Additional Resources:
Product Page
3D Model
date
11/13/2019
page
1 of 3
MODEL: CEP-2260A │ DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
wire leads with panel-mount tabs
12 Vdc rating
93 dB
3.5 kHz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
3
at rated voltage
rated frequency
3,000
sound pressure level
at 30 cm, rated voltage
dimensions
Ø32.0 x 13.5
3,500
units
Vdc
Vdc
10
mA
4,000
Hz
93
dB
mm
weight
material
ABS UL94 1/16” HB (black)
terminal
wire leads
7.7
g
operating temperature
-30
85
°C
storage temperature
-40
95
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
cuidevices.com
Product Page
3D Model
CUI Devices │ MODEL: CEP-2260A │ DESCRIPTION: PIEZO BUZZER INDICATOR
date 11/13/2019 │ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
PERFORMANCE CURVES
P: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
ˣ
cuidevices.com
Product Page
3D Model
date 11/13/2019 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
06/03/2005
1.01
applied new spec template
06/16/2015
1.02
brand update
11/13/2019
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CEP-2260A”相匹配的价格&库存,您可以联系我们找货
