TJ-L3FYTGHRMTCSFLC3R-A5 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
承 認 書
Specification For Approval
Customer: (客戶)
Description: (產品描述)
3MM圓頭霧狀紅髮紅燈珠
Part number:(產品型號) TJ-L3FYTGHRMTCSFLC3R-A5
Date:
(日期)
Approved By: (客戶承認)
Prepared By:(我司承認)
Approval
核准
Check
Design
審核
製作
Sales
業務
Customer Service Hotline:400-676-8616
TEL:0769-8662 5999
0769-8200 2226
E-MIAL∶dg@togialed.com
FAX:0769-8200 2227
WEB:www.togi aled. c om
3.8
Features :
* Low power consumption
* Small efficiency.
* Versatile mounting on p.c board or panel.
* I.C compatible/ low current requirement.
* Package Dimensions:
1
5.3
3
Unit : mm
2.0
18.5
0.5
2.54
0.5 pin*2
Note:
1:All dimensions are in millimeters (inches).
2:Tolerance is ±0.25mm (.010”) unless otherwise noted.
3:
Specifications are subject to change without notices.
4:This specification is for reference only for one year
2/8
Absolute Maximum Ratings at Ta=25℃
Parameter
Rating
Unit
72
mW
Peak Forward Current(1/10 Duty Cycle 0.1ms pulse
Width
100
mA
Forward Current(IF)
mA
Reverse Voltage(VR)
5
V
Power Dissipation(Pd)
Operating Temperature Range
-20℃ ~ +80℃
Storage Temperature Range
-30℃ ~ +100℃
Lead Soldering Temperature(4.0mm Form Body
260℃ for 5 Seconds
Electronical / Optical Charateristics at Ta=25℃
Test
Condition
Parameter
Min
Tvo
Max
Unit
Luminous Intensity(IV)
30
60
mcd
If=20mA
Viewing Angle(2 θ1/2)
45
deg
If=20mA
The wavelength(λ)
640
655
nm
If=20mA
Forward Voltage(VF)
1.7
2.5
V
If=20mA
5
µA
Vr=5V
Reverse Current(IR)
Selection Guide :
Lens color
Chip
Material
Emittedcolor
λp(nm )
Red Diffused
AlGaInP
3/8
Red
650
Selection Guide
0°
10°
20°
30°
光 谱 分布 特 性 曲线
Relative Spectral Distribution
1. 2
1. 0
40°
0. 8
1.0
50°
0. 6
60°
0. 4
0.8
70°
0. 2
80°
90°
400
450
500
550
600
650
700
750
波 长( Wavelength ) (nm )
SPATIAL DISTRIBUTION
2.5
Luminous Intensity
Relative Volue at IF=20mA
Forward Current(mA)
50
40
30
1.5
1.0
0.5
1.7
1.9
2.1
2.3
2.5
40
50
Forward Voltage(V)
IF-Forward Current(mA)
FORWARD CURRENT Vs.
FORWARD VOLTAGE
LUMINOUS INTENSITY Vs.
FORWARD CURRENT
Relative Luminous Intensity
50
Forward Current(mA)
相 对 光 强 ( Relativ e Lu mino us In ten s ity ) ( % )
Typical Electrical/Optical Characteristics Curves(25℃ Ambient Temperature Unle
40
30
2.5
2.0
1.5
1.0
0.5
60
80
-40
100
Ambient Temperature(° C)
-20
60
FORWARD CURRENT
DERATING CURVE
AMBIENT TEMPARATURE
4/8
80 90
Labe
P/N: The product model
IV: Luminous intensity rank
VF: Forward voltage rank
TC: Color temperature
Q`T: number
QC: Production order
The packing
Desiccant
Aluminum moisture-proof bag
The cardboard
Package specification:
Package Method: packaged in anti-static bag White:Packaged in sorted light and color
2000pcs/bag
note:
General light 2000pcs/bag
Package specification mentioned above is under normal circumstance. Specific
demand can be negotiated
5/8
Supporter shaping:
Shaping of the supporter must be conducted before welding. While shaping, the bending
position of the supporter must at least be located at 3mm from the bottom of the
encapsulating resin. Also, avoid multiple bending on the same position。Please choose the
appropriate apparatus to fixate the supporter in order to avoid exerting extra pressure on
resin. Using the jointing section of the pin and resin as fulcrum is strictly prohibited since
the pressure mounted would directly damage the internal 。illuminating structure and thus
cause irreversible defection of the product..Due to the same reason, the interval between
the welding hole on the PCB board should be strictly matched with the pin interval of the
product when assembling the product.
6/8
Reliability experiment items and conditions
Serial
number
1
Sample
quantity
Acceptance/rejection
-40℃- +100℃
20min 10s 20min
Testing time;100 cycle
High temperature;100℃
-40℃-- +100℃
60min 20min 60min
Testing time;20 A cycle
260℃(Max), The biggest not
more than 5 seconds
Testing project Test conditions
Life test
Test current;20MA
temperature;25℃
Testing time;1000 hours
2
3
High
temperature
high humidity
(static test)
Cold and hot
impact
temperature;=+65℃
humidity;90% RH
Testing time;240 hours
High temperature
4
storage
5
6
7
Low temperature
Low temperature;-40℃
storage
temperature
cycle
Reflow
soldering
note
Reliability experiment unqualified decision criteria
IV; Attenuation of more than 30% VF; Change more than 20% ;
1. The same project experimental results of the test must be completed within two hours
2. Testing must be in every experiment is completed. Material return to normal conditions to carry out
7/8
ESD protective
1 Electrostatic generation
1;Friction: in the daily life. Any two different material object contact after the
separation, can produce a staticelectric,Static electricity and the most
common method,Is triboelectrification。The insulation material, the better,More
letEasy triboelectrification。In addition,Any two different material object contact
after separation,Can also produce electrostatic。
2. Induction: in view of the conductive material is concerned, because the
surface of the electronic can free flow, such as placed it in electric
fieldbecauseGay repellent,Opposites attract,Are negative ions will transfer,
In its surface can produce charge。
3. Transmission: in view of the conductive material is concerned, because the
surface of the electronic can free flow,If charged object contact, will be
charge transfer.
4. The harm of static electricity LED:
.1 For the moment's electric field or the heat generated by the current,Make LED
localinjury,For the performance of the leakage current increase quickly,Can
stillwork,But the brightness is reduced (white light will change color), life is
damaged。
5 Because the electric field or current failure LED insulating layer,Make device can't work
(destroyed),Performance for die lamp。
6;Electrostatic protection and elimination measures:
a.
For the whole process (production, testing, packaging, etc.) All LED directly contact member
must do it well Prevent and Eliminate electrostatic measures, basically have: workshop laid
anti-static floor and well grounded。
b. Table for esd workstation, the production of the good earth
c. Operator wear anti-static clothing, with wrist strap, gloves or foot ring。
d. Application of ion fan, welding solder iron well grounding measures。
e. The package antistatic material
8/8
TJ-L3FYTGHRMTCSFLC3R-A5 价格&库存
很抱歉,暂时无法提供与“TJ-L3FYTGHRMTCSFLC3R-A5”相匹配的价格&库存,您可以联系我们找货
