Additional Resources:
Product Page
3D Model
PCB Footprint
date
04/07/2022
page
1 of 3
SERIES: UJ2-ADH-TH │ DESCRIPTION: USB RECEPTACLE
FEATURES
USB type A jack
USB 2.0
horizontal orientation
through hole mounting
dual port
PART NUMBER KEY
UJ2-ADH - X X - TH
Base Number
Insulator Color:
“blank” = black
W1 = white
Contact Plating
Thickness (gold):
1 = 3 µ”
3 = 15 µ”
Packaging Style:
TH = through hole
Notes:
1. White insulator option only
available with 3 µ” plating
SPECIFICATIONS
parameter
USB standard
conditions/description
min
typ
rated input current
between terminals and mating plug
insulation resistance
voltage withstand
30
Vac
1.0
A
30
mΩ
500
Vac
35
N
1000
MΩ
for 1 minute
insertion force
withdrawal force
10
operating temperature
-20
life
N
85
1,500
flammability rating
UL94V-0
RoHS
yes
Note:
units
USB 2.0
rated input voltage
contact resistance1
max
°C
cycles
1. When measured at 20 mV / 100 mA.
2. All specifications measured at 15~35°C, humidity at 25~85%, under atmospheric pressure of 86~106 kPa, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
dipped in solder pot for 5 ±0.5 seconds
min
cuidevices.com
typ
240
max
units
°C
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: UJ2-ADH-TH │ DESCRIPTION: USB RECEPTACLE
date 04/07/2022│ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
MATERIAL
PLATING
contact terminals
phosphor bronze
contact: gold over nickel
solder: tin over nickel
shield
brass
nickel
insulator
PBT
PCB edge
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 04/07/2022│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
08/05/2016
1.01
brand update
02/05/2020
1.02
added USB standard
04/07/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“UJ2-ADH-1-TH”相匹配的价格&库存,您可以联系我们找货
