S2A
S2M
THRU
2.0 AMP SURFACE MOUNT SILICON RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
2.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* High surge current capability
DO-214AC(SMA)
.110(2.79)
.100(2.54)
.058(1.47)
.052(1.32)
MECHANICAL DATA
.177(4.50)
.157(3.99)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Terminals: Solder plated, solderable per MIL-STD-202F,
method 208 guranteed
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 gram
.012(0.31)
.006(0.15)
.087(2.20)
.071(1.80)
.005
MAX.
(.127)
.205(5.20)
.189(4.80)
.060(1.52)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
S2AA
S2BA
S2DA
S2GA
S2JA
S2KA
S2MA
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
at Ta=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
2.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 2.0A
Maximum DC Reverse Current
Ta=25 C
50
A
V
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RqJA (Note 2)
Operating and Storage Temperature Range TJ, TSTG
100
60
47
1.1
5.0
-55
+150
pF
C/W
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance from Junction to Ambient.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (S2AA THRU S2MA)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
CHARACTERISTICS
AVERAGE FORWARD CURRENT,(A)
10
1
3.0
2.5
2.0
1.5
1.0
0.5
Tj=25 C
40
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
Pulse Width 300us
1% Duty Cycle
.1
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWAARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
10
100
10
50
100
NUMBER OF CYCLES AT 60Hz
10
FIG.5-TYPICAL JUNCTION CAPACITANCE
Tj=100 C
175
1.0
Tj=25 C
.1
.01
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
100
150
125
100
75
50
25
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“S2MA”相匹配的价格&库存,您可以联系我们找货
