F1206HC12A0TM
F1206HC12A0TM
    AEM
    F1206HC12A0TM
F1206HC12A0TM 数据手册
Revision of March 2018 SolidMatrix® Surface Mount Fuses HC Series (High Current), 1206 Size Features: • • • • • • High inrush current withstanding capability at high voltage Glass ceramic monolithic structure Sliver fusing element and silver termination with nickel and tin plating Superior arc suppression capability RoHS compliant and lead free materials Operating temperature range: -55°C to +150°C (with derating) Shape and Dimensions: Clearing Time Characteristics: % of current rating Clearing time at 25°C 100% 4 hours min. 350% 5 seconds max. Unit Inch mm L 0.126 ± 0.008 3.20 ± 0.20 W 0.063 ± 0.008 1.60 ± 0.20 T1 0.038 ± 0.008 0.97 ± 0.20 T2 0.051 ± 0.008 1.30 ± 0.20 B 0.020 ± 0.010 0.51 ± 0.25 T1: Thickness for 10-25A; T2: Thickness for 30-40A. Agency Approval: Recognized Under the Components Program of UL. File Number: E232989. L W Patents: Patent numbers “US6,034,589”, “US6,602,766”, “US6,844,278”, “ZL00134544.3”, “ZL02114719.1”, “ZL201020551360.8”, “ZL201010299185.2”, “ZL201220030614.0”, “ZL201210020693.1”. T B Ordering Information: Part Number Current Rating (A) Voltage Rating (VDC) F1206HC10A0TM 10 35 F1206HC12A0TM 12 35 F1206HC15A0TM 15 35 F1206HC20A0TM 20 35 F1206HC25A0TM 25 35 F1206HC30A0TM 30 35 F1206HC40A0TM 40 35 Interrupting Ratings 150A@35VDC 200A@35VDC 200A@35VDC 300A@26VDC Nominal Cold DCR(Ω)1 Nominal I2t (A2s)2 Marking Code3 0.0055 15 Q 0.0045 20 X 0.0032 35 Y 0.0023 80 Z 0.0016 120 S 0.0012 180 V 0.0009 240 O 1. Measured at ≤ 10% rated current and 25 oC ambient. 2. Melting I2t at 1000% of current rating. 3. Blue Marking Character Code. Devices designed to be mounted with marking code facing up. Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses HC Series (High Current), 1206 Size 40 A 30 A 25 A 20 A 15 A 12 A 10 A Average Pre-arcing Time Curves: 100 Pre-arcing Time (s) 10 ) s ( e m i T -r a le C 1 0.1 0.01 0.001 10 100 Current (A) Website: www.aemchina.com & www.aemcomponents.com 1000 Revision of March 2018 SolidMatrix® Surface Mount Fuses HC Series (High Current), 1206 Size Average I2t vs. t Curves: 100000 40 A 30 A 25 A 20 A 15 A 12 A 10000 10 A ) s A ( t 2I 2 1000 - 100 10 0.001 0.01 0.1 1 Time (s) Website: www.aemchina.com & www.aemcomponents.com 10 Revision of March 2018 SolidMatrix® Surface Mount Fuses Product Identification: F 0603 FA 1000 V032 T M F 1206 HC 20A0 T M (1) (1) (2) (3) (4) (5) (6) (7) (2) (3) (4) (5) (6) (1) Product Code: F-Chip Fuse (1) Product Code: F-Chip Fuse (2) Size Code: Standard EIA Chip Sizes (2) Size Code: L x W (inch), the first two digits-L (length), (3) Series Code: FA - Fast Acting, SB - Slow Blow, HI - High Inrush, FF - Very Fast Acting, HB - High Current the last two digits-W (width) (4) Current Rating Code: 1000 - 1000 mA (For HB, 10 - 10A) (3) Series Code: HC Series (5) Voltage Rating Code: V032 - 32 VDC (4) Current Rating Code: 20A0—20.0A (6) Package Code: T - Tape & Reel, B - Bulk (5) Package Code: T - Tape & Reel, B - Bulk (7) Marking Code: M - With Marking Recommended Land Pattern: 0.016 (0.40) 0.028 (0.70) 0.063 (1.60) Inch (mm) 0402 Size 0.059 (1.50) 0.031 (0.80) 0.087 (2.20) 0.039 (1.00) 0.173 (4.40) Inch (mm) Inch (mm) 0603 Size 0.071 (1.80) 1206 Size Environmental Tests: No. Test Requirement Test condition 1 Soldering heat resistance DCR change  10% No mechanical damage One dip at 260C for 60 seconds 2 Solderability Minimum 95% coverage One dip at 245C for 5 seconds 3 Thermal shock 4 Moisture resistance 5 Salt spray 6 Mechanical vibration 7 Mechanical shock 8 Life DCR change  10% No mechanical damage DCR change  15% No excessive corrosion DCR change  10% No excessive corrosion DCR change  10% No mechanical damage DCR change  10% No mechanical damage 100 cycles between -65C and +125C 10 cycles 48 hour exposure 0.4 ” D.A. or 30 G between 5 – 3000 Hz 1500 G, 0.5 ms, half-sine shocks Test reference MIL-STD-202 Method 210 MIL-STD-202 Method 208 MIL-STD-202 Method 107 MIL-STD-202 Method 106 MIL-STD-202 Method 101 MIL-STD-202 Method 204 MIL-STD-202 Method 213 No electrical “opens” during 80% rated current (75% for < 1 A fuses) testing Refer to AEM for 2000 hours at ambient temperature voltage drop change shall be QIQ106 between +20C and +30C less than 20% of initial value Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses Electrical Specification: Clearing Time Characteristics: Same as specified on the Short Form Data Sheet Insulation Resistance after Opening: 20,000 ohms typical when cleared with rated voltage applied. Fuse clearing under low voltage conditions may result in lower after clearing insulation resistance values. (Note: Under normal fault conditions (low or rated voltage conditions), AEM SolidMatrix fuses provide sufficient after clearing insulation resistance values for circuit protection.) Current Carrying Capacity: 100% rated current at +25°C ambient for 4 hours minimum when evaluated per MIL-PRF-23419 Interrupt Ratings: Fuse Selection and Temperature De-rating Guideline: The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25°C, the fuse shall be “de-rated”. To select a fuse from the catalog, the following rule may be followed: Catalog Fuse Current Rating = Nominal Operating Current / 0.75 / % De-rating at the maximum operating temperature. Example: At maximum operating temperature of 65°C, % De-rating is 90%. The nominal operating current is 4 A. The current rating for fuse selected from the catalog shall be: 4 / 0.75 / 90% = 5.9 or 6 A. Specifications and descriptions in this literature are as accurate as known at the time of publish, but are subject to change without notice. Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 SolidMatrix® Surface Mount Fuses Soldering Temperature Profile: * Recommended Temperature Profile for Reflow Soldering Profile Feature * Recommended Temperature Profile for Wave Soldering Pb-Free Assembly Preheat/Soak Temperature Min (Tsmin) Temperature Max(Tsmax) Time(ts) from (Tsmin to Tsmax) 150°C 200°C 60~120 seconds Ramp-uprate (TL to Tp) 3°C/second max. Liquidous temperature(TL) Time(tL) maintained above TL 217°C 60~150 seconds Peak package body temperature (Tp) 260°C Time (tp)*within 5°C of the specified classification temperature (Tc) 30 seconds * Ramp-down rate (Tp to TL) 6°C/second max. Time 25°C to peak temperature 8 minutes max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum Notice: Wave Soldering is suitable for 1206 and 0603 size. Packaging: Chip Size Parts on 7 inch (178 mm) Reel 0402 (1005) 10,000 0603 (1608) 4,000 0603FF (1608) 6,000 1206 (3216) 3,000 Website: www.aemchina.com & www.aemcomponents.com Revision of March 2018 Disclaimer Specifications are subject to change without notice. AEM products are designed for specific applications and should not be used for any purpose (including, without limitation, automotive, aerospace, medical, life-saving applications, or any other application which requires especially high reliability for the prevention of such defect as may directly cause damage to the third party’s life, body or property) not expressly set forth in applicable AEM product documentation. It is the customer’s responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Warranties granted by AEM shall be deemed void for products used for any purpose not expressly set forth in applicable AEM product documentation. AEM shall not be liable for any claims or damages arising out of products used in applications not expressly intended by AEM as set forth in applicable AEM product documentation. The sale and use of AEM products is subject to AEM terms and conditions of sale. Please refer Website: www.aemchina.com & www.aemcomponents.com
F1206HC12A0TM 价格&库存
很抱歉,暂时无法提供与“F1206HC12A0TM”相匹配的价格&库存,您可以联系我们找货
