AZ5125-01H
Transient Voltage Suppressing Device
For ESD/Transient Protection
Features
During transient conditions, the proprietary
clamping cells prevent over-voltage on the power
line or control/data lines, protecting any
downstream components.
ESD Protection for 1 Line with Bi-directional.
Provide ESD protection for the protected line to
IEC 61000-4-2 (ESD) ±20kV (air), ±15kV (contact)
AZ5125-01H is bi-directional and may be used
on lines where the signal swings above and
below ground.
IEC 61000-4-4 (EFT) 50A (5/50ns)
Cable Discharge Event (CDE)
Ultra-small SOD-523 package saves board
space.
Protect one I/O line or one power line
Fast turn-on and Low clamping voltage
For low operating voltage applications: 5V
maximum
Solid-state silicon-avalanche and active circuit
triggering technology
Green Part
AZ5125-01H may be used to meet the ESD
immunity requirements of IEC 61000-4-2, Level 4
(±15kV air, ±8kV contact discharge).
Circuit Diagram /
Pin Configuration
1
Applications
Computer Interfaces Protection
Microprocessors Protection
Serial and Parallel Ports Protection
Control Signal Lines Protection
Power lines on PCB Protection
Latchup Protection
Description
2
AZ5125-01H is a design which includes a
bi-directional ESD rated clamping cell to protect
one power line, or one control line, or one low
speed data line in an electronic systems. The
AZ5125-01H has been specifically designed to
protect sensitive components which are
connected to power and control lines from
over-voltage damage and latch-up caused by
Electrostatic Discharging (ESD), Electrical Fast
Transients (EFT), and Cable Discharge Event
(CDE).
SOD-523 (Top View)
AZ5125-01H is a unique design which includes
proprietary clamping cells in a single package.
Revision 2013/01/08
©2013 Amazing Micro.
1
www.amazingIC.com
AZ5125-01H
SPECIFICATIONS
ABSOLUTE MAXIMUM RATINGS
PARAMETER
PARAMETER
RATING
UNITS
Operating Supply Voltage
VDC
±6
V
ESD per IEC 61000-4-2 (Air)
VESD
±20
kV
ESD per IEC 61000-4-2 (Contact)
±15
Lead Soldering Temperature
TSOL
260 (10 sec.)
o
C
Operating Temperature
TOP
-55 to +85
o
Storage Temperature
TSTO
-55 to +150
o
C
C
ELECTRICAL CHARACTERISTICS
PARAMETER
Reverse Stand-Off
Voltage
Reverse Leakage
Current
Reverse
Breakdown Voltage
ESD Clamping
Voltage
Channel Input
Capacitance
Revision 2013/01/08
SYMBOL
VRWM
CONDITIONS
T=25 oC.
ILeak
VRWM = ±5V, T=25 oC.
VBV
IBV = 1mA, T=25 oC.
VESD_CL
CIN
TYP
-5
6
IEC 61000-4-2 +6kV, T=25 oC,
Contact mode.
VR= 0V, f = 1MHz, T=25 oC.
MINI
2
MAX
UNITS
5
V
1
µA
9
V
10
7
V
9
pF
www.amazingIC.com
AZ5125-01H
Typical Variation of CIN vs. VIN
10
Input Capacitance (pF)
9
8
Pin-1 to pin-2
7
6
5
4
3
2
f = 1MHz, T=25 oC,
1
-4
-3
-2
-1
2
3
4
5
Transmission Line Pulsing (TLP) Current (A)
Typical Characteristics
V_pulse
Pulse from a
transmission line
TLP_I
100ns
TLP_V
DUT
Pin-1 to Pin-2
-10
-8
-6
-4
-2
4
6
8
Transmission Line Pulsing (TLP) Voltage (V)
Input Voltage (V)
Revision 2013/01/08
Transmission Line Pulsing (TLP) Measurement
18
16
14
12
10
8
6
4
2
-4
-6
-8
-10
-12
-14
-16
-18
3
www.amazingIC.com
10
AZ5125-01H
Applications Information
In order to obtain enough suppression of ESD
The AZ5125-01H is designed to protect one line
induced transient, good circuit board is critical.
against
Thus, the following guidelines are recommended:
System
ESD/EFT/Cable-Discharge
pulses by clamping them to an acceptable
reference. It provides bi-directional protection.
Minimize the path length between the
protected lines and the AZ5125-01H.
Place the AZ5125-01H near the input
The usage of the AZ5125-01H is shown in Fig. 1.
terminals or connectors to restrict transient
Protected line, such as data lines, control lines,
coupling.
or power lines, is connected at pin 1. The pin 2 is
connected to a ground plane on the board. Since
The ESD current return path to ground
should be kept as short as possible.
AZ5125-01H is bi-directional, these connections
Use ground planes whenever possible.
can be reversed (protected line to pin 2, ground
NEVER route critical signals near board
to pin 1). In order to minimize parasitic
edges and near the lines which the ESD
inductance in the board traces, all path lengths
transient easily injects to.
connected to the pins of AZ5125-01H should be
Input
Output
VBR
Transient
Voltage
-VBR
VCL
gnd
gnd
-VCL
VBR
Normal
Operation
-VBR
gnd
gnd
1
Protected
Devices
2
Fig. 1
Revision 2013/01/08
4
www.amazingIC.com
AZ5125-01H
Mechanical Details
SOD-523
LAND LAYOUT
PACKAGE DIAGRAMS
0.8mm
TOP VIEW
0.6mm
Notes:
This LAND
SIDE VIEW
0.9mm
LAYOUT
is
0.6mm
for
reference
purposes only. Please consult your
manufacturing partners to ensure your
company’s PCB design guidelines are met.
MARKING CODE
PACKAGE DIMENSIONS
Symbol
Millimeters
Inches
MIN.
MAX.
MIN.
MAX.
A
0.5
0.715
0.020
0.028
b
0.25
0.35
0.010
0.014
C
0.08
0.2
0.003
0.008
D
0.7
0.9
0.028
0.035
E
1.1
1.3
0.043
0.051
E1
1.5
1.7
0.059
0.067
fX
1
2
f = Device Code
X = Date Code
Part Number
Marking Code
AZ5125-01H
fX
Ordering Information
PN#
Material
Type
Reel size
MOQ/internal box
MOQ/carton
AZ5125-01H.R7G
Green
T/R
7 inch
4 reel=12,000/box
6 box=72,000/carton
Revision 2013/01/08
5
www.amazingIC.com
AZ5125-01H
Revision History
Revision
Modification Description
Revision 2009/04/29
Original and Formal Release.
Revision 2009/08/13
Update the ESD clamping voltage.
Revision 2009/08/20
Update the PACKAGE DIMENSIONS.
Revision 2011/07/28
1. Update the Company Logo.
2. Add the Ordering Information.
Revision 2012/04/03
Modify the Circuit Diagram.
Revision 2012/04/25
Update the level of ESD per IEC 61000-4-2 (Air) from 15KV to 20KV.
Revision 2013/01/08
Revision 2013/01/08
6
www.amazingIC.com
很抱歉,暂时无法提供与“AZ5125-01H.R7G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.31672
- 20+0.28912
- 100+0.26152
- 500+0.23392
- 1000+0.22104
- 2000+0.21184
