NJM2904
SINGLE-SUPPLY DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM2904 consists of two independent, high gain,
internally frequency compensated operation amplifiers, which
were designed specifically to operate from a single power
supply over a wide range of voltages. Operation from split
power supplies is also possible and the low power supply
current drain is independent of the magnitude of the power
supply voltage.
Application areas include transducer amplifiers, DC gain
blocks, and all the conventional op amp circuits, which now can
be more easily implemented in single power supply systems.
For example, the NJM2904 can be directly operated off of the
standard +5V power supply voltage, which is used in digital
systems and will easily provide the required interface electronics
without requiring the additional ±15V power supplies.
■ PACKAGE OUTLINE
NJM2904D
NJM2904M
NJM2904E
NJM2904V
NJM2904R/RB1
NJM2904L
■ FEATURES
● Single Supply
● Operating Voltage
+3V~+32V
● Low Operating Current 0.7mA typ.
● Slew Rate
0.5V/μs typ.
● Bipolar Technology
● Package Outline
DIP8, DMP8, SSOP8, SIP8, SOP8 JEDEC 150mil
MSOP8 (VSP8) MEET JEDEC MO-187-DA
MSOP8 (TVSP8) MEET JEDEC MO-187-DA / THIN TYPE
■ PIN CONFIGURATION
( Top View )
1
2
3
4
8
A
7
B
A
B
6
5
1
NJM2904D, NJM2904M
NJM2904E, NJM2904V
NJM2904R/RB1
2
3
4
5
NJM2904L
6
7
8
PIN FUNCTION
1. A OUTPUT
2. A –INPUT
3. A +INPUT
4. V
5. B +INPUT
6. B –INPUT
7. B OUTPUT
8. V
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Ver.2014-03-20
-1-
NJM2904
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
+ + V (V /V )
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
32 ( or ±16 )
32
-0.3~+32 (note 2)
( DIP8 ) 500
( DMP8 ) 300
( EMP8 ) 300
( SSOP8 ) 250
(MSOP8(VSP8/TVSP8) ) 320
( SIP8 ) 800
-40~+85
-50~+125
UNIT
V
V
V
mW
˚C
˚C
(note 1) Continuous short-circuits from output to GND is guaranteed only when V 15V.
(note 2) For supply voltage less than 32V, the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V+=5V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Large Signal Voltage Gain
Maximum Output Voltage Swing
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Output Source Current
Output Sink Current
Channel Separation
Operating Current
Slew Rate
Unity Gain Bandwidth
-2-
SYMBOL
VIO
IIO
IB
AV
VOPP
VICM
CMR
SVR
ISOURCE
ISINK
CS
ICC
SR
fT
TEST CONDITION
RS=0Ω
RL≥2kΩ
RL=2kΩ
VIN =1V,VIN =0V
VIN =0V,VIN =1V
f=1k~20kHz,Input Referred
RL=∞
+ V /V =±15V
+ V /V =±15V
MIN.
3.5
0~3.5
TYP.
2
5
25
100
85
100
30
0.7
0.5
0.6
MAX.
7
50
250
1.2
UNIT
mV
nA
nA
dB
V
V
dB
dB
mA
mA
dB
mA
V/μs
MHz
Ver.2014-03-20
NJM2904
■ TYPICAL CHARACTERISTICS
(Ta=25ºC)
100
Input Bias Current IB (nA)
Operating Current ICC (mA)
Input Bias Current vs. Operating Voltage
Operating Current vs. Operating Voltage
4
3
2
Ta=0 to 75ºC
1
75
50
25
Ta= -20ºC
Operating Voltage V+ (V)
Channel Separation vs. Frequency
Open Loop Voltage Gain AV (dB)
Channel Separation CS (dB)
(Ta=25ºC)
160
100
80
60
40
RL=20kΩ
120
RL=2kΩ
80
40
100
1k
10k
Frequency f (Hz)
100k
vs. Frequency
(V+=15V, Ta=25ºC)
40
vs. Frequency
(RL=, Ta=25ºC)
140
Maximum Output Voltage Swing Vopp (V)
40
Voltage Gain vs. Operating Voltage
(V+=5V , RL=2kΩ)
120
10
15
10
5
100
V+=30V
80
60
40
V+=10V to 15V
1k
Ver.2014-03-20
10k
100k
Frequency f (Hz)
1M
1
100
10k
Frequency f (Hz)
1M
-3-
NJM2904
vs. Temperature
(V+=5V)
5
28.8
28.6
Input Offset Voltage VIO (mV)
Maximum Output Voltage VOPP (V)
Input Offset Voltage vs. Temperature
(V+=30V, RL=2kΩ)
29
28.4
28.2
28
27.8
27.6
27.4
27.2
27
26.8
4
3
2
1
-2
-3
-4
26.6
-50
-25
50
75
100
Ambient Temperature Ta (ºC)
-50
125
(V+=5V)
80
1.2
(V+=5V)
90
1
0.8
0.6
0.4
0.2
70
60
50
40
30
-25
50
75
100
125
-50
(RL=2kΩ, Ta=25ºC)
125
(V+=5V, Ta=25ºC)
4
Maximum Output Voltage Vopp (V)
30
-25
50
75
100
vs. Load Resistance
25
10
5
3
2.5
2
1.5
1
0.5
125
Input Bias Current vs. Temperature
Operating Current vs. Temperature
1.4
-25
50
75
100
10
40
10
100
1k
Load Resistance RL (Ω)
10k
Ver.2014-03-20
NJM2904
Maximum Output Voltage vs. Operating Voltage
(V+=5V, Ta=25ºC)
5
4.5
15
5V
4
10
+VOM
Output Voltage VO (V)
Maximum Output Voltage (V)
Output Voltage vs. Sink Current
(RL=2kΩ, Ta=25ºC)
-10
-VOM
-15
ISINK
1V
3.5
Vo
3
2.5
2
1.5
1
0.5
-20
±5
±10
±15
Operating Voltage V+/V- (V)
±20
0.1
1
10
100
1000 10000 100000
Sink Current ISINK (μA)
Source Current
(V+=15V, Ta=25ºC)
Output Voltage from
Operating Voltage V+-VO (V)
6
V+=15V
5
1V
4
V+-Vo
Vo
3
2
1
Ver.2014-03-20
1
10
Output Source Current Isource (mA)
100
-5-
NJM2904
■ APPLICATION
Improvement of Cross-over Distortion
Equivalent circuit at the output stage
NJM2904,in its static state ( No in and output condition ) when
design,QU being biassed by constant current ( break down
beam ) yet,QL stays OFF.
While using with both power source mode,the cross-over
distortion might occur instantly when QL ON.
There might be cases when application for amplifier of audio
signals,not only distortion but also the apparent frequency
bandwidth being narrowed remarkably.
It is adjustable especially when using both power source
mode,constantly to use with higher current on QU than the load
current ( including feedback current ),and then connect the
pull-down resister RP at the part between output and V pins.
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-6-
Ver.2014-03-20
很抱歉,暂时无法提供与“NJM2904M-TE1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.94200
- 10+3.28320
- 30+2.94840
- 国内价格
- 1+1.23532
- 30+1.18817
- 100+1.14103
- 500+1.04673
- 1000+0.99958
- 2000+0.97129
