Technical Data Sheet
18K101-K00L5
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
Mini-SMP Adaptor Jack - Jack
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
MIL-STD-348
Mateable with GPPOTM (Gilbert Engineering Co., Inc.)
and SSMPTM (Connectors Devices, Inc.)
Documents
N/A
Material and plating
Connector parts
Center contact
Outer contact
Dielectric
Material
CuBe
CuBe
PTFE
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
AuroDur®, gold plated
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/2
18K101-K00L5
RF_35/09.14/6.2
Electrical data
Impedance
Frequency
Return loss
50
DC to 65 GHz
26 dB, DC to 18 GHz
15 dB, 18 to 26.5 GHz
13 dB, 26.5 to 50 GHz
Insertion loss
Insulation resistance
Center contact resistance
Outer contact resistance
Working voltage (at sea level)
0.05 x f(GHz) dB
5 G
6.0 m
2.0 m
325 V rms
125 V rms
(at 70000 feet)
Mechanical data
Mating cycles
if mating part is smooth bore
if mating part is full detent
Center contact captivation
Engagement force
- smooth bore
- full detent
Disengagement force
- smooth bore
- full detent
500
100
7N
11 N typical
19 N typical
11 N typical
29 N typical
Environmental data
Temperature range
Thermal shock
Vibration
Shock
Moisture resistance
Climatic Category
RoHS
-55°C to +155°C
MIL-STD-202, Method 107, Condition B
MIL-STD-202, Method 204, Condition A
MIL-STD-202, Method 213, Condition A
MIL-STD-202, Method 106
IEC 60068 55/155/21
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
0.1 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
J. Wengler
25.01.08
Chr. Janßen
20.10.20
f00
20-1927
S. Huber-Siegl
20.10.20
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/2
很抱歉,暂时无法提供与“18K101-K00L5”相匹配的价格&库存,您可以联系我们找货
