bottom of the outer shell.
MKP62
■ Maximum permissible voltage change per unit of time
Rated
Voltage
(Vac)
P=7.5mm
P=10mm
P=15mm
P=22.5mm
P=27.5mm
P=37.5mm
P=52.5mm
305
500
500
400
200
150
100
50
dV/dt(V/us)
at 440 Vdc
Note:
1. Rated voltage pulse slope (dV/dt)R at rated voltage.
2. If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In
this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR/U.
■ Impedance Vs. Frequency
TYPICAL GRAPHS
Z=f(f) Typical values
■ Quality ensuring test (before shipment):
Inspection item(each batch)
Inspection level (GB/T 2828.1, ISO2859-1)
IL
AQL
II
1.5
II
0.25
S-3
2.5
Appearance inspection
Dimensions
Capacitance
Tangent of the loss angle
Dielectric strength
Insulation resistance
Solderability
MKP62
■ Test Method And Performance
No.
Item
1
4.5 Solderability
2
4.3
Terminal strength
3
4.4
Resistance to solder heat
4
Test Method
(IEC 60384-14)
Performance
4.20
Solvent resistance
of the marking
4.2 Initial measurement
4.6 Rapid change
of temperature
Good quality of tinning
Solder temperature: 245˚C 5˚C
Immersion time: 2.0s0.5s
There shall be no visible damage
Tense: 0.50d≤0.80, 10N
0.80d≤1.25, 20N
Bend: 0.50d≤0.80, 5N
0.80d≤1.25, 10N
The terminals shall be bent 2 times in
each direction
C/C 5(relative to the initial value)
Solder temperature:260˚C5˚C
Immersion time: 10s1s
The marking shall be legible
Solvent: Industrial isopropanol.
Solvent temperature:23˚C±5˚C
Dipping time: 5min0.5min
Condition: scrub
Scrub material: absorbent cotton
Reverting time: No
Capacitance, Tg
There shall be no evidence
of deterioration.
4.7 Vibration
of deterioration.
4.8 Bump
of deterioration.
5
Final measurement
TA=-40˚C, TB =+110˚C
Duration: t=30min
5 cycles
Amplitude 0.75mm or acceleration
100m/s2 (whichever is the smaller
severity), f: 10Hz to 500Hz.Three
directions, 2h for each direction,
total 6h.
4 000 times,
Acceleration: 400m/s2,
Pulse duration, 6ms
C/C5(relative to the initial value)
Initial
measurement
+110℃, 16h
Dry heat
Damp
heat, Cyclic
Test Db, Severity: b, the first cycle
-40℃, 2h
Cold
6
4.11
Climate
sequence
Damp heat,
cyclic other
Final
measurement
Test Db, Severity b, the other cycles
There shall be no visible damage,
legible marking
Increase of tg:
CN1F: 0.008 (10kHz)
CN1F: 0.005 (1kHz)
Dielectric strength : there shall be no
permanent breakdown or flashover
I.R.: 50 of the rated value
MKP62
No.
7
8
Item
Performance
4.12
Damp heat
steady state
legible marking
Increase of tg:
CN1F: 0.008 (10kHz)
CN1F: 0.005 (1kHz)
4.13
Impulse voltage
There are three or more waveforms
which indicate that no self-heating
breakdown have occurred when it is
monitored by the monitor
Test Method
(IEC 60384-14)
Temperature: 40˚C 2˚C
Humidity: 933RH
Duration: 56 days
Each individual capacitor shall be
subjected to 24 impulses of the same
polarity (when any three successive
impulses are shown by the monitor to
have a wave form indicating that no
self-healing breakdown have taken place
the impulses can be stopped), the time
between impulses shall not be less than
10S, and the peak value of the voltage
impulse: 2.5kV(suitable for CN 1F;
When CN1F, the capacitor can endure
pulse voltage value is 2.5 / CN kV)
9
4.14 Endurance
legible marking
C/C10(relative to the initial
value)
Increase of tg:
CN1F: 0.008 (10kHz)
CN1F: 0.005 (1kHz)
Dielectric strength : There shall be no
I.R. : 50 of the rated value
+110˚C, 1.25URVa.c., 1 000h
The voltage shall be subjected to
1000Vrms for 0.1s every one hour
during test.
Times: 10 000
Duration of charging: 0.5s
Duration of discharging: 0.5s
10
11
4.15
Charging and
discharging
4.17
Passive
flammability
C/C 10(relative to the initial
value)
Increase of tg:
CN1F: 0.008 (10kHz)
CN1F: 0.005 (1kHz)
The flaming time of each capacitor
shall not go beyond 10s after it is
taken apart from the flame.
Drop of each capacitor caused by
flame shall not fire the tissue below.
Charging voltage: 2 UR Vd.c.
Charging resistance: 220/CN() or
the current ≤1.0A (whichever is the
minor)
Discharging resistance:
2UR
R
dU
CN
dt
CN: Capacitance (F)
dU/dt(V/us) : 100V/s
Ref.item 4.17
Needle flame test
The category of flammability: B
Expose time: 1 time
Capacitor Volume Exposing time
250
