DATA SHEET
TCM 310 /TCM 310U
Transceiver Gateway Modules
TCM 310 / TCM 310U
TCM 310 enables the realization of gateways
for the EnOcean 868 and 902 MHz radio systems. It provides a bi-directional radio interface at one end and a bi-directional serial
interface at the other end. Radio messages
are sent transparently through the serial
interface in both directions from and to an
externally connected host processor or host
PC. In addition control commands can be
sent from the host, e.g. to configure the
repeater functionality or to manage the
Smart Ack functions. TCM 310 can act as
postmaster for up to 15 bi-directional sensors using Smart Ack technology.
Product variants
TCM 310: SMD transceiver module 868MHz
TCM310U: SMD transceiver module 902MHz
Feature
Smart Ack controller functionality
Transparent radio channel
Programmable repeater functionality
(1 / 2 Level)
EnOcean Serial Protocol V3 (ESP3)
Type
Ordering Code
TCM 310
TCM 310U
S3003-K310
S3053-K310
Features overview
Antenna
Frequency
External whip or 50Ω antenna mountable
TCM 310: 868.300MHz
TCM 310U: 902.875MHz
125 kbps
Data rate
Modulation type
Receiver Sensitivity (at 25°C)2)
Conducted Output Power
Power Supply
Serial Interface
Current Consumption
Dimensions of PCB
Operating temperature
Radio Regulations
1) According to ISO/IEC 14543-3-1x
© 2019 EnOcean | www.enocean.com
TCM 310: ASK 868 MHz1)
TCM 310U: FSK 902MHz1)
TCM 310: typ. –96 dBm (868MHz)
TCM 310U: typ. -98 dBm (902MHz)
TCM 310: typ. 3 dBm (868MHz)
TCM 310U: typ. 1 dBm (902MHz)
2.6…4.5V
UART (ESP3)
Receive mode: 33 mA
Transmit mode: 24 mA
22x19x3 mm
-25° to +85°C
TCM 310 (max. radiated power +1.4 dBm with whip): RED (EU)
TCM 310U: FCC (US) / ISED (CA)
2) 0.1% telegram error rate (based on the combination of 3 received sub-telegrams)
Subject to modifications | June 2019
很抱歉,暂时无法提供与“S3003-K310”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+92.61229250+11.22409
- 国内价格 香港价格
- 1+152.792261+18.51756
- 5+138.648175+16.80337
- 20+126.3959620+15.31847
- 50+118.2878850+14.33582
- 125+110.17980125+13.35317
